CGE won't stop spinning in dec
18 replies to this topic
#1 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 07 July 2014 - 11:22 AM
The CGE mount here at Camp Eberhart will not stop spinning when initializing. The same happens when trying to goto objects as well. I've tried a few things but there doesn't seem to be an easy fix. Any help would be appreciated. Thanks
#2 rmollise
Posted 07 July 2014 - 11:24 AM
It would help if you'd say what your "few things" were. Anyhow, the place to begin with these mounts is the cables.
#3 Eddgie
Eddgie
Posted 07 July 2014 - 12:18 PM
First I would look at the external cables.
Get some DeOxit and liberally spray the contact jacks and plugs while plugging and unplugging each connecter about 10 times. This will "wipe" any corrosion off of the contacts.
90% Of the time, this will correct the problem.
If this does not fix it, then next step is to open the top of the Mini-pier and pull the boards, and once again, spray all the contacts with DeOxit and replug a few times.
If the problem is that you can't even get past alignment, the last thing to check are the RA orientation switchs.
Take scope and weight off and move the RA shaft in an arc across its full range while listening to for the switch contacts making and breaking.
Starting from either end of the full travel, you should hear a click shortly after the mount travles from the stop.
As the saft crosses the plane if the north leg, you should here a click, and then just before you get to the other limit, you should hear another click.
Go back and listen for the clicks in the oppisite direction, paying particular attention to the click that occurs wat the leg crossing.
Now, move the saddle so that the DEC switch breaks and makes, which should happen when the saddle is pointed to 90 degrees DEC.
I would test several times.
If you fail to hear a click at any of these spots on ANY pass, you may want to adjust the travel of the switchs.
These kinds of switches should last 1M+ state changes so it is highly unlikely (though not impossible) that the switch has failed.
What usually happens is that the swicth moves slightly in its bracket so that the roller that follows the groove in the axis does not travel sufficently for the switch to make or break in one direction.
The adjustment is simple. Pull the cover and watch where the roller of the switch contact arm is on the ramp when it is making/breaking.
It will not make/break exactly in the center of the ramp in both directions.
The adjustment is simply to get it to break a bit before the end of the ramp in each dirction. You do this usually by loosening the screws that hold the switch and tilting it as necessary to get the roller to "average" out the break near the center of the ramp. This might sound confusing, but once you watch the roller on the ramp, it is easy to see what I mean.
If the cables don't do the trick, you might as well get a clock battery and have it on hand before you open the mini-pier because if you are going to pull the boards, you might as well change the battery.
Not promising that any of these are the problem, but most of the time, one of these will do it for you.
#4 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 08 July 2014 - 09:27 AM
Thanks Eddie I will try this suggestion soon and will PM you with questions. Thanks
#5 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 09 July 2014 - 10:54 AM
PM sent
#6 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 13 July 2014 - 04:50 PM
Still no luck here the mount won't stop spinning in dec when trying to do initial setup or goto of objects. My next question is simply how do I get it to simply track? If I just goto manually I can at least use the scope to view some objects. What order of buttons do I push? I'm a dob guy so please assume I know nothing of this mount make it simple thanks.
#7 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 13 July 2014 - 05:30 PM
Darren,
You can't. The mount must find it's starting or home position before it will go on to the initial alignment and start tracking. The mount will drive the DEC motor until the switch position is found.
Have you gone through all the troubleshooting of the home position switches?
- Verified by ear the switches are opening/closing?
- Adjusted the position of the switch on the DEC axis? (sometimes the roller/switch is stuck and simply changing the position of the switch causes it to release and start working). You normally don't adjust the position of the switch with the two little Phillips head bolts that go through the body of the switch ... you use the two small Allen head bolts that hold the plate the switches are bolted to. You can also (carefully) depress the switch while the mount is driving the DEC motor to see if the switch position was a problem.
- Verified electrically that the switches are opening/closing? (at the switch, then at the connector and then to be complete at the connector on the MC board in the pier).
If all that checks out you've verified the operation of the switch, the connectors, the external cable, and the wiring up to the MC board in the pier. The next possibility is the MC board itself.
#8 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 13 July 2014 - 08:28 PM
Mark thanks but not really sure what all that means as I'm out a my element here. I've been a dob pusher all these years. It's a camp scope and only I deal with it. I know tracking is possible I did it last summer when the same problem was involved and a cn member told me how to track. ...
#9 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 16 July 2014 - 09:37 AM
I do not hear the click I have been told to listen for. Not really sure what is next
I have looked inside but am just out of my element here. I'm a dob pusher...AstroCamp is next week and I would hate for this scope to be inoperable.
#10 rmollise
Posted 16 July 2014 - 09:42 AM
Surely there's somebody in your club who can have a look see. Sounds like for whatever reason your position switches are not closing.
#11 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 16 July 2014 - 09:47 AM
I'm living out a state for the summer but did goto the Kalamazoo club meeting last week to ask for help but no one there was able to.
#12 wargrafix
wargrafix
  • Loc: Trinidad
Posted 16 July 2014 - 11:03 AM
sounds like the4 dec motor.
#13 rmollise
Posted 16 July 2014 - 11:19 AM
Not if he isn't hearing the switch making. ;)
#14 Carl Wright
Carl Wright
Posted 16 July 2014 - 11:26 AM
I also told Darren to move the saddle sideways and at startup instead of going to switch position to undo to accept position. This bypasses the micro switches all together...Carl
#15 rmollise
Posted 16 July 2014 - 12:48 PM
Yep, and very good advice.
#16 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 16 July 2014 - 04:51 PM
If anyone who really knows this mount is willing to talk me through some of these suggestions send me a pm and I will forward my cell number. ..
#17 junomike
junomike
  • Loc: Ontario
Posted 16 July 2014 - 04:59 PM
Have you seen this thread?
#18 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 17 July 2014 - 09:22 AM
I saw it and he fixed it by expanding metal shield on cable. What does that mean?
#19 mclewis1
mclewis1
    Thread Killer
Posted 17 July 2014 - 09:49 AM
It probably means that the failure was in the 9th connection in that cable ... these mounts use the 8 pins in the connector and the ground braid and the case of the connector to provide a 9th connection.
For a variety of reasons the metal shell of the RJ45 cable connector doesn't always make good electrical connection with the metal shell of the socket on the mount. A little work (changing the shape of the connector, adding foil, etc.) improves this connection. This is unfortunately not the only failure in this area, there can also be solder joint issues between the socket and board supporting it for example.
Overall it's a fairly common failure, it's why regular Ethernet patch cables won't work (the ones that don't have the metal connectors), and it's one of the primary reasons that Gary Bennett's cable replacement/upgrade kits work so well (he completely replaces the RJ45 cables, connectors, sockets, and boards).
