Astronomers Without Borders 80ED isStill Available
471 replies to this topic
#451 Peter Besenbruch
Peter Besenbruch
  • Loc: Oahu
Posted 16 February 2015 - 04:04 PM
Thanks. Now I understand that the tool in the Twilight 1 is for setting the angle of the arm, and perhaps for tightening it in the field if that's necessary. What I do is just gather all the tools I might possibly need, put them in a little zippered bag and throw the bag in a stone bag hanging from the spreader.
Well, I would pass on taking the Allen key for tightening the arm. Once cinched down, it doesn't come loose. The Twilight 1 is a cheap mount, but "they" thought out some of the details on it. My one complaint involves the shortness of the tripod.
#452 evan9162
evan9162
  • Loc: Boise, ID
Posted 24 March 2015 - 08:56 PM
I jumped on a killer deal on a GSO 2-speed linear bearing focuser.  It was secondhand, but unused - it came off a GSO R/C scope.
The retaining collar on the GSO focuser is the same M90x1.0 thread on the end of the C80ED tube.  The focuser flange doesn't match the ID of the OTA, but if you found something to act as a filler gasket (O-ring or even plastic plumbing gasket), this would not require any adapters to mount to the tube, and would simply bolt on.
In addition, the GSO focuser is a bit more than an inch shorter than the stock focuser, so you would make your scope instantly binoviewer friendly without (the apparently horrendously offensive and sinful act of) shortening the tube.
However, since I already had committed said crime, and wanted proper focuser spacing, I machined an adapter to both make up the additional length, and mate exactly to the mounting flange of the GSO focuser.  I also plan on mounting a Vixen-style finder bracket to the flange.
The drawtube travel of the new focuser is quite a bit shorter than the stock focuser, so I also made an extension tube for mono-viewing and imaging.
The new focuser is a HUGE upgrade to the stock focuser (obviously).  No backlash, no image shift, and precise focusing.  With the old focuser, the drawtube would tilt easily, affecting collimation.  Now collimation is perfect, even with heavy binoviewers hanging off barlows and extension tubes.
  • Sarkikos likes this
#453 jonkjon
jonkjon
  • Loc: Hartfield, VA
Posted 26 March 2015 - 05:50 PM
That's a thing of beauty right there....nicely done. Who among us has not sinned? lol.....
--Jon
#454 evan9162
evan9162
  • Loc: Boise, ID
Posted 26 March 2015 - 07:09 PM
Not without bumps in the road though...
Last night, I was mounting a vixen finder shoe to to the mounting ring - drilling and tapping two holes to receive screws for the shoe.  I was halfway through tapping the first hole when the tap snapped off just below the surface, leaving the broken half completely buried inside.  I always use cutting fluid and proceed slowly.  Apparently, I did not drill a large enough hole for the thread (M4-0.7).  I'd used the same size drill for other holes I had tapped with the same thread, but they were not as deep as these.
So now there's an ugly hole with a tap buried in it to the side of the mounting shoe.
Lesson learned - always make sure you've really got the right size hole for the tap you're using.
Edited by evan9162, 26 March 2015 - 07:10 PM.
#455 MSimmons
MSimmons
    Vendor - Astronomers Without Borders
  • Loc: California, USA
Posted 07 June 2015 - 05:21 PM
SURPRISE!
It's been quiet here for a while so to liven things up I have an announcement that should be of interest to those of you who missed out on buying the Celestron 80 ED before the last of them were sold.
In what amounts to an archaeological dig (in other words, packing to move) an employee has found two remaining 80 ED's that are now available to purchase.
Both appear to be returns (open box). They have been checked out and are unused, in the box, with full Celestron new product 2-year warranty.
  1. A complete telescope with nothing missing selling for the regular price of $349 (which is still way below the normal retail when this was a current item).
  2. A telescope missing the tube rings, otherwise unused. If you're going to be mounting the telescope without using the included mounting rings then this will save you $20 on something you don't need anyway. Selling for $329.
Both prices include free shipping in the US, as before.
One only Celestron 80 ED for $349
One only Celestron 80 ED missing tube rings for $329
Post questions here. First come, first served. Come and get 'em!
  • BFaucett likes this
#456 MSimmons
MSimmons
Posted 07 June 2015 - 05:46 PM
And for those wanting a super deal on something bigger, we now have a 127mm f/6.5 from Explore Scientific that was discontinued when an updated version was introduced. This is an air-spaced doublet (achromat). We have 3 only available for sale at $450 with free shipping in the US. It's as good a steal as the Celestron 80 ED is, just $100 more for more than twice the light-gathering power and 50% more resolution.
Both the Celeston and Explore Scientific telescopes are available for purchase outside the US if the customer pays shipping.
#457 MSimmons
MSimmons
Posted 07 June 2015 - 11:30 PM
And #1 is gone. Who will be the lucky purchaser of #2?
Or the Explore Scientific 127 achromats?
Remember, 100% of proceeds go to Astronomers Without Borders worldwide astronomy programs. You get new gear at a great price while doing something good. It's not a tax deduction since you're getting something in return but it might help convince your other half that it just needs to be done. :)
#458 bgi
bgi
  • Loc: Ga
Posted 08 June 2015 - 12:56 PM
Yep the allen wrench is for assembly/dis-assembly of various components.  There's a lever on the brakes.  If the top is too wobbly, you'll need to remove the spreader, take the top off, and tighten a hex nut to take out some of the "wobble" but don't get it too tight.  That should be a one-time adjustment.  The Orion-branded version I got had terribad instructions, but it's not too hard to assemble once you get the spacer ring and snap ring on the spreader bolt.
#459 MSimmons
MSimmons
Posted 14 June 2015 - 03:01 PM
And the two recently discovered Celestron 80mm ED refractors are now gone.
The Explore Scientific 127 refractor and other items on sale -- donated by vendors to support Astronomers Without Borders programs -- are still available in the AWB store.
#460 mattyk-usa
mattyk-usa
  • Loc: Savannah, GA
Posted 14 June 2015 - 06:54 PM
There is one less ES 127 is no longer available, I'm afraid. The combination of opportunity and value was too much to pass by.  :salute:   Thank you Mike, for all you do.
Edit: thought there was only one left, sorry Mike.
Edited by mattyk-usa, 14 June 2015 - 06:58 PM.
#461 Peter Besenbruch
Peter Besenbruch
  • Loc: Oahu
Posted 14 June 2015 - 10:31 PM
Nice looking upgrade, but I get no image shift or backlash with the standard focuser. There are these tiny adjustment screws on the top of the focuser that take care of the image shift. Other screws on the bottom of the focuser take care of the backlash. It's surprising how tweakable the stock focuser is.
#462 MSimmons
MSimmons
Posted 15 June 2015 - 10:47 PM
Thanks for supporting Astronomers Without Borders through your purchase.
There were three of the Explore Scientific 127mm refractors donated to us by Woodland Hills Camera and Telescopes so there are two left, priced to move quickly.
Clear skies and enjoy the scope!
#463 Toddeo
Toddeo
  • Loc: Sierra Vista, AZ
Posted 16 June 2015 - 12:51 PM
Well, I picked up a used 2-speed focuser - off of a RC-6 scope. It screws right on(90mm threads). To give me more back focus , I bought a 1" threaded P1140333_opt.jpg P1140331_opt.jpg extension ring from Agena and also a 2" extension focuser tube(quicker to mount/dis mount). This focuser is much better than the stock focuser, Todd.
Edited by Toddeo, 16 June 2015 - 01:00 PM.
  • SteveG and BFaucett like this
#464 Sarkikos
Sarkikos
  • Loc: Per sylvam ad astra
Posted 16 June 2015 - 09:58 PM
I just now brought in my C80ED from an enjoyable observing session with my wife.  The scope was in its original clamshell and dovetail, which I mounted on a 501HDV and Bogen tripod.  I also brought out a foldable camping stool.  A Baader Zeiss prism diagonal was in the focuser.  The only eyepiece I used was a Nagler 3-6 Zoom.  I have the original focuser, which I've never adjusted.  It works fine, no problem.
We were able to look at Saturn, Rasalgethi, Graffias and M5 before the clouds rolled in for the next storm.  The seeing was good.  We could see the Cassini Division all the way around, the crepe ring, shadow of the globe on the rings.  The diffraction ring around the primary of Rasalgethi was sharp and steady.  I had no trouble pushing the power up to the 3mm setting, giving 200x and 0.4mm exit pupil, on all of these objects.  63x per inch!  And the C80ED was ready-to-go as soon as I set it out, no waiting.
I don't think this little scope will be going anywhere anytime soon.   :waytogo:
Edited by Sarkikos, 17 June 2015 - 05:53 AM.
  • Crow Haven, rockethead26 and BFaucett like this
#465 Peter Besenbruch
Peter Besenbruch
  • Loc: Oahu
Posted 17 June 2015 - 01:17 PM
I just now brought in my C80ED from an enjoyable observing session with my wife. ...
Nice. Yes, the optical quality is first rate. I replaced the erecting prism with a standard Takahashi 1.25". It's not as versatile as the Baader/Zeiss, but it gets the job done. I also appreciate the longer f-ratio. Was the seeing steady enough to get 200x with your zoom?
#466 Sarkikos
Sarkikos
Posted 17 June 2015 - 01:38 PM
Yes, the seeing was steady enough for the NZ 3-6 at 200x.  It was the only eyepiece I brought out with me.  Next time I think I'll bring out the 24 Pan as well.   Those two eyepieces should do well enough.
I have 2" diagonals that would widen the view with 2" eyepieces.  But they also make the setup heavier for grab-n-go and more unbalanced when viewing near zenith.
Edited by Sarkikos, 17 June 2015 - 01:38 PM.
#467 MSimmons
MSimmons
Posted 20 June 2015 - 12:43 AM
And another is gone, so there is only one left.
#468 jag767
jag767
  • Loc: Massapequa, NY
Posted 28 January 2016 - 05:10 AM
Never got the opportunity to pick one of these up, since at the time I had enough otas in this size range. Now that the barn is almost empty I picked one up second hand for a great price.  It gets here today, and already ordered a threaded adapter for a dual rate moonlite I have sitting on a shelf. Once it gets here I plan on breaking it down to remove all the paint from everything other than the lens cell and give her a nice polished aluminum finish. Will also flock everything before reassembly. I haven't done an all polished scope, and since moonraker is out of the budget it'll have to do!
  • Herr Ointment likes this
#469 jag767
jag767
Posted 28 January 2016 - 10:44 PM
 A little preview. Still need to buff out the dew shield a bit more, flock it, then move onto the main body. Man the quality of the aluminum under the paint is low. A lot of sanding required. It'll look top notch finished though.
#470 jag767
jag767
Posted 28 January 2016 - 10:47 PM
One more
#471 markdturner1
markdturner1
    Vendor - Moonraker Telescopes
  • Loc: Teddington Middlesex England
Posted 01 February 2016 - 08:42 AM
Looks like it's going to be spectacular, very nice indeed. :waytogo:
  • jag767 likes this
#472 jag767
jag767
Posted 01 February 2016 - 09:02 AM
Thanks Mark!  All done.
Edited by jag767, 01 February 2016 - 12:54 PM.
  • doctordub likes this
