iAstroHub: Tablet astrophotography comes true!
307 replies to this topic
#301 anat
anat
Posted 11 September 2014 - 11:22 PM
Hi Anat, i'm Manuel from Italy. Thank you for your incredible work. I am trying to install on a original MK808B and I had the same problem of user InZet. I flashed the image of MK808B and loading stops as in your screenshot in post # 102, but if I press ALT + F1 I can not access the login page so I can not make changes to enable the wifi. I have verified that the wifi chip is RK903 and I flashed the kernel Finless 2.1, replacing recovery.img with the mk808b kernel. For the image iAstrohub I used a sd card Sandisk 16 GB Class 10.
Do you have any idea on how I can resolve this situation?
Thank You very much
Manuel
Hi Manuel
The screen shows when it cannot detect the micro SD card.  You may need to try another SD card or use another PC to write the card.
Best regards,
Anat
#302 Corsaro2k
Corsaro2k
Posted 13 September 2014 - 02:12 AM
Dear Anat, I solved it by flashing the image on the same SD Card but using a notebook with windows starter 32 bits. IAstrohub works perfectly. I hope this is useful to anyone who has had the same problem.
I tried to configure Linguider using 2 different configurations but none work. I have a ZWO ASI120MM and a MagZero MZ5M and both use the same sensors of QHY Camera but Linguider does not recognize them. I hope that in the future be added to the drivers for these devices.
Thank you very much for your wonderful work.
Manuel
#303 Soncebos
Soncebos
  • Loc: Germany, NRW
Posted 13 September 2014 - 05:00 AM
Dear Anat,
thanks again for this wonderful piece of software.
It works perfectly for me now. Guiding is great, platesolving
helps a lot to find the right picture orientation.
Camera control is working good.
The only thing i could not find out yet is how to
manually select a star for guiding in linguider.
If i tap on a Star on the sceen and save coordinates it
says "processing" and "ready" but taking some other pace on the picture.
So I have to repeat "auto" until it takes a star that works.
Here is a link to a picture from last night:
http://www.astrobin.com/120469/
Edited by Soncebos, 13 September 2014 - 05:01 AM.
#304 anat
anat
Posted 13 September 2014 - 05:20 AM
The position where you remove your finger after dragging the star is used ...aka Ondragstop
#305 anat
anat
Posted 13 September 2014 - 05:21 AM
Thanks for sharing nice images.
#306 Soncebos
Soncebos
  • Loc: Germany, NRW
Posted 13 September 2014 - 06:59 AM
Thanks I will try that the next night.
#307 tango13
tango13
  • Loc: Rome, Italy
Posted 15 September 2014 - 01:32 AM
Hi all,
this is my latest shot with iAH, hope you like it.
Thanks Anat! ;)
Ciao,
Piero
#308 ivynetca
ivynetca
Posted Yesterday, 01:16 PM
Hi Anat - many thanks for a great application. Definitely a boon to astrophotography, especially for travel setups.
A couple of questions
 - possible to shut off LED somehow to avoid light pollution? I have the MK809 strapped to the lens to aid dew heater.
 - I find the control of my D600 very  hit or miss (mostly miss). It seems to work fine through qDSLRdashboard, but capture through the iAH main web page DSLR Camera Control not so much. Does seem to work fine with my EOS600D though.
Thanks - Jeff
