Mount Orion ED80T on Nexstar 8SE OTA?
9 replies to this topic
#1 Amaranthus
Amaranthus
  • Loc: Tasmania, Australia
Posted 14 May 2014 - 11:57 AM
I'm looking at the following setup:
Celestron 8SE OTA
AZ-EQ6 mount
Orion ED80T (piggyback)
I already own the 8SE, and want a dual-purpose imaging/visual setup. This seems like an ideal combination to me, as the total load, including camera/CCD, will be only ~10kg (vs 20kg rating for the AZ-EQ6 mount), and I can use one OTA as a guidescope while I image with the other (depending on whether I want narrow or widefield imaging).
Two questions:
1. Does this type of setup make sense? (apart from to me!)
2. Has anyone tried mounting the ED80T on the C8 OTA? If so, what mounting bracket would I need for my C8?
Thanks for the feedback!
#2 nodalpoint
nodalpoint
  • Loc: FEMA camp
Posted 14 May 2014 - 12:52 PM
Make sure your mount can handle all that weight. I'd go with a small 50mm guide scope for the refractor instead of mating the other two together.
#3 Amaranthus
Amaranthus
Posted 14 May 2014 - 12:57 PM
That's another option, yeah. But the total weight would be 5.6 kg (C8 OTA) + 2.5 kg (ED80T OTA) + camera/imager (0.5-2kg), for a total of ~8.5 to 10 kg. The AZ-EQ6 is rated to 20 kg load, so I'm 50% under spec, which seems ideal to me.
#4 Smittty692k4
Smittty692k4
  • Loc: East Bernard, TX
Posted 14 May 2014 - 01:43 PM
Seems legit to me... Alot of positive reviews too of people using it in AltAz mode.
#5 Stacy
Stacy
    Star Partyer
  • Loc: Seattle, WA
Posted 14 May 2014 - 08:23 PM
ADM is the place to get the mounting hardware. Top notch outfit.
#6 hopskipson
hopskipson
  • Loc: Queens, New Yawk, Light pollution Headquarters!
Posted 15 May 2014 - 06:06 AM
One consideration, have you included dew straps, dew shield and mounting hardware into your weight?
#7 Amaranthus
Amaranthus
Posted 15 May 2014 - 11:04 AM
The dewshield for the C8 weighs only a few hundred grams. I don't currently use other dew control, but the dewstraps are light. Remember, I'm planning to underspec the mount by 50%, so there is a lot of margin here, following the 66% rule of thumb.
#8 Smittty692k4
Smittty692k4
Posted 15 May 2014 - 11:07 AM
Imaging is usually a 50% rule of thumb if I am not mistaken.
#9 Smittty692k4
Smittty692k4
Posted 15 May 2014 - 11:08 AM
Which I think you would still be under.
#10 Amaranthus
Amaranthus
Posted 16 May 2014 - 09:24 AM
I just re-checked the load-bearing capacity of the AZ-EQ6 and it is actually 25 kg.
http://www.opticstar...sp?p=0_10_2_0_3
My max conceivable load with the 8SE OTA, the ED80T and imaging paraphernalia will be <12 kg, so I'm sweet on the 50% rule too :)
