Barker's Bluff Observatory Begins
124 replies to this topic
#101 JJK
JJK
Posted 18 September 2014 - 04:53 PM
I can move my RoR with one finger (on the motor switch).
#102 JHGIII
JHGIII
  • Loc: Barker's Bluff Observatory, 34' -87'
Posted 24 September 2014 - 07:00 PM
Touche'
I will begin finger excercies as no motor is planned in the near future :)
#103 JHGIII
JHGIII
Posted 30 September 2014 - 06:40 PM
So close I can taste it. Outreach room.
#104 JHGIII
JHGIII
Posted 30 September 2014 - 06:57 PM
Observatory lacks door, so no valuables can stay overnight.
#105 JHGIII
JHGIII
Posted 08 October 2014 - 05:53 PM
Beauty and the Beast.
Door arrives !!
It weighs about 200 lbs. Door perimeter is 3/8 inch steel box.
Stained and four coat satin sealed panels belie the impenetrable structure
#106 JHGIII
JHGIII
Posted 08 October 2014 - 05:57 PM
The interior that Larry and I designed is a grid of rebar, welded at a 6 inch grid.
Of course, door knob and deadbolt will help it work better :grin:
#107 JHGIII
JHGIII
Posted 08 October 2014 - 05:59 PM
Floor is stained and sealed.
Rain gutter handles run-off from closet roof.
#108 JHGIII
JHGIII
Posted 10 October 2014 - 07:32 AM
My deepest apologies to those of you in the Southeast.
The observatory is to be completed by this afternoon. I will move the scopes in and commence with finalizing cable runs.
There will then be 3-4 days of concentrated leak testing which may adversely affect your sky conditions this weekend.
I will make every effort to wrap this up before the new moon.
#109 JHGIII
JHGIII
Posted 12 October 2014 - 01:18 PM
Friday and Saturday brought security.
Four roof toggle clamps (each rated at 300 lb capacity) were installed to keep roof locked when closed.
The two on the West side are angled to keep the roof tight against the West side stops on the rails.
The other two are neutral.
#110 JHGIII
JHGIII
Posted 12 October 2014 - 01:21 PM
The door knob, deadbolt and receiver in the door frame have been added.
Doubt this door could be kicked in.
#111 JHGIII
JHGIII
Posted 12 October 2014 - 01:27 PM
So now it is safe to bring in the scopes. Hooray!!!
C11 is happy on G11 topping Linak column.
Fully extended:
Fully retracted:
Controller conveniently mounted on pier adapter.
Wires temporarily taped until I decide on final arrangement.
#112 JHGIII
JHGIII
Posted 12 October 2014 - 01:29 PM
Dob parked neatly in closet:
Storage and ventilation under bench.
#113 JHGIII
JHGIII
Posted 12 October 2014 - 01:32 PM
Lights over bench are in Red and White, plus I ran a red rope light around the south wall perimeter (but will need to add a dimmer).
#114 JHGIII
JHGIII
Posted 12 October 2014 - 01:36 PM
The floor outlet boxes are a deep design that allows the plugs to be completely recessed beneath the covers with rubber gaskets to help keep out moisture and dirt.
Two boxes contain AC outlets, and the third will carry all data feeds
#115 JHGIII
JHGIII
Posted 12 October 2014 - 01:47 PM
Now that the building is finally complete, we will move on to landscaping.
North side of complex:
South side:
#116 rockethead26
rockethead26
  • Loc: Northern Arizona, USA
Posted 12 October 2014 - 03:10 PM
Impressive work! Lookin' mighty good.
#117 ThomasT
ThomasT
  • Loc: Etoile, Texas
Posted 12 October 2014 - 04:02 PM
Your entire project is far out.
#118 JHGIII
JHGIII
Posted 15 October 2014 - 04:40 PM
UPDATE astronomers n the Southeast U.S.
Thank you for your patience during leak testing. During the past week, the observatory has been tested with over five inches of torrential rainfall.
In order to expedite the testing process, straight line winds up to 60 MPH were added on two occasions.
While some nearby trees were downed, they were not implicated in direct impact tests.
In the interest of public safety, hurricane and tornado tests are on indefinite hold, but may be activated with little warning.
Testing should wrap up this evening with a 20% chance of additional leak testing. However due to the excellent performance of the observatory over the past week, testing tonight may be limited to tolerance of overbearing cloud cover.
All tests should be completed by tomorrow 10/16/14.
You will then be returned to your typical fall weather:
Days should be sunny and clear in the mid to high 70's - good for solar observing
Nights will be clear and cool with highs in the mid to high 40's with light breezes from the Southwest after Friday.
As promised, testing has been completed prior to the new moon.
Clear Skies y'all
  • Vesper818 likes this
#119 bamastar
bamastar
  • Loc: Childersburg, Alabama
Posted 14 December 2015 - 08:39 AM
This is the first time I've read this thread, and I've spent the last hr reading it from star to finish. After coming to Barkers Bluff twice to observe with you, I totally appreciate your observatory more now that I've seen it from start to finish. It is everything you have plannedfor it to be, all the way to enjoying the Dob deck for a break and enjoying and adult beverage, which we did the other night. I feel glad you and I have struck up a friendship and a few times a year get to enjoy what you have built. It is a very nice observatory!
  • FOUNTAIN1 likes this
#120 StephenW
StephenW
  • Loc: San Jose, CA
Posted 14 December 2015 - 03:51 PM
Can I ask which brand/make you used for your roof clamps?  I have been looking for something similar on line but can;t find anything wit as long an arm - most seem to have a much shorter reach.
thanks!
Steve
#121 JHGIII
JHGIII
Posted 15 December 2015 - 06:45 AM
https://www.amazon.c...e?ie=UTF8&psc=1
Steve,
If you are asking about the toggle clamps, I found them on Amazon. The original arms were shorter but my metal guy added extensions (in the pic you can see a female female connector about mid arm). It is just a piece of threaded steel. If you mean the roof hold downs on the exterior, those were custom fabricated. The black pipe rail they mate with is just black gas pipe. I'll shoot my metal guy a text and see if he remembers the source for the extensions for the toggles.
John
#122 JHGIII
JHGIII
Posted 15 December 2015 - 08:37 AM
Steve,
Larry said threaded rod is sold at big box home improvement stores. I assume the coupler/connector is as well, but did not see it online
#123 JHGIII
JHGIII
Posted 15 December 2015 - 10:28 AM
Marc,
Glad you enjoyed the build thread. The obs was designed from the start to share astronomy with intetested friends and neighbors. You are always welcome to join in
  • bamastar likes this
#124 bamastar
bamastar
Posted 15 December 2015 - 01:54 PM
Thanks John. Off topic,,, that cut out on the pans I asked you about. I figured out what it's for last night using my son's 70 mm. For it to seat all. The way in the diagonal, the locking screw on the diagonal that locks the ep in place fits into that slot. That's the only way the ep can rest fully into the diagonal.
#125 FOUNTAIN1
FOUNTAIN1
  • Loc: Winder, Ga
Posted 18 December 2015 - 08:43 AM
Very nice observatory John and well thought out! Thoroughly enjoyed looking through your thread. :waytogo:
