Etx-ls 6
6 replies to this topic
#1 Sariin
Sariin
  • Loc: Baton Rouge, Louisiana
Posted 12 July 2014 - 11:36 PM
I'm looking at picking one up from a friend for $600. Is it worth it? Anything I should know about the older etx branded models? It's an acf with the monitor. Thanks in advance .
#2 astrogeoguy
astrogeoguy
  • Loc: Thornhill, Ontario, Canada
Posted 13 July 2014 - 10:27 PM
The optics are superb. See if it boots up and works, including getting a GPS fix outside. If so, you got a good deal. After that, search the forums for making a firmware reload 2 Gb miniSD card.
Chris
#3 Geo.
Geo.
  • Loc: Upstate NY
Posted 16 July 2014 - 03:58 PM
Other than the firmware upgrade, the only real difference was badge engineering.
#4 OzAndrewJ
OzAndrewJ
Posted 16 July 2014 - 05:03 PM
Gday George
In the very early units, the DEC clutch was not adjustable either. Later models can be tweaked.
#5 astrogeoguy
astrogeoguy
Posted 16 July 2014 - 06:13 PM
No clutches at all on the Lightswitch scopes. They only allow pushbutton slewing.
#6 OzAndrewJ
OzAndrewJ
Posted 16 July 2014 - 08:49 PM
Gday George
Not totally true ;)
There are clutches of a sort, but they arent user adjustable by "normal means".
As per the attached piccy, the DEC clutch is actually provided by a preloaded rubber disk, and mine "oozed" under load ( hence how i found it ).
The outer plate effectively does double duty as the DEC axle support in the vertical plane, and the clutch preload in the horizontal direction.
Later versions had a screwable insert added to allow the clutch tension to be adjusted in the shop before sealing it up.
#7 astrogeoguy
astrogeoguy
Posted 17 July 2014 - 09:01 PM
Interesting! But as you said, not a clutch in the sense of the other Meade scope models.
Thanks.
