Rigel or Telrad?
25 replies to this topic
#1 Heim
Heim
  • Loc: NW Florida
Posted 24 June 2014 - 10:56 AM
I'm sure this is a century old debate, but I would appreciate some opinions. For my 8" dob, I was thinking of replacing my 8x50 scope with a telrad, then I looked into rigel and liked how it's lighter, and runs on lithium batteries since I can buy them in bulk for my lazer collimator as well.
So what does everyone suggest? I've never tried one or the other, so I can't base a decision off experience. Thank you :jump:
#2 youngamateur42
youngamateur42
  • Loc: La Verne, CA
Posted 24 June 2014 - 11:04 AM
A Telrad AND your 8x50 finder combination is pretty optimal, because when your looking for a faint object, you need to reference the fainter stars that your finder shows, with the fast aiming of the Telrad make it the best choice.
#3 paul hart
paul hart
  • Loc: Long Island, New York
Posted 24 June 2014 - 11:11 AM
I'll second that. I own both and use the Rigel on the smaller scope. I prefer the Telrad where possible because unlike the Quik Finder there is very little parallex, and the batteries on the Telrad last just about forever.
#4 Jon Isaacs
Posted 24 June 2014 - 11:19 AM
If your skies are dark, dark enough to see the Milky Way without strain, then replacing your magnifying finder with a Telrad or Rigel is reasonable. Otherwise, there are not enough guide stars visible to use a non-magnifying finder.
As Justin and Paul have said, both an 8x50 and a Telrad/Rigel are best, that's what I do. I very much prefer the Telrad, the 4 degree ring is a big help as is the much reduced parallax error. The long battery life is also a bonus. If you forget to turn it off, it will run for months...
The question is whether there is enough room for both the Telrad and a magnifying finder. If not, then the Rigel maybe a better choice.
#5 Heim
Heim
  • Loc: NW Florida
Posted 24 June 2014 - 11:30 AM
Telrad it is. Seems the lithium battery idea is a mute point when AA last forever in the telrad. My fan uses AA anyway, so shouldn't be hard sparing some if the telrad ever needs them. Thanks!
#6 StarStuff1
StarStuff1
  • Loc: South of the Mason-Dixon Line
Posted 24 June 2014 - 11:43 AM
For almost 2 decades I used a Telrad. Worked fine. The only thing I didn't like was the bulk.
An 8-in Celestron dob moved into my arsenal and there was a need for another reflex finder. There really was not enough room for a Telrad so I bought a new Rigel. I really like it. The knob that turns on the unit was small so I put a rubber tip on it. A few years after I got it the battery finally failed. It has a coin shaped 2032 battery. Since I was observing and didn't want to run to the store I took a battery holder for 2 AAAs and modified it to the Rigel.
My only real complaint about the Rigel is that it seems less robust than the Telrad.
#7 StarStuff1
StarStuff1
Posted 24 June 2014 - 11:45 AM
The above pic was the "cobbled up version I did that night. The next day I made a batter cover and re-routed the wires.
#8 Heim
Heim
  • Loc: NW Florida
Posted 24 June 2014 - 11:51 AM
Looking sharp :grin:
#9 rockethead26
rockethead26
  • Loc: Arizona, USA
Posted 24 June 2014 - 12:04 PM
I had eye placement issues with the Rigel and went back to the Telrad. I really liked the smaller size of the Rigel, but it was literally a pain in the neck for me because it took me so long to find the projected reticle.
#10 AMerritt
AMerritt
Posted 24 June 2014 - 03:36 PM
Exactly so about there being enough room! On my smaller scope, the XT10, I use a Rigel placed in between focuser and 9x50 finder, a Telrad is a tighter fit, plus a little more back strain to get the angle under it, however, I have often seen the Telrad mounted on the other side of the 9x50 finder or on the left of the focuser. Like the others said, do not replace the 8x50 - not only guide stars but faint nebulosity can guide you!
#11 Dodge2013
Dodge2013
  • Loc: Jackson, Tennessee
Posted 24 June 2014 - 09:42 PM
If anyone is interested go to Astrosystems.biz and look at their offerings of the Telrad and Rigel. Especially the dew shield for the Telrad. They also have a Rigel with external battery pack. I just happened on this sight.
#12 Dadadee
Dadadee
  • Loc: Near Montreal, Qc, Canada
Posted 25 June 2014 - 12:29 AM
I concur with Jon. Both is the way to go. Telrad is limited in heavier light pollution. But still useful. But I could not go without my 9x50 RACI finder
#13 Hesiod
Hesiod
Posted 25 June 2014 - 04:52 AM
I agree with Jon Isaacs too, use them together.
I am a Telrad supporter, but if there is not enough room to place it near the finderscope, then go for the Rigel.
I have both (can not place the Telrad on my 4" ED because is too long) and in my opinion there is not a lot of difference between them (unless you really need the 4° circle); Rigel has a built-in pulser, very nice, but feels more brittle.
#14 nicknacknock
nicknacknock
  • Loc: Nicosia, Cyprus
Posted 25 June 2014 - 07:10 AM
Just tried the Rigel the last couple of sessions with my 5" frak. All I can say is that I am reverting to a Telrad ASAP. It may be bulky, it may be heavy, but it is still the best option if you have enough room to mount it.
The Rigel strikes me as a very cheap construct. It displays extreme parallax effect and it is uber sensitive to eye placement relative to the tiny window.
Now, why can't someone make a Telrad which is not so long (yes, you can hack nearly half of it off, but I am as technically inclined as a Smurf).
#15 Jon Isaacs
Posted 25 June 2014 - 09:18 AM
The length is the reason that there is minimal parallax error. That and the space for the AA batteries. But the I have never found the length to be a problem, if need be, I just let the Telrad stick out past the end of the scope.
I recently purchased a Scopestuff Telrad mount that fits the Vixen/Orion/Celestron/Skywatcher finder shoe. It works well with my NP-101 refractor, very sweet. The dovetail doesn't fit all my scopes though, I am going to have to do some grinding.
#16 AMerritt
AMerritt
Posted 25 June 2014 - 11:06 AM
That is a MUCH better option than the Televue Qwik Point Finder which I found way too small to be useful on my NP-101.
#17 Jon Isaacs
Posted 25 June 2014 - 12:58 PM
I find a simple red dot finder is quite effective with my NP-101, I use it in conjunction with the 35mm Pan or 31mm Terminagler.
I purchased the Scopestuff Vixen-Telrad mount so I could use the NP-101 as a remote, unmounted finder scope for my large Dob.. The refractor is on it's own alt-az mount. I find the object or specific region with the NP-101, then I match the Telrad images to point the big scope. I also work the other way, find something interesting in the big scope and then see if I can see it in the smaller scope. Electronic charts with Telrad circles are helpful but there is nothing quite like the naked eye view.
#18 Starman81
Starman81
  • Loc: Metro Detroit, MI, USA
Posted 25 June 2014 - 03:25 PM
I will readily admit that the Telrad is superior but I agree with the points mentioned above. On an 8", there isn't much real estate for a Telrad + 9x50 and the longer body will also make you contort your body more to be able to get a view through it. Also, by design, the Rigel has a built-in 'riser', but it can be tricky to find the reticle at times and there is parallax.
So with an 8", Rigel is more suitable, though a compromise. Personally, I use Multi-Reticle finders on my 8"ers, without any optical aid (8, 9x50). It makes for some lengthy, character-building star hops in the less than dark skies (SQM 19.5) I often find myself observing in!
#19 Jon Isaacs
Posted 25 June 2014 - 04:06 PM
Looks can be deceiving, the height of the Telrad and the Rigel reticule are, for all practical purple shirt, identical.
#20 GeneT
GeneT
    Ely Kid
  • Loc: South Texas
Posted 25 June 2014 - 05:44 PM
I like the Telrad over the Rigel. If your telescope can handle it, consider using both the optical and Telrad. They complement each other.
#21 chemtchr
chemtchr
  • Loc: Central Ohio
Posted 26 June 2014 - 08:32 AM
Definitely use both as many have stated already. If your optical finder is not RACI, then I would consider replacing it with a RACI finder and using it with the Telrad/Rigel. If, however, you are accustomed to using an image-inverted finder, then stick with it. The advantage of the RACI finder is it matches the chart views. Very handy.
Paul
#22 Thomas Karpf
Thomas Karpf
  • Loc: Newington, CT
Posted 26 June 2014 - 11:01 AM
If anyone is interested go to Astrosystems.com and look at their
I think you mean http://www.astrosystems.biz/
#23 AMerritt
AMerritt
Posted 26 June 2014 - 11:21 AM
Last night using my XT10 after a long hiatus - I would now recommend the Telrad - had a hard time getting the right view through the reticle on this small a scope. (have very long legs, so this may not be an issue for everyone!!) One can also get riser extenders for the Telrad to raise it up - and I am going to place the Telrad so it extends over tube and not flush for more height.
#24 JMW
JMW
  • Loc: Nevada
Posted 26 June 2014 - 12:23 PM
I use multiple scopes at the same time. I like having a Telrad on each so I can match up the Telrads on the different scopes once I find the object on one scope. I think a Telrad is the only solution for a dob that needs a ladder since you can see it while several feet behind it. The Rigel requires that you are fairly close to it to use it.
#25 Jon Isaacs
Posted 26 June 2014 - 01:52 PM
:waytogo:
One could mount a Rigel nearer the mirror end of the scope but with a scope large enough to require a ladder, there should be plenty of real estate to mount a Telrad. The Telrad is handy for initially pointing the scope because you can do it while standing on the ground. That makes it much easier to position the ladder.
