The Little Owl Micro Observatory (on a balcony)
44 replies to this topic
#26 astrovirus
astrovirus
  • Loc: The Netherlands
Posted 27 August 2014 - 03:59 PM
Made some good progress again today, out on the balcony in the nice sunny weather. Installed the clips that will lock down the top frame and also the back frame when the observatory is closed. Also constructed the backframe and installed the rain gutter and drainpipe for the observatory and also a reroute from our drainpipe for the appartment roof that would empty on the balcony, which now follows a gutter to the drainpipe for the balcony itself. So most of the roof water will not have to pass beneath the obeservatory now. Still I will put up a damp barrier under the floor which I have to install over the coming days, to prevent moisture from entering the structure from below.
Attached File  IMG_6637 (400x600).jpg   134.24KB   11 downloads
Clip to lock down the top
Attached File  IMG_6636 (400x600).jpg   147.57KB   8 downloads
Clip to lock down the back
Attached File  IMG_6639 (400x600).jpg   148.85KB   10 downloads
Gutter/pipe installed on the back panel
#27 astrovirus
astrovirus
Posted 27 August 2014 - 04:01 PM
And some more
Attached File  IMG_6640 (400x600).jpg   154.57KB   8 downloads
Back panel in place after opening the observatory
Attached File  IMG_6642 (400x600).jpg   136.53KB   6 downloads
Back panel removed with gutter/pipe
#28 astrovirus
astrovirus
Posted 09 September 2014 - 11:54 AM
Another small update with some pics.
Attached File  IMG_6645 (400x600).jpg   169.67KB   5 downloads
Made some finishes to the Alu-frame and als the sides of the shiplap.
Attached File  IMG_6646 (600x400).jpg   146.4KB   2 downloads
Placed extra handle for opening/closing observatory and also put some caps in the foldable stand.
Attached File  IMG_6648 (400x600).jpg   147.68KB   4 downloads
Put up a plank to prevent rain from entering on sloped sides and also serves as a alignment help when closing the observatory.
#29 astrovirus
astrovirus
Posted 09 September 2014 - 11:56 AM
Continued.
Attached File  IMG_6651 (400x600).jpg   134.69KB   4 downloads
Bracing pins for the closings.
Attached File  IMG_6650 (400x600).jpg   181.85KB   5 downloads
Power lines, sockets and data pipe.
#30 astrovirus
astrovirus
Posted 13 September 2014 - 01:57 AM
So, the light at the end of the tunnel is coming into sight. This week, I pulled 3 active USB cables through the data pipe, which prove more of a problem then I had anticipated beforehand, but in the end with a little help we managed. Then I also wanted to get the EQdit cable in, which also succeded with some effort. I also place the NEQ6 mount on the pier and leveled it, and then came the moment of thruth, to see if the observatory would properly close with the OTA fitted. And it did, so I did my homework, measurements, and building properly to my specs. First Light is approaching now, although I still have to do a lot of tiny things around and in the observatroy. Also the control PC will have to be installed at the inside of the balcony/window wall, so I'll have to install a mounting for that, as well as configuring the PC, as I have decided to swap my old PC for another oldie, that has a much smaller footprint. However this means installing XP pro again with its 111 updates and after that getting all my astronomy software up and running again, with some nice new additons to start experimenting with (AT plate solving and maybe after that FocusMax autofocusing).
Attached File  IMG_6657 (600x400).jpg   150.58KB   9 downloads
Observatory closed as seen from the roof of our shed.
Attached File  IMG_6653 (600x400).jpg   141.8KB   6 downloads
Mount installed on the pier.
Attached File  IMG_6654 (400x600).jpg   157.95KB   9 downloads
OTA installed.
#31 astrovirus
astrovirus
Posted 13 September 2014 - 01:58 AM
And one more.
Attached File  IMG_6652 (400x600).jpg   169.07KB   13 downloads
Everything fits like intended.
#32 TimN
TimN
  • Loc: Ontario, Canada
Posted 13 September 2014 - 04:27 PM
From one Tim to another - that is a great solution. I'm sure your ideas will be copied by many others. Well done!
Tim
#33 Starman27
Starman27
  • Loc: Illinois, Iowa
Posted 14 September 2014 - 10:54 AM
Well Done.
#34 hbastro
hbastro
  • Loc: CA, USA
Posted 14 September 2014 - 12:41 PM
Hi Tim,
Very resourceful and creative solution to an overwhelmingly confined space, very well done...
Dave
#35 astrovirus
astrovirus
Posted 18 September 2014 - 04:32 AM
LOMO is alive. Yesterday I got around to instal the rest of the equipment and started to prepare the control PC with the much needed software. All connections between software and equipment are up and running, so I'm nearing "first light". However, before that, polar aligning will prove somewhat of a challenge as I have almost no view of the Northern sky and Alignmaster strongly favors starpairs with a component in the Northern sky. So I'll probably will also try the polar alignment help in AstroTortilla, or EQalign to perform polar alignment. Images of the completed setup will follow in the coming days, as there is still some cable mess to sort out on the observatory floor.
#36 JJK
JJK
Posted 18 September 2014 - 08:42 AM
Use a clinometer to set your mount ALT angle, point roughly to true North (use a compass and correct for the deviation), and then use drift alignment.  You'll be dead-on in under two hours, and drift alignment is the final arbiter anyway.
#37 astrovirus
astrovirus
Posted 27 September 2014 - 12:03 PM
So, finally managed to take some images to show the latest progress.
Attached File  IMG_6658 (427x640).jpg   138.73KB   8 downloads
1. Control PC ready for action on polar algnment tonight. On the right is a simple weather station to monitor temperature and humidity in the observatory when not in use.
Attached File  IMG_6660 (640x427).jpg   151.92KB   6 downloads
2. Another view of the control unit with the imaging equipment ready for action in the background. The PC is attached to the monitor stand so it has a nice small footprint.
Attached File  IMG_6661 (427x640).jpg   177.78KB   10 downloads
3. Camera mounted, with all needed cables/hub.
#38 astrovirus
astrovirus
Posted 27 September 2014 - 12:04 PM
Attached File  IMG_6662 (427x640).jpg   186.07KB   8 downloads
4. Finder guider and main data cable.
Attached File  IMG_6664 (427x640).jpg   108.26KB   8 downloads
5. Outdoor sensor of the weatherstation mounted on the lower casing of the observatory. In the background, some of the polystyrene isolation I'm in the process of installing is visable.
#39 tim57064
tim57064
  • Loc: Southeast South Dakota,USA
Posted 28 September 2014 - 09:11 AM
Tim,hopefully you are planning on running your setup from a different locating during the winter. That computer may not last long next to that heater. Just a thought.
#40 astrovirus
astrovirus
Posted 28 September 2014 - 02:40 PM
It is a central heating system with warm water running thru, no electrical radiation heater or something like that, so it doesn't get that hot and in addition we don't have it turned on that often, as our home is pretty well isolated and we usually have the thermostat set at about 18°C. So, I think it should be alright, but thanks for pointing it out, and I'll keep an eye out on it during the coming winter time.
#41 astrovirus
astrovirus
Posted 18 October 2014 - 04:58 PM
So, finally a clear night without any other obligations, so spent some time on polar aligning the NEQ6 using AstroTortilla Polar Alignment tool. Despite having read some bad experiences with this tool, I have to say it worked out rather well to get my mount reasonably polar aligned without having any views of polaris from my balcony. Also using Alignmaster proves difficult as it has a preference for N-S star pairs and I have hardly any view towards the Northern skies. With a couple of itterations AT now reports my altitude error as 48' (coming from 5°) and my azimuth error was around 2-3' so I left that alone. Plate solved corrected goto precision is now spot on and I already tested shooting 5 minute guided subs with no problems. Looks like LOMO is now truly getting ready for a serious first light.
  • ThomasT likes this
#42 Unknownastron
Unknownastron
  • Loc: CatsEye Observatory,Rural Southern Oklahoma
Posted 29 October 2014 - 11:07 PM
Tim, an excellent use of existing space.  I like the name, too.  May the Little Owl perch happily on your balcony for many years!
Clear skies and clean glass,
#43 Hilmi
Hilmi
  • Loc: Muscat, Sultanate of Oman
Posted 30 October 2014 - 04:40 AM
That looks excellent. All you need is a little heat source inside to control condensation.
#44 astrovirus
astrovirus
Posted 05 November 2014 - 10:25 AM
Heat source is already installed inside the observatory and will also serve as frost protection, keeping the temperature at +5°C when the observatory is closed.
#45 jdfjeff
jdfjeff
  • Loc: San Antonio, Tx.
Posted 08 November 2014 - 04:35 PM
Nicely done, Tim!   A very clever design.  Clear skies!
