Post a picture of your refractors (PART 7)
2364 replies to this topic
#301 MAURITS
MAURITS
  • Loc: Belgium
Posted 21 August 2014 - 02:15 AM
A recently restored 1925 Zeiss alt-az
That is one BEAUTIFUL scope!!!!!!!!!!!!!!!!!!!!!!! :bow:  :bow:  :bow:   :waytogo:  :waytogo:  :waytogo:  :like:  :like:  :like:
  :waytogo:
#302 Adam S
Adam S
  • Loc: Gunnison, Colorado
Posted 24 August 2014 - 10:30 PM
Adam_S - Very interested - What is the finder on your FS-102 and how do you have it mounted?
Great set-up - Like the Nova Hitch as well - very much.
Hi Pete, it's actually the Lunt 35mm Ha filter which is attached to the Tak clamshell with a single bolt on a Vixen made camera attachment.  The Lunt is light enough that it's very stable.  I center there Tak in white light mode then using the up/down and side/side knobs on the Vixen center the Lunt.  Quick set up and takedown.
Edited by Adam S, 24 August 2014 - 10:41 PM.
  • Scott Beith and Perseus_m45 like this
#303 Adam S
Adam S
Posted 24 August 2014 - 10:50 PM
  • Scott Beith, Exnihilo, Perseus_m45 and 1 other like this
#304 ngc2289
ngc2289
  • Loc: Corpus Christi, TX.
Posted 25 August 2014 - 01:51 AM
Here is my latest set-up.  It is a SV66ED on my Unitron Model 128 Equatorial Mount.
#305 TG
TG
  • Loc: Latitude 47
Posted 25 August 2014 - 01:41 PM
Here's mine.
Sorry, couldn't resist.  :lol:
  • Scott Beith, droid, MarkGregory and 1 other like this
#306 jaymocha
jaymocha
  • Loc: Seoul, KR
Posted 25 August 2014 - 01:44 PM
Perfect!  Well done TG :)
#307 AustinAstronomer
AustinAstronomer
Posted 25 August 2014 - 01:53 PM
Here's mine.
Is that a blue tube Astro-Physics???
#308 Jeff B
Jeff B
Posted 25 August 2014 - 05:16 PM
Here's mine.
Sure looks like one.  I cut mine back to make it bino-friendly.  The only thing in the picture that gives me pause is the hammer.   :)
  • bgi likes this
#309 tag1260
tag1260
  • Loc: Ohio, USA
Posted 25 August 2014 - 07:11 PM
Here's mine.
Shouldn't that be" WAS that a blue tube Astro-Physics?" :lol:
#310 bremms
bremms
  • Loc: SC
Posted 25 August 2014 - 07:26 PM
My 6" F10 Jaegers  with all home built tube and mount. Mount is just completed and the pier is not powder coated.
Edited by bremms, 25 August 2014 - 07:27 PM.
  • Scott Beith, Deep13, bgi and 4 others like this
#311 Scott in NC
Scott in NC
    Refractor Fanatic
  • Loc: NC
Posted 25 August 2014 - 07:43 PM
:like: :waytogo:
  • Dr. Woo likes this
#312 TG
TG
  • Loc: Latitude 47
Posted 25 August 2014 - 07:46 PM
Here's mine.
Here's mine.
Yep, it's a blue tube A-P. Jeff, what you call a hammer is also known as "collimation tool". :grin: I used it to tap the back-plate till square, using a piece of wood which you can also see lying on the floor, and a laser with a center dotted paper mask on the objective. Roland Christen had told me that these oiled triplets aren't completely coma corrected so it is important to get the focuser square to the lens. I think I got it square to within 0.5mm. Doing that first required squaring a Glatter laser - they're very good but mine was off by a tiny bit. Finally, the lens was collimated using a Takahashi collimating scope. Views of Albireo at 320x were out of this world.
It was all done as part of shortening the tube to better accommodate a Mark V and the results are just sweet. I can now use 35mm Ultrascopics without an OCA, framing the double cluster in a mere 50 degree AFOV! With the 3" A-P extension tube, I can use my normal mono eyepieces as well. The extension tube isn't strictly needed but I don't like using the focuser at the end of its range.
I'll post a pic of the shortened tube when I get a decent one.
Tanveer
#313 TG
TG
  • Loc: Latitude 47
Posted 25 August 2014 - 07:50 PM
:bow: I'm always impressed with from-scratch builds. I wish I had the skills. But don't you think the objective looks kind of crumply? :lol:
#314 JJK
JJK
Posted 25 August 2014 - 08:50 PM
Berms, did you cut the worm gears?
Edited by JJK, 25 August 2014 - 08:50 PM.
#315 bremms
bremms
  • Loc: SC
Posted 25 August 2014 - 10:36 PM
No, that's an older Mathis gear. I don't have access to a gear hob. It is a great scope, but an F10 achromat has limitations. There is a bit of a halo around stars at high magnification due to the CA. The scope has very nice airy discs. At some point, it would be nice to get a 150mm APO lens for the scope.
#316 bremms
bremms
  • Loc: SC
Posted 25 August 2014 - 10:44 PM
The crumply bit is a special adaptive optic.it wigglees around in the wind to correct the incoming wavefront. :lol:
#317 george tatsis
george tatsis
  • Loc: Flushing, NY
Posted 25 August 2014 - 11:16 PM
Superb set up Marc. There's always something magic about big refractors on a pedestal ! :waytogo:
George
#318 Walter E.
Walter E.
  • Loc: Winter Springs, FL
Posted 26 August 2014 - 08:56 PM
Finally got some somewhat clear skies for about an hour plus tonight so I drug out the mount and the ES 152 to check it out. First target was Saturn and it looked pretty darn good without any filters. I ran up to a 2.7x Barlow with an ES 8.8 for 300x. Not mushy at all except the seeing was in and out a lot more. Backed off to a 20mm with the 2.7x and was pretty crisp. Some purple haze but barely noticeable. I put the Baader Fringe Killer in and the image did improve some but not a great deal. It did almost look sharper but I think my mind was telling me things :-)
Went to a tight double in Scorpius, the visual double that one component is a very tight double. It split with the ES 8.8 with no barlow. Looked very nice.  Then went over to the double double in Lyra. with the 20mm lens both components were clearly split with no problem.
All in all I am a happy camper. The scope has only one detractor, IT IS HEAVY!!  It almost feels heavier than my Celestron 6" f/8. Have to get some scales out.
Walt
Edited by Walter E., 26 August 2014 - 08:57 PM.
  • Exnihilo and gitane71 like this
#319 KevH
KevH
  • Loc: Maine
Posted 29 August 2014 - 01:10 PM
Just picked up an Astro-Tech AT102EDF.  I've now owned every Kunming United doublet except the big 6" achro.  I think the 4" ED is the best of the bunch.  Doesn't give up much to the 110, but is quite a bit lighter.  Much better light grasp over the 80 and far better color correction than the 102 f11 achro.  It takes power very well and goes plenty wide for sweeping.  A very nice all around scope.
#320 jrbarnett
  • Loc: Petaluma, CA
Posted 29 August 2014 - 10:20 PM
Tak TSA-102 on a Half-Hitch Mark II
Beautiful Hans!
- Jim
#321 jrbarnett
  • Loc: Petaluma, CA
Posted 29 August 2014 - 10:27 PM
The big 6" Kunming achromat is the only Kunming scope I have!
- Jim
  • Scott Beith, Exnihilo and Perseus_m45 like this
#322 karstenkoch
karstenkoch
  • Loc: Northern Virginia
Posted 29 August 2014 - 11:03 PM
Brilliant!
#323 KevH
KevH
  • Loc: Maine
Posted 30 August 2014 - 07:33 AM
- Jim
One of these days!  Although I'll have to get a beefier mount to go with it.
  • Exnihilo likes this
#324 ngc2289
ngc2289
Posted 30 August 2014 - 06:41 PM
Jim how do you like the SV focuser on the 6 inch?
#325 SteveG
SteveG
  • Loc: Seattle, WA
Posted 02 September 2014 - 02:24 PM
WO ED120 - f7.5  Dew shield extended:
  • Scott Beith, Perseus_m45 and gitane71 like this
