CLOUDY NIGHTS FORUM ARCHIVES
"Live Forums" can be found here: Live Forums
samsys
newbie
Reged: 07/27/07
Binoviewer and 10 Inch Dobsonian !!!!!! new
      #1763977 - 08/07/07 03:43 PM
Since last few days, I have been doing lots of research on binoviewers.
I have Zhumell 10 Inch Dobsonian and want to know if anybody has
used Binoviewer with Dobsonian...
If so, what's your experience? which binoviewer will go with my 10 Inch dob?
Do I have to add any accessories along with BV so that they will be compatible with Dob?
How's WO?
Really appreciate your response....Thanks in advance ....
15x70 Binocular
Binocular: 15x70 Skymaster
b1gred
Enginerd
Reged: 04/01/04
Loc: Castle Rock, CO 6677' MSL
Re: Binoviewer and 10 Inch Dobsonian !!!!!! new [Re: samsys]
      #1764077 - 08/07/07 04:27 PM
They will play nicely, but you may not have enough 'in focus', so you may need an optical corrector (sort of a low power barlow). The truss dob I'm looking at has adapters in the trusses to make it shorter for binoviewing.
"Dark Skies & Great Viewing"
RandyR / W0RDR
GPS 9.25 XLT/Sky Align /FeatherTouch
TV85 w/FeatherTouch
ndelo
Reged: 08/02/06
Loc: Light-polluted New Jersey
Re: Binoviewer and 10 Inch Dobsonian !!!!!! [Re: samsys]
      #1764453 - 08/07/07 07:27 PM
I use a Z10" and a Denk Standard (I have also tried a WO BV in this scope), and here are the specific issues I have run into:
1) You'll need an OCA. Your BVs will not come to focus otherwise, and the 1.6x OCA that comes with the WO BVs will not work. I got a PowerMag Wheel from Siebert optics, and it works fantastic. I have purchased both a 1x and 1.3x element for this setup, which means, with the 1x element screwed in place, I can switch between 1x-2x-3x; and with 1.3x element in place, I can switch between 1.3x-2.5x-3.5x.
While this may not be the setup you want to use, my experience with the PowerMagWheel gives me the impression that you may not be able to bring the BVs to focus with a 1x OCA (aka zero-mag) without upgrading your focuser to something with more drawtube travel. I have a low profile Moonlight CR2 with a 2.75" long drawtube and I can just reach focus at 1x with the focuser racked all the way in, and the OCA sticking into the light path. If you don't use the MagWheel, perhaps you'll have a different experience. A single mag OCA may not require the same focuser travel that the multi-mag wheel requires. But, alas, I've only used the MagWheel. Maybe others have experience they can shed on this subject. The focuser travel of the stock Z10 focuser was sufficient for me to use the 1.3x element.
Your best bet is to call Harry Siebert (he's a nice guy), if you want a decent OCA. Tell him what you have (a stock Z10, presumably), what you want, and he'll hook you up with an OCA solution.
If you don't use an OCA, you can barlow your BVs, but the magnification that this will produce will be too high to be usable on anything but planetary work.
2) Your BVs might be too heavy for the stock crayford focuser. This was a pet-peeve of mine and what led me to upgrading my focuser. I found that I always had to crank the focuser lock real tight to keep the drawtube from occasionally slipping inward. This, of course, made fine-tune focusing difficult. Then again, the added weight of the MagWheel might have contributed to this. You're mileage will vary depending on how much your BVs weigh, how much your EPs weigh, how much the OCA weighs, etc. I did not experience this issue using WO BVs with the included 20mm EPs, and a TV barlow. It was only after I upgraded to the Denks with the MagWheel that things started getting heavy.
3) You may need counterweights. Your scope will get very nose heavy. I purchased magnetic weights from scope-stuff and they work great. How many you'll need depends on how much stuff you have on the nose of your scope and how heavy your eye pieces are.
Once you get your BVs working, you'll love them. I use nothing but my BVs now and don't see myself ever giving them up. In fact, I almost exclusively use nothing but a pair of Siebert 24mm Ultras with the MagWheel. I've sold off almost all of my other EPs. I do have a pair of 24 Pans (fantastic BV EPs!), but the eye relief is too tight for me to use with my eyeglasses.
Anyway, that's what I went through in search of a nice BV/Z10 setup.
Hope this helps.
Edited by ndelo (08/07/07 10:06 PM)
Joe Ogiba
Reged: 02/14/02
Loc: NJ USA
      #1765466 - 08/08/07 09:40 AM
My Denk II works great in my XT10 Dob. I use the WO 2.5x APO 2" barlow or Denk 2x multiplyer to reach infinity focus. As long as the WO binoviewer reaches infinity focus with the 1.6x barlow it should work great.
Pentax PF-80ED,Meade 102ED APO,Orion EON 72,120ST
Apex 127,C6 XLT,CR150,C9.25,XT10 ,Celestron Regal 100 F-ED, CT152
Zeiss 7x42 FL,Canon 10x42L IS WP,15x50 IS
12x36 IS II , Pentax 8x32 ED
Garrett Optical 28x110 HD-WP Signature Series
Oberwerk BT-80 45, Apogee RA-88-SA
Denk II Power x Switch binoviewer w/13mm Ethos, 20mm Pentax XW's, 20mm Widescan III's.
21mm Ethos,17mm Ethos, 22mm Nagler, 40mm Pentax XW, 14mm Pentax XL, 5.2mm Pentax XL, 8-24mm Pentax XL Zoom, 31mm Axiom LX
Member #17
samsys
newbie
Reged: 07/27/07
Re: Binoviewer and 10 Inch Dobsonian !!!!!! new [Re: ndelo]
      #1765511 - 08/08/07 10:06 AM
Thanks much ndelo for your valuable inputs. Your reply pretty much gave me proper directions on what to do next....
David E
Reged: 05/25/06
Loc: North Carolina
      #1765864 - 08/08/07 12:54 PM
I think you will absolutely love using binoviewers with your Dobsonian! I use Stellarvue binoviewer with my 8" Zhummel. I had to purchase their BVA to get it to focus. This give me somewhere around 2x with my eyepieces (probably a little bit more perhaps). I use magnets to balance my scope with heavy eyepieces, and I put an 8" eyebolt on one magnet to help with the balance using the binoviewers. I thought that tracking would be harder with binoviewers, but this ended up not being the case. I did have to practice a bit, learning how to focus and adjust the binoviewers and where to position my eyes. But I quickly got the hang of it. Binoviewers on a big Dob- IloveitIloveitIloveit!
David E
David E
The funniest thing about this message is that by the time you realize it doesn't say anything, its too late for you to stop reading it.
Mozhoven
Reged: 05/26/05
Loc: Middletown, CT
Re: Binoviewer and 10 Inch Dobsonian !!!!!! new [Re: David E]
      #1771538 - 08/11/07 01:58 PM
I've used binos with my 8" EQ mounted Newt for years and have loved it! (except for serious balance issues and awkward viewing angles with slewing changes...) So recently, I sold my 8" favor of a 12" dob (XT12i). I had my reservations, specifically with worries about balance and access to focuser at various heights. (can't rotate the tube on a dob).
Well, I am very happy to say that I have had no issues on both counts. Luckily, the XT12i comes with a "correct-tension" knob that allows me to compensate for added weight at the focuser, and the natural "tilt" of the focuser seems to be perfect for almost any viewing angle.
You can probably solve the balance issue on your Zhummel (if there are any) with weights and/or a improved spring system.
The benefits of the larger aperture make the pairing of the two fantastic - OCS or not.
I was blown-away the other night with my first view of Jupiter through my 12"/bino combo. The seeing was terrible, but the view was spectacular. Tried it mono - not nearly as impressive.
Go for it.
Jeremy Davis
Sculptor & Certified Binoviewer Addict (CBA) (Ironically with no Binoviewer )
Orion XT12i - 12" f/4.9 "Alfred E. Newtonian"
Wyorock Custom Crayford
12x60 Oberwerk Binos
www.jdavisgallery.com
NickG
Reged: 11/06/06
Re: Binoviewer and 10 Inch Dobsonian !!!!!! new [Re: Mozhoven]
      #1775920 - 08/13/07 11:19 PM
I have a 10" dob which is used with WO BV'er set. It needs a better OCS than the one WO supplies (1.6X), to get enough inward focus on Newtonians especially.
Got a Seibert multimag (1.25X/ 2X/ 3.5X) which works a treat. Works in all my Newts and refractors with this OCS.
Must say though, I'm not a complete convert to binoviewing yet, enjoyable and comfortable as it is, I see a loss of detail when looking at planets compared with cyclops mode, even though I have some excellent eyepiece pairs (Pentax and Tak), so maybe the BV'er is the problem and I need a better one. (Denk II?) Also a loss of image brightness too of course,
CS
Nick
0 registered and 2 anonymous users are browsing this forum.
Moderator:  EdZ, jrcrilly
