Buhlig
Reged: 12/03/07
Loc: Derby, KS
Convince me I need Photoshop - M33
      #3400894 - 10/20/09 07:26 PM Attachment (58 downloads)
I've seen many rave about Adobe Photoshop, but I'm still on the fence considering a purchase. Anyone care to take a stab at processing my latest M33? I'd like to see how much a difference it makes. The full size .jpg is here
Sean
Celestron 80mm ED Apochromatic Refractor
Orion 8" Newt
Celestron 80ST achro (guider)
PHD via handcontroller interface
CG-5 Advanced GT Mount
Canon 350D
Philips SPC900NC
http://www.flickr.com/photos/derbysluggers/sets/72157605255114566/
Rankinstudio
Reged: 04/05/08
Loc: Salt Lake City, UT, Lake Powel...
Re: Convince me I need Photoshop - M33 new [Re: Buhlig]
      #3400937 - 10/20/09 07:57 PM Attachment (48 downloads)
Be better if you uploaded the .tiff
1 minute adjustment in photoshop
Ran it through Gradient X Terminator
Curves Adjustment
Color Balance
David Rankin
http://www.rankinstudio.com
Astro Gallery
Orion 254mm F4.7 (imaging scope)
Baader MPCC
Quickcam pro 9000 (guider, imager)
Canon Rebel XSi (self modified)
Atlas EQ-G (EQ MOD)
Canon 50mm F1.8 II Lens
Canon 28-200 F3.2 Lens
DSLR peltier cooler
Nils_Lars
Reged: 01/04/08
Re: Convince me I need Photoshop - M33 new [Re: Rankinstudio]
      #3401176 - 10/20/09 10:14 PM
Ya we need a crack at the Tiff Stack to really do it justice but I have seen people do great things with Photoshop or Iris or Pixinsight along with other programs I think it just depends on the difficulty level and how much you want to spend.
Erik
Orion ED 80
Williams Optics VII reducer
Celestron 8" SCT
Orion Starshoot Autoguider
PHD guide
NexImage webcam
Buhlig
Reged: 12/03/07
Loc: Derby, KS
Re: Convince me I need Photoshop - M33 new [Re: Nils_Lars]
      #3402237 - 10/21/09 01:47 PM
a'right...I'll post the .tiff tonight. It doesn't seem quite "red" enough, but I definitely like the gradient reduction. Looks like it lost a little detail, hard to tell from the small size. Do you guys want a raw stack out of neb? That is, unstretched full spectrum?
FWIW, I've tried IRIS and had a really difficult time with the stretch in IRIS (asinh)...finally just gave up. The registration is nice in IRIS though. Neb seems to have a much finer means of stretching and scaling...but I could be just missing the IRIS boat I suppose.
Sean
Orion 8" Newt
Canon 350D
Philips SPC900NC
Ion01
Reged: 01/25/08
      #3402294 - 10/21/09 02:22 PM Attachment (33 downloads)
Here is one with a little work on the JPG. I am sure we could get a ton more with the tiff as you obviously picked up a lot of information in your image! This is an incredible shot!
Buhlig
Reged: 12/03/07
Loc: Derby, KS
Re: Convince me I need Photoshop - M33 new [Re: Ion01]
      #3402971 - 10/21/09 07:55 PM
apparently, flickr converts .tiff uploads to .jpg, urrggh!...how can I get you guys the .tiff file?
Sean
Orion 8" Newt
Canon 350D
Philips SPC900NC
Samir Kharusi
Reged: 06/14/05
Loc: Oman
      #3403353 - 10/21/09 11:13 PM
Transfer big files
Bored? Peruse my website:
http://www.samirkharusi.net/
Psyire
Reged: 06/24/07
Loc: 55* North
Re: Convince me I need Photoshop - M33 new [Re: Samir Kharusi]
      #3403426 - 10/21/09 11:46 PM
Make sure the .tif is just a stacked version, not one that has been post processed with an image editor. (that will make a difference too)
Celestron CPC 1100 XLT, Sky-Watcher Equinox 80ED
TV 31T5-Nagler, 8&13mm-Ethos
EarthWin Binoviewers w/ 24mm Panoptics
Elusive Photons.com
Buhlig
Reged: 12/03/07
Loc: Derby, KS
Re: Convince me I need Photoshop - M33 new [Re: Psyire]
      #3404842 - 10/22/09 07:15 PM
ok...here it is M33HIRES . It is stacked in Neb, nothing else. Darks and flats applied prior to color conversion. Thanks in advance. I very curious to see how it turns out. This is 15x5min subs with a 10" f/5 newt in pretty dark skies. Should have a ton of detail.
Sean
Orion 8" Newt
Canon 350D
Philips SPC900NC
John Miranda
Reged: 09/13/09
Loc: Oro Valley, Arizona
      #3405219 - 10/22/09 10:37 PM
Ion101 - Your adjustments are wonderful.
Would you share the workflow/tools you applied in PS?
John Miranda
www.johnmiranda.com
Rankinstudio
Reged: 04/05/08
Re: Convince me I need Photoshop - M33 new [Re: John Miranda]
      #3405390 - 10/23/09 12:31 AM Attachment (15 downloads)
yea, playing with jpg's doesn't help much. Here is the tiff after I spent about 45 mins on it playing around. I have to compliment you on the capture, it is really good with tons of detail. Was a real pleasure working on it. Hope you like the results...
Full Res
http://www.slas.us/gallery2/main.php?g2_itemId=2651&g2_imageViewsIndex=1
Opened the image, stretched it with curves, did a color balance adj. - used gradient X terminator - another curves adjust - another color adjust - reopened original image - layed it over and made a layer mask to bring back the bright areas - flattened image - increased saturation - pulled out a better exposure balance with the shadows/highlights tool (set final black point) - used Noel Carboni's "Deep space noise reduction" & "color blotch reduction" saved it out
David Rankin
Astro Gallery
Baader MPCC
Atlas EQ-G (EQ MOD)
DSLR peltier cooler
Edited by Rankinstudio (10/23/09 02:08 PM)
Nils_Lars
Reged: 01/04/08
      #3405420 - 10/23/09 12:50 AM
You have some super data here Buhlig its wasnt hard to get it look good and I could have done a few simple tweaks and been happy but I kind of went as far as I could just to see what I could get out of using Photoshop.
I guess I went a little bluer then David did but thats easy enough to fix , its all personal taste.
I kind did my standard routine of a run through Nebulosity for the DDP which was a little darker then my subs come out but I usually stack in DSS.
First ran a couple more curves and then I set black points in levels in each channel.
I ran GradX like they recommend on there web site and croped it down a bit.
Then reset black points again in each channel and then using curves and ctrl click on the darkest points and brightest points and then using arrow keys to adjust I was able to pull some detail up.
I did a high pass filter layer to sharpen then did a inverse mask as shown on the light buckets site with noise ninja and a color boost with match color.
Erik
Orion ED 80
Celestron 8" SCT
PHD guide
NexImage webcam
Edited by Nils_Lars (10/23/09 12:55 AM)
justabob
Reged: 05/05/07
      #3405482 - 10/23/09 01:48 AM
Great data!
cs3
http://www.pbase.com/rkn/astro&page=all
Vixen Sphinx SXW
Meade sn6
Canon EF 200mm f/2.8L II USM Lens
Hutech 1000d
Self modded 350d
ST8300c on order
DSI PRO II
Bob
Psyire
Reged: 06/24/07
Loc: 55* North
Re: Convince me I need Photoshop - M33 new [Re: justabob]
      #3405492 - 10/23/09 01:58 AM
Amazing Data! I spent about an hour on this process and had a lot of fun, thanks! 100% Photoshop...
Click for Higher Resolution:
Elusive Photons.com
Samir Kharusi
Reged: 06/14/05
Loc: Oman
      #3405520 - 10/23/09 02:45 AM
Folks, I am most impressed by both the capture quality and the processed examples.
jcham21
Reged: 12/02/07
Loc: Tucson, Arizona
      #3405526 - 10/23/09 02:54 AM
Here is my version done in PS CS2:
Larger: http://i129.photobucket.com/albums/p218/jcham21/m33_stack1.jpg
Curves
Noels Astronomy Tools
Took about 20 minutes. Very good data.
James
James
Canon XTi
Canon EF 200mm f/2.8L II Camera Lens
Celestar 8
Main Astrophotography Gallery
Comet Lulin Gallery
How To Make a 6" F/15 Refractor
Brane
Reged: 07/02/06
Loc: Slovenia, Europe
Re: Convince me I need Photoshop - M33 new [Re: jcham21]
      #3405762 - 10/23/09 08:26 AM Attachment (6 downloads)
Nice data.
High resolution ftp://ftp.hicsalta.si/incoming/astro/m33_stack-3-big.jpg
http://www.rezman-obs.si
Edited by Brane (10/23/09 10:25 AM)
Agnotio
Reged: 08/29/08
Loc: Ottawa, Canada
Re: Convince me I need Photoshop - M33 new [Re: Brane]
      #3405971 - 10/23/09 10:45 AM
I really like Nils version, makes me consider getting Nebulosity. Although I think most of the work flow was in Photoshop, the high pass filter especially makes a difference. The only thing was maybe he could have pulled out more of the Ha nebulosity to made it redder.
EQ6 Pro with EQMOD
Canon 450D
Sky-Watcher 10" f/4.7 Dob
xatamec
Reged: 09/12/09
Loc: Catalonia, Spain
      #3406021 - 10/23/09 11:12 AM
I'll try to convince you that you don't need PS, but need PixInsight instead. Much cheaper and much more powerful and focussed for astrophotography works. I would have liked to process it from the very beginning though.
Steps:
Gradients elimination with Dynamic Background Extraction
Histogram stretch
Dynamyc range compression with HDRWavelets
Tiny noise reduction with GreyCRestoration
Color saturation with curves
Sergi
My telescopes: WO Megrez 88FD APO and SW 200/1000
My mount: SW EQ6
My cameras: Cooled Canon 350D, QHY5
...and very little time to play with these toys!
Tonk
Reged: 08/19/04
Loc: Leeds, UK, 54N
Re: Convince me I need Photoshop - M33 new [Re: xatamec]
      #3406069 - 10/23/09 11:37 AM Attachment (9 downloads)
Simple processin - Images Plus DDP, Gradient XT, Iterative curves stretch, LCE, NR, Colour sat
Televue 85, GM-8/Gemini, Canon 40D (unmodded), Canon 450D (modded w/Astronomiks clip-ins - UV/IR, OWB)
Coronado SM60/BF10, Baader Herschel Wedge
Leeds Sky Clock Ripon Sky Clock
5 registered and 6 anonymous users are browsing this forum.
