iAstroHub: Tablet astrophotography comes true!
481 replies to this topic
#476 Jazzle85
Jazzle85
Posted 24 March 2015 - 02:34 AM
I attach the steps to make the image of iAstroHub 2.2 with the working AP mode in CX919.  See the previous post for the image file and details.
Hi Anat,
thanks for all the good work!
I've ordered the CX919 from your link, am still waiting for it to arrive. One thing is not clear to me; do i need to use the image file "iAstroHub2.2_CX919_20150311.img", write to SD, insert & run and that's it?
Or do i need to use iAstroHub2.2 src.zip from Sourceforge and follow steps as described in file "steps CX919.txt"?
Kind regards
Jasper
#477 anat
anat
Posted 24 March 2015 - 04:26 AM
Hi Anat,
Kind regards
Jasper
Jasper,
You can just flash the image file "iAstroHub2.2_CX919_20150311.img" Nothing else to be done. The step is for people who want to build everything from sources.
Anat
#478 anat
anat
Posted 24 March 2015 - 05:35 AM
Hi anat,
Could you please give a detailed camera list of which are supported in ver 2.2?
I use the latest version of gphoto2 and pktriggercord. Please refer to the following websites for supported cameras
http://gphoto.sourceforge.net/
http://pktriggercord.sourceforge.net/
Anat
#479 ecloud
ecloud
Posted 24 March 2015 - 05:42 AM
Hi anat,
Anat
Thanks Anat,
But I also want to know the list of QHY and SBIG CCD cameras
#480 anat
anat
Posted 24 March 2015 - 05:45 AM
Hi anat,
Anat
Thanks Anat,
I see.  For SBIG cameras, iAstroHub should work with all recent cameras with USB ports. It has been tested with ST10, ST2000, STF8300.
For QHY supports, please refer to the website on openskyimager:
https://github.com/O...t/OpenSkyImager
Anat
#481 colgs3b
colgs3b
  • Loc: Zionsville, IN
Posted 24 March 2015 - 07:42 AM
Anat,
Perhaps a noob question, but this is baffling me.  Pointed West, auto guiding is fine.  Pointed East, guiding works for a few seconds and then is rapidly lost only in one axis.
Mon Mar 23 03:21:06 UTC 2015
107:DRIFT_DATA:-0.04 0.56
107:DRIFT_DATA:-1.77 -0.54
107:DRIFT_DATA:0.30 -0.01
107:DRIFT_DATA:-1.14 0.13
107:DRIFT_DATA:-0.17 -0.64
107:DRIFT_DATA:1.64 -0.34
107:DRIFT_DATA:0.67 -0.33
107:DRIFT_DATA:1.91 -0.78
107:DRIFT_DATA:0.92 -0.66
107:DRIFT_DATA:-0.92 0.52
107:DRIFT_DATA:0.98 0.02
107:DRIFT_DATA:0.80 1.06
107:DRIFT_DATA:0.14 1.65
107:DRIFT_DATA:-2.03 1.21
107:DRIFT_DATA:0.67 0.37
107:DRIFT_DATA:0.66 0.47
107:DRIFT_DATA:-0.17 1.69
107:DRIFT_DATA:0.97 1.93
107:DRIFT_DATA:0.32 2.17
107:DRIFT_DATA:3.23 3.21
107:DRIFT_DATA:2.13 4.90
107:DRIFT_DATA:0.51 7.07
107:DRIFT_DATA:-0.03 11.13
107:DRIFT_DATA:-0.45 17.21
107:DRIFT_DATA:0.06 30.02
107:DRIFT_DATA:1.85 46.63
107:DRIFT_DATA:-0.04 64.62
107:DRIFT_DATA:-0.69 83.73
107:DRIFT_DATA:0.48 102.78
107:DRIFT_DATA:-0.72 122.92
107:DRIFT_DATA:0.41 145.16
107:DRIFT_DATA:2.89 165.53
I aligned on a different star, and the same issue.  I rotated the camera (QHY5II-L-M), recalibrated, and the same result.  This happened over two separate nights, only when pointing East.
Thoughts?
Jeff
#482 anat
anat
Posted 25 March 2015 - 01:23 AM
Set Dec gain to zero and see the result. If it happens, it means the problem with your mount setup
