C5 V. C102: Any Advantage?
50 replies to this topic
#1 KarlL
KarlL
  • Loc: Northern Illinois
Posted 09 April 2014 - 02:09 PM
Given its large CO, Is there any advantage of a C5 over a C102, other than the much shorter tube? I have the C102 and like it a lot. I am curious about the C5. The CA of C102 does bother me a bit. OTOH, there is no CO on the C102.
Am I missing something?
Karl
#2 OrdinaryLight
OrdinaryLight
  • Loc: Massachusetts
Posted 09 April 2014 - 04:12 PM
I recently came across this article that compares several scopes including the C5 (well, G5 which was a C5 on a GEM) and C102HD refractor: http://www.cloudynig...php?item_id=640
I have a 102mm f/7 ED refractor and a C5 and my impressions from a side by side comparison on Jupiter is that the refractor is a bit brighter and sharper than the C5. The 2" focuser on the C102 will allow a much wider TFOV as the C5 with it's 1.25" visual back is limited to ~1.3º. You can put a 2" SCT back on the C5 but it is debatable how much extra field you'll actually get due to the 27mm baffle diameter.
The C5 is much more compact. It does a nice job on the planets (significantly better than my 90mm mak) and is good on brighter DSOs at home. The size/weight is the reason I bought it. It packs some decent aperture into a small space and mounts on a photo tripod (I use a Bogen 3011 and UA DwarfStar combo that weighs 6lbs). I really like the scope.
Besides improving the CA, what are your goals in making the switch? It size important?
If you want something that can out perform the C102 you should look at the C6. It is larger than the C5 and would require a somewhat heftier mount, which for me puts it in another class in terms of portability. On the other hand it will probably work great on the mount you have for the C102.
#3 azure1961p
azure1961p
  • Loc: Triton
Posted 09 April 2014 - 07:27 PM
I'm educatedly guessing here but ill take a leap and say the c5 and 102 will have equal detail on planets. I used to wave a hand at CA with my 70mm Ranger but afte three years of having my reflector on ice, when it finally was operating again to see an image come to focus clean with no color was actually very refreshing!
Its an interesting comparison but if it were me - it'd be the C5 - so long as it was a good one . Slightly higher angular resolution, color free, great on doubles (I kno because my C6 is) and will split slightly tighter pairs. The compactness is a real point here too.
Either way your good but Id personally go with the sct. Strict collimation and it'll be a superb performer. And none of that blasted fringing.
Pete
#4 KarlL
KarlL
Posted 09 April 2014 - 08:26 PM
Dave -
Thanks for the link.
Buying a C5 is probably something that I will put on the backburner for now. I like the C102, but the CA is bothering me.
I continue to love my C90.
Karl
#5 stevew
stevew
    Now I've done it
  • Loc: British Columbia Canada
Posted 09 April 2014 - 08:40 PM
I've owned a C5 for many years.
It's a great travel scope, and wonderful to use for a short session in the back yard.
Is there an advantage over a 102mm refractor? A lot depends on the refractor you have. The C5 is obviously easier to mount, and also has a greater range of back focus for photography. It also works well with inexpensive eyepieces, and due to the 1250mm focal length it does not require short focal length eyepieces to attain higher magnification.
My excellent example shows more details on Jupiter than a 4 inch F-6 achromat that I own, as the achromat has plenty of chromatic aberration.
It also came close in performance to a TV Genesis SDF I used to own, however the Televue did show better contrast.
Yes it has a large central obstruction, but the extra aperture does help make up for the contrast loss.
With that being said, if I didn't already own a C5, I'd probably purchase the C6.
Steve
#6 areyoukiddingme
areyoukiddingme
Posted 10 April 2014 - 02:42 AM
Ditto on the C6. Comparing between 80mm apo, 90mm achro, 101mm apo, c6 . . . the c6 goes deeper than the 101. If you can get over the restricted field of view, it's a wonder. Moon in binoviewers tonight in the c6, fantastic.
#7 orion61
orion61
  • Loc: Birthplace James T Kirk
Posted 10 April 2014 - 07:56 AM
If the Chromatic Aberration is bothering you buy an anti Fringe filter. Baader is the best, Orion sells one but makes things kind of a sickly yellow Green, I mount a very light blue filter in the end of the diagonal and it makes it more natural.
I agree on the C6, they are much more compact than the C8 tube
as far as mount, My SLT Go-To mount holds my C6 just fine,
no trouble at all!
The C6 is one of the most influential scope tubes to come out in decades! I think the perfect starter scopes.
plus they are Pretty sitting in the corner..
#8 Eddgie
Eddgie
Posted 10 April 2014 - 08:58 AM
Some of these should be self evident from the design.
C5 is smaller, easier to mount, perhaps more comfortable to use.
C5 has a narrower field, coma, field curvature, and less contrast than the C102.
Owned them both, own neither now.
SCTs advantage is packaging. It has always been packaging, and always will be packaging.
But the C5 falls a bit short in all performance criterion vs the f/10 acromat with maybe the exception of brightness, which can be important for planets (I like a bright image).
Get a C5 if you want one, and if your reason for wanting one is that they are compact, easy to mount, and comfortable to use, you will be happy.
But if you want it to give more enjoyable or more detailed views than a 100mm medium focal ratio acro, you might be disappointed.
C5 has its place and I found it much easier to deal with than the long acromat, but the views in the acro are better overall I would say.
#9 Erik Bakker
Erik Bakker
  • Loc: Netherlands, Europe
Posted 10 April 2014 - 09:23 AM
Given comparable optical quality in the samples, the 102 achro has the better images and brightness, the C5 is the most convenient and compact. Perhaps a C6 is a better solution for you. it will beat the 102 achro on everything except field of view.
#10 Ed Holland
Ed Holland
  • Loc: San Jose, CA and Oxford, UK
Posted 10 April 2014 - 09:49 AM
Indeed, to echo Eric's comment its probably worth waiting until you are ready to get a little bigger aperture rather than duplicate - in a sense - what you have already in the 102mm refractor. Have you considered buying a used instrument? This can be a great way to upgrade on a modest budget.
(But dont listen to me I have two 5" scopes and a C102 and just enjoy different scope flavours for the heck of it :))
#11 Usquebae
Usquebae
  • Loc: 43° N, 73° W
Posted 10 April 2014 - 09:52 AM
I bought a C6 specifically for viewing planets & moon. I do find it better than the C102 in that capacity, plus I like the compact size, eq tracking, and no-fuss binoviewing as compared to my 8" dob. I can use the C6 on a small alt-az, though I would not call that set-up rock-steady. I have no experience w/ a C5 but expect it would perform pretty close to the C102 image-wise, even on planets, only with a far more limited fov. C6 may be a better planetary upgrade; C5 sct would more likely be a replacement for your mak than your refractor.
As for achro filter info, you should find David Russell's comparo thread. He liked Baader 495 Longpass best, though for a faster scope than you have. I bought his Lumicon #8 for my C102 and am quite happy with it.
#12 shasca
shasca
Posted 10 April 2014 - 09:50 PM
I have the spotting scope version of the C5, and a 4 inch Explore Scientific APO. At equal magnifications, the refractor provides much better contrast. It also has more depth of field, and an easier to use focuser. The C5 is, of course, much lighter, and comes with Celestron's fantastic spotting scope warranty. The biggest drawback of the C5 is the focuser. It's slow, and I'm not aware of an aftermarket 2 inch focuser for it (need at least a C6 for that.) If life had an undo function, I'd have the C6 instead. If I had to choose one or the other, it would be the refractor.
#13 t.r.
t.r.
  • Loc: 1123,6536,5321
Posted 11 April 2014 - 12:36 PM
KarL...As someone else said, buy a filter for the C102. A minus violet is a good first choice, but may be expensive to you. I took the poormans choice and went with a cheap #8 Light Yellow filter. Does a great job at reducing CA to tolerable levels in the C102 and allows for higher mags to be used while sharpening the view. I can run my C102 over 200x now on planets and detail is commensurate with what a 4" should show. Without the filter, about 100x was it before the CA robbed contrast and detail. IMHO, any thoughts of getting a C5 is a lateral move...or even backwards. Think C6 if you must...but my C102GT does quite well compared to my C6 and in winter/spring seeing, I prefer the contrast in the 102 with filter.
#14 Ed Holland
Ed Holland
Posted 11 April 2014 - 05:56 PM
I've wondered about filter options as well. Since I have another achro it would enhance more than just the C102, so perhaps is a bit more justified.
#15 EverlastingSky
EverlastingSky
  • Loc: Vancouver Canada
Posted 11 April 2014 - 06:23 PM
Slightly off topic but: It really ought to be mentioned that the early 1980's Japanese made C102 was often of a rather high optical quality. Some samples of those early Vixen 102's were of an especially high correction and smoothness of their figure and are around 1/8+ wave. The more recent Chinese sourced C102 and C102HD is simply not comparable to the old Vixen C102 and shouldn't be confused with it.
#16 Bill Barlow
Bill Barlow
  • Loc: Overland Park KS
Posted 11 April 2014 - 07:23 PM
Would the Celestron version of this fluorite doublet be the same design as the Vixen? There is a Celestron 102 fluorite doublet for sale on the other site now.
Bill
#17 rguasto
rguasto
  • Loc: Long Island, NY
Posted 11 April 2014 - 07:30 PM
I have to agree on the C6. You'll see more.
#18 stevew
stevew
    Now I've done it
Posted 11 April 2014 - 08:53 PM
I completely agree. I owned 3 Celestron/Vixen 102s over the years and 2 were very good, and one was spectacular.
Steve
#19 EverlastingSky
EverlastingSky
Posted 11 April 2014 - 11:16 PM
Bill
The 102F was f/8.85 (902mm) and has a reputation for excellence. Here is a link to a brief bit of history and an overview by Roland Christen This was one of the first fluorites sold. I would definitely consider buying an 102F if you can find one...
#20 n1toga
n1toga
  • Loc: New Delhi, India
Posted 12 April 2014 - 01:43 AM
I own a C6 and have recently acquired the skywatcher 120mm f8.3 achro. The difference is sharpness! It is staggering... Detail is about the same between the two but it is just more obvious in the refractor. More easy to see is how I would put it. Yes there is colour in the achro but my orion V block cures that just fine and sharpens the view even more.
The positives about the C6 are it's compact dimensions and relatively light weight. Weights at 9.5 lbs with 1.25 Inch di-electric diagonal and standard finder. Snaps to focus + knob is butter smooth and no image shift. Had mine an SLT mount no problem just a little focus wiggles fixed with anti vibe pads. You can have a C6 OTA for just over 400 dollars, the C5 spotter is more expensive I think.
Rahul
#21 Bill Barlow
Bill Barlow
Posted 12 April 2014 - 09:37 AM
Thanks for the information and link, Luke.
Bill
#22 KarlL
KarlL
Posted 12 April 2014 - 10:08 AM
I think you guys have convinced me to stick with the C102.
I see mostly yellow fringing. Would the Baader Fringe Killer reduce that?
Karl
#23 Gary Riley
Gary Riley
  • Loc: White Bluff, TN
Posted 12 April 2014 - 12:25 PM
Hello Karl!
I own a Celestron Omni XLT 102mm f/10 achro refractor and I also have the Baader Fringe Killer. It does help with toning down CA but it gives a very slight yellow tint to objects.
Good luck!
Gary
#24 azure1961p
azure1961p
  • Loc: Triton
Posted 12 April 2014 - 11:29 PM
If the difference is staggering you've got one lousy C6.
Pete
#25 n1toga
n1toga
Posted 13 April 2014 - 05:09 AM
Or maybe a great sw 120...to my eyes the detail is just more obvious..just easier to see. Like I said the ammount of detail is about the same but the sw 120 is just sharper overall.
Rahul
