Winter viewing
10 replies to this topic
#1 Rolex2
Rolex2
Posted 29 July 2014 - 08:06 PM
I live in northern MN where the winter temps 0 and below. My observatory is a skyshed pod with a LX200. I want to view in the winter. I can stay warm but what about the scope(tube and electronics)? I don't see anyway to heat the skyshed. Any feedback would be helpful.
#2 Mr Greybush
Mr Greybush
  • Loc: Virginia
Posted 30 July 2014 - 12:40 AM
perhaps a greenhouse tube heater will provide adequate heat?
#3 Christopher Erickson
  • Loc: Waikoloa Village, Hawaii
Posted 30 July 2014 - 04:53 AM
You really want the scope and observatory to be the same temperature as the surrounding environment. Otherwise thermal currents will ruin your seeing.
#4 mich_al
mich_al
  • Loc: Rural central lower Michigan Yellow Skies
Posted 30 July 2014 - 08:13 AM
The electronics will heat themselves. I keep my hand controller in the house till I'm ready to use it. The LCD display will be sluggish if it's cold so I attach a dew heater strip. Other than dew control, the scope tube needs to be at ambient temp. The mount mechanicals are OK in the cold so long as the grease is OK and normally it is. Fingers, ears and toes are the main concerns.
#5 GJJim
GJJim
  • Loc: más y menos
Posted 30 July 2014 - 09:07 AM
Unless there is a tight mechanical fit that causes pinching, the optics are fine at any temperature you can stand. Some glasses are sensitive to sudden temperature changes. When its -5F don't bring a scope or large eyepiece from room temperature and uncap it in the cold.
Mechanicals and electronics are another story. Greases thicken at low temps and the slew rates should be set accordingly. Most consumer electronics are only rated to work down to 32F. I've had USB hubs misbehave at 15F, and a camera power cord that cracked at -5F. Computers generally heat themselves to a reasonable internal temperature, but any fans inside will quickly announce if the bearings are up to snuff for cold weather use.
Batteries have only about half their normal power capacity at low temperatures. Lithium cells are much better in this regard.
#6 TimN
TimN
  • Loc: Ontario, Canada
Posted 30 July 2014 - 04:45 PM
I have a Pod that I use until the temperature reaches -25C to about -30C ( say around -15F).
There are really 2 issues. The first is when you are not observing/imaging while the second is when you are.
In weather this cold the temperature can swing easily and my equipment was often covered in dew/frost. Also, the area between the dome and walls has a nice space for air circulation. However, in winter this can let in snow so I block it with 1" foam strips. To keep the equipment dry I run a small heater/fan. The slight heat and moving air keeps things dry. I use this one http://tinyurl.com/l3co4aw
When imaging/observing I do not have any heat on as that would cause air currents. As stated above the equipment warms itself until the temperatures I mentioned - then I have problems, so I head inside.
P.S. - don't forget to lubricate the lock as it can freeze easily in winter.
#7 Rolex2
Rolex2
Posted 01 August 2014 - 08:29 AM
Thanks for the imput. I have started insulation the skypod. Ordered the West Marine fan. Two questions: do you cover your scope? I thinking for added protection of a cover made with R11 insulation. How do i lube the locks?
#8 Bob Griffiths
Bob Griffiths
    Getting Grouchy
  • Loc: Frederick Maryland
Posted 01 August 2014 - 08:30 AM
Do as I did and invest LESS the the cost of a single ETHOS eyepiece and buy a some heated motorcycle clothing...
I use Gerbrings stuff...just a heated jacket LINER which I wear over a plain t-shirt BUT under an extra large sweat shirt ...a pair of heated GLOVE liners (one size smaller then normal) that I wear under a pair of finger-less mittens and a pair of heated socks ...I also use a thermostar that allows me to heat all 3 items to the temperature I want individually...
Glove liners have heating element on the top of the hand as well as between each finger The socks I use have heating elements on top of the foot as well as the bottom of the feet... I wear them over a regular pair of socks and a pair of bedroom slippers...
Seriously I am very comfortable down well below freezing..although I seldom go out on the rare nights here that the temp drops to zero...
Bob G.
#9 TimN
TimN
Posted 01 August 2014 - 09:05 AM
I never insulated my Pod - just the 1" foam strips to fill in the space left for air circulation. I assume that's what you mean.
I leave my scope uncovered and place the West Marine fan on a small table to let it blow over the scope. It actually creates enough air movement to keep the Pod above the dew point. Its made to run all the time and I always have it on during the winter unless I'm observing/imaging. It seems to create almost no heat and hardly turns - this is ok. It only draws about 75 watts even though it says it draws 90 watts on the box. I talked to the engineer and the 75 watts is correct. I always worry about covering my scope as the cover can hold the moisture in and not let the air from the fan blow over it.
I assume any lock lubricant will work - even just WD40. Also, lock de-icer should work. After mine froze up the first winter, I've always kept lock de-icer on hand - just in case.
Also, I started to close the Pod so that the lower dome - the part that slides under - is facing south. This allows the sun to shine on it keeping the ice off and allowing it to slide easily under the upper dome.
I'm not sure where you are located but we have had cold and rainy weather this July and we are hoping for a better August. All this planning for winter is great but I'm still waiting for a proper summer. :)
#10 Raginar
Raginar
  • Loc: Pensacola, FL
Posted 01 August 2014 - 02:03 PM
I live in SD and our weather is similar temperature and humidity wise. My equipment stays in my shed year round without any 'heat' required.
The only issue I've heard is that many cameras can't handle having a temperature less than ambient... so if it's -35C, you're going to have a hard time controlling cooling. Essentially unregulated.
#11 TimN
TimN
Posted 01 August 2014 - 07:21 PM
Chris, I tried leaving my stuff in the obs. without a fan or heat and it was covered in moisture in the fall and frost in the winter. This isn't surprising as tools left in my shed or garage start to rust after a couple of years. I tried just adding heat with "goldenrods" but that didn't help. However, the marine fan only gives off a very little heat and the slight movement of the fan helps keep things nice and dry. I guess if the op doesn't have a problem with moisture this fall/winter that's great. If he does then the marine fan is a nice solution.
