Awesome Samsung SDC435/SCB2000 camera controller
12 replies to this topic
#1 Martin Lyons
Martin Lyons
  • Loc: Cape Town, South Africa
Posted 11 July 2014 - 12:33 PM
Folks, just thought I'd share my latest discovery.
The Samsung SDC435/SCB2000 series cameras can be controlled via the video coaxial cable using a UTC Controller (Up The Cable controller) as pictured.
They are available from any cctv camera vendor for very little money.
Use it, don't use it....... :grin:
  • buddyjesus likes this
#2 Dom543
Dom543
Posted 11 July 2014 - 12:41 PM
In the US you can get it from here
http://www.astro-vid...eo-cameras.html
--Dom
#3 Martin Lyons
Martin Lyons
Posted 11 July 2014 - 01:00 PM
--Dom
Sheesh!! Quite expensive there.
I paid 1/5 of that price locally and we normally pay a premium for any gadget here in Cape Town.
#4 David B in NM
David B in NM
Posted 11 July 2014 - 01:49 PM
My SDC-435s are not Coaxitron compliant. Therefore the UTC remote cannot be used. I have a hardwired remote box for them.
Added: You are correct. I see it appears hidden in my manual (not in the specs). They say you learn something new everyday! Thanks for drawing this to my attention. :bow:
My SCC-B2331s are Coaxitron compliant. The UTC remote does work with them.
The SCB-2000 is Coaxitron compliant. I'm assuming that is the camera you are using and that's why the UTC remote is working for you.
If a camera is Coaxitron compliant, it will state so in the user's manual.
David B in NM
#5 XRinger
XRinger
  • Loc: Woburn, MA USA
Posted 11 August 2014 - 01:56 PM
Got mine from Amazon for 10 USD. It works great on the SCB-2000N.
"eSecure UTC OSD Controller with BNC Connector"
I was reading about soldering wires to points inside the camera keypad, when I saw there was a better way..
It's got to be cheaper than buying wire and buttons for the solder-it hardwired DIY controller.
This controller makes it very easy for a novice (like me) to quickly check out the difference camera settings.
And it's nice that it's not too expensive either.
Now, all I need to do is borrow a telescope and see if I really want to get in deep.
Rich
Edited by XRinger, 11 August 2014 - 01:58 PM.
#6 ccs_hello
ccs_hello
Posted 11 August 2014 - 06:41 PM
I also bought one at that famous auction place for $8 shipped.  Search keywords:
UTC Remote Controller OSD.
Gut feeling it is using RJ Electronics' RJ201 chip
<edit> indeed it is RJ201 but it is a 16 pin version and
only has 1 lead tapping onto the CVBS video..  I.e., video is straight thru.
(i.e., without battery video can still flow thru unaffected.)
Works on my Samsung SDC-435.
BTW, tried it on LN300 and another videocam.  UTC/Coaxitron did not work on them.
Clear Skies!
ccs_hello
Edited by ccs_hello, 11 August 2014 - 07:51 PM.
#7 Craig in Tacoma
Craig in Tacoma
Posted 14 August 2014 - 10:52 PM
Not all SDC-435's are created equal?
On page 30 of the SDC435 users guide, bottom entry of Operations, Communication: Coxaial (Pelco coaxitron) ... If yours doesn't work, you may have gotten a bad part.
Mine does work,  it's a "P" model (12vdc/24vac) SDC435 mfg Dec 2010.
Just saying....All hopeful Samsung SDC-435 or SCB-2000 users should check their model and compliance spec's. before ordering.
Hope that helped someone
Craig
#8 David B in NM
David B in NM
Posted 15 August 2014 - 03:21 AM
Craig,
Please re-read my post above.  You'll see I did recheck my manual and thanked the OP for teaching me something new that day.  You'll see a bow in the second line.
David B in NM
#9 ccs_hello
ccs_hello
Posted 06 September 2014 - 09:40 AM
Clear Skies!
ccs_hello
Such unit can be obtained from Aliexpress for about $6.
It has a bug though (due to 1-wire tap design), when the screen is very bright  (e.g., over exposed to be almost 100% white), it losses the control of the videocam
and requires camera-back button pushes.
Anyone has the full datasheet of the 16-pin version of the RJ201 (such that it can be converted it back to the standard design)?
Clear Skies!
ccs_hello
#10 core
core
  • Loc: Mostly in Norman, OK
Posted 07 September 2014 - 01:09 AM
Thanks for the heads up!  I was previously looking at units like the Samsung SPC-300 controller (~$118 refurb), thinking about AstroV's $50 - but at ~$10 for (more likely than not) the same thing, it's a no-brainer!
#11 StarmanDan
StarmanDan
  • Loc: Deep in the heart of Texas
Posted 07 September 2014 - 09:36 PM
Got mine a few weeks ago and it works very well!
#12 TropixSky
TropixSky
  • Loc: United States
Posted 07 September 2014 - 11:18 PM
Got mine from amazon a couple of days ago and it works great on my scb2000N.
Mario
#13 will w
will w
  • Loc: oxford,ms
Posted 10 September 2014 - 12:09 PM
well i just got around to ordered one.according to manual it should work with my sdc-435 cam. will w
