CLOUDY NIGHTS FORUM ARCHIVES
"Live Forums" can be found here: Live Forums
xcy
Reged: 05/15/06
Loc: Europe
CG5-GT power requirements
      #3513923 - 12/21/09 12:55 PM
What are the power requirements for the Celestron CG5-GT mount? What extras are needed in order to be able to use this mount?
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: CG5-GT power requirements new [Re: xcy]
      #3513983 - 12/21/09 01:24 PM
The mount is happiest with 12-14v DC at about 2 amps, it will draw less than 1/2 amp when just tracking. Good power and good power connections usually alleviate (or prevent) the majority of issues.
A set of anti vibration pads under the tripod often helps a bit, as does hanging some extra weight (10-20lbs) from the spreader bar.
If your using the mount in the cold (below freezing) you may also have to keep the hand controller warm otherwise it gets sluggish and hard to use. There are a number of ways to do this, wrapping a chemical hand warmer to the back is easy, a more robust solution is to also add a transparent cover (and still use the hand warmer).
Mark
C11, C6, APM/TMB115, and AT80ED - Pier mounted CGE in a POD, and CG-5A, WO EZ-Touch and AT Voyager
25x100s and 8x56s, T-Mount Light, Mark 1 eyeballs - 350Da, DSI-P, SPC900, NexImage, Mallincam
Just because you can doesn't necessarily mean that you should
xcy
Reged: 05/15/06
Loc: Europe
Re: CG5-GT power requirements new [Re: mclewis1]
      #3514023 - 12/21/09 01:41 PM
Would a battery of 12V at 7A be sufficent? What regulator (AC to DC) would I need to get to connect to the mains power? I was told that the same regulator could be used to charge the battery, is this correct?
mclewis1
Thread Killer
Reged: 02/25/06
      #3514052 - 12/21/09 01:56 PM
No, don't use a battery charger to power the scope, they aren't regulated (can often put quite a bit more than 14v into the scope) and usually can't supply the required amperage. You want a good quality 12-14v regulated DC power supply rated for at least 2 amps (you can get by with 1.5amps but 2 will give you some head room). Look for regulated 12v power supplies (which will often also be listed as 13.8v power supplies). You'll also need the correct power cable. The mount needs a 2.1 x 5.5mm plug. If you've got the Celestron power cable (it has a cigarette lighter style connector at one end) you're probably all set.
As I mentioned in my previous posting the mount will draw less than .5amp when tracking. This means with a 7amp/hr battery you could run the mount for 6-7hrs. First you usually don't want to take a battery down below 50% capacity very often. As a battery goes down it will also drop the output voltage a bit. The CG-5 goto electronics start to act "strange" below 10.5 volts. So a 7amp/hr battery is really a 3.5amp/hr unit for the purposes of planning. Just tracking at less than .5amp means that battery will last over 7 hours. You will likely need to slew (gotos) to various objects which will draw a bit more power so I suggested that this would mean the battery would give you between 6 and 7 hours of use.
Mark
Reged: 07/06/07
      #3514192 - 12/21/09 02:49 PM
For brief observing sessions with few/short go-tos, yes. For more that that--all evening with fairly frequent slews, 17ah is the minimum. Trot down to Walmart (or Asda in the UK) and get a jump start battery pack.
And, as you've been told, don't try to run it on the charger. Unhappiness will result.
Uncle Rod
Rod's Latest Book:
Choosing and Using a New CAT
Uncle Rod's Astroblog: http://uncle-rods.blogspot.com/
Edited by rmollise (12/21/09 02:50 PM)
astroalex
Reged: 08/24/08
Loc: Buggy Florida
Re: CG5-GT power requirements new [Re: rmollise]
      #3514269 - 12/21/09 03:28 PM
I'm using the Sears Die-Hard Portable Power #950. It has two 12vdc "Lighter" outlets, jumper cables, and also a nice light in the front that's flush mounted. Cost = $90
I did, however, hard wire a power cable into the unit with an on-off switch. This baby is built GOOD and should last a long time. The battery is one of those sealed units.
xcy
Reged: 05/15/06
Loc: Europe
Re: CG5-GT power requirements new [Re: astroalex]
      #3526525 - 12/28/09 07:45 PM
Would a 12v 3A AC to DC regulator work? This comes with a number of different plugs, but I don't know if it includes the 2.1 x 5.5mm required by the mount. Is this plug used only by Celestron?
mclewis1
Thread Killer
Reged: 02/25/06
      #3526641 - 12/28/09 08:59 PM
12v 3a regulated DC power supply should be just fine ... but emphasis on getting a regulated one. Some of the less expensive units will work but may not be regulated (most are however).
The 2.1mm plug is quite common, and certainly not unique to Celestron.
Mark
xcy
Reged: 05/15/06
Loc: Europe
      #3527879 - 12/29/09 02:34 PM
So far I found 2.1x5mm and 2.5x5.5mm plugs, but not 2.1x5.5mm. Could any of these work?
mclewis1
Thread Killer
Reged: 02/25/06
      #3528279 - 12/29/09 06:47 PM
Yes the 2.1 x 5mm should be fine, there is usually a flat spring inside the socket side that presses against the outer barrel. The barrel of the plug may be a bit loose going in but should seat solidly when pressed all the way in.
Mark
xcy
Reged: 05/15/06
Loc: Europe
      #3529829 - 12/30/09 03:32 PM
I tried a plug marked as 5x2.1 (which I suspect it is the same as 2.1x5mm) and although it looks a little louse inside the socket it seems to work fine.
RTLR 12
Reged: 12/04/08
Loc: Capistrano Beach, Ca
      #5513115 - 11/10/12 12:18 PM
The correct size for the CG-5 and all Celestron mounts is a 5.5 mm X 2.1 mm.
Stan
Celestron CG-5│, CGEM, C6-N, C6, C8,
Nexstar 8SE, ONYX 80 EDF
Stellarvue SV115T20, SV70 ED, M1
Orion ST 80 A
Vixen R130SF w/Porta II mount
Losmandy StarLapse
Meade DSIc and DSI PRO III
Wichßhpih'a
1 registered and 80 anonymous users are browsing this forum.
