photonovore
Moonatic
Reged: 12/24/04
Loc: tacoma wa
Just stumbled onto some interesting data on just what the common binocular prism designations of Bak4 and Bak7 may actualy mean, especially concerning Chinese made binoculars.
Turns out the equivalency tables for glass indicate that the Chinese optical industry calls the glass type that is their equivalent to Schott Bak-4 as Bak7! You can see this for yourself here, here and here.
It can also be seen (from the above equivalency tables) that Chinese Bak4 is not equivalent to any sort of Schott Bak-type glass at all but instead to a glass called "Schott PSK3", which is a dense phosphate crown glass. The specs of PSK3 glass, to which Chinese BaK4 is equivalent, is as follows:
Schott Bak4 / Chinese BaK4(Schott PSK3) / Schott Bak7:
Bubble Class: 0, 1, 0
nd refractive index: 1.57, 1.55, 1.52
The bubble class: this is a standard where the bubble content in the glass as well as the frequency and size of occlusions are quantified. A "1" designation allows for twice as many bubbles per 100cubic cm of glass than a "0" designation. A "1" designation allows for occulsion sizes up to 0.02mm-sq, where a "0" designation allows only up to 0.006mm-sq maximum size. For a prism, a "0" designation would obviously be preferable.
So what does this all mean? Well, if the glass manufacturer of the prisms in a pair of binoculars is *not* specified, then an unqualified designation of "BaK4(BK4)" could mean (and most likely does in the case of Chinese manufacture) that it's prisms are actually made of Chinese PSK3 quality glass, not BaK anything. If it's designated generic BaK7(BK7) then the prisms may actually be the Chinese version of Schott BaK4! (and likely are) Kind of turns the BK4/BK7 picture on it's head...
So, when dealing with Chinese optical product specifications (binoviewers and binoculars) "BaK4" likely measn you're getting PSK3 prisms; BaK7 means you likely have BaK4 prisms. Neither of these glasses are anything like Schott BaK7--to which the equivalent is Chinese "K9" glass--which is probably a good thing. Confused yet?
-------------------- Mardi
4" achromat, ETX-70, 8"cat.
Whitepeak Lunar Observatory Website
DJB
Reged: 02/23/05
Loc: Lisle NY
Hi Mardi,
I think this is good news--maybe. But how do we know that their quality assurance programs actually check this if the supply side is low?
Anyway, good references and thanks. This IS new to me!
Regards, Dave.
MIKADO
Reged: 03/21/06
It is rather confused!  What I know it is: The BaK7 prisms are borosilicate glasses whereas BaK4 are containing barium sulphate, and that for the same theoretical value of luminosity BaK4 have a better quality of transmission.
EdZ
Professor EdZ
Reged: 02/15/02
Actually, if what Mardi has found can be corroborated, this may not necessarily be good news. But, depending on other design parameters, it may not be a bad thing at all.
The confusion here lies in the fact that what the consumer thinks may be BaK4 prisms, which are better suited to fast focal ratio light cones of most binoculars, may in fact not be the forumla for glass as we normally refer to BaK4. If the formulated glass is indeed closer to BK7, then the resultant prism (if still made to the same size) would have the affect of causing considerable light loss within the prisms. But there is no indication the formulation is close to BK7.
Frankly, I have not seen any evidence of this in any Chinese binocular. So much more explanation is needed to understand what is going on here. This may in fact account for the new trend it what is being referred to as oversized prisms in many models, because if it were a glass formulated closer to BK7 it would require a larger sized prism to accomodate the light cone. The good side to that would be, if is is formulated closer to BK7, and it is made bigger, it's a better glass to use for prisms.
Read this From our Best Of links on BaK4 vs BK7
BaK4 (Barium crown) has no advantage over BK7 (Borosilicate) when used in in a situation where the incoming light beam angle is very narrow. However in wide field applications such as low power binoculars there are advantages - increasing the brightness of the edge of field while having no effect on the on-axis image. There would be no advantage to BaK4 over BK7 to any part of the image for instance in a Binoviewer because of the narrow beam angle wherein generally they are slow systems without wide fields.
The disadvantage of BaK4 is that it introduces more spherical aberration into the optical path than BK7. BaK4 also introduces more chromatic aberration than BK7. You may not notice this, particularly if the optics are poor to begin with, you may not be able to separately identify which component is causing the aberration. These aberrations can almost always be noticed in binoculars, but as stated above BK7 if made to the same size is simply the wrong choice for prisms in fast binoculars. Exceptions might be those f/11 BT80 Vixens, or opther f/8 and slower binoculars.
BK7 may be the clearest, most defect-free optical glass available for prisms. BaK4 is close, but not quite as good. BaK4 is ok for low power applications of a typical binocular, but not for high power low contrast situations seen in telescopes or binoviewers. For a high powered slow f# telescope, with a very narrow light beam, BK7 would be a better choice for a prism. Similar applications are found in binoviewers.
Unless you plan to use your binoviewer on an f/4 or f/5 telescope, BK7 would be the preferred glass for prisms in a binoviewer. So why is BaK4 glass normally found in binoculars. The need to handle a wider faster light cone.
Of course none of this explanation answers, What is the formulation of the Chinese glass currently being referred to as BaK4?, as noted in Mardi's post above. Hopefully we will find out more.
Although you should be careful not to trip here. Take note that Schott BaK4 is labeled Chinese equivalent BaK7, NOT BK7. So there is no confusion here between BaK4 (Barium crown) and BK7 (Borosilicate). There is a difference in the number from 4 to 7 (not to mention other differences). Then also note that Schott BK7 is labeled as the Chinese equivalent of K9.
Of course further confusion arises not only from "who's term" for Bak4 is being used, Schott or Chinese, but also from any typos in trying to relate the information. In any layman's (typical forum) references to these terms the extreme caution should be noted that more than half the time the letters are confused by the writer. The glass and the terms as we know them from Schott are BaK4 (Barium crown) and BK7 (Borosilicate). If you were to read a forum post and the term "BaK7" were typed, you would have no idea if you were reading a reference to a Chinese glass term or someone had mistyped BK7.
edz
Edited by EdZ (03/28/06 11:44 AM)
photonovore
Moonatic
Reged: 12/24/04
Loc: tacoma wa
The one i see as most relevant to the buyer of Chinese binos is that seeing "BaK4" in the specs might very well mean Schott equivalent PSK3 glass is actually used instead. So my question would be what the story is on this glass (PSK3) as used in a bino or BV prism application compared to Schott Bak4? A second quetion would be if the Chinese actually use their Bak7 glass and the Western distributers then correctly re-refer to it as it's Schott equivalent, Bak4?
Joad
Wordsmith
Reged: 03/22/05
An email to Kevin Busarow at Big Binoculars might yield an answer to the mystery.
Glassthrower
Vendor - Galactic Stone & Ironworks
Reged: 04/07/05
Loc: Oort Cloud 9
PAGING Mr. Bill Cook, paging Mr. Bill Cook.
-------------------- Michael Gilmer - Member of the Meteoritical Society & Collector of Falling Stars.
☄ ⒼⒶⓁⒶⒸⓉⒾⒸ ⓈⓉⓄⓃⒺ ☞ www.galactic-stone.com
EdZ
Professor EdZ
Reged: 02/15/02
I would also like to here from Roland Christen on this subject, but in all likelyhood, we would need to take the discussion to him, rather than have him come here to the discussion.
edz
-------------------- Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
MIKADO
Reged: 03/21/06
Excuse me but I had read this article where besides I found there almost word for word some passage "Product Information - About the Denkmeier Deepsky Binoviewer" on the site http://www.optcorp.com/product.aspx?pid=383-400-2342  For my part I remain persuaded that the BaK4 prisms are better for the binoculars than the BK7. To be convinced some it is enough to look with which type of prism are made the top-of-the-range binoculars. As a user, I find that the binoculars with BaK4 prisms give more luminous images and a better acuity on the edge. But this can be subjective.
EdZ
Professor EdZ
Reged: 02/15/02
The article you pointed to About the Denkmeier Deepsky Binoviewer
supports exactly what I have stated above. It shows very clearly that BK7 has more desirable properties than BaK4 for those instances where it can be used in slower optics and it clearly describes the typical uses for each glass. Yes BaK4 is the better choice for fast binoculars, as I said above, because of the fast light cone from an f/4 binocular.
edz
member#21
pcad
Reged: 01/17/05
Loc: Connecticut
Interesting stuff.
Since few companies are advertising instruments with BK7 prisms or the chinese equivalent, K7, I doubt we'll be seeing diamond/square exit pupils any time soon. Whether this is good or bad is another question.
A glass company can name their products whatever they want as long as they list the glasses properties correctly. Listing equivalent glasses from other companies is convienient but not required. I do find it misleading to use the same name from a differant company to describe a differant glass.
Will using Chinese BaK4 (Schott PSK3) instead of Schott BaK4 (Chinese BaK7) in binoculars make any differance? It would seem unlikely. The Chinese BaK4 has a slightly lower index of refraction than Schott BaK4. This means that Chinese BaK4 will start developing a squared off pupil with slightly slower objectives than Schott BaK4 objectives. Considering that a lot of the bigger astro-binos tend towards the slower f ratios it's unlikely that we'll see any differance in the exit pupil edge illumination.
As far as oversized prisms are concerned, one can make any prism UNDERsized regardless of glass type. The critical size is whether the full light cone can enter the prism. Once inside the prism the light cone becomes less steep, but cannot become larger than the it was when it entered the glass. In fact it will always be getting smaller since it will always be a cone. Snell's law for light entering a denser medium states that the angle of incidence will be greater than the angle of refraction with respect to the normal. So for a normal, symmetric, Porro prism where the entry area is equal to the exit area and the 45 deg faces are properly positioned with respect to the entry and exit areas oversized prisms are superfluous. There are examples of nonstandard porro prisms that get progressively smaller in order to save weight but that gets to be pretty expensive.
Peter
-------------------- Peter
Telescopes 25 - 318 mm
Binoculars 12 - 100 mm
Microscope 50x - 1000x
DJB
Reged: 02/23/05
Loc: Lisle NY
Hi all and Ed's explanation post,
Now I am getting confuseder and more confuseder.
Ed reiterated some good points concerning prism glass type and size. But, would the Chinese designers choose to use larger prisms versus material type? I believe a cost analysis would be in order. Perhaps the Chinese are on to something.
Also, as Ed pointed out, we may have some translation/typo ambiguities here! I'm almost inclined to believe that this may.......
(Ed, from a previous post: The Miyauchi BINON 7x50 prism block DOES use blackened prism edges and backs, since we are talking about prisms here. FYI).
Best regards, Dave.
EdZ
Professor EdZ
Reged: 02/15/02
It would be interesting to have someone explain the value in that, since prisms use total internal reflection to move entering light out the other side of the prism.
edz
member#21
johnno
Reged: 05/03/04
Hi All,
EDZ,et all
Dont know if this is relevant,But some of my Earlier made Japanese Binoculars,have a Brass covering OVER the Prism Backs/Tops.
I dont know if the inside of these covers are Blackened,or not,But they are there??,covering the "ANGLED",top section of the Prism's. Regards. John
pcad
Reged: 01/17/05
Loc: Connecticut
Here are the Abbe numbers for the glasses in question.
Schott catalog #/Chinese catalog #------Abbe #
BK7/K9-------64.07 PSK3/BaK4---63.36 BaK4/BaK7---56.05
Since the PSK3/BaK4 value of 63.36 is closer to the BK7/K9 value of 64.36, the PSK3/BaK4 glass may introduce fewer aberrations than BaK4/BaK7.
The index of refraction of PSK3/BaK4 (1.55248) is almost as large as BaK4/BaK7 (1.56889), while BK7/K9 (1.5163) is a bit lower.
This PSK3/BaK4 glass may make a nice prism material with dispersion properties similar to BK7/K9 and the index of refraction close to BaK4/BaK7. There may be other reasons why this glass is not used more often such as clarity, bubbles, price, workability, stability and so on.
I thought of a better way to describe what I said earlier on prism size. Prisms can be too small. Once they are big enough to prevent vignetting at the prism entrance, making them bigger will not improve their performance. If BK7/K9 prisms are used in an instrument that is too fast there will always be a diamond/square pupil no matter how big the prisms are.
The brass prism covers may have other uses. They may be involved with holding the prisms in place. The cover may keep stray light from entering a prism at its 45 deg face and decrease glare. If the prism isn't performing with total internal reflectance, the cover traps the light that's being lost, again possibly decreasing glare. In some cases it may protect the prisms from damage.
Peter
EdZ
Professor EdZ
Reged: 02/15/02
Another source for glass specifications
http://www.newportglass.com/optcat.htm
Just to reiterate the need to be extremely careful when using these glass names, BAK4 and BaK4 are two different glass with different specifications.
edz
member#21
Glassthrower
Reged: 04/07/05
Loc: Oort Cloud 9
Is Chinese BaK7 glass really Schott BaK4 glass?
So what's the verdict? Is it or isn't it?
This thread just withered and died without the original question being answered....or was it and I missed it?
MikeG
EdZ
Professor EdZ
Reged: 02/15/02
Links are provided to several different tables of glass specs so you can see for yourself where all the glass falls on the charts.
The answer to your question is yes. However that does not answer whose term is being used when the specification is attahed to the product, nor does it answer the implications of using other glasses.
But you did miss this.
and
and
edz
member#21
pcad
Reged: 01/17/05
Loc: Connecticut
The names for the glasses seem to vary from website to website. The site I used which came from Photonovores initial post is chinaopticsnet.com. Their Chinese glasses include names like BaK4 and BaK7. The site EdZ uses, Newportglass.com, only lists Chinese glasses labled with all capital letters, such as BAK4 and BAK7. Are these the same glasses? Maybe, maybe not. I tried to be consistant with the site I was using. I would point out that all three sites mentioned in the initial post list a Chinese BaK4.
In reviewing the Newport Glass site, it seems to have better information and they list the references used. It also illustrates that the Chinese glasses, whether they use all capitals or not, are not the same glasses that are found in the Schott catalog. Similar maybe, but not identical.
As to which glass is used in what instrument, we don't really know. I suspect/belive that BK7 and Bak4 still indicate the Schott catalog numbers and not the Chinese catalog numbers. Maybe sellers of binos will have to start saying Schott BaK4 when specifing prism material to eliminate any confusion.
Thanks for putting me straight EdZ.
Peter
Edited by pcad (04/08/06 12:36 PM)
EdZ
Professor EdZ
Reged: 02/15/02
If they would use the international standardized 6 digit numbering system, it wouldn't much matter whose glass it was. But then, few people would know what kind of glass it is without reference to some charts.
edz
member#21
