Orion Ranch Observatory nears completion
135 replies to this topic
#51 hm insulators
hm insulators
  • Loc: Phoenix, Arizona
Posted 18 March 2014 - 11:52 AM
Beautiful observatory!
#52 Lord Beowulf
Lord Beowulf
  • Loc: Cedar Park, TX
Posted 19 March 2014 - 06:06 PM
Originally Posted by tim57064:Beo,love the look of everything. You've been doing a great job. Would like to know where you got the almost all sky camera and dome so as I can build a similar one. Thanks Tim.  This is the camera came I used.  It has integrating capability, etc., although I had to turn off the auto ranging to keep it from getting too noisy at night.  They actually offer a range of "starlight" cameras, and this was in the middle as far as cost.  Supposedly this lens would give a full 180 degrees if it was used on a 1/2" CCD instead of the 1/3" it's paired with.
Here's the dome.  Just toss the black inner shroud.  Both together cost under $100.  If I leave out the cost of the other stuff I tried looking for a cheap solution, the whole thing was probably under $150, excluding the DVR from the security system that's recording for me.
Beo
#53 Lord Beowulf
Lord Beowulf
Posted 19 March 2014 - 09:19 PM
November 27th, 2013:
Started excavating the second pier on this day, 2009!
So the automatic gain mode of the camera wasn't really working well at night as it would turn the gain too high and cause a lot of static in the images, rather than just showing stars against black.  I had already cabled to allow the addition of a remote control of the camera menu, but hadn't obtained a separate joystick assembly for that purpose.  I finally just decided to risk the cable I had and create a new assembly.  Worked like a charm!  Here's the new camera side assembly.
Installed on the camera along with the new adapter for the control cable.
And then the menu control joystick adapted to allow using a network cable run between.  The cable can always be adapted to replace this with an IP camera or the like somewhere down the line if that becomes necessary.
Went ahead and installed the rest of the observatory lights temporarily.
Beo
#54 Lord Beowulf
Lord Beowulf
Posted 19 March 2014 - 10:08 PM
November 29th, 2013:
Routing speaker wires for stereo surround sound, a speaker on the other side of the door, and zone 2 speakers in the observatory.
Remote speaker zone in the observatory itself.
Adding a remote control cable to the air conditioner outlet to allow the PC to control the temperature.
Adding an extra cable or two for observatory cameras and future expansion.
LOTS of cables in the wall, including power, network/data, camera, speaker, and control cables!
Beo
#55 Lord Beowulf
Lord Beowulf
Posted 23 March 2014 - 09:19 AM
Thanks to Greg K., I have my thread back from the old/new site. I'm going to miss the HTML formatting, but hopefully we'll get it back when we go wherever we go next. In the meantime it's back to the old BBCode links!
Beo
#56 Starman27
Starman27
  • Loc: Illinois, Iowa
Posted 23 March 2014 - 07:55 PM
This build is so nice!
#57 John Fitzgerald
John Fitzgerald
    In Focus
  • Loc: AR ..on the minus side of +36 deg
Posted 27 March 2014 - 06:34 PM
Wow! I've seen these metal roofs go up, but didn't realize what a pain in the neck those ridge caps are.  Lots of detail work.
That is not the usual ridge cap used on most metal buildings and residential roofs. The common ridge caps are much wider and screw onto the ridges of the roof sheets with rubber washer screws. They go on rapidly. The caps shown here are deluxe top of the line virtually leak proof designs.
#58 Lord Beowulf
Lord Beowulf
Posted 06 April 2014 - 08:39 AM
Thanks Herman. Yeah, John, the nice thing about the standing seam roof designs is that there are no exposed penetrations, and the only possible way for water to get in (if installed correctly) is for it to blow up over a ~1" high barrier. The only exposed fasteners at all are pop rivets added to the ridge caps on the outside of the Zee to prevent them from slipping or the wind from possibly blowing them off. Any water that goes through the pop rivet hold ends up on the outside of the roof under the edge of the Zee.
Beo
#59 Lord Beowulf
Lord Beowulf
Posted 06 April 2014 - 08:53 PM
November 30th, 2013
Finished anchoring all cables and cleaning up the warm room prior to installing insulation.
http://photos.orionr...1130-184013.jpg
http://photos.orionr...ages/link31.png
http://photos.orionr...1130-184015.jpg
http://photos.orionr...1130-184210.jpg
Getting all the insulation moved in to be ready for next time.
http://photos.orionr...1130-185153.jpg
December 8th, 2013:
First roll of 5.5" insulation in the ceiling.
http://photos.orionr...1208-100046.jpg
The remainder of the first roll of batting.
http://photos.orionr...1208-100059.jpg
Second roll installed:
http://photos.orionr...1208-113449.jpg
Finished the ceiling insulation installation with some very tired arms!
http://photos.orionr...1208-160958.jpg
http://photos.orionr...1208-161014.jpg
http://photos.orionr...1208-161023.jpg
Installing the first piece of insulation on the wall.
http://photos.orionr...1208-163853.jpg
First roll done.
http://photos.orionr...1208-171612.jpg
First wall almost finished by the evening.
http://photos.orionr...1208-183013.jpg
Beo
#60 Lord Beowulf
Lord Beowulf
Posted 13 April 2014 - 04:31 PM
December 11, 2013:
Forgot to mention on the last post, but this is just over four years since the second pier was poured (December 5th, 2009), and two years since I was finishing up the footings for the warm room.
One last wiring task. Installing one more conduit for routing a secondary ground wire from outside to the breaker box.
Running a ground wire from the breaker box to the ground rod outside and connecting with the secondary lightning suppression.
Of course the ground post was originally driven near the end of the conduit, but when it wouldn't go any deeper, this is where the top ended up!
Filling the end of the conduit with caulk to keep bugs and water out.
Completed the insulation on the first wall by lunch time.
http://photos.orionr...1211-110425.jpg
Finished the north wall by the end of the day, with a few bats cut for the east wall. Working around all those outlet boxes and cables is a pain!
http://photos.orionr...1211-180320.jpg
http://photos.orionr...1211-180331.jpg
http://photos.orionr...1211-180342.jpg
December 14, 2013:
Even slower going on the east wall with all the cables!
http://photos.orionr...1214-094021.jpg
Finished the east wall by about 12:30.
http://photos.orionr...1214-123847.jpg
Saved the hardest for last, putting insulation over the electrical panel and conduits.
http://photos.orionr...1214-172649.jpg
Finished the insulation in the mid-wall and stuffing bits in the cracks at the corners. The camera lens is fogged up due to the temperature and humidity from my breath after bringing the camera in from the cold observatory!
http://photos.orionr...1214-191939.jpg
It's finally time to bring in all the paneling for the walls, and when I uncovered everything, my worst fears were realized. Some critter got under all the tarps and ate through the inner layer protective plastic lining so water leaked in and ruined most of the plywood! :( :bawling:
http://photos.orionr...1214-192821.jpg
I was able to salvage just enough panels to do the warm room. I'll have to buy more to do the observatory. Put them in the warm room to acclimatize overnight.
http://photos.orionr...1214-195345.jpg
And a few more that can be used after cutting off the bad portions. These should work in locations where only partial panels are needed.
http://photos.orionr...1214-195351.jpg
http://photos.orionr...1214-195401.jpg
Beo
#61 Lord Beowulf
Lord Beowulf
Posted 13 April 2014 - 11:34 PM
December 22nd, 2012:
One year after the start of construction on the building, four years after completing the eyepiece holder for the piers.
Cutting the first panel for the ceiling.
Using a couple of ladders to help hold the panels in place while I staple them.
The first ceiling panel installed.
Halfway done with three ceiling panels up.
Ceiling finished with all six panels up.
http://photos.orionr...1222-134229.jpg
Putting up the west wall as it gets late. Check out all the fine sawdust floating in the air.
http://photos.orionr...1222-161006.jpg
Finished paneling the south wall up to the door by the end of the day.
http://photos.orionr...1222-191150.jpg
December 24th, 2013: Merry Christmas!
Finished paneling on the east wall.
http://photos.orionr...1224-132838.jpg
Finished trimming out the paneling around the door into the observatory.
http://photos.orionr...1224-132852.jpg
Last piece of paneling to be installed over outer door.
http://photos.orionr...1224-184027.jpg
http://photos.orionr...1224-184029.jpg
Finished paneling the north wall.
http://photos.orionr...4-191054-01.jpg
December 27, 2013:
Getting prepped for installing trim, bringing in the baseboards and window casing, as well as both saws.
http://photos.orionr...1227-083440.jpg
http://photos.orionr...1227-083447.jpg
Ripping a couple of 1x12s for the window sills.
http://photos.orionr...1227-083522.jpg
Installed the casing around the outer door.
http://photos.orionr...1227-115708.jpg
Installed the casing around the observatory door.
http://photos.orionr...1227-124928.jpg
Baseboards installed all the way around.
http://photos.orionr...1227-161503.jpg
http://photos.orionr...1227-161510.jpg
http://photos.orionr...1227-161519.jpg
http://photos.orionr...1227-161523.jpg
http://photos.orionr...1227-161551.jpg
http://photos.orionr...1227-161616.jpg
A couple of full views of the doors. WOW! :ooo:
http://photos.orionr...1227-161606.jpg
http://photos.orionr...1227-161633.jpg
Finishing with cove trim pieces in all the corners.
http://photos.orionr...1227-183413.jpg
http://photos.orionr...1227-183427.jpg
http://photos.orionr...1227-183459.jpg
Beo
#62 FOUNTAIN1
FOUNTAIN1
  • Loc: Winder, Ga
Posted 14 April 2014 - 07:31 AM
Beo, I have thoroughly enjoyed your thread. Are these latest pictures your current status of the observatory, or are they older ones reposted? I know you've been trying to repost pictures that were lost during the changeover the site experienced, but I wasn't sure if the project was completed or not. Thanks for all of the updates, it's fun to scroll and see the progress you have made.
#63 Lord Beowulf
Lord Beowulf
Posted 16 April 2014 - 08:54 PM
Thanks Glen,
I'm trying to get caught up on posting all the construction pictures. What I've posted so far is up to right at the end of December, so I'm further along than that.
Beo
#64 Lord Beowulf
Lord Beowulf
Posted 16 April 2014 - 09:54 PM
December 28th, 2013:
Installing the first window sill, made from a 1x12 ripped in half, routed, sanded, and trimmed top size.
Added more paneling to face the inside of each window frame in addition to adding the sills.
Adding casing around the window frames to complete them.
Framing the air conditioner with casing as well.
Here's a scan around the room with all the trim done. Looks pretty amazing if I do say so myself!
http://photos.orionr...1228-183600.jpg
http://photos.orionr...1228-183606.jpg
http://photos.orionr...1228-183621.jpg
http://photos.orionr...1228-183635.jpg
http://photos.orionr...1228-183642.jpg
December 29th, 2013:
Finishing touches before painting.
I had to glue the edges of the ceiling panels together to keep them from bowing differently and introducing gaps.
http://photos.orionr...1229-131753.jpg
Then I had to put wood filler in the trim all around and come back and sand it clean. And remember, if you really want to see all of these, you can always follow the link icon and view neighboring pages.
http://photos.orionr...1229-131819.jpg
And after having glued all of the inter-joist joints.
http://photos.orionr...1229-190025.jpg
Finally, I had to remove all the labels with a blow dryer to warm them, then acetone to remove the glue. I'm not sure WHY they put those on the finish side of the panels!
http://photos.orionr...1229-190017.jpg
December 30th, 2013:
Adding the first coat of polyurethane. Makes the wood look extremely rich!
http://photos.orionr...1230-172107.jpg
Took me the rest of the day to get the first coat everywhere.
http://photos.orionr...1230-172113.jpg
http://photos.orionr...1230-192848.jpg
http://photos.orionr...1230-192904.jpg
http://photos.orionr...1230-192933.jpg
http://photos.orionr...1230-192937.jpg
http://photos.orionr...1230-193013.jpg
December 31st, 2013:
After another full day of painting the second coat of polyurethane, I finally get to put up the ceiling fan with the custom artwork I'd designed (and now I finally get to share the pictures!).
http://photos.orionr...1231-192906.jpg
http://photos.orionr...1231-193202.jpg
http://photos.orionr...1231-193131.jpg
And the actual artwork.
http://photos.orionr...231-193131b.jpg
Installing light switch covers and other finishing details.
http://photos.orionr...1231-193219.jpg
http://photos.orionr...1231-211842.jpg
And the nice flashy window frame after two layers of polyurethane.
http://photos.orionr...1231-193228.jpg
Enjoy!
Beo
#65 FOUNTAIN1
FOUNTAIN1
  • Loc: Winder, Ga
Posted 17 April 2014 - 05:35 AM
Absolutely beautiful! The ceiling fan was a very nice touch to the O.R.O.! :bow:
#66 Raginar
Raginar
  • Loc: Pensacola, FL
Posted 17 April 2014 - 08:07 AM
Cool fan! :) Nice job.
#67 Midnight Dan
Midnight Dan
  • Loc: Hilton, NY, Yellow Zone (Bortle 4.5)
Posted 17 April 2014 - 09:43 AM
Wow! That fan is awesome! Great job on the artwork and a nice compliment to the rest of the work you've done! :bow:
-Dan
#68 tim57064
tim57064
  • Loc: Southeast South Dakota,USA
Posted 17 April 2014 - 09:55 AM
Lookin' Great Beo.
#69 MAURITS
MAURITS
  • Loc: Belgium
Posted 17 April 2014 - 10:04 AM
What a great project, congrats ...
#70 MHamburg
MHamburg
  • Loc: Brooklyn, NY/Berkshires, MA
Posted 17 April 2014 - 04:59 PM
What a refuge from all things mundane!
Michael
#71 Lord Beowulf
Lord Beowulf
Posted 17 April 2014 - 09:16 PM
Thanks everyone! I've been waiting a long time to finally post the pictures of the fan, as I'm pretty happy with it too! I have one or two other cool things to post when I get there.
BTW, I discovered that the link to the original thread is broken after the move (it points to the "new" site that's no longer there). Thus, I'm re-posting that link here.
http://www.cloudynig...3430560/page...
Beo
#72 crazyqban
crazyqban
  • Loc: Miami, Florida
Posted 17 April 2014 - 11:31 PM
Looks great, I love the fan, excellent job. Enjoy!!!!
#73 Lord Beowulf
Lord Beowulf
Posted 20 April 2014 - 05:06 PM
Thanks Sergio.
January 2nd, 2014:
Installing an RGB LED strip for a red light night light. Attempt one, anyway, since it kept falling down until I stapled it in place. The glue on these isn't worth much. This attempt was to stick it to the trim in case I ever needed to replace it.
The power supply and driver is installed under a blank plate and controlled from a light switch below.
Adding some cheap speakers installed as rear surround sound speakers.
Installing the PIR motion detector for the alarm system.
A shot of the finished wall with outlet plates installed.
January 3rd, 2014:
Finished north, east, and west walls with outlet plates installed. Still have some work to do on network keystones, etc. but that may only happen as needed.
http://photos.orionr...0103-121828.jpg
http://photos.orionr...0103-121850.jpg
http://photos.orionr...0103-121842.jpg
http://photos.orionr...0103-121835.jpg
Completely repaired, cleaned, and installed sectional sofa and area rug. See additional images on the site if you're interested in the process of getting the sectional back together.
http://photos.orionr...0103-211422.jpg
That rug will have to go, but it's good enough for now!
http://photos.orionr...0103-211433.jpg
http://photos.orionr...0103-211443.jpg
And with the queen sleeper open. We probably only used this twice in the 20 years we've had the sofa. The mice that got into it in storage spent more time in it than we have!
http://photos.orionr...0103-212400.jpg
Nothing like buying new furniture to mess up your design plans, but Fry's had a good deal on for Christmas. Originally I was going to place the old stereo on a pedestal in the corner, with old cheap desks to either side. Now I have to run speaker wires to the corner from the rack.
http://photos.orionr...0103-211453.jpg
Beo
#74 Lord Beowulf
Lord Beowulf
Posted 22 April 2014 - 12:25 AM
Given that I've posted all of the exterior pictures up to now, I suppose I can go ahead and make this post for all of you who have stuck with me this long!
So I finally took the time to piece together close to a year of time lapse video and create a short construction video of the entire build. I’ve posted the two minute long, 1800X version, and will post a slower 20 minute version later. That one contains the full number of frames but at 6X the speed of the five frame per second version as shot. I'm missing bits here and there due to dead batteries, full memory cards, and even a dead camera. You'll also see where I switched cameras a couple of times before going back to a replacement of what I started with which was far superior to the others. If you watch closely you might catch some deer and my donkeys. You'll also see some wild weather including a freak snowfall. Just another little treat for those of you who've stuck with me through all of this. I hope you enjoy it!
Beo
#75 FOUNTAIN1
FOUNTAIN1
  • Loc: Winder, Ga
Posted 22 April 2014 - 05:41 AM
That was a great time lapse video!!!! Looking forward to the full version you mentioned. I kept trying to pause the frames randomly so I could catch your donkeys in the frame. Finally did it at 1:53. :grin:
