CLOUDY NIGHTS FORUM ARCHIVES
"Live Forums" can be found here: Live Forums
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Anyone control the HEQ5 from a PC with TheSky6?
      #3128339 - 05/26/09 02:08 PM
I posted this problem in the sofware section with no luck so I thought I would try posting it here:
I setup my CGEM to be controlled by TheSky6 from a PC and it works perfect. But I decided to try it out on the Orion Sirius (HEQ5). Everything works fine except I keep getting this error message after every slew command. The slews work and go to the right place and the ra/dec coordinates appear on the hand controller so why the error?
This is the message:
NO RESPONSE FROM THE DEVICE ERROR CODE = 203 (0xcb)
I can just ignore the error and everything is ok but it is kind of annoying having to do that after every command. I would also like to know that this will go away if I upgrade to the TheSkyX ?
There is no specific selection for Sirius or HEQ5 in the list of compatible telescopes for the TheSky6, but I was told that it should work if I select CG-5. I select CG-5 for the CGEM and it works great. I have actually tried controlling the HEQ5 with just about everything in that list but either get no connection or I get that error message.
Peds
Reged: 03/07/07
Loc: Brasília, Brazil
Re: Anyone control the HEQ5 from a PC with TheSky new [Re: Lane]
      #3129412 - 05/26/09 11:54 PM
It works perfect with my Atlas EQ-G which is similar to your Sirius... Have you updated the hand controller? Are you connecting the mount from the controller to the computer using a serial cable?
I'm currently connecting my Atlas to the computer through the go-to hand controller with a serial cable and a usb/serial adapter. All I have to do to get it working is choose the appropriate COM port and then select "Nextar GPS", I believe, from the choice of mounts.
P.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: Anyone control the HEQ5 from a PC with TheSky new [Re: Peds]
      #3129426 - 05/27/09 12:08 AM
Peds, it sounds like we are connecting in the exact same way, but I have never updated the hand controller and I have had this mount for about 1.5 years, so that could be the problem. Do you know off hand what version you are on?
PS - I did try Nexstar GPS and got the same error.
Edited by Lane (05/27/09 12:11 AM)
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #3129505 - 05/27/09 01:38 AM
Thanks Peds
Your suggestion worked. My hand controller was on version 3.01 and I just updated to 3.24. Now TheSKY6 is able to control the mount with no error messages in the way.
Peds
Reged: 03/07/07
      #3130527 - 05/27/09 03:49 PM
I'm glad it is now working for you! 3.24 is the latest version.
P.
0 registered and 32 anonymous users are browsing this forum.
