Computer Fan....will it work?
8 replies to this topic
#1 cadfour
cadfour
  • Loc: Melbourne, Florida
Posted 24 April 2014 - 04:42 PM
I just grabbed a computer case fan out of a dead computer (12v 1.5A) 4" to screw holes on a diagonal, it might fit my 8" Skyview Pro but I haven't gotten home yet to check. Anyway, it has 3 wires, red, black, and yellow. I will assume the red and black are the positive and negative wires. Is the yellow a ground wire?? Are my assumptions wrong and if so, how do they connect to a battery power source?
I would like to try and connect a fan to my scope to reduce cool down time.
Thanks.
#2 rlmxracer
rlmxracer
  • Loc: Motocross Mecca (Riverside) , CA
Posted 24 April 2014 - 05:28 PM
Red= +
Blk= -
Yel= Fan speed (unused)
It should be similar to the fan that the GSO dobs come with.
#3 coopman
coopman
  • Loc: South Louisiana
Posted 24 April 2014 - 06:12 PM
I'm using a PC fan with a Radio Shack battery holder that holds 8 AA batteries. Works great.
#4 Billytk
Billytk
  • Loc: Geneva, Fl.
Posted 24 April 2014 - 06:13 PM
Orion does sell fans for their scopes and they are fairly cheap.
#5 azure1961p
azure1961p
  • Loc: Triton
Posted 24 April 2014 - 06:23 PM
It should work great - been there doin that. Do not however run it at 12 volts - way overkill, noisy and shaky. Six volts and its a charmer.
Pete
#6 cadfour
cadfour
Posted 24 April 2014 - 06:24 PM
Yes i saw Orion's fan, but if I can get one working for free why not try it. If it fails, I can always fall back to the Orion fan.
ok..so now about the batteries. Is there a certain amount I should use...3?, 6?, 8? D cells? I sort of have to figure out a holder for them too....any ideas?
Oh, and thanks for the helpful replies.
#7 City Kid
City Kid
  • Loc: Northern Indiana
Posted 24 April 2014 - 07:43 PM
I use a computer fan on my Orion XT10. I started off with a 9v battery using a holder from Radio Shack. I decided that the 9v batteries were going dead too fast so I switched to a AA holder from Radio Shack that holds 8 AA batteries. Both work fine but it ended up being cheaper for me to go the AA route so that's what I do now.
#8 azure1961p
azure1961p
  • Loc: Triton
Posted 24 April 2014 - 09:58 PM
I use a boxy 6v flashlight battery that has the spring could coming out the top. Works great a really and lasts quite a while.
Pete
#9 Mirzam
Mirzam
  • Loc: Lovettsville, VA
Posted 25 April 2014 - 06:44 AM
I use a 7 AH gel cell with my fans and run them through a converter to reduce the voltage and speed if necessary. The fans will run for several multi-hour sessions (at least) before the cell needs recharging.
JimC
