Celestron C80ED
20 replies to this topic
#1 jhighfield
jhighfield
Posted 16 July 2014 - 03:13 PM
My first refractor in 40 years arrived today.
Bought the C80ED from Astronomers without Borders.
I know everyone harps on the focuser as being subpar but mine seems to operate fairly smooth.
I think it will make a nice edition mounted on top of my CPC1100 :)
#2 joseph07081
joseph07081
  • Loc: Chippewa, PA
Posted 16 July 2014 - 03:32 PM
Congrats..... I hope you enjoy your new toy.
I am happy with the performance of the stock focuser for visual. I still have not tried it with my DSLR yet....
If at that point I feel it is lacking, then I will order a Moonlite focuser.
#3 nodalpoint
nodalpoint
  • Loc: FEMA camp
Posted 16 July 2014 - 03:39 PM
The focuser is fine with a DSLR camera - at least fine enough that the money to upgrade the focuser would probably be wiser to put towards a better scope overall.
#4 evan9162
evan9162
  • Loc: Boise, ID
Posted 16 July 2014 - 04:09 PM
The focuser benefits greatly from a teardown, degrease, regrease, and rebuild. The stock grease acts more like partially cured epoxy than a lubricant.
Afterwards, I could focus the moon (prime focus) and Saturn (with a 2x barlow) with reasonable effort for imaging with my DSLR.
I got the C80ED as a low power, wide field scope to complement my C6 SCT - thus, I intend to use it only for magnifications of 50x or less. At those powers, focusing is not as critical or touchy as it is at higher powers.
My only challenge now is figuring out the best way to adapt the scope for binoviewing while keeping its wide-field abilities.
#5 niteskystargazer
Posted 16 July 2014 - 04:13 PM
J,
Enjoy your New Scope :).
#6 Binojunky
Binojunky
Posted 16 July 2014 - 05:21 PM
I bought two, one for me, the other for a friend, focusers on both were fine for visual anyway, in fact I prefer it to the Crayford on the Orion ED80, DA.
#7 jhighfield
jhighfield
Posted 16 July 2014 - 05:28 PM
Epoxy may be a good name for it :)
I also bought it for low power viewing. I doubt I'll ever have it higher than 30x magnification.
Skies are beautifully clear tonight so I'll be out looking at some wide fields :)
#8 pdxmoon
pdxmoon
  • Loc: Oregon
Posted 16 July 2014 - 06:42 PM
I too use it mostly on the full Moon at low power, but for visual. I also use as a grab and go. It is a wonderful scope. Enjoy!
#9 t.r.
t.r.
  • Loc: 1123,6536,5321
Posted 16 July 2014 - 08:02 PM
In cold weather, the focuser will almost seize, and will make the rubber grips slip and spin freely. It is best to clean out the goop and relube! ;)
#10 evan9162
evan9162
  • Loc: Boise, ID
Posted 16 July 2014 - 09:32 PM
The rubber grips on mine were pretty loose out of the box.
#11 k5apl
k5apl
  • Loc: Arkansas
Posted 16 July 2014 - 09:40 PM
Enjoy your new C80ED. If you decide to re-lube the focuser, I gave a brief description on how I did mine on the older thread.
I also did as someone suggested and put electrical tape on the objective cover to shim it so it won't fall out as easy.
The new lube in the focuser, plus some small adjustments, make it a lot better performer. and, I agree with the other person that it is preferable over the Crayford focuser found on similar telescopes.
Can you give us your first light report?
Wes
#12 joseph07081
joseph07081
  • Loc: Chippewa, PA
Posted 17 July 2014 - 05:30 AM
Wes
I read your post in the other thread, very nice instructions.
I plan to follow those myself when I can get the time to strip mine down.
#13 StarStuff1
StarStuff1
  • Loc: South of the Mason-Dixon Line
Posted 17 July 2014 - 04:26 PM
I hope your C80ED is as good visually as the C80 fluorite I had about 20 years ago. How I wish I had not sold that scope... :foreheadslap:
#14 dmgriff
dmgriff
  • Loc: 30 degrees latitude, USA
Posted 17 July 2014 - 04:45 PM
My AWB c80ed arrived about the same time.
All I will change is the 1.25in 45deg terrestrial diagonal with a 2in or 1.25in star diag that I already have.
Other than that, its good to go for my needs.
I think you will enjoy yours.
Good viewing,
Dave
#15 Stelios
Stelios
  • Loc: West Hills, CA
Posted 18 July 2014 - 01:36 AM
I think you'll find it a superb grab-n-go scope at magnifications up to 150x and more. I was amazed at how well it took magnification, and how color-free it was.
I bought it as grab-n-go, but now use it for photography, something else it's quite good at.
I did replace the focuser, but from what I understand the quality on the stock R&P varies greatly. Mine was one of the poorer ones. I may replace the focuser again--I bought the regular GSO Crayford, but I suspect I should have bought the linear bearing version for photography, as I think there might be a bit of flexure there. I couldn't quite justify a Moonlite for such an inexpensive scope.
#16 RussL
RussL
    Music Maker
  • Loc: Cayce and Lancaster, SC
Posted 18 July 2014 - 07:09 AM
Congrats, pal. I got mine from AWB just a few months ago, and I've been enjoying it very much. I've had it up to 150x with no problems. Also haven't done a thing to my focuser. It works fine for now, but I dunno how it will feel when it gets cold yet. I've also enjoyed 18x using my TV Wide Field 32mm as well as 15x with a simple 40mm Plossl. No color issues except that I could see just a tiny hint on Jupiter at high mag. But nothing like my ST80 or 120ST achros. Very nice scope indeed. Mine rides on an eq2 for easy management.
#17 photiost
photiost
  • Loc: Montreal, Canada
Posted 18 July 2014 - 10:24 PM
Great scope.
I have mine for a few years now and dont plan to part with it anytime soon.
congrats.
#18 DCS
DCS
  • Loc: Cypress, Texas
Posted 19 July 2014 - 05:40 AM
The stock focuser works fine - it's a bit on the "basic" side but for this price that's what you get. I did have a little problem with the rubber grips slipping when you adjusted, but it wasn't that much of a bother. It held weight well (cameras, barlows, heavy eyepieces).
Eventually I replaced the focuser with a GSO double speed crayford. After this conversion, the C80ED is more like a mid to premium scope with nicely performing components at both ends of the tube.
-Pete
#19 zyzyz
zyzyz
  • Loc: Mid Michigan
Posted 19 July 2014 - 10:27 AM
I used the parts from a flip mirror to make a fine focus adapter for mine. Mated the helical focuser and eyepiece barrel with a plastic ring cut from a piece of 1 1/4 pvc pipe. I've used it with a barlowed 6.4mm at 188X for a colorfree view of the moon. It's made it easy to get a razor sharp focus at high power.
#20 rg55
rg55
  • Loc: western US
Posted 22 July 2014 - 08:34 PM
I've been very happy with mine.
#21 photiost
photiost
Posted 22 July 2014 - 11:28 PM
I have been using a Prism diagonal on my C80ED and I like the results.
