CLOUDY NIGHTS FORUM ARCHIVES
"Live Forums" can be found here: Live Forums
DCS357
Reged: 10/20/08
Loc: Lubbock, Tx
CG-5ASGT CGEM Pier mount
      #3312030 - 09/03/09 12:56 AM
I am having a plate machined for my CG5 to be mounted on a pier in my back yard. Was wondering if a CGEM would fit on the same plate or is there some difference in the way a CGEM attaches to the tripod than a CG5 would? Kind of looking to get a CGEM and would be happy if it would mount the same way as my CG5.
thanks
don c
TV NP101
Celestron 9.25 SCT
Astro-Tech AT8IN F/4 Imager
AT72ED
Celestron Omni XLT 120
CGEM, CG-5ASGT, Voyager Alt-z
Orion 100mm f\6
Hyperion 17, 8-24 Zoom
Canon T2i,450Xsi,30D,20D
Obs in backyard
Charlie HeinAdministrator
Reged: 11/02/03
Loc: 26.06.08N, +80.23.08W
Re: CG-5ASGT CGEM Pier mount new [Re: DCS357]
      #3312295 - 09/03/09 06:46 AM
Since the base of the CGEM is quite a bit larger than the CG-5. This means that the azimuth adjustment bolt will be further out from the center hole than it is with the CG-5.
You *could* design a larger plate with two holes for the AZ bolt to deal with this...
Weston CSC:
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: CG-5ASGT CGEM Pier mount new [Re: Charlie Hein]
      #3312914 - 09/03/09 01:04 PM
Don, If you're poking around for info keep an eye out for specs on the Atlas/EQ-6, the base of the CGEM is the same as the Atlas.
Mark
C11, C6, APM/TMB115, and AT80ED - Pier mounted CGE in a POD, and CG-5A, WO EZ-Touch and AT Voyager
25x100s and 8x56s, T-Mount Light, Mark 1 eyeballs - 350Da, DSI-P, SPC900, NexImage, Mallincam
Just because you can doesn't necessarily mean that you should
      #3313543 - 09/03/09 07:00 PM
Nope.
I have an Atlas and a CG5-GT, and an adapter that allows me to mount the Atlas into the top of the Orion SVP pier extension. The Atlas base and CGEM base are "pin compatible."
I had hoped that the adapter would allow me to mount the Atlas on mt Antares Pier (which is currently configured for a CG5-GT), but alas no. The three bolt tappings that hold the adapter in the Pier do not match up with the holes drilled into the Pier for the CG5-GT adapter. The Atlas adapter mounts "deeper" down the throat of the Pier. I plan on drilling an extra set of holes equidistant between and below the existing holes to make the Pier "dual use".
I observe vicariously, through myself. When I purchase a new telescope, it's value increases. At star parties, attendees line up to observe me. My observing philosophy: Find out what it is that your telescope doesn't do well, then don't do those things. At historic observatories I am allowed to touch the equipment. My legend precedes me the way the Big Bang precedes everything else.
- The Most Interesting Astronomer in the Universe
DCS357
Reged: 10/20/08
Loc: Lubbock, Tx
Re: CG-5ASGT CGEM Pier mount new [Re: jrbarnett]
      #3315255 - 09/04/09 03:42 PM
Thanks for the info. I guess I will wait till I get the CGEM :-) and have a second plate machined.
agin
thanks
TV NP101
Celestron 9.25 SCT
AT72ED
Orion 100mm f\6
Obs in backyard
Taylor
Reged: 07/10/05
Loc: Owasso, OK
Re: CG-5ASGT CGEM Pier mount new [Re: mclewis1]
      #3315325 - 09/04/09 04:16 PM
Would the Atlas pier extension Orion sells be compatible with the CGEM and its tripod?
mclewis1
Thread Killer
Reged: 02/25/06
Re: CG-5ASGT CGEM Pier mount new [Re: Taylor]
      #3315489 - 09/04/09 05:35 PM
From what I've heard from CGEM owners ... yes it is.
Mark
1 registered and 77 anonymous users are browsing this forum.
