Review: William Optics Star 71
77 replies to this topic
#1 gatsbyiv
gatsbyiv
  • Loc: Whitehouse Station, NJ
Posted 19 June 2014 - 09:30 PM
I just finished my initial review of the WO Star 71 after receiving it on Monday. You can read the review on my blog at http://digitalstars....s-star-71-im..., or see below, where I've had to spread it over a few posts to include the pictures.
I can’t speak for everyone, but my criteria for evaluating a wide-field imaging scope are:
  • Fast optics: since the goal is typically to capture large, diffuse, and dim objects (usually nebulae), focal ratio is key.
  • Quality optics: stars should be sharp to the corners, it should be truly apochromatic, and the field is evenly illuminated.
  • A good focuser: the zone of critical focus is very narrow at fast focal ratios, so any focus shift is unacceptable.
Living under light-polluted New Jersey skies, my preference is to shoot narrowband objects, as that negates most of the effect of the light pollution. I have an affection for small refractors, and I particularly enjoyed having a Borg 77EDII, which was a super-fast f/4.3, until I recently sold it. There’s something nice about the simplicity of small refractors. They are light, easy to balance, easy to align. Give me a fall evening, a wide-field scope, and a camera set up for narrowband imaging, and I’m happy.
The William Optics Star 71 recently caught my eye as a replacement for my old Borg 77. I signed up for the pre-order, and Agena AstroProducts delivered my scope this week. The WO Star 71 has a stated focal ration of f/4.9 and a focal length of about 354 mm* (though this is not explicitly stated anywhere I can find), which nicely frames many large showpiece objects on common sensors. For an APS-C sized sensor, the field of view is 3.6 x 2.4 degrees. For a 4/3 format sensor like the KAF-8300, the field of view is about 2.9 x 2.2 degrees. I plan to use it mostly with the ST-8300, and this field of view nicely frames a lot of narrowband targets I’m after this year.
(* Based on the field of view calculated by astrometry.net (3.61 degrees) and Canon’s stated 22.3 mm sensor measurement on the long side for their APS-C sensor, I calculated a focal length of 354 mm, which leads to a focal ratio of 4.98 if the aperture is truly 71 mm. If they fudged a bit, and it’s 72 mm, the ratio would be 4.91, which would match the stated 4.9.)
The evening I got the scope, it was actually clear. Now, it was a lousy night for imaging because it was over 80 degrees, the winds were gusting, and high humidity made for terrible transparency. Worse, the waning gibbous moon would only allow for about two hours of dark skies. So it was a terrible night for imaging… but perfect for taking a few test shots.
#2 gatsbyiv
gatsbyiv
Posted 19 June 2014 - 09:32 PM
Look and Feel
Before it gets dark, let’s have a look at the scope.
This is classic William Optics: white and gold. The focuser has a thermometer–neat, but I’m not sure how much I’ll use that. The scope comes with a nice pair of rings, a Vixen-style dovetail, and a M48 to Canon adapter. So even visually, it’s clear that this is an imaging scope. The focuser terminates in M48 threads, not a 2″ eyepiece holder. (Note, that’s M48, not the standard T-thread of M42.) If you want to use this scope for visual use, you have to buy a special adapter, which is fine with me, because imagers prefer to keep all the connections threaded. For scale, you can see the Orion 50 mm guidescope mounted on top, and the Canon 450D/XSi DSLR. For a 71 mm scope, it’s actually pretty big. I don’t have my Borg 77EDII anymore, but I’m almost certain this is bigger.
What you can’t see in the photo is how heavy the scope is. WO claims it’s 5.3 lbs with the rings, and that seems about right, but until you handle the scope, you don’t realize how dense that is. There is clearly a lot of glass in there, and not just at the objective end. It’s the same impression I got the first time I picked up my Tak 106ED. This thing is solid. WO notes that FPL-53 glass is used, and that there are a total of five elements in three groups. People seem to attribute almost mystical powers to FPL-53, and while it is found in the best optics in the world, the glass type doesn’t matter if the elements aren’t well matched or poorly figured. But between the weight and glass type, we’re off to a good start.
#3 gatsbyiv
gatsbyiv
Posted 19 June 2014 - 09:33 PM
Imaging Performance
Let’s get down to brass tacks. How did it perform for imaging?
Bear in mind that this was just a chance to take some quick test shots, so hopefully I’ll be able to do more extensive imaging work with it later, but first let’s check the overall field of view with a DSLR.
This is a single 30-second exposure of the area around M81 and M82, just to give a sense of scale. Yeah, that’s a wide field.
#4 gatsbyiv
gatsbyiv
Posted 19 June 2014 - 09:34 PM
“Great,” you say. “But is the field of view flat?” Let’s check. Here are extreme close-ups of stars at the corners and center. (These are from a different, 15-second exposure, since wind gusts kept streaking the stars a little. The color was dropped to help reduce noise.)
These are 200×200 pixel areas from the edges and center. The stars are sharp, and that’s a pretty flat field, especially for f/4.9. This substantially outperforms my old Borg 77EDII (though to be fair, that scope was f/4.3 and not known for exceptional flatness of field or perfect apochromatism). It’s probably not as good as the Tak 106ED at f/5.0, but it’s slightly better than the Tak at f/3.7.
#5 gatsbyiv
gatsbyiv
What about vignetting? WO claims the scope will deliver a 45 mm usable imaging circle. That would be large enough for a full-frame 36 x 24 mm sensor. That’s always a bit of a judgement call, because the manufacturers never seem to state what level of light falloff is acceptable in determining the size of the usable imaging circle, but okay. An APS-C sensor needs about a 27 mm circle, so that’s all I can test for now. I took a flat frame, and then I measured the 8-bit brightness level at the corners and in the center. I’m sure someone with CCDInspector could provide a pretty 3D map, but this method will tell you what you need to know.
The flat field image was exposed to stay in the linear range of the sensor, and we can see that there is only about a 3-4% falloff from the center to the edge. That’s really good.
#6 gatsbyiv
gatsbyiv
Posted 19 June 2014 - 09:35 PM
All right, final test… what about apochromatism? Do all the colors come into focus at the same plane? Sorry, I’ll have to update this review later with that information once I get a full night out with this scope and my ST-8300.
And what about the focuser? I monitored focus through a Bahtinov mask, and as expected, focus is really touchy at f/4.9. The critical moment came once I had lined up focus and turned the focus lock knob. This is where cheap focusers will suddenly throw the image out of focus, leading to an annoying game of “How far out of focus do I need to start so that it will be in focus after tightening?” (Oh, you’ve played that game, too I see.) In fact, I used to have an early Zenithstar II from William Optics whose focuser was… well, it kinda sucked. And judging from comments on forums, WO has had some challenges with their focusers.
The Star 71's rack and pinion focuser performed well. The image stayed in focus after tightening the locking knob. I have to say that the focuser does not feel as tight as a Moonlight or Feathertouch, but it did the job admirably.
#7 gatsbyiv
gatsbyiv
Posted 19 June 2014 - 09:37 PM
Summary and Final Thoughts
My initial impressions of this scope are very good. I’m really pleased so far, and I hope to provide a fuller review with images at a later date.
In my view, here are the WO Star 71's strengths:
  • A sharp, flat field
  • Exceptional fit and finish
  • Nice focuser
  • Solid tube rings and a Canon adapter are included
  • Fast enough focal ratio
I would have been thrilled with f/4 or even f/4.5. An 80 mm objective, but still at around 350 mm focal length would have been amazing, but I’ll take it at f/4.9. It’s substantially better than some similar scopes. (I never bought the AT65EDQ because no matter how sharp it is, at f/6.5 I’d never get a narrowband image finished.)
If I had to name a few “opportunities for improvement,” I’d say:
  • I would rather have had an M48 to M42 T-thread adapter included
  • No case is included
  • The dew shield only extends 1.5 inches past the objective lens cell. This is too short, especially for those of us in humid climates.
And I’m not sure how I feel about the price of $998. ($898 for the first few sold.) I know this is a new, patented optical design. And the optical performance looks really good. And it’s f/4.9. But it’s also only 71 mm of aperture. The price compares well to the Borg 77ED or 71FL, and the Televue 76. But WO sells their own Zenithstar 71 + 0.8x focal reducer for $568, and that would be an f/4.9 system as well. Granted, I don’t know if the field is as flat, the optics are as sharp, or the focuser as good, but it makes for an interesting comparison at over 40% less. To be fair, WO explicitly notes that the Star 71 is a “[n]ew, unique, patented design – not a conventional objective/flattener/reducer design.” But having another 71 mm f/4.9 scope out there plants a little seed of doubt.
I have a unique consideration when reviewing this scope. I originally ordered two with the plan to create a dual-scope narrowband imaging set-up. I reasoned that I only get a few nights a month of decent weather, so why not double up on the exposure time with two scopes? But I’ve had a hard time finding another used ST-8300, and once I started pricing everything I’d need, I started to chicken out and reduced my order size to one scope. (Oh, so that’s why no one seems to be imaging with a dual-scope setup…) So the question for me now is not whether I’m keeping the Star 71 (I am), it’s whether I’m going to buy another one.
  • ZeusB likes this
#8 Starman27
Starman27
  • Loc: Illinois, Iowa
Posted 19 June 2014 - 09:50 PM
Thanks for the detailed and well presented review.
#9 John Anthony
John Anthony
  • Loc: Sterling Heights Michigan
Posted 20 June 2014 - 06:08 AM
Nice review, nice scope, thanks. :like:
#10 Orion58
Orion58
  • Loc: Southern Wisconsin
Posted 20 June 2014 - 08:00 AM
I enjoyed your review. With a bit of luck the weather may allow me to give mine its first test tonight. My imaging setup is different than yours (filter wheel/CCD with smaller chip) and I will also check for a flat field and vignetting.
Thanks for taking the time to post your thoughts.
#11 SteveG
SteveG
  • Loc: Seattle, WA
Posted 20 June 2014 - 02:04 PM
[*]The dew shield only extends 1.5 inches past the objective lens cell. This is too short, especially for those of us in humid climates.
That's extremely odd. The dewshield looks proportionately long enough from the outside. Are you sure the set-screw is not hanging up on something?
EDIT: oops - I just checked the spec's and you are correct. The extension is 45mm (1.77") - too short!
#12 gatsbyiv
gatsbyiv
Posted 20 June 2014 - 06:48 PM
Yes, it's very strange. When the dew shield is fully extended, the objective basically sits in the middle of the dew shield, not at one end. I thought it was stuck or something, but that's as far as it goes. I'd love to hear from WO on this.
#13 PatHolland
PatHolland
  • Loc: Clever, Missouri
Posted 20 June 2014 - 08:51 PM
Will this create issues when using dew strips?
#14 timmbottoni
timmbottoni
  • Loc: W Chicago suburbs, IL USA
Posted 20 June 2014 - 08:58 PM
Excellent Review! You did a very good job of highlighting the important parts. I just got my WOSTAR71 today, was on vacation. Hoping to test it out soon! Looks like an awesome scope!
Timm
#15 gatsbyiv
gatsbyiv
Posted 21 June 2014 - 10:56 AM
It shouldn't create any issue with dew strips, but it will make me more likely to use them.
#16 Jonas C
Jonas C
Posted 22 June 2014 - 06:07 AM
Thanks for a great and valuable review. The Star 71 seem to as good as the specs say. Information say that we in Europe will have to wait another 3 months before we can buy it though.
Regards
Jonas
#17 PatHolland
PatHolland
Posted 22 June 2014 - 09:15 AM
Will there be a problem using dew strips since you cannot get close to the primary objective with a dew strip because the dew shield is in the way?
  • rockwallastro likes this
#18 nodalpoint
nodalpoint
  • Loc: FEMA camp
Posted 22 June 2014 - 01:14 PM
Don't think so, as long as a bit of heat is transferred to where it's needed.
#19 timmbottoni
timmbottoni
Posted 22 June 2014 - 09:31 PM
Is shouldn't be a problem at all. You can see the arrangement if you unscrew the gold ring from the dew shield and remove the white dew shield.
Timm
#20 PatHolland
PatHolland
Posted 23 June 2014 - 08:31 AM
Mine is arriving today. Don't know when I will get a chance to use it though.
#21 timmbottoni
timmbottoni
Posted 27 June 2014 - 11:20 PM
Clouds here again - argh
#22 N1ghtSc0p3
N1ghtSc0p3
  • Loc: Texas
Posted 04 July 2014 - 08:25 AM
Excellent review, thank you! I received mine about 2 weeks ago, but it has been (ironically) cloudy or hazy every night since! Grrr...the dreaded curse strikes again! I bought this scope as a step up from my AT72ED, and from your initial review, it looks like its definitely going to fit the bill. Looking forward to more pics taken with this nice little instrument.
#23 SunBlack
SunBlack
  • Loc: Rome (IT)
Posted 04 July 2014 - 03:23 PM
Any dude here tried this scope with full frame dslr?
#24 rjweng
rjweng
  • Loc: OP, NY
Posted 14 July 2014 - 07:52 PM
How is the focuser on it, I have the WO 81 GTF and there is a little sag from my ccd camera.
#25 timmbottoni
timmbottoni
Posted 14 July 2014 - 08:14 PM
Hi - see this post where I commented on how to adjust the focuser to get rid of any sag due to the rotation mechanism - http://www.cloudynig...6621825/page...
Timm
