First M13 and M57
7 replies to this topic
#1 Mkofski
Mkofski
  • Loc: Greenfield, Indiana, USA
Posted 22 April 2014 - 01:29 PM
Well, I finally got out with somewhat clear skies and temps above 30 degrees F. Not real happy with the results but they are better than I've had in the past.
I was using the zEQ25 mount, Canon 1000D and an inexpensive 90mm f/10 refractor. I only did a fast Polar Alignment with the Polar scope on the z25 with no drift adjustment. Both shots were unguided 45 second exposures. I used Equinox Pro for camera control and did the stacking and processing in Nebulosity.
#2 Mkofski
Mkofski
Posted 22 April 2014 - 01:30 PM
And here is M13
#3 shawnhar
shawnhar
  • Loc: Knoxville, TN
Posted 22 April 2014 - 01:55 PM
Very Cool!
#4 Mkofski
Mkofski
Posted 22 April 2014 - 03:56 PM
Thanks Shawn... It is getting a little less frustrating.
#5 copperneck
copperneck
    Phalanges Compressor
  • Loc: PG, Utah
Posted 22 April 2014 - 04:01 PM
Great first grabs! That is a good sign that the frustration is less :)
#6 torsinadoc
torsinadoc
  • Loc: Fayetteville AR
Posted 22 April 2014 - 04:40 PM
Great job. I liken the learning curve as being similar to when I was an intern in the ICU my first year. Very steep learning curve but rewarding if you hang in there.
#7 Mkofski
Mkofski
Posted 23 April 2014 - 12:16 AM
While I was out on Monday night I also gave the Double Double a try. The seeing wasn't very good but I got this from my mono ImageSource camera (DMK21AF04.AS). You can't see the separation between A abd B or C and D but you can see the components elongated north and south for A/B and east west for C/D.
Thanks for looking!
Edit: the lable of bottom "pair" should read "C and D".
#8 Mkofski
Mkofski
Posted 23 April 2014 - 12:21 AM
Well, maybe not quite as steep a learning curve as an ICU internship but I get your point. It is probably the hardest thing I've done relating to a hobby!
