Craigslist, ebay and other Vintage Telescope Finds
1817 replies to this topic
#1801 Bomber Bob
Bomber Bob
  • Loc: The Deep South, USA
Posted 16 December 2015 - 05:43 PM
I'm glad you got the TRAQ 545 - and at a fantastic price!!
Towa lenses are very good, and the mounts & tripods can be tightened up to hold steady at higher powers.
My first big scope was a Tasco (Towa) 80x1200 (a 339 with slight modifications), and I logged thousands of happy hours with it.
#1802 BigC
BigC
  • Loc: SE Indiana
Posted 17 December 2015 - 10:56 AM
The Traq is minty.But had to  reverse the head in the mount base as the pointer was on the side opposite the elevation marks.Hope to check it out on the stars tonight. Have pics and will post after resizing.
#1803 bdaniele79
bdaniele79
  • Loc: Reggio Emilia, Italy
Posted 21 December 2015 - 11:55 AM
A nice find in Netherlands....a Polarex 50/700  :)
Attached File  IMG_20151215_183955.jpg   167.16KB   14 downloads
Attached File  IMG_20151215_185751.jpg   70.71KB   4 downloads
Attached File  IMG_20151215_185842.jpg   107.86KB   5 downloads
  • Vesper818, xavier, terraclarke and 1 other like this
#1804 CharlieB
CharlieB
  • Loc: Southern NH
Posted 21 December 2015 - 12:44 PM
Very nice.  It's one of my favorite 50mm scopes, and they are hard to come by.  Yours has the swinging finder like my 40mm Unitron, and mine did not come with a wooden case.  I'm pretty sure mine is from the very late 1970's or eraly 1980's.
#1805 TexasSky
TexasSky
Posted 24 December 2015 - 12:39 PM
Hi all!.....well I promised myself no more telescopes......but darn it, a taco 19te observatory telescope came up on eBay......these seem to be pretty rare, so I snagged it......looks to be in "OK" condition.....missing box, eyepiece tray, and the coveted light pen though!....Ill post some pics when I get it......will probably need a light restoration....if you do a eBay search on taco 19te and then select "completed listings" you should be able to see original add.....
bob
#1806 Chuck Hards
Chuck Hards
Posted 24 December 2015 - 06:25 PM
Between CL and eBay, about a half dozen of these original-series grey & black DX8's came to market this past late summer through fall.  I grabbed one that I hoped was the best combination of low serial number and good condition of the lot.  It's been sitting in the shop since I got it, but with some time off work for the holidays, I dug it out.
Condition is very good, just a few small paint chips.  The finder is in great shape, just a tad dirty.  Main optics look pristine, in fact the whole telescope looks hardly used.  The DEC lock knob would pop-off when loosened and I suspect this is the reason it didn't get used much, if at all, by the original & previous owners.  Examining it revealed that not enough of the knob shaft threads were making it into the receiver hole on the DEC clutch.  Only two threads were engaged when it was tightened-down, so once loosened to move the scope in DEC, it popped-out and of course the scope wouldn't stay aimed.  I chucked the shaft in the mini lathe and reduced the diameter for about 3/8" of an inch beyond the end of the threads, so now the entire threaded section engages the DEC clutch and it works as designed.  It appeared to be a factory flaw, the shaft had not broken-off but the shoulder was just too close to the threaded portion.  Problem solved.
The laser says it's collimated, but of course that's not precise, so a star test will still be needed, and it's just socked-in here tonight.  Too many other projects on the workbench to set up for autocollimation tests at the moment, maybe in a few days.
But the good news is that, on daytime targets at least, the imagery is very sharp at even high powers.  It blows-away my later model blue-and-light-grey DX8.  I can't help but think that the optics, as a complete system, are much, much better than my later model Dynamax.
I had reasoned that a very low serial number might indicate a unit produced before the Celestron lawsuit forced Criterion to switch their corrector plate figuring method.  Buying a DX8 is always a crapshoot with very poor odds, but judging by my terrestrial tests, this may be a reasonably good way to at least hedge one's bet with these things.  I won't pronounce the optics "good" or better until I've done some actual testing, but the initial views are very promising.
Attached File  001.jpg   115.56KB   7 downloads
  • A6Q6 and Bomber Bob like this
#1807 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 24 December 2015 - 06:47 PM
I wonder if any of these D8's had good optics?
#1808 Chuck Hards
Chuck Hards
Posted 24 December 2015 - 07:25 PM
You and everyone else, Chas.
#1809 fjs
fjs
  • Loc: Olympic Peninsula, les États-Unis
Posted 24 December 2015 - 07:35 PM
Sounds encouraging though.
#1810 Chuck Hards
Chuck Hards
Posted 24 December 2015 - 07:43 PM
Frank, I think it's going to perform MUCH better than my blue one, just because at high power, I get crisp detail on far-away terrestrial targets.  The blue one goes soft once you get above only about 50X; high-power daytime views don't produce any kind of recognizable image, it's truly awful.  A grove of trees at 1/4 mile is just a green blob.
But this one has my attention.  Night-time views and a Ronchi on the bench will reveal all, but I can already tell it's a couple orders of magnitude better than the blue one.
  • A6Q6, fjs and Bomber Bob like this
#1811 CHASLX200
CHASLX200
Posted 24 December 2015 - 07:50 PM
Sounds like it could be a winner. I had two very bad  Meade 2045's that looked ok at 50x on land objects. But at 150x or more at nite on the stars, total mush.
#1812 mfalls
mfalls
  • Loc: Boston Mountains
Posted 05 February 2016 - 11:19 PM
Purchased a Tasco 11T 4 1/2 inch Newtonian  to educate my grandkids .
Excellent view of M42 with the original  Huygens 20 mm eyepiece.
Downside is .965 eyepieces and the useless finder.
  • Chassetter, terraclarke and Bomber Bob like this
#1813 BigC
BigC
  • Loc: SE Indiana
Posted Yesterday, 10:38 AM
Quick! Go to Bill Vorce's telescope-warehouse.com and buy the Meade 25 MA in .965-it will GREATLY increase the ease and quality of the view.Also consider the Meade 40mmMA in .965 and Bill's re-purposed bino eyepiece the 8mm .965.These  with and without a decent glass-lensed barlow in .965 will really bring out the full potential of the 11T.
Edited by BigC, Yesterday, 10:39 AM.
  • mfalls and Bomber Bob like this
#1814 A6Q6
A6Q6
  • Loc: Stroudsburg,Pa,U.S.
Posted Yesterday, 10:58 AM
I really like the case the DX8 came in.  Looks more professional than the regular Kmart foot locker Celestron  provided for their SCT's.
Edited by A6Q6, Yesterday, 11:05 AM.
  • Bomber Bob likes this
#1815 tim53
tim53
  • Loc: Highland Park, CA
Posted Yesterday, 11:06 AM
While not a telescope, I was pretty delighted at the Zeiss Ikon Nettar 515 120 film camera I bought at the swap meet yesterday.  I paid $70, and it's probably worth about that, considering it looks new.  It looks so new, in fact, that I didn't think it was older than about the 60's, but it looks like it was probably made before WWII, between 1937-40.
It's got B and T settings, so if I can find one of my cable releases, time exposures would be pretty straightforward.
But I did find others on ebay for quite a bit less.  Not a great bargain, but a cool addition to my collection of vintage camera gear.  I may even fiddle with it piggyback on a scope one of these days, for hoots.
-Tim.
  • PaulEK, gelkin, Bomber Bob and 1 other like this
#1816 mfalls
mfalls
Posted Yesterday, 04:17 PM
"While not a telescope, I was pretty delighted at the Zeiss Ikon Nettar 515 120 film camera I bought at the swap meet yesterday.  I paid $70, and it's probably worth about that, considering it looks new."
Good for you!  Small, lightweight foldout camera with an excellent lens for medium format piggyback astrophotography. I tried to find a Nettar several years ago. In like new condition, no pinholes in bellows, clean fungus free lens ( if I remember correctly)  I could not find one for under $200.
#1817 Ben H
Ben H
Posted Yesterday, 04:27 PM
Rod Mollise ain't dead yet, but if he were, he'd be rolling in his grave at all the DX8's we've bought.  :lol:
I still say they're way more attractive than any orange tube.
#1818 mikey cee
mikey cee
  • Loc: bellevue ne.
Posted Yesterday, 10:39 PM
I've always thought so too! :waytogo: Mike
