Mounting 4" binoculars on a Half Hitch MKII
27 replies to this topic
#1 rfic1
rfic1
Posted 06 August 2014 - 04:20 PM
I recently acquired a Half Hitch Mark II mount to use with my 4" Miyauchi binoculars. I finally received the L bracket required to mount the binos to the dovetail plate. All is properly mounted but I am having considerable trouble acheiving proper balance for the mount to funtion properly. Point the mount up to the zenith and they fall backwards, Towards the horizon and they fall forward. If I tighten the tension brake to slove slove that issue, then the Alt slow motion control slips.  For a number of years I have used the Lightspeed Wagon to mount the binos and they did a great job. I however sold them in favor of the lighter more portable half hitch. I'm begining to think I made a huge mistake in doing so. Any tips on mounting the 4" Miyauchi's to the half hitch would be appreciated.
#2 Tamiji Homma
Tamiji Homma
  • Loc: California, USA
Posted 06 August 2014 - 05:36 PM
Hi
HalfHitch mount needs a little effort to understand how to do two axis balance properly.
It took me some time to get used to it.  You might want to email to Charles to get two axis balance
instruction note first.
You would need to change saddle height and L-bracket height to get two axis balanced besides
slide dovetail back and forth, weight trimmer, finder scope if you have it.
Once you achieve two axis balance and perfectly leveled, HH moves smoothly and stops at any direction, and
slow motion control does not slip at all.  You need to master it :)
I have a few photos to show how I mounted APM 100ED binoculars on HH.
With APM 100ED, The L-bracket didn't have enough width so I had to cascade dovetail.
It looks ugly but it did work.
Smaller binoculars (like Kowa Highlander) did fit without extending the bracket).
Probably Miyauchi fits well.
Good luck :)
Tammy
#3 rfic1
rfic1
Posted 06 August 2014 - 06:23 PM
Thanks Tammy,
That's exactly how  I have them mounted. I do have the balance weight.  I guess I need to fiddle with them a bit more. BTW the Miyauchi's do fit without a extended plate off the L bracket.
#4 Quintessence
Quintessence
    Vendor
  • Loc: Austin, Texas
Posted 09 August 2014 - 01:56 PM
You will NOT need the balance trim-weight.  As Tammy has correctly stated, you WILL need to perform the two-axis balance procedure -- and I do have instructions for doing it.  It is important to follow a methodical procedure that isolates the up-down component of balance from the end-to-end compontent of balance.  If the Half Hitch is dedicated entirely to the Miyauchi binocular, I would suggest entirely removing the trim-weight AND bracket PRIOR to performing the two-axis balance procedure.  You just won't need it -- and taking them off enhaces portability.
Charles
#5 Howard Gao
Howard Gao
  • Loc: Shanghai, China
Posted 22 November 2016 - 09:28 AM
Hi
Good luck :)
Tammy
Hi Tammy
Your setup was excellent and I'm still copying it after more than 2 years. Just one question - were you mounting the Highlander with only 1 screw? I thought it's difficult to stop the binocular from moving around with only 1 screw fixed on the L bracket. Is there any additional secure measure you used?
Howard
#6 Tamiji Homma
Tamiji Homma
Posted 24 November 2016 - 01:31 PM
Hi Howard,
Yes, single screw isn't enough to prevent from rotating if you apply force hard enough to binoculars.
Practically, it wasn't issue since HH mount rotates smoothly by pushing binoculars.
Ideally, it would be nice to do either multiple screws or somehow utilizing the two dimples to secure the binoculars to prevent from rotating even with enough force.
I've tried to put thin film (or tape) between L-bracket and binoculars shoe to increase friction.  It was some success but it wasn't perfect.
Tammy
#7 Rich V.
Rich V.
  • Loc: Lake Tahoe area, Nevada, USA
Posted 24 November 2016 - 02:44 PM
Tammy, is there anything you see that would prevent drilling and tapping those "dimples"?
Rich
#8 Howard Gao
Howard Gao
Posted 24 November 2016 - 08:21 PM
Hi Howard,
Tammy
Thanks for the answer Tammy.
#9 Tamiji Homma
Tamiji Homma
Posted 25 November 2016 - 11:25 AM
Rich
Hi Rich,
No, I don't see anything preventing from tapping threads in the dimple area.
I am thinking of buying Kowa Highlander's center mount for my Christmas.
since US dollar is getting stronger against yen :)
Tammy
  • Rich V. and Stellarfire like this
#10 Howard Gao
Howard Gao
Posted 26 November 2016 - 03:27 PM
Rich
Hi Rich,
Tammy
I'm thinking about the same. Can the Kowa mount be used for other binoculars like Nikon 18x70?
#11 Rich V.
Rich V.
Posted 26 November 2016 - 04:36 PM
The Kowa center mount looks like it's proprietary for the Highlander.  Looks nice and simple, though, compared to the Half Hitch.   :D
Here's a photo:   http://www.eurooptic...nt-bl8j-mt.aspx
All you need for your 18x70s is the Nikon 7806 adapter.  It fits any mount/tripod head/QR plate with a 1/4"-20 attachment screw.  The Nikons need an adapter that grabs the hinge; no threaded mounting hub...
https://www.bhphotov...od_Adapter.html
Rich
#12 Howard Gao
Howard Gao
Posted 26 November 2016 - 10:01 PM
Rich
Thanks for the info Rich. I already have the Nikon adapter but I'm not happy with it as it can not hold the binocular steadily. I'm just trying to find some justifications for the purchase of Kowa mount - it will be very convincing if it can support other binoculars.
#13 Howard Gao
Howard Gao
Posted 26 November 2016 - 10:32 PM
This is a Nikon 18x70 with adapter mounted on a quarter hitch and RRS tripod. I have to more it carefully as there is only one screw fixed on the adapter.
#14 Allardk
Allardk
  • Loc: Budapest Hungary
Posted 27 November 2016 - 07:41 AM
I use the Cartoni Focus HD for the Kowa. Works effortlessly. Together with a geared Manfrotto Carbon tripod it became my travel setup.
The Cartoni is about 550 euro in Europe. Heavily overpriced in the USA.
For the APM100-45 I use a Manfrotto 516. Works very well together.
Problem with video heads at some point is the price. If you go heavier than the APM 100-45 APO the price shoots up. In favor: easy to setup and use.
  • Stellarfire likes this
#15 Tamiji Homma
Tamiji Homma
Posted 03 December 2016 - 07:27 PM
Rich
The Kowa Highlander Center Mount delivered from Japan today.  I put it on Avalon T-Pod 130 with single center 3/8"-16 bolt, flat surface, standard interface like DM-4/DM-6/T-Rex/HalfHitch.
It looks nice and moves smoothly as designed.
Close up on mounting area:
Tammy
  • Howard Gao and Stellarfire like this
#16 Howard Gao
Howard Gao
Posted 03 December 2016 - 11:38 PM
Rich
Tammy
Thanks for the report and it looks awesome! So I don't think the kowa mount can be used with any other binoculars you have, right?
Do you think I can mount the kowa and mount on a RRS TVC-34 as a G&G setup?
#17 Allardk
Allardk
Posted 04 December 2016 - 02:43 AM
Beautiful engineering....but for me a geared tripod is essential for comfortable observing.....
#18 Tamiji Homma
Tamiji Homma
Posted 04 December 2016 - 11:41 AM
You would need special adapter to utilize the Kowa Center Mount for other binoculars.
Well, the mount comes with the adapter for Kowa Highlander.  You replace original adapter with the adapter
to attach binoculars to Center Mount.
RRS TVC-43 may be a little too small for this.  Here is difference between TVC-43 and TVC-33.
Here is Kowa Highlander on Kowa Center Mount/RRS TVC-43.  I think it has good stability.
Tammy
#19 Howard Gao
Howard Gao
Posted 04 December 2016 - 03:25 PM
Thanks Tammy. I'll place an order on the central mount!
#20 Tamiji Homma
Tamiji Homma
Posted 02 January 2017 - 04:37 PM
I decided to get dedicated tripod for Kowa rather than using camera tripod since I need the tripod for photography.
I looked around to find Kowa original tripod. It seems that most Highlander related products are out of stock and Japanese Kowa web site says "sold out."  I hope it isn't a sign of dropping the product but a sign of renewal :)
I settled with familiar tripod Avalon T-Pod 110 with extender.
A little close up:
Tammy
#21 Howard Gao
Howard Gao
Posted 02 January 2017 - 05:21 PM
That's a very beautiful setup. Kowa highlander has been in sold out status on Kowa website. I even think they may have stopped production and just sell the stock. You should still be able to buy the tripod from Kyoei but I think Kowa tripod is actually made by berlebach, just with some special painting.
#22 range88
range88
Posted 02 January 2017 - 10:38 PM
A little close up:
Tammy
I'm curious where do you get the red exention column Tammy, that looks substantial.
#23 Howard Gao
Howard Gao
Posted 02 January 2017 - 10:44 PM
A little close up:
Tammy
http://www.avalon-in...extender-linear
#24 range88
range88
Posted 03 January 2017 - 03:10 AM
A little close up:
Tammy
太贵了。。买不起。Tammy真是大壕。
Edited by range88, 03 January 2017 - 03:11 AM.
#25 Howard Gao
Howard Gao
Posted 03 January 2017 - 06:44 AM
A little close up:
Tammy
太贵了。。买不起。Tammy真是大壕。
:fingertap:  :fingertap:
