Amalia
Reged: 10/16/04
Some news about planetary eyepieces
The German astronomy magazine Inter Stellarum number 41 shows
a comparison of five planetary eyepieces, written by Carsten Reese
and Ronald Stoyan.
I found this information in the internet and by performing a rally to town,
I was able to get it just 5 minutes before the kiosks in the main station closed!
I try to give you an impression. The text is four pages long...
The tested eyepieces are:
Televue Nagler zoom 3 - 6mm (used only in the 5mm position) (5 elements in 3 groups)
5mm Pentax XO (5 elements in 3 groups)
5mm Astro Physics Super Planetary (3 elements in 2 groups)
5mm TMB Supermono (3 elements in 1 group)
5mm Televue Radian (7 elements in 5 groups)
The used telescopes were:
8" Newtonian f-5
14" Newtonian f-5
4.7" Astro Physics APO f-8
4" TMB APO f-8
The tests were performed by both astronomers independently.
Now only what I found interesting:
They got the construction designs only from Pentax and TMB.
Televue and Astro Physics were not willing to give the drawings of
the lens assembly or any other informations, even when they asked
these two companies about them.
I skip the laboratory measurements as the observation part is more
interesting.
My thoughts are in {}.
Under not perfect observation conditions there were no differences
between the eyepieces to be noticed with 8". But with the 14"er and
the high quality APOs the differences were already obvious at a medium
seeing.
{I have suspected since quite a time that eyepiece comparisons performed
with small scopes under not optimal seeing conditions don't show enough:
Ouch! for several, well many, eyepiece comparisons I have read...}
Definition (or sharpness)
The test object was a seldom shadow-sickle shown by the shadow of Io
when passing in front of Jupiter. The sickle was here because Io covered its
own shadow (this is shown very clearly by a drawing and a foto in the actual test).
In all scopes the Pentax XO showed the best sharpness on-axis with a
minimal unsharpness at the border. It was followed very close by the TMB
Supermono which was sharp to the border. The Nagler Zoom was not able to
show such a sharp view, followed by the AP SPL. Last was the Radian.
I skip the eye relief and observation-comfort part as this can be read elsewhere.
(They were "more or less satisfied" with all EPs - except by the Radian which
showed "shadow-phaenomenas" if one does not get the right eye position).
Colour fidelity
Observing Jupiter with the two Televue eyepieces one doesn't notice any error in
the colours. But if one observes after with the extremely clear and white Pentax
or TMB eyepieces so the slightly yellow tint of the TV Radian and Nagler zoom
becomes obvious. Also the AP SPL shows this yellow.
I skip the distortion as there were only slight differences by observing.
Ghost pictures (reflections)
No reflections in the TMB.
Faint ones in the Pentax XO when the planet enters or leaves the field of view.
Nagler zoom shows some reflections when Jupiter is in the field of view,
but they disappear as soon as Jupiter gets out of the FOV.
Radian shows obvious reflexions when Jupiter enters or leaves the field of view.
Strongest reflections showed by the AP SPL.
Quality of coatings (scatter)
{I hope I translate "Streulicht" correctly by "scatter".}
The two moons of Saturn (Tethys, mag10.1, and Dione, mag10.3) were used
to judge the quality of the coatings, since they are situated near the bright planet.
This is not to be confused with transmission, as a transmission difference of 10%
will lead to a magnitude difference of circa 0.1mag which will be hard to notice
{finally a clear definition of transmission differences, finally! }.
With the 8" telescope the Nagler zoom shows both moons when using averted vision.
The TMB shows them also (always with averted vision), but fainter than the zoom.
The Pentax XO shows Tethys constantly, but Dione only sporadically.
The AP SPL shows Tethys sporadically, but Dione not at all.
The Televue Radian does not show any of them.
Conclusions
The best performer when observing Jupiter and Saturn was the Pentax XO with
a very clear and very white view.
A tad behind is the TMB Supermono, which is very free of reflections. It is also the
least expensive of all tested eyepieces, but shows only a 32° field.
Unbeatable in its manifoldness is the Nagler zoom, which, being a zoom, can replace
several single eyepieces, unfortunately it shows a slightly yellowish colouring.
The Televue Radian is the most comfortable of the five tested eyepieces, but shows
the same yellow as the zoom.
Disappointing is the performance of the Astro Physics Super Planetary. It can only
keep up with the other four eyepieces regarding sharpness on-axis and off-axis.
{in the section "definition" they did not describe it so well...}
I have tried to translate as well as I can and to sum up as well as I can.
I hope to have been able to give you an impression of this test and to
give you the main results. There were some posters in the past who asked
for a comparison TMB Supermono vs. AP Super Planetary. Here it is.
If you have questions, I will see if the text tells something and write you back.
I have worked far more than three hours on this text.
If you think it was interesting, and don't even write a thank you -
so I wish you very bad dreams tonight!
Amalia
Edit: Corrected the section about reflections.
Edited by Amalia (07/31/05 11:11 PM)
spaceydee
Reged: 04/16/04
Loc: Where the Kittens Are
I found it very interesting. Thanks Amalia!
-------------------- Dee
space-scientist
student violinist
Nexstar8i,SV80S,80/9D,FC100,94 Brandon,TMB92SS,GM8
8" f/7 Discovery,12.5" Portaball, PST
John Jarosz
Astro Gearhead
Reged: 04/25/04
Loc: Chicago area, IL
Wow, Amalia;
Thanks for your effort. It's good to be able to read some non-US opinions.
john
-------------------- 6" F4.6(w/Paracorr) Reflector , 8" F11 Dall Relay Scope ,
6" F5 RFT Refractor w/Istar Obj , G11 Mount Gemini1 Level 4
edl
Reged: 06/24/04
Amalia,
Thank you, I always enjoy your eyepiece discussions. A very interesting and timely report. I wonder why they did not include an ortho, especially the Baader one. (It's the "Baadest" planetary ocular in my collection!)
Best, Ed L.
~Steph~
Texas Wildflower
Reged: 06/11/05
Loc: North Texas
Amalia, thanks for this and for all that you do on CN! Hey, you have a new signature line, what happened to the "playful art" signature (although I like this new one very much!)?
Steph
-------------------- Steph
Taking it one day at a time...
I'm in the fight! - Support Liver Disease Awareness
10" RCX400 ~~ 4" TV102 ~~ WO ZS80FD ~~ PST
Serenity Observatory
lighttrap
Reged: 02/06/04
Loc: cloudy, foggy, humid NC, US
Amalia, I found your summary of this article to be of interest, and thank you for taking the time to read, translate and post about this article.
I'm confused by one thing regarding the radian. First there's this:
I skip the eye relief and observation-comfort part as this can be read elsewhere. (They were "more or less satisfied" with all EPs - except by the Radian which showed "shadow-phaenomenas" if one does not get the right eye position).
Then there's this:
The Televue Radian is the most comfortable of the five tested eyepieces, but shows the same yellow as the zoom.
Seems like if there are the expected problems with kidney beaning and blackout with a long eyerelief eyepiece that it would be labeled as comfortable by those that need long eyerelief, and less so by those that don't need long eyerelief.
But, anyway, of more interest to me is your idea that to best assess eyepieces, one needs a larger aperture scope. That must mean that those of us who are separating eyepieces based on small scopes, must have some real dogs for eyepieces if we can clearly percieve radical differences between A & B eyepieces tested in small scopes.
Seriously, I suspect there may be a good amount of truth to your assumption. But, what I'm getting at is that if one eyepiece allows me to see rilles and crater detail on Luna in a 125mm scope, that is clearly missing when a similar f/l eyepiece is used on the same scope, in the same night and with the same viewing conditions, then that disparity must be really magnified, (ahem), when the same eyepieces are used in a much larger scope on something as subtle as shadow transit shadow details. IOW, if a certain plossl clearly, and consistantly shows more detail than a certain similar focal length ortho with a 125mm, then when used in a 300mm, the difference must be very pronounced. I wonder if folks find this to be true. It makes sense, that larger apertures would show more detail, and therefore be more sensitive to subtle amounts of detail transmission.
Thanks for posting, Mike
Amalia
Reged: 10/16/04
Thank you, Dee and John! I wish you sweet dreams!
@ Ed: Do I understand you right? Is the Baader ortho not really satisfying you?
Some of us, me included, would really like to know more about it!
Maybe you can tell us? The critical meanings are always the most interesting!
In the meanwhile: Thank you for answering!
@ Steph: Yes, I have changed my signature line right now.
What I am doing right now on CN has not much to do with "playful" - unfortunately!
I am looking forward to spend my evenings with observing - playful observing!
When I went to town, some hours ago, there was this advertising for a drink:
"Who wants to get normal, is not normal`"
It made me laugh a lot - and I wanted to take it as a signature line.
But as I have learned to be careful - I chose this version!
@ Mike:
They were writing about "Abschattungen" - I can't find this word in any dictionary.
Must be "kidney" or "blackout" - I can't say exactly which. "Schatten" is "shadow".
"Real dogs" is good!
Your words about the comparison between a middle size scope and a bigger one
make very much sense to me.
I thought this for the first time when I read a comparison of a barlowed widefield
versus a planetary eyepiece, using a rather smalll scope and finding no clear difference.
"Radian (...) shows the same yellow."
I try to translate better:
As with the Nagler zoom the planets are slightly coloured yellow (with the Radian).
"leicht gelb eingefärbt" - or: coloured slightly yellow -
or: slightly yellow coloured, no this is the German way to write a sentence.
I hope you understand better!
Sweet dreams!
Amalia
half meter
Reged: 05/05/04
Loc: Great Lakes
Amalia, this is very interesting and I appreciate your translation effort (and your race to town to get the magazine) I've always wondered how the AP eyepieces would perform when compared to the TMBs.
When you write "Unbeatable in its manifoldness is the Nagler zoom" I believe you mean "Unbeatable in its usefulness is the Nagler zoom". And either one of these is correct: coloured slightly yellow - or: slightly yellow coloured. Anyway, your summary is very understandable and these are just small points.
Once you finish your profile on the Pentax eyepieces, I'm going to have to study it. To this point I haven't paid much attention to the Pentax line, but more and more (and this article is an example) I've been hearing good things about them.
Thanks once again for making this article available to english speaking folks.
-------------------- Gary
Collins I3 (Thin Film) Image Intensifying Eyepiece
Coronado Maxscope Double Stacked 90mm <0.5A w/BF30
6" f/8 TMB/A&M Carbon Fiber APO; f/5 with 4" Borg ED Field Flattener/Reducer
8" f/5.6 Starmaster Versa V8/Zambuto Mirror/ServoCat Jr dob
30" f/4.5 Obsession/OMI Mirror/ServoCat/Argo Navis dob
ngc2289
Reged: 04/13/05
Loc: Some Where Around The Maypole.
Thank you very much for the summary. I am in the process of buying a TeleVue 3-6 so it is nice to know that it didn't completely flunk.
-------------------- Mike Traub(Mr. Congeniality): I've learned that I don't suffer from insanity, I enjoy it!:Shipfitters mottos; Cut to suit, pound to fit, paint to hide!: If it dosen't fit get a bigger hammer!......Retired and BROKE!!!!!!!!:SV 80DL Triplet:6" f/6 Home built newt.:PST: UniversalAstronomics UniStar Deluxe.
Amalia
Reged: 10/16/04
Thank you for answering, Mike!
Actually they think good about the zoom. I try to translate better: "(section sharpness) Off axis sharp, but it was not able to show such "a hard picture" as the TMB and Pentax. (section conclusions) The only real disadvantage of the zoom is the slightly yellow colour."
I have read somewhere else that the zoom can be very useful by its possibility to tune the magnification very exactly according to the seeing.
Do you know:
http://www.cloudynights.com/documents/tmb2.pdf
Amalia
Amalia
Reged: 10/16/04
Thank you, Gary!
I was wondering, too, about the SP. It is amazing we hear so little about it. Unfortunately it seems not to be overwhelming.
Thank you for the feedback about the linguistic aspect!
I have been writing a lot about the Pentaxes in the past. Then I have stopped, as I did not want to become too "missionary". But meanwhile they have started to become more known - even on CN!
Sweet dreams!
Amalia
aporigine
Reged: 07/03/05
Loc: Tuolumne foothills CA
I wonder if Abschattung might be vignetting.
cheers aporigine
-------------------- Beauty is in the eyepiece of the beholder.
starpal
Reged: 08/06/04
Loc: Mid-USA
Thank you very kindly, Amalia, for the "good stuff" translation work done for us with that review. Very interesting made me chuckle to learn new (or confirm old) things about a couple of those eyepieces
For anyone in USA wishing a super nice bargain on the Pentax 5mm XO go here:
http://www.adorama.com/PX5XO.html
If you need one sent Amalia JLMK to get it for you.
Please also wish for me some good sleep I could use it!
smitty
Reged: 07/27/04
Loc: Georgia, USA
Amalia, thanks for all your work and for sharing this with us. It would have been nice if they would have included the Pentax XW in their comparison too.
-------------------- Steven "Saratoga Smitty" Smith
10" & 16" Dobsonians
Coronado PST
10x40 & 11x70 "opera glasses"
2 ton eyepiece case
http://www.saratogamuseum.org
Psycho_pup
Reged: 03/22/05
Loc: Singapore
Thanks Amalia for the translation! May you be blessed with many cloudless nights for your good deed!
And now I must blame you for my new order of a 5mm Pentax XO!
-------------------- Meade ETX90, Celestron 8i, Canon 18x50 IS
Questar Duplex, Orion 100mm ED APO, Vixen VC200L
PST/SM40, ZS 66 APO, ZS 80 FD
Edited by Psycho_pup (08/01/05 02:00 AM)
Mike Hosea
Reged: 09/24/03
Loc: "Metrowest" Boston
I agree that using larger scopes and higher contrast scopes like APOs will reveal more about eyepiece contrast, and in the case of the larger scopes, lateral color as well. The larger scopes use planetary eyepieces with larger exit pupils (since the atmosphere will not typically allow them to be used at the same exit pupil as a medium-size scope), implying a brighter image with greater tendency for scatter to be detectable to the human eye. In the case of the APO there is simply less background scatter from the telescope optics, making the contribution of the eyepiece more easily noticed.
I suppose it's another debate whether reviews should be primarily concerned about a minority of observers using certain types of telescopes. It seems equally important to me that a difference cannot be seen in a smaller scope as it is important that a difference can be seen in a larger one.
I nearly bought a 5mm Pentax XO, but I have no patience for such short eye relief. It's like buying a high performance car with no cushions on the seats.
- 7" f/6.7 home-built Newt and equatorial platform
- 120mm f/8.3 home-built grab-n-go Newt
jbecaria
Reged: 03/15/05
Loc: Burbank, CA
I've been curious about the Pentax XOs for a while now, ever since Daniel Mounsey showed me one at the local scope shop.
The comfort level is actually surprisingly tolerable. The XOs come with a detatchable rubber eyeguard. It doesn't really look like it's supposed to be taken off to be honest, but it give the eyepeice a more comfortable 'cone top' feel. Just be mindful of blinking! Otherwise, they seemed very bright and noticably "whiter" than TV Plossls, IMO. This is based on looking through them at a bright white surface, never through a scope though. Even so, one can't help but imagine how sharp they would be if they were anything like the praised .965" barrel Pentax orthos. Then you start imagining the views... then it's all downhill from there!
A very tempting situation to say the least...
...but I was able to resist
...for now...
-------------------- James
Orion 100ED on CG5/GT
Celestron Ultima 8x40 Binos
mirage
Reged: 09/23/04
Loc: central texas
Thanks for posting the comparison!
I often wonder about warm/cool eyepiece rendition. Obviously warmer optics make cool optics look cooler and vice versa, just by virtue of comparison and the way we perceive color, but which eyepieces render colors more accurately?
It's a complicated phenomenon to assess - not only based upon target color, but the relevant net perceptual effect of nonlinear color response across the visible spectrum. I think most people set aside all the complexity such an analysis would entail and instead prefer an eyepiece tone based upon aesthetic taste.
-------------------- imber stellarum 10x50 binoculars
architectural advisor
friends of the austin planetarium
jbecaria
Reged: 03/15/05
Loc: Burbank, CA
Oh, and Amalia...
AWESOME POST
Thank you!
Kenny
Reged: 07/04/05
The best performer when observing Jupiter and Saturn was the Pentax XO with a very clear and very white view. A tad behind is the TMB Supermono, which is very free of reflections. It is also the least expensive of all tested eyepieces, but shows only a 32° field.
I still think that I will get the TMB, especially since I will probably only go as low as 6mm. I hope that doesn't cost you a commission from Pentax!
Disappointing is the performance of the Astro Physics Super Planetary. It can only keep up with the other four eyepieces regarding sharpness on-axis and off-axis.
I bet that this is the real reason why they won't accept new orders right now. They are probably trying to fix the design and bring out an improved version. Reputation is important, and AP products are not supposed to lose in comparison tests.
Well, I wasn't so much asking as I was begging on my knees with tears running down my face. But it's not important.
I have worked far more than three hours on this text. If you think it was interesting, and don't even write a thank you - so I wish you very bad dreams tonight!
Hmmmmm . . . should I or shouldn't I? . . . Should I or shouldn't I? Well, ok, but only because I FEAR THE ALMIGHTY POWER OF AMALIA!!!
THANK-YOU! THANK-YOU! THANK-YOU!
Ken.
P.S. when Ed wrote that his Baaders were the "Baadest", he meant that they were his best. It is a very old "street slang" expression from the early 1970's. Although you are very careful with your translations to make sure that everyone understands you, some are not as careful with the use of slang and can therefore confuse people from other countries. I really hate those Hosers eh!
