Astronomers Without Borders 80ED isStill Available
471 replies to this topic
#251 bgi
bgi
  • Loc: Ga
Posted 26 August 2014 - 09:26 PM
Mine sits on an Orion VersaGo III blem.  Works great!  I got a dovetail from dodgeman7 on ebay, drilled and tapped the clamshell that came with the scope.  It's dandy.  The stock focuser is fine.
Edited by bgi, 26 August 2014 - 09:26 PM.
#252 Bignegs
Bignegs
Posted 28 August 2014 - 10:30 PM
I've read and re-read this thread a few times. I have to get one. I don't need one. I have to get one, it's a super deal, and supports a good cause. I don't need one.
I ordered one.
I reckon it'll be my  grab and go scope to complement my ES 127 ED, that I recently got. I might use it as a guide scope, and as a scope for imaging, as I have been impressed with the images posted.
Now, I face the difficult task of choosing another toy or two to sell.
Life is hard, LOL!
But seriously, thanks guys for the heads up on this deal. I can't wait til it arrives.
  • BFaucett likes this
#253 pdxmoon
pdxmoon
  • Loc: Oregon
Posted 30 August 2014 - 11:12 AM
Mine on the Porta II is the ideal winter grab and go. I can have it outside before the cup of coffee gets cold!
#254 Sarkikos
Sarkikos
  • Loc: Per sylvam ad astra
Posted 30 August 2014 - 05:46 PM
Mine goes out on a 501HDV and Bogen tripod. I want to put it on my NexStar SE 6/8 mount, but refractors don't play well on them.  I have a slotted dovetail on backorder from Astronomics so I can do a Ron's Rail thing.  I could set the slew limits to prevent it from going toward zenith and hitting the mount.  But I don't like doing that.  It's still not safe. Slew limits won't keep me from slewing it by hand past those limits.
Edited by Sarkikos, 30 August 2014 - 05:47 PM.
#255 Far-Out
Far-Out
Posted 02 September 2014 - 04:24 PM
Got mine today.
Initial impression very well built.
Addressing earlier comments.
Cover fell off, adjusted  the 4 plastic prongs cover. Just put some gentle thumb pressure
on the four plastic prongs, which seemed to just sit behind the overall outer cover.
Gentle pressure a few trials in between. And now the cover fits snug.
Whether or not it's a permanent fix, time will tell.
Optics clean and perfect.
Tested day time, tonight will be the real test.
Marks under clam shell dull ring around tube, I can live with that.
Attaching to dovetail of my astrotech Voyager mount and tripod fits good and I can see why people buy rings,but it seems to hold mine just fine.
Everything seems to be metal with the exception of the finder eyepiece which was in two parts. The end part that I had to screw In seemed to be all plastic, balance metal.
Also the dovetail holder on the scope seemed to be twice as long as what was required to hold
the finder. Just wonder why? As it doesn't seem to have  any function.
The inner box seal was broken, which indicated to me someone opened box prior to shipment to check contents. Everything else looked factory new. With consideration that it was sitting in a box for maybe 7 years.
The focuser is smooth and does not stick. And that sticky focus noise cannot be heard.
The focuser works well in daytime, who knows what the night may bring.
The supplied  eyepiece  has a lot of eye relief,I have to back my eye away from the lens a considerable distance to get the full,view.
Because there is no rubber cup protecting from light entering from sides this may cause a problem with extraneous  light entering .
if your in a dark space this may not be a problem. But neighbors lights are always on.
I have an Orion EON80F6.2 which I like a lot. And I'm hoping to get a least a little better views out of inexpensive eyepieces.
I can't see spending more money for my eyepieces than than my telescope. I joke.
Would love to have them  and at Stellefane Nagler raffles,I'm always waiting for my number to be called.
So I will do some testing the next few day and try to get back.
I emailed AWB and  the wave of orders has slowed a bit so there's still time to buy one.
Edited by Far-Out, 02 September 2014 - 04:28 PM.
#256 GOLGO13
GOLGO13
  • Loc: St. Louis area
Posted 02 September 2014 - 11:30 PM
Took mine under the stars for the first time.  Wow. Great optics. I wouldn't mind putting a moonlight focuser on it but the focuser isn't too bad.  The star test was equal to my Televue 60mm and 103mm vixen.
The moon and Saturn were stunning.  It's a keeper for sure.
#257 Binojunky
Binojunky
Posted 03 September 2014 - 11:36 AM
Got mine today.
The cap fit can be fixed with three strips of sticky backed felt (available for a couple of bucks at a craft store) placed at 120 degrees between the plastic prongs,the dull section on the tube paint has been an issue from day one, probably caused by the fact the paint hasn,t fully cured and the clamshell is rather tight, it can be removed with gentle rubbing useing Turtle wax polish, some tube are hardly marked, others more so. The focuser is fine for visual use, the only thing I,m not fond of is the finder, I use a red dot, enjoy the scope, DA.
#258 Ain Soph Aur
Ain Soph Aur
  • Loc: West Tennessee
Posted 04 September 2014 - 08:38 PM
I just ordered one of these from AWB along with a flange to mount a moonlite. Does anyone reading have any experience with this scope + Moonlite + Baader Maxbright/T-2 Zeiss prism? I only have a 1.25x GPC. Curious if this combo will work at native f/l, with the 1.25x OCA or will I need the 1.7x or 2.6x GPC?
Edited by Ain Soph Aur, 04 September 2014 - 08:39 PM.
#259 evan9162
evan9162
  • Loc: Boise, ID
Posted 04 September 2014 - 08:50 PM
I have a Maxbright binoviewer.  I currently use it on my C6 SCT w/o an GPC.  I plan on using it with my C80ED w/o a GPC, and have done a bunch of measuring and calculating to figure out the best way.
With the stock focuser and 2"-1.25" adapter, the C80ED has about 110mm of back focus.  The MaxBrights add about 110mm to the light path.  You can actually use them straight through (no diagonal) and they will come to focus with most eyepieces.
According to this:
http://www.alpineast...nstructions.pdf
The MaxBright + Zeiss combo light path length is 151mm (bare) or 134mm (w/ 1.25x GPC).  Your Moonlight focuser would have to be at least 24mm shorter than stock to come to focus with the 1.25x GPC, and 41mm shorter w/o it.
My plan is get the non-Zeiss prism diagonal and use the stock focuser, but replace the 2"-1.25" adapter with one that's lower profile, saving about 20mm.  I also plan on shortening the tube by 1".  That will give me 45mm to compensate for the 38mm light path from the diagonal.  Hopefully this will allow nearly any eyepiece in the MaxBrights to come to focus.
#260 evan9162
evan9162
  • Loc: Boise, ID
Posted 04 September 2014 - 11:18 PM
This scope is a fun wide-field imaging scope.  I'm having a blast imaging with it, even with my pokey EQ-3 mount unguided.  I'm happy with what I've done so far, even only being able to take 20 second subs.  A field flattener would certainly help improve stars in the corners.
#261 Ain Soph Aur
Ain Soph Aur
Posted 04 September 2014 - 11:27 PM
Hi Darin. You have sure done your homework, thank you. I will measure the stock focuser and Moonlite before I swap them out, and keep my fingers crossed the Moonlite has significant less optical path than stock :) i have not had good luck in trimming OTA's with threaded adapters, so if the T-2/Maxbright doesn't work (native or with 1.25x)  with the Moonlite, I will decide if I want to invest in a stronger GPC or not.
This is my first ED refractor, so I am going to play around with planetary/lunar photography with the ZWO ASI120MM to compare with long f/l achromats. My stongest barlow is a 2.25x Baader, should I look into a x4 barlow with this scope with the camera?
I do have to admit, I am most looking forward to using the ES 82/30 with this scope for a hopefully awesome 20x 4 degree field :)
#262 Ain Soph Aur
Ain Soph Aur
Posted 04 September 2014 - 11:58 PM
Evan, awesome pics. What camera are you using on those shots?
#263 evan9162
evan9162
  • Loc: Boise, ID
Posted 05 September 2014 - 09:11 AM
The rule of thumb for planetary/lunar imaging seems to be to operate in the F/20 to F/30 range.  This also depends on the pixel size of your imaging camera.  I don't see much improvement going over F/20 with my T4i DSLR, which has 4.3um pixels.  The ASI120MM looks to have 3.75um pixels, so it seems you wouldn't want to go any higher than that either.  Your 2.25x barlow will give about F/17, so you're getting in the ballpark.
I'd say try with your 2.25x barlow first.  If the image is getting dim, or you end up having to crank up the gain/sensitivity on your camera, you won't benefit from any higher magnification.  You can also use extension tubes to increase the effective magnification of your barlow - spacing the sensor farther away from the barlow lens elements increases the magnification - though you could run into issues with focus travel.
#264 evan9162
evan9162
  • Loc: Boise, ID
Posted 05 September 2014 - 09:12 AM
Unmodded Canon T4i DSLR
#265 Sarkikos
Sarkikos
Posted 05 September 2014 - 09:52 AM
The C80ED has become my grab-n-go lunar scope.  Yesterday evening I had the scope out for over an hour viewing lunar features, mostly along the terminator.  It picked up all the rilles visible toward the terminator at the time.  I also saw Kies Pi and the lunar domes near Hortensius.  I was waiting for the sun to expose more of Gruithuisen Gamma so I could try to resolve the craterlet at its crest, but I had work the next day and decided to go in.  Maybe next time.
Edited by Sarkikos, 05 September 2014 - 12:12 PM.
#266 GOLGO13
GOLGO13
Posted 05 September 2014 - 10:42 AM
should be a very nice grab and go in the winter...pretty good cool down I would expect.
#267 Sarkikos
Sarkikos
Posted 05 September 2014 - 12:14 PM
Yes, the cool down is fast.  Certainly faster than any of my Cats.
#268 Far-Out
Far-Out
Posted 05 September 2014 - 10:20 PM
Thanks Binojunkie.
I'll be buying some sticky backed felt.
The contrast  on the Moon has been fantastic with this scope.
 I did replace the diagonal with Knight Owl 2" 99% reflectivity dialectic . Wow this diagonal is built to last
it is very heavy. Machined  from solid aluminum.
I also replaced the finder with Orion 6x30 RACI, I had the part.
Now I have a nice system. I'm interested to compare it to my Orion EON8O F6.5 which has the nicest black finish I have ever seen
and the chrome on the dew shield , My vote for one of the best looking ED's.
Do you spend more time looking at your scope than through it. Old  funny Unitron  add.
Get one before there gone. Destined to be a classic!
Edited by Far-Out, 05 September 2014 - 10:22 PM.
#269 Bignegs
Bignegs
Posted 10 September 2014 - 09:35 AM
Got mine yesterday.
Miraculously, the clouds parted as the sun set, and I managed a brief bit of viewing of the moon.
First impressions: crisp, contrasty views. Using the stock diagonal and a TV 5mm Radian, there was a slight bit of yellow fringing, but barely noticeable.
I'm very happy so far. The build quality seems quite good, and my focuser was a bit sludgy, but not bad. I think that the advice given here about relubricating the focuser is likely correct, and I'll tighten up the cap fitting as well.
This seems to be a genuine bargoon, and the fact that it supports a worthy cause is a bonus.
Thanks to the guys in this forum for making me aware of this deal!
#270 GOLGO13
GOLGO13
Posted 10 September 2014 - 07:22 PM
The optics on mine are better than I expected.  I will give the focuser tweaks a try but would have no problem putting a moonlight focuser on it. currently the focuser seems ok but just a little stiff.
Great deal I agree.
  • Sarkikos likes this
#271 Ain Soph Aur
Ain Soph Aur
Posted 11 September 2014 - 09:04 AM
I am looking to order a focusing mask for the 80ED. Can anyone who has their 80ED handy please measure the OD of the dew shield?
#272 Bignegs
Bignegs
Posted 11 September 2014 - 04:57 PM
My best measure is about 107 mm at the front edge, tapering a few mm wider further back.
How precise a measure do you need?
#273 Ain Soph Aur
Ain Soph Aur
Posted 12 September 2014 - 12:44 AM
Thanks Bignegs, after a chat with Astrozap and then your measurement for a sanity check I was able to order the correct mask in time for astrozap shipping!
#274 Ain Soph Aur
Ain Soph Aur
Posted 12 September 2014 - 12:58 AM
The 80ED arrived! Getting the stock foucser off was a bear, it took strap wrenches and a little WD40... The Moonlite is mounted and is impressive as expected,WO rings and ADM dovetail incoming. Collimation is off a bit so fingers crossed I can fix that up with the Moonlite collimation screws.
#275 Binojunky
Binojunky
Posted 12 September 2014 - 10:42 AM
Their have been cases of owners damaging (in one case the owner wrecking)the scope getting the stock focuser off, this is due to the paint getting on the treads while soft then acting like  Lock Tite when it hardened.
  I know its non of my business :grin:  but considering the cost of putting a Moonlite focuser on this scope why didn,t you go the route of say a scope from Skywatcher , you would get a far better focuser than the stock Celestron plus a case , diagonal ,finder, eyepieces  etc, ? at $350 the Celestron is a great buy, stick a $300-400 focuser on tit and it become a non bargain in my opinion.
         In the two I picked up the stock rack and pinion worked very well, for visual anyway.DA.
