CLOUDY NIGHTS FORUM ARCHIVES
"Live Forums" can be found here: Live Forums
Photon
Reged: 03/10/06
Loc: Aurora, Colorado, USA
How do you illuminate your sketch pad?
      #2059322 - 12/18/07 01:46 PM
I want to do some sketching, well very basic drawing at this point. But, I need to find some convenient way to illuminate my paper, preferably a red light. I assume you've all solved this problem, but how. All advice welcome...
Thanks, Pete
Orion 120mm f/5 achro refractor
10" Homebuilt Dob for backyard use
5.1" Newt on equatorial mount in the RV
Telrad finders on both
Celestron Nexstar 6SE
7x50 Oberwerk binoculars
bethebestteacher.com
bchase
Reged: 10/04/07
Loc: Conway AR
Re: How do you illuminate your sketch pad? new [Re: Photon]
      #2059411 - 12/18/07 02:31 PM
I use a red LED light from Wal-Mart, it's made for strapping around your head, but I took the straps off and the plastic the straps attached to fits under a clip-board nicely. I also clear taped a strip of paper towel across the LED to tone it down a bit. I'm cheap so didn't buy anything just used what I had.
One of those book lights with a red transparency taped over the white light might work better. Hobby Lobby here sells a red transparency (I guess it's some sort of wrapping paper) which I use a couple layers for to tape over my laptop.. It's still too bright but would probably work better if I used 4 or 5 layers.
Orion StarQuest 8" - f/5.9
Orion 100mm ED - f/9.0 - Atlas EQ-G
8x40 Nikon Binos
rodelaet
Reged: 04/28/06
Loc: 50°56' N - 4°58' E (Belgium)
Re: How do you illuminate your sketch pad? new [Re: bchase]
      #2059515 - 12/18/07 03:13 PM
Pete,
I feel good with a little Petzl led light. It comes with a head strap. When I sketch, I use the strap around my neck, so the light rests on my chest, illuminating everything in front of me except the eyepiece I look into. I cannot look into the lightbeam. I never get blinded this way and changing eyepieces or filters is a breeze to do.
Rony
'The Casual Sky Observer's Guide.'
My Astronomical Sketches
My Binocular Sketches
Callibrate your Monitor with this little strip.
Reged: 06/13/06
Loc: Illinois
      #2059523 - 12/18/07 03:20 PM
As Barry above has said I also use a "geek" light with head straps. I have a red filter cover for the maglight. I also use two clip on lights for my clip board. I originally bought these for tying on flies while fishing
at night. I also made a flat standing light with a brightness control I made from the volume control off an old car radio. I can set this on the clipboard while sketching. Clip on battery powered light sold in bookstores also work well.
Frank
My Gallery
Rogerio
Reged: 09/01/07
Loc: Salvador; BA; Brazil
Re: How do you illuminate your sketch pad? new [Re: frank5817]
      #2059727 - 12/18/07 05:12 PM Attachment (161 downloads)
I use this. it's a headlamp.
8'' F6 Dob - ATM
8'' F8 Dob - ATM
Pentax PFC WPII 20X60; Pentax PFC WPII 8X40
24Pan; 16T5Nag; 10Rad; 7XW
rolandlinda3
Reged: 01/24/06
Loc: Crozet VA 22932
Re: How do you illuminate your sketch pad? new [Re: Rogerio]
      #2060186 - 12/18/07 09:17 PM
if your location to sketch is relatively fixed, you can also use a low wattage outdoor flourescent on a desk type lamp but shield the lamp to obtain your desired amount of light. The light tends to be even and will spread as far as you let it. It does not produce enough heat to be a concern when using a towel or piece of cloth to mask the light. Little metal clamps or strong clothes pins act as your variables to change the location or extent of footprint. When we are doing sketches that need some reasonably fixed and even light, this is what we do. Otherwise, like the others have said, a simple headstrap light works great.
Roland
Roland
Blog: www.rolandlinda3.wordpress.com
Older sketches in Members Galleries (rolandlinda3)
For other sketches/inspirational stories: contact me via PM for information
WadeVC
Reged: 12/02/05
Loc: Lodi, California,
      #2060580 - 12/19/07 12:35 AM
I use a Mini-MAG flashlight. I replaced the lens cover with a piece of red plastic I cut from an old tennis ball can. It give me a nice gentle red light without being too harsh. The size allows me to either hold it between my fingers while sketching.
It fits in my pocket nicely when not in use, is not cumbersom; and is easy to operate with gloves on.
Orion XTi10 f/4.7
Orion XTi8 f/5.9
Meade NGC 70mm f/10
Orion UltraView 10x50 Wide-Angle Binoculars
My Sketch Gallery
My Astronomy Blog
A wise man can see more from the bottom of a well than a fool can from a mountain top.
pike_fly
Reged: 10/10/07
Loc: Roxborough Park, Colorado
Re: How do you illuminate your sketch pad? new [Re: WadeVC]
      #2074700 - 12/26/07 10:11 AM
I use a red LED headlight found at Home Depot for $14.95. It pivots so I can aim the light in different directions as I observe and sketch (high in the sky when looking through the eyepiece and low when sketching). I tried other methods of attaching red lights to my clipboards (many mentioned above), but there seemed to be too many shadows and I did a lot of double checking to see if I already drew something.I didn't like rotating the clipboard just to draw a dot...but that's just me.
Lee
10" Zhumell Dobsonian
Class 4 Bortle Scale Backyard Site
View Lee's Gallery
JoeF
Reged: 03/18/05
Loc: 'Sunny Loftus' - N E England
Re: How do you illuminate your sketch pad? new [Re: pike_fly]
      #2076516 - 12/27/07 05:07 AM
As I use a reflector I use a red headtorch with the straps around the tube so the light 'hangs' just under the eyepiece. So long as objects are not too close to the zenith it can usually be adjusted to light up my notebook nicely.
Another alternative, I forget the name, are small red Leds with built in battery as used by fishermen to. These have a push switch and last for a quite a few sessions. They can be taped to your pencil - ideal for quick notes with one HB but not for complicated drawings where you are using a number of pencils.
I dont like wearing torches on my head, or peaked caps for that matter as they always seem to bash into the eyepiece!
Ideally have 2-3 torches. A dim red sketching light, medium red headlamp for general use and a bright white light for packing up. Also IMO the Led torches are much better than the old bulb type as the batteries last so much longer.
Joe
Orion Optics 200mm f6 & Accufocus on GP/E Mount
Opticron BGA 10x50 Binos
NELM 5.2 rural skies
Under tripod canine footwarmer
Erix
Toad Lily
Reged: 12/25/04
Loc: Texas, USA
Re: How do you illuminate your sketch pad? new [Re: JoeF]
      #2076856 - 12/27/07 10:43 AM
I use a headlamp too that I dangle from the eyepiece holder. Sometimes I hold it in my left hand along with the clipboard instead for keeping out glares of the pencils if I use that medium for stars.
The headlamp has both a red light and a pale blue light. I use the blue for planetary and lunar, red for DSO's and sometimes planetary. If the red is too bright, I put layers of sports tape over it until it is the brightness I'm happy with.
I used to put the headlamp on my head, but it not only created problems for others that were viewing with me, it also created a glare in my eyes from the reflection off my scope when I'd put my eye back to the eyepiece. In other words, it got in my way.
Currently, I'm leaning towards a better handheld lamp that I can also hand from the eyepiece holder, or lamp that will clip to my clipboard.
Erika
Automatic doors make me feel like a Jedi.
Zhumell 16", 10" LX200 Classic,Celestron 102 XLT, ETX70-AT, DS Maxscope 60mm, AT6RC
PCW Memorial Observatory
bicparker
Reged: 02/07/05
Loc: Plano, TX
      #2077011 - 12/27/07 11:56 AM
I use a variety of lights, but they all have a few things in common:
1) Variable intensity that can be reliably taken to a very dim level.
2) I have velum or other light flattening material so I get an even level of light. I cannot over-emphasize how important this is, especially if you are sketching dim faint fuzzies as opposed to planets.
I have found that most lights/lamps have severe gradients/shadows in their output, often created by the lens, reflector, lamp, and a combination of all of the above. When you are sketching faint objects and they fall into one of these shadows on your paper, it adds a lot to the difficulty of sketching.
I personally don't use headlamps for a couple of reasons: 1) I don't want to inadvertently look up into someone else's eyes with it (that has happened to me too many times), and 2) Sometimes I look (i.e., face my head) towards a reflective piece of metal, so the light goes right back into my eyes.
The first one is bad for others, the second is bad for me.... so.. no headlamp.
David Moody, FRAS
17.5" f/5 dob
10" f/10 SCT
5" f/8 refractor
80mm f/6 refractor
66mm f/6 refractor
Plus a few others out of the rotation
o1d_dude
o1der than dirt
Reged: 10/03/07
Loc: The Wolfpack
Re: How do you illuminate your sketch pad? new [Re: bicparker]
      #2216778 - 02/24/08 11:41 PM
Sorry for the thread necromancy here but I've been looking for this information for some time now but the search feature never brought up this thread, nor is is listed in the sketching sticky.
I recently purchased two clip-on LED book lights at a Harbor Freight-like store in my neighborhood for $1.50 each. I'm still working on modifying them to provide red light. I may have to install the guts in another type of enclosure to eliminate stray light which is the problem now.
I like the idea of mounting a headband on a clipboard but wonder if that wouldn't be too bright. We'll see.
Kit
'Don’t worry about what telescope you own, or its quality. Just get out under the night sky, and enjoy God’s wondrous universe.' - Thomas M Back
markseibold
Reged: 01/19/08
Loc: Portland Oregon
      #2613329 - 08/30/08 11:19 AM
Thanks, Pete
As I found this thread accidentally today, I find it interesting that with all the advice here, no one mentions the fact that using red light causes a misrepresentation of color, that is, if you are concerned about proper color rendition in your artwork. One would have to assume that many artists here are working in only black and white if they use red lights to do their sketching artwork by.
Have you ever looked at a multicolored image, say a photo under red light? You will notice that all red portions of the printed photo appear as white under a red light. Light is an amazing thing in this universe as to how it responds in appearance under any less than pure white light- Which is of course as you know, white light is the combination of the total spectrum of all light. Conversely, a color such as blue appears as black under red light. For other colors, the range is nominal and wide ranging yet inaccurately rendered as seen under a single colored light such as red.
We have had many discussions locally with other serious astronomers and astronomy teachers over the years about this over-preponderance to religiously adhere to red lights for astronomy work. It has been found to be beneficial to simply use a standard flashlight with newspaper or other similar white or brown paper bag material taped over its lens to simply dim the white light and enjoy accurate color rendition of whatever the light is pointed at; a star chart, a photograph, etc. while working in the dark. We have agreed time and again that there is an over-concern about using the color of red lights to maintain dark adapted eyes. It has been tested to show that the visual purple chemical in the retina of the eye that is responsible for dark adaption of the eyes, is not necessarily sensitive to any color of light but rather that the light used while maintaining dark adaption is kept significantly dimmed.
With that said, I prefer to use as natural to white light as possible while sketching and to keep it dim and at a distance so as to not blind my dark adapted eyes. I use a small standard desk lamp kept pointed down almost as if to obscure the lamp by burying it down to near the tabletop, also to adjust whatever color on the tabletop is just below the light, say a sheet of white or black paper reflecting, allowing only a small portion to stray extraneously to my artwork. Also an occasional smaller LED astronomer’s flashlight which can be mounted to the table top nearby or just simply hand held at times. If at the desk lamp at a distance, I want to see more fine detail in my work, I simply move the work briefly from the board cradled in my lap, nearer to the light and then draw back to my adjusted seated distance again where I work at the eyepiece. This seems to reflect a natural feeling while working, rather than have the headlamp dancing around, the artists neck and head having to perform extra physical feats of ‘light pointing acrobatics’ which I believe will eventually annoy the artist with unnecessary light motion which becomes unnatural and physically fatiguing to the neck, head and thus also to the mind while working in the dark has already initially added to the labor intensive artwork process. I use the ‘less is more’ approach. Some renaissance artists worked by candle light. To see an old world image of the head mounted lights, see the famed and highly respected movie, Lust for Life with Kirk Douglass playing as Van Gogh. He wears a candelabra on his head at night while painting under the stars. There are other untold advantages for new artists to see this movie if they have not. It will humble you to no end as an artist. There is much to be learned from it.
I have never been thrilled by wearing a light on my head as it dances all over and as one respondent Bic mentioned here, you could inadvertently and accidentally aim it at others eyes. Unless you operate totally alone while sketching as I prefer to concentrate on art while alone, the head mounted lamp I would still find as annoyingly not like working under a constant and natural ambient light as aforementioned above.
But then, in the material world of abundance of products we feel compelled to own every gadget that becomes available- The overstuffed pocketbook will dictate to every ones every whim.
I tend to be old-world-old-school and now you have me thinking of working as many renaissance artists did, by candlelight again although that is a bit warm in color. Add more candles to adjust to desired whiter light effects perhaps.
I hope this helps; please RSVP!
Mark
JanisR
newbie
Reged: 06/26/08
Loc: Pennsylvania
Re: How do you illuminate your sketch pad? new [Re: markseibold]
      #2613585 - 08/30/08 01:39 PM
I use red light to do do white/black sketching, and when I want to do color work, as for planets, I work under red light using *labeled* pastel pencils - ya gotta really know your colors to do this - then periodically pause to examine the drawing under *white* light just to make sure I am on track. This does cost me time for readapting, but I'm also old-fashioned, and I prefer to do all my work at the eyepiece.
I learned this lesson about labeling my pastel pencils the hard way. I once worked on a drawing of Jupiter for several hours, only to discover that what I assumed was brown was actually green. The result was, er, interesting.
JanR
8" f/7.8 Criterion Custom Deluxe Dynascope
6" Criterion Dynascope
80mm Stellarvue ED
105mm Stellarvue APO
Coronado PST
Meade 60mm EXT
My CN Gallery
Erix
Toad Lily
Reged: 12/25/04
Loc: Texas, USA
Re: How do you illuminate your sketch pad? new [Re: JanisR]
      #2614268 - 08/30/08 09:50 PM
Something that people can keep in mind though, is that lunar and planetary don't generally require dark adapted eyes. Therefore, if you wanted to use color with them, you could use a white light to illuminate your pad.
Erika
JanisR
newbie
Reged: 06/26/08
Loc: Pennsylvania
Re: How do you illuminate your sketch pad? new [Re: Erix]
      #2614788 - 08/31/08 09:46 AM
I agree. I have often thought the red light was probably unnecessary for making color sketches of planets. I've never used white light while sketching myself, but that is mostly due to the fact that I tend to observe in the company of other amateur astronomers and the "red light rule" is in effect.
It would be fun to experiment with different types of light, to see just if/how each variation in light changes the image.
JanR
80mm Stellarvue ED
Coronado PST
Meade 60mm EXT
My CN Gallery
Erix
Toad Lily
Reged: 12/25/04
Loc: Texas, USA
      #2614900 - 08/31/08 11:06 AM
... I tend to observe in the company of other amateur astronomers and the "red light rule" is in effect.
Ah, now there's a good point. I observe mainly by myself or with my husband. He's an imager, so when we go to the observatory, he doesn't need to look through the eyepiece of his scope since it's already aligned and ready to go on the pier.
When I go to star parties, I only use a red light.
Do you find it distracting to sketch at star parties? I have a very hard time sketching because there are so many others around to share views or I'm off comparing views through other's scopes.
I'm still experimenting. I just bought a hand held one that works very well. I need to put a film over it since it tends to "bullet" the illumination.
Different sketch media affects the illumination as well. For example, graphites tend to shine, sometimes making it hard to see the markings on the paper.
Erika
JanisR
newbie
Reged: 06/26/08
Loc: Pennsylvania
      #2617131 - 09/01/08 02:42 PM
[quote. Do you find it distracting to sketch at star parties?
Many group observing sessions are very quiet events, where everybody has their own scope and agenda for the evening. If I plan to make a drawing, I pretty much attend to that exclusively until it is either finished or my brain is fried. (It's funny how short a time that is!) In general, my companions are content to leave me to it, so the only interruptions are usually calls to see some "wow" object in someone else's scope. My own 8" Dob is *by far* not the biggest scope in use at these sessions, which also tends to explain why I get to work in peace.
I make it a rule not to look at the object I am currently sketching through any other scope than my own until after I am finished with it. What's *really* difficult is resisting the temptation to go back and "tweak" that little sketch of mine once I've seen it through somebody's Really Big Dob or Refractor, so once I've closed the sketch book on a drawing, it stays closed for the rest of that session.
Now, public star parties are a *whole* different story...
JanR
80mm Stellarvue ED
Coronado PST
Meade 60mm EXT
My CN Gallery
Odin
Reged: 03/21/07
Loc: Ont, Cdn 46N 84W
      #2631760 - 09/08/08 10:22 PM
I use a pen light, when the pen is pushed down on the paper the whole assembly glows red shining down onto the paper.
only a buck at the dollar store.
A time will come when men will stretch out their eyes. They should see planets like our Earth.
- Christopher Wren
LX90 8" EMC
Rigel Quickfinder
ETX125PE UHTC
60mm Refractor Meade Digital Series
Meade Electronic Eyepiece
32mm,26mm,15mm,9.7mm series 4000 Super Plossl
20mm Garrett FMC SWA, Meade 2x Barlow
10x50 Tasca Binoculars
rodelaet
Reged: 04/28/06
      #2635327 - 09/10/08 04:26 PM
Me too, I can hardly concentrate will all the buzz going on. Last time, I had the Sky Window with me. It got some pretty attention by several observers. And once they took place behind the bino's, they grew very silent. I had little time to observe myself, but enjoyed the oohs and aahs from the visiting observers behind my simple bino's.
Rony
0 registered and 7 anonymous users are browsing this forum.
Moderator:  Charlie Hein, cildarith
