Atlas Pro
8 replies to this topic
#1 thesubwaypusher
thesubwaypusher
  • Loc: New York City
Posted 08 July 2014 - 12:38 PM
Sorry I don't have time to research this in the forums. I am quite certain it has been covered, but...
The Orion Pro mount looks really attractive to me because it is Altaz also. And I would like to try a C-14 for a while. Please:
1- The Cgem DX is too high. Does the Orion sit lower?
2- Does the mount have variable speeds on the slew rate? I need at times to quiet it down.
3- With a 44-pound payload, do you think I can get away with a 45-pound C-14, and about 7 pounds of accessories?
4- Lastly, has anyone tried a C-14 in altaz?
Thanks, Chris
#2 frolinmod
frolinmod
Posted 08 July 2014 - 01:50 PM
The mount slews quietly without needing to be slowed down.
I would not attempt to place a C-14 on it.
#3 guyroch
guyroch
    Vendor (BackyardEOS)
  • Loc: Under the clouds!
Posted 08 July 2014 - 01:59 PM
Imagining? NO.
Observing? Yes IMO.
#4 BKBrown
BKBrown
  • Loc: Northern Virginia, USA
Posted 08 July 2014 - 03:21 PM
Thanks, Chris
It's a really nice mount and I have come to appreciate mine a lot. That said...
1- The CGEM DX is higher because it sits on the same tripod provided with the CGE Pro; you sure don't have to rack the tripod legs out all the way on the Atlas if you want it real short.
2- Yes...and it's pretty darn quiet even at the highest slewing speed
3- No way I would do that for imaging, and certainly not on the stock 2" tripod.
4- No, but I have had my C11 Edge on there and that wasn't bad. Don't think I would want to try a C14, again, especially not with the stock tripod (it's a balance issue).
Hope this helps!
Clear Skies,
Brian
#5 thesubwaypusher
thesubwaypusher
Posted 09 July 2014 - 10:34 AM
This is great. I assumed it would be loud like the Cgem. I guess it is like the Sirius.
#6 thesubwaypusher
thesubwaypusher
Posted 09 July 2014 - 10:36 AM
Good to know. Thanks!
#7 thesubwaypusher
thesubwaypusher
Posted 09 July 2014 - 10:42 AM
Hi Brian:
Actually, 4 pounds in accessories.
What I will do is try it in Altaz with plenty of counterweight and keep the tripod low. I'll also not engage the gearing and swing it around a few times and even observe with it. From the general consensus, it sounds like the 14 would be okay visually, as long as I keep it low. Then I will make then determination whether or not it needs a different tripod.
Thanks much!
Chris
#8 MarkCPC11
MarkCPC11
Posted 11 July 2014 - 08:24 PM
I noticed in the picture the weights have space between them, is there any reason for this, I never saw the need to have them apart?
#9 BKBrown
BKBrown
Posted 11 July 2014 - 08:46 PM
I typically rack one all the way to the bottom and then adjust the inside one to balance the load...just my way of doing business :grin:
Clear Skies,
Brian
