CLOUDY NIGHTS FORUM ARCHIVES
"Live Forums" can be found here: Live Forums
Atlas Tripod Issue: Repair Suggestions?
      #3077955 - 04/30/09 09:42 PM
Hi. Last Saturday I noticed that one of the black, pointy aluminum feet on my Atlas tripod was loose. I could rotate it on the stainless steel tripod leg. I'm assuming these fittings are glued in place. What sort of adhesive ought I to use to re-secure it? (Bonding cast aluminum to stainless steel.)
- Jim
I observe vicariously, through myself. When I purchase a new telescope, it's value increases. At star parties, attendees line up to observe me. My observing philosophy: Find out what it is that your telescope doesn't do well, then don't do those things. At historic observatories I am allowed to touch the equipment. My legend precedes me the way the Big Bang precedes everything else.
- The Most Interesting Astronomer in the Universe
Edited by jrbarnett (04/30/09 09:43 PM)
Scott BeithAdministrator
SRF
Reged: 11/26/03
Loc: Frederick, MD
Re: Atlas Tripod Issue: Repair Suggestions? new [Re: jrbarnett]
      #3077992 - 04/30/09 10:00 PM
jbweld bonds everything.
SLAP Observer --- TMB130SS, SV102V(LOMO Lens), SV80ED Deluxe
"The only thing necessary for the triumph of evil is for good men to do nothing." -- Edmund Burke.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- George Orwell
"The measure of a mans greatness is not determined by what he accomplishes for himself, but by what he accomplishes for others. -- Some Bald Guy
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: Loc: Loc:
Re: Atlas Tripod Issue: Repair Suggestions? new [Re: Scott Beith]
      #3078237 - 05/01/09 12:35 AM
JB Weld rocks! Can't go wrong with that stuff.
Kerry
Re: Atlas Tripod Issue: Repair Suggestions? new [Re: Sky Captain]
      #3079108 - 05/01/09 01:59 PM
Thanks Gents, JB Weld is is then.
It's raining today (and all weekend) so I may as well fix 'er up.
jim molinari
Reged: 02/02/08
Loc: California
      #3079453 - 05/01/09 04:55 PM
Did you check to see if there was a set-screw to tighten it?
Jim Molinari
20" Spica Eyes Slipstream
14.5" Starmaster
180mm Orion Mak Sirius EQ-G
Telescopeman54
Vendor - Trapezium Telescopes & Services, LLC.
Reged: 08/17/07
Loc: New Hampshire
Re: Atlas Tripod Issue: Repair Suggestions? new [Re: jim molinari]
      #3079493 - 05/01/09 05:21 PM
I'd use contact cement because if I ever needed to remove the foot to service the leg it could be done. JB weld will not allow you to do that. Once it's on, it's on for good!
Steve
Stephen Forbes - President
10013 Calle de Palencia
Navarre, FL 32566
1.850.736.3559 (Cell)
Web: http://TrapeziumTelescopes.com
Email: Stephen.Forbes@TrapeziumTelescopes.com
Phone:1.850.736.3559
A whole bunch of stuff mostly mounted on a Mini Tower Super Charger.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: Loc: Loc:
Re: Atlas Tripod Issue: Repair Suggestions? new [Re: Telescopeman54]
      #3080653 - 05/02/09 09:34 AM
Steve
Actually, JB Welded pieces can be removed if needed. I have had to do it several times over the years. Of course it does depend on the media being joined together. In this case both are metal...this removal can be done by heating both pieces with a propane torch. It depends on how much JB was used too, but generaly just 250 to 350 degrees will soften the JB product. It will become soft and both pieces will come apart.
Of course you will need to wear thick leather gloves so as not to burn yourself and \ or a clamping devise to hold each piece.
Kerry
Reged: 07/06/07
      #3080887 - 05/02/09 11:23 AM
There are no screws. All the Celestron/Synta leg tips are glued on and will fall off eventually. I used Superglue, but JB is prob'ly better.
Uncle Rod
Rod's Latest Book:
Choosing and Using a New CAT
Uncle Rod's Astroblog: http://uncle-rods.blogspot.com/
StarStuff1
Reged: 04/01/07
Re: Atlas Tripod Issue: Repair Suggestions? new [Re: rmollise]
      #3082485 - 05/03/09 10:18 AM
I haven't had good luck with Superglue or JB. Better luck with epoxy. Just about my favorite adhesive for non-woodworking use is Goop. It will bond most anything to anything. Parts can be separated by wicking some acetone on the joint-the Goop will temporarily soften. Do NOT use Goop on telescope mirrors.
Tools that make objects very far away appear much closer than they actually are.
0 registered and 131 anonymous users are browsing this forum.
