CLOUDY NIGHTS FORUM ARCHIVES
"Live Forums" can be found here: Live Forums
bcuddihee
Reged: 11/04/06
Loc: Cincinnati Ohio
2" leg upgrade on a CSE mount...anyone?
      #3285537 - 08/21/09 08:51 AM
I was hoping to retrofit my C8SE mount with the larger diameter 2" stainless steel legs instead of the 1-1/2" inch ones it comes with. I feel it would add greatly to the stability of this mount. Has anyone done this and which legs from what mount would be interchangeable. I had at one time a Skyview pro mount and from what I remember those loegs would seem to do the trick. Anyway, I'd appreciate hearing from anyone who has upgraded their c8se mount in this way. Thanks bc
B Cuddihee
1968 Jason Empire 60X700mm refractor
1977 Jason Empire 313 discoveror EQ
Celestron Nexstar8SE "The Bumblebee", with Feathertouch Microfocuser, and
Celestron CPC Heavy Duty Tripod.
Antares 89mm finder
Stellarvue 50mm "Sparrowhawk" finder
Denk bino's with Power x switch.
Pair of Edmund 15 and 28 plossls.
Pair of Edmund 28 RKE'S
Pair of 32mm Brandons.
Pair of 24mm Brandons.
Pair of Smart Astronomy 19 EF's.
pollux
artiste
Reged: 04/01/04
Loc: Burnaby Canada
Re: 2" leg upgrade on a CSE mount...anyone? new [Re: bcuddihee]
      #3285657 - 08/21/09 10:15 AM
can you post a photo of the tripod (espeically the hub)?
need to make sure it is the same (or similar) one I dealt with before
if so I have a solution but it will cost some $$$$
My Web Site
bcuddihee
Reged: 11/04/06
Re: 2" leg upgrade on a CSE mount...anyone? new [Re: pollux]
      #3285845 - 08/21/09 12:13 PM
Pollux, here is the hub.
B Cuddihee
Antares 89mm finder
bcuddihee
Reged: 11/04/06
      #3285846 - 08/21/09 12:13 PM Attachment (26 downloads)
oops
B Cuddihee
Antares 89mm finder
pollux
artiste
Reged: 04/01/04
Loc: Burnaby Canada
      #3285848 - 08/21/09 12:14 PM
Need a bottom view.
My Web Site
bcuddihee
Reged: 11/04/06
      #3285852 - 08/21/09 12:20 PM Attachment (24 downloads)
another
B Cuddihee
Antares 89mm finder
pollux
artiste
Reged: 04/01/04
Loc: Burnaby Canada
      #3285865 - 08/21/09 12:28 PM Attachment (24 downloads)
Very easy solution.
All you need is to buy a set of 2" steel leg for either Meades' LXD75 or Antares EQ5 (tripod alone if I am not mistaken it's around $200 new. Used of course is a lot cheaper)
Take the leg out and install it to your C8's hub. The width is 99% the same. Depending on your case you may need *very* little shimming or filing. But in the three transplants I have done require none.
My Web Site
1 registered and 208 anonymous users are browsing this forum.
