Are binoviewers just as great on DSO's?
164 replies to this topic
#151 bgi
bgi
  • Loc: Ga
Posted 14 October 2014 - 11:27 AM
A 6" does not really show much.
Hmmm. Don't tell that to my 6" refractor... One of the finest views I've seen of M13 was with a 6" f/8 achromat and binoviewer with 20mm widefield eyepieces, working at 60x. It was not the view with the most stars resolved, but it was of an exquisite beauty I've not seen in any other scope since.
Clear skies!
Thomas, Denmark
Not doubting that it was beautiful, but IME, globs look MUCH better with large aperture and high power.
#152 REC
REC
  • Loc: NC
Posted 17 October 2014 - 08:08 AM
I finally got a clear night with great transparency and had my 8" SCT out.  Checked out M92 and M13 with the BV in place.  The best view I had with the BV was the butterfly cluster, almost 3D look.
  • Procyon likes this
#153 Eddgie
Eddgie
Posted 17 October 2014 - 10:22 AM
oou
Clear skies!
Thomas, Denmark
I share this sentiment.  M13 is lovely in my 6" APO, but far better in my 12" dob.      Just as in everything else, it is hard to dismiss the advantage that aperture offers and for binoviewing, I think that the Newt/Dob is the best possible platform, especially when coupled with a powerswitch type system.
Edited by Eddgie, 17 October 2014 - 12:49 PM.
#154 Vondragonnoggin
Vondragonnoggin
  • Loc: Southern CA, USA
Posted 12 November 2014 - 08:53 AM
Kind of sad to see jdbastro's suggestion mocked here. Binoviewing with intensifiers is pretty amazing. One can equate a properly filtered night vision device with c-mount adapter and 1.25" or 2" nosepiece to using a short focus achro on bright objects.
they are very similar in this respect. In a short focus achro, the color fringing from CA is seen in only the brightest objects and is not detected on most DSO's. In regards to star brightness, this is the same kind of dynamics with the green hue. It appears white mostly and on very bright objects, the green will become more apparent as a fringing effect. Brightest nebula will exhibit green cast as well, but it is definitely not sickly looking and definitely not a "fail". The improved gain, and detail seen by that gain is, to me, well worth the hue on brightest objects. Proper filtering really is key to making things look more normal in the intensifier.
Incidentally - they make white phosphor tubes if you absolutely hate green. PVS-7 WPT. There are several options in resolution depending on price. They can be as low as 45 lp/mm all the way up to 72 lp/mm (lp/mm = line pairs per mm on the Air Force resolution chart) the best commercially sold ones will have a range like 60-72 lp/mm but you can get a custom ordered tube that tests high if you're willing to pay enough.
the green phosphor tubes that are gen 3 thin film autogated are 64-72 lp/mm.
you would not use any narrowband filtering when looking for globs, but a 640nm Longpass filter is great for globs.
I use one with my PVS-7 when looking at GC's and OC's or dense Milky Way regions. That particular filter will also bring out HII regions very well in white zone LP.
for nebulae, I like a 3nm Ha filter. Most stars and nebula appear grey/whitish with a 3nm Ha in place, but the brightest like M42, M8, M20 still have greenish hue on brightest regions.
No OCS required for PVS-7 and in fact, I frequently use a .5x reducer on my ST120 and AT72ED when the PVS-7 is in. It's native eyepiece is equivalent to a 26mm but the PVS-7 has an AFOV of around 40 degrees that actually takes on an appearance like it was wider. Similar to using Plossl's in a BV. So you still can get very large TFOV's particularly using a reducer with it. Of course for globs, you would not use a reducer.
#155 Eddgie
Eddgie
Posted 12 November 2014 - 09:28 AM
While I agree that the mocking (which i personally did not feel was intended in a mean way at all) may have distracted people from the recommendation, the big thing that probably keeps most people from adopting this kind of technology is the cost.
Most people would not consider spending $3500 or more on this kind of solution.
I have the $3500 to spend I guess, but I have gone back and forth on this before.   I am a visual observer.  I like sitting at the eyepiece because I feel like I am experienceing the sky "in person".
If I were to put a peice of technology between myself and the sky that processes the view and presents it to me in an altered fashion, then why not just put an image intensifier camera in the eyepeice holder and stay inside and view it on my computer monitor.
And if I am going to do that, why not simply just view the thousands upon thousands of images available on the web and dispense with my telescope viewing entirely?
I am not at all saying it is in any way wrong for anyone else to choose to enjoy an electronically augmented reality.  That is not at all my intention with this response.
Rather, my intention is to say that while using electronic augmentation may be a great way to see the sky in a different way, it is a different way, and for me personally, much of the enjoyment is the challange of seeing targets and resolving them with my own two eyes.
is not "Cheating" to use an image intensifierIt is though to me, a completly different kind of activity.
If I were going to do it though, I could see myself doing it with a small refractor. In fact, I think I would rather do this than use my 6" APO with binoviewers.   Why bother with a big honking telescope on a heavy mount if you can see more in a small, inexpensive telecope on a simple alt-az mount?
I get that.  I really really do.   For $4000, you could see more than with the best 6" APO ever made.  How could that be bad?  Not for everyone, but I absolutly totally get the appeal.  Heck, just talking about it makes me wonder sometimes if I should one day take that step...
Edited by Eddgie, 12 November 2014 - 09:37 AM.
#156 Vondragonnoggin
Vondragonnoggin
Posted 12 November 2014 - 09:41 AM
You are definitely entitled to your opinion. I've seen the contempt about it though in plenty of other threads. Just as using a binocular telescope is binoviewing, so is using a PVS-7. It is a visual only experience for me. Uses the same concepts as traditional binoviewer with the added electronics part stuck in the middle. Equating it to sitting inside and looking at pictures on the Internet is quite a stretch in your condemnation of the technology.
It is the norm here on Cloudy Nights unfortunately.
#157 Vondragonnoggin
Vondragonnoggin
Posted 12 November 2014 - 09:43 AM
Oops. I replied to your post before you edited. Has a different tone now.
I also bought used and ended up spending about $2500 including the filters needed.
Compared to Binotron and accompanying gear, not a whole lot of difference.
Make no mistake though - not to be used on the moon or planets or tube damage may occur.
Too bright.
So, that, besides cost, is a big detractor. The thread was about DSO's though, which these excel at. The other major detractor is export laws. These cannot be exported overseas although if looking carefully, can find variants in other countries besides the USA.
Suitable variations to PVS-7:
NVG-7
NYX-7
PVS-7 comes in two types - older is PVS-7 A/C which has 25mm ER and newer is PVS-7 B/D which has 15mm ER. Actually 4 different models, but still only two types.
PVS-7 uses MX10130 tube and it's variations (MX10130C/UV, MX10130D/UV, MX10130A/UV, probably a few more depending on defense contracts at the time)
Other biocular variations:
PVS-4 with Wide Angle Eyepiece - a single eyepiece so wide you can use two eyes to view through single ocular. ER is very very long and allows you to comfortably view with both eyes. Nearly 4" of lens. Very rare to find now. I have one of these as well.
Russian Panoramic viewer - this is what was being sold with the Astronomy oriented BIPH and was coupled to a PVS-7 body. I think I would prefer to use the larger 25mm intensifier tubes as what is in the PVS-4. PVS-7 uses the 18mm tube and that is the reason for the approx 40° AFOV. The 25mm tubes appear more like a 60° AFOV and even more with wide angle EP on them.
This is all two eyed views through a single scope, although the PVS-7 type is really the closest to traditional binoviewer with beam splitter and all.
Edited by Vondragonnoggin, 12 November 2014 - 10:21 AM.
#158 De Lorme
De Lorme
Posted 10 February 2015 - 02:28 PM
I really liked the PVS-7 B/D when I had them. Using them on my CR6" made the difference. What I didn't like and is why I sold them was the noise, and
cost. The C14" brought in the globulars with the clarity I was looking for.
Although I'll have to buy the cheap Arcturus Binoviewers I can't wait to
use them on the C14". What really surprised me was using the Meade 56mm
on M13. I was anticipating M13 sitting further back into the field of view
but it was much closer and really great. So I'm excited on the
anticipation on what globulars will look like using the binos with the C14"
De Lorme
#159 Eddgie
Eddgie
Posted 10 February 2015 - 05:46 PM
C14 with Binoviewers is a great way to view Globulars.
#160 Procyon
Procyon
  • Loc: Eastern Canada
Posted 10 February 2015 - 06:25 PM
Great point!
De Lorme
"was the noise"
That was my first reason why I did not want to use night vision g's with a telescope, and the cost for sure. I wonder what view those would show looking out into the sea at night...would you be able to see around half a mile deep? Or even a 1/4 mile..
Good point guys about Globulars looking great in a C14...I'm sure they would!
With a focal length of around 4200mm which eyepieces do you plan on using for Globulars? A pair of 24-25mm? That would give you about 168x-175x magnification.
Edited by Procyon, 10 February 2015 - 06:28 PM.
#161 junomike
junomike
  • Loc: Ontario
Posted 10 February 2015 - 09:03 PM
I concur!  M13 (or M5/M3) offers an amazing view from, even at 400X (I prefer 200X).
#162 De Lorme
De Lorme
Posted 10 February 2015 - 11:44 PM
Procyon, I have to go the cheap route for awhile{like forever LOL}so I'm
going to buy another Meade zoom eyepiece to use with the Arcturus and a
1.25 diagonal. Awhile back I had a pair of the William Optics binos but sold them to finance a reflector. I can't tell you how many times I regret
selling them.
If your just looking at something down the street at night you really
don't see the noise. It's only when you point them to the sky with a
telescope that it becomes obvious.
If I wasn't able to finance the C14" I wouldn't have sold the PVS-7 though.
Looking at something in green{and noise}is better then seeing nothing at all
I have to remind myself that I will never be able to afford the Hubble
and so trying to be satisfied with what I got. I think it's a lost cause
though{LOL}. I think I need therapy{LOL}!
Had a lot of fun looking at the Double cluster last night. Really look
forward to all the other DSO through the Binos.
De Lorme
#163 Procyon
Procyon
Posted 11 February 2015 - 12:43 AM
selling them.
De Lorme
Do you find the Williams Optics Binos were better than the Arcturus ones?
I had a Meade Zoom, don't you find it insanely hard to twist to the next setting, I would not be able to handle them in binoviewers.
#164 De Lorme
De Lorme
Posted 11 February 2015 - 03:27 AM
Procyon I haven't bought the Arcturus binoviewers yet, but hope to soon.
The Meade zooms weren't hard to turn for me. It would be nicer{easier} if
they were the click stop like the Baader. I know others have had problems
seating the Baader zooms so I'll just have to wait and see how they fit.
#165 Vondragonnoggin
Vondragonnoggin
Posted 11 February 2015 - 05:09 AM
De Lorme
Were you using any filters with your PVS-7 and if so, what filters? I don't find mine noisy. There is some minor scintillation that happens, but the view is darkened considerably from the green of unfiltered. Globs come out looking pretty awesome in them with the right filter.
also, you seemed to have them only a very brief time before selling and getting the C14. Did you ever try narrowband Ha viewing or viewing with 695, 640, or 610 Longpass? When I can view the HH and flame from my white zone backyard with an AT72ED, it kind of overcomes the amount of scintillation. All the views we describe could be different from what a truly high spec tube with low EBI and low halo deliver with a very high S/N ratio. All tubes are not equal, that's for sure. Much like video, where certain chips are better or have a lot higher S/N.
Edited by Vondragonnoggin, 11 February 2015 - 05:16 AM.
