Mounting Orion ED80T CF refractor on Celestron AVX
4 replies to this topic
#1 Shaunavon
Shaunavon
  • Loc: Round Rock, TX, USA
Posted 27 February 2014 - 11:37 AM
I have been searching around and failed to find a solution to this problem of mine. I have an Orion ED80T CF refraction for imaging which is mounted on the Celestron AVX mount. The stock L-shaped leg on the OTA is not sufficent to keep the OTA, DSLR, FF, autoguider, gudiescope affixed
to the mount safely. It is just too much weight. I need to get a pair of OTA rings and a dovetail to mount this scope on the AVX mount. Can anyone tell me what combination would you recommend? Or if you know what type and size dovetail bar is typically used on the Celestron AVX mount would be a great start.
#2 nodalpoint
nodalpoint
  • Loc: FEMA camp
Posted 27 February 2014 - 12:14 PM
Standard Vixen type dovetail fits it.
#3 rigel123
rigel123
  • Loc: SW Ohio
Posted 27 February 2014 - 10:13 PM
I use Williams Optics 90mm rings and an 8" dovetail plate to mount my ED80T to my Atlas
#4 Xeroid
Xeroid
  • Loc: USA
Posted 27 February 2014 - 10:38 PM
Shaunavon,
ScopeStuff sells rings and dovetail bars at very reasonable cost:
Rings: http://www.scopestuff.com/ss_rings.htm
Dovetail bars: http://www.scopestuff.com/ss_eqdb.htm
ADM also very good rings and bars but at a higher cost:
http://admaccessorie...eries_Rings.htm
#5 Shaunavon
Shaunavon
Posted 28 February 2014 - 10:02 AM
Thank you all for adding your bit of recommendation. Thanks to you I find a suitable solution.
