Newbie Meade 114eq-dh4 need new worm gear
13 replies to this topic
#1 boltdude
boltdude
Posted 31 January 2014 - 01:04 PM
I just bought this telescope on Craigslist for $50 (hopefully a ok deal)
I need a new worm gear its worn down I had to tape it so it stay in place
where can I buy a new one or even old worm gear (I know its a 100 tooth Alt / Az ratio of 4.56296
thanks
Steve
#2 Starhawk
Starhawk
    Space Ranger
  • Loc: Tucson, Arizona
Posted 31 January 2014 - 01:52 PM
That's the mount. Sorry.
-Rich
#3 boltdude
boltdude
Posted 31 January 2014 - 04:24 PM
-Rich
Yes the Mount
#4 Falcon-
Falcon-
  • Loc: Gambier Island, BC, Canada
Posted 31 January 2014 - 05:18 PM
Steve: Welcome to Cloudy Nights!
I am having trouble picturing how the worm could be held in place with tape and am wondering if terminology is being mixed up. Would you mind posting a picture of the problem part/damage/wear? Seeing the damaged part may help here.
The mount itself looks like an EQ-2 equivalent but with a full range of motion on DEC (instead of a tangent adjustment like my older EQ2).
I actually own a similar 114mm aperture newt (144mm = 4.5") on a similar mount, only without the fancy drives. If the mirror is in good shape you should do well with the setup, especially for viewing targets like Jupiter (jupiter is a good one right now).
In the short term even if the drives are not working you can still get pointed at a bright target like Jupiter and just manually nudge with the RA axis lock disengaged. Just make sure your scope is as well collimated as you can manage so you get a clear view. :) If this is your first newt or first scope just google collimating a newtonian and you will find *many* instructions for doing so.
#5 jrcrilly
jrcrilly
    Refractor wienie no more
  • Loc: NE Ohio
Posted 31 January 2014 - 08:28 PM
I believe that this is the same mount. It would provide that worm assy plus plenty of extra parts...
#6 boltdude
boltdude
Posted 01 February 2014 - 12:29 AM
Thanks that's the one
I will bid on it
#7 boltdude
boltdude
Posted 01 February 2014 - 12:40 AM
the tape job is just to keep the telescope from moving all over the place the gears where really worn out.
other then that it has no purpose..
gear does not work at all
and if I cant get motorized its still a good beginner telescope.
thanks again
Steve..
#8 boltdude
boltdude
Posted 01 February 2014 - 12:44 AM
now need to find a power source/plug 15volt
and a control box or can the starfinder plug right into to a pc?
with out a control box..
Steve
#9 jrcrilly
jrcrilly
  • Loc: NE Ohio
Posted 01 February 2014 - 01:15 AM
Steve
The mount and controller will run fine on 12VDC. It was originally supplies with a 15VDC battery pack on the assumption that the AA battery voltage would quickly drop to 12V.
There was a Meade #506 cable/converter assembly for PC use with the 494 Autostar (electrically the same as the Starfinder but different firmware) but I think that connected to an aux jack on the mount and I don't think the DH4 has an aux jack.
#10 boltdude
boltdude
Posted 01 February 2014 - 06:56 AM
no aux just hbx for control box
Steve
#11 boltdude
boltdude
Posted 01 February 2014 - 07:37 AM
I bided on ebay for tripod parts..
bought a starfinder control box
found a power plug that works
not a bad day
Thanks everyone who helped me out
steve
#12 ccs_hello
ccs_hello
Posted 01 February 2014 - 09:20 AM
Steve,
Yours is almost identical with Meade 4504.
Join Y! Meade4504telescopes group to get a lot of info.
Clear Skies!
ccs_hello
#13 boltdude
boltdude
Posted 01 February 2014 - 04:54 PM
will do thanks
Steve,
Clear Skies!
ccs_hello
#14 boltdude
boltdude
Posted 01 February 2014 - 08:34 PM
Won the auction for mount hardware $44
should have a fully working telescope by next week.
still have to collimate lens..
I will bid on it
