CLOUDY NIGHTS FORUM ARCHIVES
"Live Forums" can be found here: Live Forums
kpendlebury
Vendor Main Sequence Software
Reged: 11/12/08
Loc: Central TX
Celestron ASGT (CG-5) Counterweight Compatibility
      #3222650 - 07/17/09 12:47 AM
Hi All,
I am a new GEM owner. I received my CG-5 today and was going through the balancing procedure. Upon picking up the 11 lb counterweight to balance out my 6 lb scope, I knew things were going to turn out badly.
My question is: Is anyone aware of smaller weights that are compatible with the ASGT?
I searched the forums for a bit and found a thread that was about 3 years old indicating that the Stellarvue M6 weights and some generic weights from scopestuff would work. Unfortunately the SV weights are 8.5 lbs which I think is still too heavy and it appears as though scopestuff no longer sells small ASGT weights.
I think a weight between 5 and 7 lbs will work nicely, but cannot find one anywhere.
Any advice or thoughts here would be greatly appreciated.
Ken
Ken
Try Sequence Generator Pro! Image capture software for CCDs and DLSRs with Plate Solving and Auto Focus support.
My Photo Stream
Stellarvue SV105T
Takahashi EM-200 Temma 2
QSI 683WS-8
Deven Matlick
Vendor - Criterion Machine Co. LLC
Reged: 12/31/05
Loc: Moatsville, WV
Re: Celestron ASGT (CG-5) Counterweight Compatibil new [Re: kpendlebury]
      #3222659 - 07/17/09 12:51 AM
There was a EQ-3 weight in the range you are looking for that would fit. Or one could be made.
Sincerely,
Deven Matlick
"We Meet Your Criterion"
Rt 1 Box 253A
Moatsville, WV 26405
www.criterionmachine.com
neptun2
Reged: 03/04/07
Loc: Bulgaria
Re: Celestron ASGT (CG-5) Counterweight Compatibil new [Re: Deven Matlick]
      #3222737 - 07/17/09 02:21 AM
Why don't you just measure the counterweight shaft diameter and look for compatible counterweights?
Photo: Sony NEX-5N + 18-15 , Nikon D90 modified, Meade DSI Pro 2 as guider, TS 9mm off-axis guider
Binoculars: Nikon Action 12x50
Telescopes: Skywatcher Evostar 120ED f7.5 APO + TS 2" flattener
Mounts: HEQ5 Pro
Eyepieces: Nagler 11mm type6, Pentax XW 7mm, Televue 2X barlow 1.25"
Eddgie
Reged: 02/01/06
Re: Celestron ASGT (CG-5) Counterweight Compatibility new [Re: kpendlebury]
      #3222912 - 07/17/09 07:30 AM
Not sure at all why this would be a problem. The CG5 can easily handle the weight.
That being said, if you want smaller weights, Orion used to sell a weight that was about 5 lbs. It was very thin.
I personally prefer the Vixen GP weights. These are much smaller diameter than the Celestron and Meade weights. Also, the hole is smaller on one end than the other. The reason Vixen did this was so that you could put the weith on the shaft with the smaller hole facing up. Now, the "Bottom" hole was big enough so that it would allow the weight to be slid down so the bottom was PAST the safety screw. This put the weight further away allowing you to sometimes use a smaller weight and still get balance. There is a Vixen 2.8 KG weight available (about 6.5 lbs). There is also a 1 KG weigh (about 2.2 lbs). I really like the Vixen weights, but they are expensive.
The Vixen CW is my favorite kind of weight for this class mount.
Good luck.
Celestron CGE 1400
Astro-Physics 6" f/8
Celestron EdgeHD C8
Antik AR1/Revenge Plates/Heartless Voodoos
The night sky is my mistress. She seduces me away from all other lovers.
GaryML
Reged: 02/16/09
Loc: San Diego, California
      #3223072 - 07/17/09 09:55 AM
The CG-5 counterweight shaft is the same size as the Meade LXD55/75 and the Vixen GP2/Sphinx. Anything said to be compatible with these mounts should work. As Eddgie pointed out, Vixen makes some lighter CW that will fit and they are good quality.
The Scopestuff CWs for the CG-5 are small 1 lb weights that screw into the the end of the shaft in place of the safety screw, so they are sometimes called "toe saver CWs." You can use up to three of them and their main purpose is to allow fine balance when one regular CW is not enough but two is too many. Even with three 1 lb weights at the end of the shaft, I think it may not be quite enough to balance your scope.
Sky conditions in San Diego, California:
Celestron NexStar 8 SE
Nikon 7x50 IF SP Binoculars
______________________________________________________
Avatar: Gemini North on Mauna Kea, November, 2008.
2 registered and 165 anonymous users are browsing this forum.
