Counterweights for Celestron AVX
8 replies to this topic
#1 TeamHawkins
TeamHawkins
Posted 18 February 2014 - 12:22 AM
Anyone know of any counterweights that are compatible with this mount? Looking for one in the 5 lb. - 7 lb. range for my ST-80.
#2 RTLR 12
RTLR 12
  • Loc: The Great Pacific NorthWest
Posted 18 February 2014 - 12:32 AM
These will fit...
Stan
http://www.telescope...Orion-Counte...
#3 Jeff2011
Jeff2011
  • Loc: Sugar Land, TX
Posted 18 February 2014 - 01:53 AM
+1
Got the 7.5lb Orion weight for my AT72ED. Works well on my AVX.
#4 TeamHawkins
TeamHawkins
Posted 18 February 2014 - 02:17 AM
Thanks RTLR 12 I check them out
#5 BarrySimon615
BarrySimon615
    Pa Bear
  • Loc: New Orleans, LA
Posted 18 February 2014 - 11:14 AM
+1
What is the diameter of the Orion 7.5 lb weight? Their description does not say.
Pa Bear
#6 RTLR 12
RTLR 12
Posted 18 February 2014 - 11:23 AM
The OD of the 7½ lb CW is 4¾".
Stan
#7 T1R2
T1R2
  • Loc: NeverWhere, 35*N
Posted 18 February 2014 - 05:36 PM
berry, its the same weight as on the Omni CG-4, and the larger diameter thinner weight(11#) is one for the CG-5, AVX mounts, they fit the 0.786in or 19.9mm(20mm) shaft's
#8 Intihuatana
Intihuatana
  • Loc: Weston, FL
Posted 19 February 2014 - 08:43 AM
Vixen sells 4,6 and8 lb counterweights that fit the 3/4" shaft of the AVX, I've got the 4lb and fits perfectly ( although it is white...and not cheap!):
http://www.vixenopti...indiv/2577.html
#9 Mr Greybush
Mr Greybush
  • Loc: Virginia
Posted 20 February 2014 - 12:09 PM
you can also use microphone boom weights they fit also.
