iAstroHub: Tablet astrophotography comes true!
586 replies to this topic
#576 tango13
tango13
  • Loc: Rome, Italy
Posted 13 June 2016 - 02:49 AM
Wow, glad to hear that iAH will soon support INDI!
That will be another big improvement.
Thanks for your great work Anat!
Ciao,
Piero
#577 Lobo59
Lobo59
Posted 14 June 2016 - 12:46 PM
Thank you Anat for the link.
I look forward to ver 3.0 and I'm impressed by both your programing skills and you patience! I for one appreciate
what you and the others are doing.
Larry
Lobo59
#578 SXBB
SXBB
Posted 20 June 2016 - 08:23 AM
Hi Anat,
I'm on the finally on the verge of installing iAstroHub!  Where can  download the cooked firmware for the ASUS WL-330N3G?
Bruce
#579 anat
anat
Posted 21 June 2016 - 04:43 AM
Bruce:
Why do you need ASUS WL-330N3G  for iAstroHub?  :)  What devices do you use now?
Best regards,
Anat
#580 SXBB
SXBB
Posted 21 June 2016 - 10:00 AM
Hi Anat,
I have an IC8300 and earlier you recommended that I use  the ASUS WL-330N3G because of the limitations of the IC8300 wifi.  You said your custom firmware for the ASUS WL-330N3G would work better.  My IC8300 came bundled with a ASUS WL-330N3G which is either a happy coincidence or I guess was at your suggestion because of your work with QHY?
Bruce
#581 anat
anat
Posted 23 June 2016 - 08:30 AM
Hi Bruce,
I gave the custom firmware to QHY as well. If the interface of the router is one of OpenWRT, it is my custom firmware. Otherwise, you can get it here.
https://drive.google...iew?usp=sharing
Please get the firmware restoration app from
http://www.asus.com/...pDesk_Download/
The benefit of this firmware is that the wifi to serial bridge is installed in the router. So you can connect a FTDI or PL2303 based usb- serial adapter to the router and to your mount. Then you can control the mount from Skysafari.
Best regards,
Anat
  • ccs_hello and SXBB like this
#582 SXBB
SXBB
Posted 23 June 2016 - 11:26 AM
Hi Anat,
I'll check the router to see if it's running OpenWRT.  I have used it before and don't believe that to be the case.  I'd really like to use your wifi to serial bridge!  I have SkySafari 4 Pro and it's my favorite planetarium software.  My mount is an Atlas Pro AZ/EQ GT and rather than a serial port on the mount, the hand controller connects via an RJ45.  My hand controller does have a DB9 on the bottom and that can be used in PC Direct Mode.  The IC8300 has built-in serial ports and a USB port.  I do have a USB to Serial adapter.  I'm unclear how I would make the connections between the IC8300, USB to Serial, and Router to make this work.  Are you saying connect the IC8300 via wifi to the router, connect the USB to Serial adapter to the USB of the IC8300 and the DB9 of the hand controller in PC Direct Mode, and connect the tablet or laptop running SS4 to the router via WIFI?  I suppose I could use the IC8300 internal serial port cable to connect rather than a USB to serial adapter?
Thank You,
Bruce
Edited by SXBB, 23 June 2016 - 11:28 AM.
#583 SXBB
SXBB
Posted 24 June 2016 - 05:04 PM
Hi Anat,
Actually, I was incorrect about the DB9 connector on the hand controller.  It has an RJ12 port and came with an RJ12 to DB9 cable.
Thank You,
Bruce
#584 Mr.Coffee
Mr.Coffee
Posted 01 July 2016 - 07:56 PM
Hi, guys, does anyone has the source of iAstroHub 3.0? Could you please provide a link for download? Thanks!
#585 pepe.lombris
pepe.lombris
Posted 16 August 2016 - 07:07 AM
I have a question which not so much related to iAstrohub as such but rather to its router functionality. I'd like to establish a teamviewer connection between two computers in the field. Would it be possible to achieve this by using iAstrohub as a WLAN router?
Sorry if that's a bit off topic but don't worry I will continue iAstrohub for its functionality too :-)
Best regards
Stephan
#586 anat
anat
Posted 17 August 2016 - 01:21 AM
Stephan
When iAH is used as an access point, it is possible to connect between to PCs via TeamViewer. You will need to accept "incoming LAN connections" under Extra > Option. Use IP address for connection.
Anat
#587 anat
anat
Posted 30 September 2016 - 06:48 PM
iAstroHub 3.0 is released here
http://www.cloudynig...trophotography/
Please continue the discussion in the new topic. Thank you for all your support.
Best regards,
Anat
