6" F10 Jaegers finally on a proper mount
50 replies to this topic
#1 bremms
bremms
  • Loc: SC
Posted 02 August 2014 - 03:05 PM
Well, finally finished the pier.
  • terraclarke likes this
#2 bremms
bremms
  • Loc: SC
Posted 02 August 2014 - 03:07 PM
Didn't look big in the garage.
#3 Chuck Hards
Chuck Hards
    Pour le Mérite
Posted 02 August 2014 - 03:26 PM
Very nice, Marc! Looks solid as a rock.
Is that a 10" or 11" Byers drive? It will track like a Swiss watch.
Looks like the eyepiece height will be just about perfect when viewing at the zenith, and seated.
#4 astroneil
astroneil
Posted 02 August 2014 - 03:39 PM
Fabulous Marc,
Your pride restored! :bow: :bow: :bow:
Neil. ;)
#5 DocFinance
DocFinance
  • Loc: Clear Lake, Texas
Posted 02 August 2014 - 04:13 PM
That thing is massive. And gorgeous. It will certainly be worth the time you've spent on it. There's no substitute for a good mount.
#6 roscoe
roscoe
    curmudgeon
  • Loc: NW Mass, inches from VT
Posted 02 August 2014 - 05:57 PM
What are the shaft sizes? It makes that GPDX look like it wants a 60mm.....
#7 actionhac
actionhac
  • Loc: Seattle
Posted 02 August 2014 - 08:33 PM
You did a beautiful job, very nice.
Robert
#8 bremms
bremms
  • Loc: SC
Posted 04 August 2014 - 08:05 AM
Took the scope out last night inbeteen clouds. Nice and steady. One issue I knew would be a problem is stiction in the clutch. The later all nylon clutches have a lot of stiction. I have a 7" drive for the mount, but need to rebore the clutch to fit the shaft. The 10" drive is a bit bulky for this semi portable scope. The 7" is an earleir starmaster and has very little stiction. I could try some lube on the bigger drive. Have an electric dec adjuster in the works, and will convert the drive to a stepper or servo.
Thanks for the kudos  everyone.
Edited by bremms, 04 August 2014 - 08:05 AM.
#9 Svezda
Svezda
  • Loc: Texas
Posted 05 August 2014 - 11:19 PM
So no pictures show up in posts like they used to? Am I the only one not seeing how to view pictures or is it a glitch of the new forum look that I just noticed today?
#10 bremms
bremms
  • Loc: SC
Posted 05 August 2014 - 11:35 PM
Yes the pictures have flown the coop. Maybe the fox had a good dinner.
#11 actionhac
actionhac
  • Loc: Seattle
Posted 06 August 2014 - 12:04 AM
Edited by actionhac, 06 August 2014 - 12:06 AM.
#12 turk123
turk123
  • Loc: N.E. Ohio
Posted 06 August 2014 - 04:20 AM
I've been waiting for this thread to repopulate with pictures to see the Byers drive mounting.  Maybe you could post a few more pictures now to speed things up.
#13 bremms
bremms
  • Loc: SC
Posted 06 August 2014 - 06:18 AM
I'll repost pictures later this morning. Turns out I have a bit of a binding problem with the drive clutch. The part that clamps onto the shaft is too tight in the bore of the drive gear. The clutch assy is all nylon and changes dimensions with temperature and humidity.  It was a bit tight when received from Ed. Luckily I can take it to work and machine off a couple thousands.
#14 Chuck Hards
Chuck Hards
    Pour le Mérite
Posted 06 August 2014 - 06:48 AM
Marc, I replied to you in the ATM forum on this, but was thinking that it might be the clutch faces.  A tight bore is an easier fix.  See what that does, first.
Barstow is a lot drier on average than South Carolina, that's for sure.
#15 bremms
bremms
  • Loc: SC
Posted 06 August 2014 - 12:13 PM
Yes, it takes time for the moisture to come out of the Nylon, bonds to the polymer.  The bore is part of the issue. it was 85 degrees the other nigth when i took the scope out.
The problem got worse the longer it was warm. Knew there was a problem when I backed the clutch screws off all the way and it was still locking up. It's all machined now and I added two more shaft clamping screws as not to distort the hub too much. It's clear tonight but I have plans. Maybe tomorrow.
#16 terraclarke
terraclarke
  • Loc: Kentucky!
Posted 06 August 2014 - 12:33 PM
Well I don't know about the rest of you but I'm looking forward to seeing pictures! ;)
#17 bremms
bremms
  • Loc: SC
Posted 06 August 2014 - 02:05 PM
I'll get more pictures together and explain a bit more about what I am doing. Going to use steppers with an arduino to control them. For variable drive rates and centering.  No GoTo crap. The ATM Forum is more appropriate for that discussion.
#18 rwiederrich
rwiederrich
    Goldfinger
  • Loc: Gorst Washington(center of the Universe)
Posted 07 August 2014 - 08:58 AM
What!....No pix?
Rob
#19 bremms
bremms
  • Loc: SC
Posted 07 August 2014 - 09:17 AM
Been very busy, I'll try later this evening to post some picures. I'll try again from my phone, but it didnt work during a test yesterday.
#20 bremms
bremms
  • Loc: SC
Posted 07 August 2014 - 12:07 PM
Using the **** resizer on my phone.
#21 tim53
tim53
  • Loc: Highland Park, CA
Posted 07 August 2014 - 02:44 PM
Really nice!
#22 turk123
turk123
  • Loc: N.E. Ohio
Posted 07 August 2014 - 02:48 PM
Can we get a few closeup pictures of the Byers drive and how it was mounted?  I have the same gear.
#23 terraclarke
terraclarke
  • Loc: Kentucky!
Posted 07 August 2014 - 06:00 PM
Really nice Marc. That picture doesn't do justice to its true size. You ought to post the one you put on FB. That tele is HUGE!
#24 terraclarke
terraclarke
  • Loc: Kentucky!
Posted 07 August 2014 - 06:02 PM
And yes, I too would like to see a couple of close-up pics of the drive and how it is attached as I have been considering a Byers 7" drive for my Meade #826 mount.
#25 Bomber Bob
Bomber Bob
  • Loc: The Deep South, USA
Posted 07 August 2014 - 08:50 PM
Awesome Classic Scope -- from one end to the other!
