Looking for 30" mirror maker
84 replies to this topic
#76 Dick Jacobson
Dick Jacobson
  • Loc: Cottage Grove, Minnesota, USA
Posted 19 August 2014 - 06:58 PM
Well let me start a war by saying PLOP makes a gross assumption which invalidates the whole program.  It assumes that the supports for the triangles are infinitely stiff.  They are not. the two bolt rung also deflects alot differently than the one bolt rung.
If you use this program
http://metalgeek.com.../deflection.php
the aluminum tube you propose yields a deflection of .0016" deflection when the scope is pointed straight up.  with a 25 lb load and a 30inch fixed span.  it also gives you a .8 lbs/ft weight
If you use 2" tube steel with a 0.0625 wall you get a deflection of .0004", and a weight of 1.7 lbs/ft.
Again both values pointed straight up, and they taper off towards 0 pointing at the horizon
In essence your sell would weigh 4.5lbs more in steel, (which is no big deal because you will need tailweight for a 29 F4.5 anyway), and it will be cheaper.
I will post in the next day or so the way I made my 24's that uses a no weld mirror cell, that can be made with only a hand drill and a center finder.
I appreciate your comments and don't consider them a hostile action. I do question a couple of your statements.
I don't see how bending of the triangles invalidates PLOP. I believe the purpose of PLOP is to determine the optimum placement of the support points. The purpose of a triangle is to distribute the force equally from its central support point to the three outer points. The triangle is free to flop about its central support point. If the triangle bends a little, it is of no consequence as long as the bending doesn't collapse the whole structure.
I don't see that a deflection of .0016" would cause any problem. I don't intend to use the scope for imaging and I will simply refocus if there is deflection. I'm more concerned about loss of alignment when the tube tips between vertical and horizontal, and that's why I avoided the usual "ladder" frame (two points on one rung, one on the other). On my 20" there is a very slight change in alignment from vertical to horizontal, visible with a laser collimator but showing no effects in the eyepiece.
Above is a photo of my mirror cell in the old 20" mirror box; I've subsequently rebuilt the scope out of aluminum but kept the same cell.
#77 gatorengineer
gatorengineer
  • Loc: Hellertown, PA
Posted 19 August 2014 - 09:30 PM
It's not a flexture of the triangles it's a flexture or the rung.  I assumed you had a three rung traditional design.  I see you dont, my comment doesn't direct apply to your design.  But think  of it this way.  If the rungs were infinitely stiff the forces inside the glass wouldn't move around nearly as much as they do as load would be evenly be shifted from the triangle supports to the sling.  Now add in changes in the deflection of the mirror.  It's not a focus issue it's a figure issue and yes 0.0016 means alot.
#78 mark cowan
mark cowan
    Vendor (Veritas Optics)
  • Loc: salem, OR
Posted 19 August 2014 - 11:09 PM
If .0016" means a lot then so does .0004".  No way around that if you're talking about wavelengths of light.
Best,
Mark
Edited by mark cowan, 20 August 2014 - 12:15 AM.
#79 Pinbout
Pinbout
  • Loc: uhmm...still in 2nd grade
Posted 20 August 2014 - 05:21 AM
I tbought it was a tolerance in collimation issue... ;)
#80 mark cowan
mark cowan
  • Loc: salem, OR
Posted 20 August 2014 - 03:37 PM
If it's that it doesn't matter at all. :shrug:
Best,
Mark
#81 Pinbout
Pinbout
Posted 20 August 2014 - 03:44 PM
hey, what's that going on with that edge support? are you stealing Nils 2 wraps off steel cable idea but doing 90° instead of his 180°?
#82 Dick Jacobson
Dick Jacobson
Posted 20 August 2014 - 11:37 PM
It's an equatorial mount. The mirror can tip in any direction. I used four wraps of cable, each one 180°. Think of four U-shaped loops oriented with the top to the north, south, east, west. Seems to work great.
#83 gatorengineer
gatorengineer
Posted 21 August 2014 - 07:17 AM
Seems like a really cool scope, can you post more pics?
#84 Dick Jacobson
Dick Jacobson
Posted 24 August 2014 - 06:36 PM
Here's a recent photo since I rebuilt it using aluminum. The periscope is at upper left.
#85 gatorengineer
gatorengineer
Posted 24 August 2014 - 08:06 PM
Can't wait to see what you do with the 29
