starcam
Reged: 09/24/07
Loc: MD
I'm using a f/7 scope, just purchased the xw20. When looking to the stars, let's say the outer 75% stars become unfocused. When I focus on the outer stars the center stars go out of focus. Is this normal? I thought with the price tag the stars would be pinpoint to the edge. I believe I assumed wrong. I was viewing nebula's with more contrast.
-------------------- Celestron 9.25 SCT f/10 fl/2350
Stellarvue SV102ED2 F/7 fl/710
William Optics Megrez 72mm F/6 fl/432mm
Coronado PST
CG-5
UWAN 28mm
Panoptic 22mm
Televue 7T6,13T6,15wf,11
Pentax XW 7,10,20,40 / XO 5 / Zoom 8-24
RKE 8,12,15,21,28
Hyperion 5,8,17/13
TMB 2.5,4,6II,7,9
Brandon 6,8,12,16
UO HD 7mm
Oberwerk bino 15x70
Burgess 8x42 bino
WO binoviewer
Rob S
Reged: 03/16/07
Loc: NZ
For a lot of scopes this is normal.
This particular focal length XW has a lot of field curvature.
Apparently the type of scope they expected you to use it in has the opposite type of field curvature - so it cancels out.
Rob.
-------------------- 8" f5 Dob with Feathertouch
Brandon: 16
Pentax: 7, 10 & 20XW
TMB: 30 Paragon
TV: 8 & 13 Ethos;
5 & 13 NaglerT6;
24 Panoptic
Leica Trinovid 8x50 BN
slyke
Reged: 02/21/08
Rob.
Here is a graph from a previous discussion:
XW field curvature
If one thinks of eyepieces as corrective lenses for your telescope then you would want them to have equal and opposite curvature. -Stephen
Mike Hosea
Reged: 09/24/03
Loc: "Metrowest" Boston
Presumably they expected you to use it in on one of their spotting scopes, and I rather doubt that these have negative curvature. I think it's more likely that they don't think you'll be bothered by this aberration nearly as much with terrestrial viewing. They've been doing this consistently. Same situation with the 12XF the 14mm and 21mm XLs. You hear people all the time saying how the curvature doesn't bother them, and naturally this is scope-dependent, but I found there were times when I could almost convince myself that I liked the 12XF and at other times hated the curvature, so I think there's a strong component to it based on what you're doing. Which is to say, I don't think it's entirely a matter of "different eyes".
Anyway, these mid-focal-length Pentax eyepieces are not, IMO, designed to be ideal astronomical eyepieces. You may like them in spite of that because of the quality of the glass and coatings, but the curvature they left in the design leaves a lot to be desired for astronomical use. The situation is strikingly different with the eyepieces they've designed presumably mainly (or in some cases solely) for astronomical use, e.g. 2" XWs or 10.5mm and shorter XLs and XWs. Even the 8.5mm XF is much better optimized for astronomical use than its 12mm sister.
For 20mm of eye relief, I'd probably go with Pentax XWs up to (and including) 10mm, switch to Vixen LVWs 13mm, 17mm, and 22mm (eschew the 14mm and 20mm XWs), and then switch back to Pentax XWs for the longer focal lengths, 30mm and 40mm.
-------------------- Mike
Stuff that I use:
- 7" f/6.7 home-built Newt and equatorial platform
- 6 eyepieces and a Barlow
- 120mm f/8.3 home-built grab-n-go Newt
- Canon 15x50 IS and Eagle Optics 12x50 Ranger binoculars
gnowellsct
Reged: 06/24/09
This is more typically a complaint about the XW20 at F4 or F5 than f/7. I'd like to know what you think of the eyepiece in your 9.25.
Your scopes do have their own field curvature, this is the first I've heard of someone unhappy with the XW20 at f/7 in a refractor. In any case it is true that the XW14 and the XW20 are the two eyepieces that get the most negative reactions in the XW line, usually from owners of fast scopes.
It would be interesting to know how you like the eyepiece with a field flattener in your refractor.
The XW20 may not be for you, some eyepieces just don't work for some scopes. I like the XW20 a great deal in my Vixen ED double f/6.5.
I have read that the ability of the eye to focus out the effects of field curvature varies from individual to individual, you might be more sensitive than other people.
I'm sorry to read of your disappointment. I am a big booster of these eyepieces. But I wouldn't recommend the XW14 or XW20 as a FIRST XW eyepiece due to the mixed reactions. I would have recommended the XW10.
regards greg n
Greg N
-------------------- "Aperture will get you through times of no money better than money will get you through times of no aperture."
featuring selected astrojunk:
bunch o' widefield eyepieces
bunch o' narrowfield eyepieces
couple o' Barlows
couple o' scopes
couple o' mounts
couple o' tripods
and a pier 'n' stuff
Deep13
Reged: 01/25/05
Loc: NE Ohio
That seems surprising in an f/7 refractor. I have the 14 which has field curvature in my 12.5" f/5, but I don't notice it in the 8" f/6 or the TV101.
-------------------- That which can be asserted without evidence can be dismissed without evidence.
RAKing
Reged: 12/28/07
Loc: West of the D.C. Nebula
This is always quite interesting. I also had problems with the 20XW, but the 14XW is superb in my C925.
I suspect our eyes are also contributing to the differences, as mentioned in the above posts.
Ron
-------------------- Time spent looking at the stars is added to your life.
Tak FS-128, C925-CF, C6SE, other stray cats and refractors.
A-P Mach1 GTO
Zeiss orthos to Ethos - and some stuff in between.
BillP
Reged: 11/26/06
Loc: Vienna, VA
FWIW I got a peek thru the XW40 this week thru the 12" Clark Refractor at the US Naval Observatory. Having previously owned things like the 40 Paragon, 35 Pan, 40 Titan-II ED I have to say I was taken at just how more compact the 40XW was...not to mention its superb performance and really easy eye placement. It's on my list now for a future purchase A really nice 40!
-------------------- Bill Paolini
XT10i Dob---TSA-102 S-APO---APM80/480 S-APO--- P.S.T.
TMB Supermonos---Meade UWAs---TV Panoptic---AT Titan II ED
To your own eyes be true...
Mike Hosea
Reged: 09/24/03
Bill, I love my 40XW, but could this perception about it being much more compact have anything to do with it being in a 12" Clark refractor at the time?
Stuff that I use:
BillP
Reged: 11/26/06
Loc: Vienna, VA
starcam
Reged: 09/24/07
Loc: MD
A few things spoiled me the naglers and being on here learning to be more critical of the views. I luv the xw10,7 and xo5 and the zoom is awesome for the sun and night sky observing,when I'm lazy. I picked the xw20 because it supposely had less curvature than the 14 and I already have the 13t6. The xw40 works well the sv102ed2 f/7, but in the c9.25 f/10 there was a lot of curvature. I will try the xw20 in the c9.25 maybe this weekend. All is not bad as for nebula viewing, the XW20 smoked the 22pan, in light through-put. The 22 pan had less curvature to these aging eyes. I know I don't have top of the line scopes, but I saw more rave reviews then negative one's about the xw20. Wasn't sure if Hoya changed the eyepiece.
Coronado PST
CG-5
UWAN 28mm
Panoptic 22mm
RKE 8,12,15,21,28
Hyperion 5,8,17/13
TMB 2.5,4,6II,7,9
Brandon 6,8,12,16
UO HD 7mm
Oberwerk bino 15x70
Burgess 8x42 bino
WO binoviewer
gaz-in
Reged: 12/17/07
Should using the XW 14 and/or XW 20 with a Paracorr allow one to correct the field curvature issues?
ausastronomer
Reged: 06/30/03
Loc: NSW Central Coast (Australia)
Yes it does and extremely well. I use the XW's from 5mm through to 20mm in my 14" and 18" F4.5 scopes without issue.
Something to note, which 95% of people get wrong and several in this thread have already got wrong.
The field curvature perceived has nothing to do with the F-RATIO of the telescope.
It is dependant on many things, including
1)the FOCAL LENGTH OF THE TELESCOPE and the RADIUS of CURVATURE OF THE PRIMARY OPTIC . Of course for a given aperture a long focal length scope will have a slower F-ratio than a short focal length scope and less field curvature. This is where the incorrect assumption comes from that field curvature is related to F-ratio. My 18"/F4.5 Obsession has clearly a lot less field curvature with the 14mm and 20mm XW's than does my 10"/F5 newtonian. This is beautifully corrected in both scopes with a paracorr.
2)The design of the telescope is critical as to whether it has +ve or -ve field curvature and whether that matches and compensates the field curvature inherent in the eye piece design.
3) The ability of the observers own eyes to "auto adjust" or compensate for slight out of focus. This ability can vary enormously from one observer to the next and is generally the reason why field curvature bothers some people yet doesn't bother others.
In regard to the performance of the 14mm and 20mm Pentax XW's in SCT's I offer the following. Notwithstanding the scopes are slow at F10 (see my comments above re F-ratio) the C9.25 has an F2.5 primary mirror with a very short focal length of about 23" and a very tight radius of curvature. Because of this there is a large amount of field curvature inherent in the SCT design and they will not work well with these eyepieces.
-------------------- John Bambury
AS of NSW
AS of Hunter Valley
18"/F4.5 Obsession fully loaded with OMI optics
14"/F4.5 SDM fully loaded with Zambuto Optics
10"/F5 Newtonian with Argo Navis
Lots of Pentax XW's. 12mm & 17mm Nagler T4's, 31mm Nagler T5 & 13mm ETHOS. TV Paracorr and 1.8X TV Barlow and 2.5X TV Powermate
Mike Hosea
Reged: 09/24/03
Sorry, but you're totally wrong about that.The f-ratio determines the exit pupil diameter, which in turn affects the depth of focus of the eyeball. It's a simple optical fact, quite incontrovertible.
Stuff that I use:
russell23
Reged: 05/31/09
Loc: Upstate NY
My 20mm XW is great in my 120mm f/8.3 refractor - very sharp almost to the edge. However, I tried it in a 150mm f/5 refractor and found the same problem in the outer 25% of the field that you describe.
Dave
ausastronomer
Reged: 06/30/03
I don't agree. The F-Ratio in fact affects nothing, including determining the exit pupil diameter. The exit pupil is affected by 3 things:-
1) The focal length of the telescope 2) The aperture of the telescope 3) The focal length of the eyepiece
It is convenient mathematics that the exit pupil can be calculated by dividing the eyepiece focal length by the f-ratio of the telescope. That happens because the F-Ratio is a function of the first two things. Change either of the first two things and you also change the exit pupil and because it is a function of them, you also change the F-ratio.
AS of NSW
AS of Hunter Valley
gnowellsct
Reged: 06/24/09
Actually the XW20 probably didn't smoke the 22 Pan in light throughput; possible, Televue tends to run a few % behind Pentax (so far as results are posted anywhere). But more likley is that the manipulation of the field in the Pan Optic smears out stars a bit with the resulting tendency to make the fainter ones disappear. Which is throughput of a sort.
The only defect I've noticed in my C14 and f/6.5 refractor with the XW40 is my own eyes: when I got the dioptrx running, my XW40 mysteriously became crystal sharp edge to edge. If you haven't been evaluated for astigmatism lately, you might consider that. When we evaluate eyepieces we are pushing everything to the max, including our eyeballs.
Greg N
couple o' Barlows
couple o' scopes
couple o' mounts
couple o' tripods
gnowellsct
Reged: 06/24/09
I got a number of reports after I posted my astromart article on Pentax that in fact the XWs become wonderful with the paracorr. But I'm not sure I'd want to put a paracorr on original post's f/7 Stellarvue refractor.
Greg N
couple o' Barlows
couple o' scopes
couple o' mounts
couple o' tripods
Mike Hosea
Reged: 09/24/03
I think I see where you're coming from. For some reason you don't want to regard f-ratio as a first-class variable. Suppose I have a function f(x,y) = c*(x/y). All we're doing here by using f-ratio is studying instead the relationship g(z) = c*z, where z = x/y. Obviously, g(z) = c*z = c*(x/y) = f(x,y). People are pointing out (correctly) that their perception of curvature depends on z, whereas you are trying to convince us that it only makes sense to think of it as depending on both x and y. You're not wrong to say that it depends on both x and y, but you are wrong to assert that it doesn't depend on x/y, i.e. on z.
Stuff that I use:
ausastronomer
Reged: 06/30/03
Mike,
I think you are clearly missing the point I was originally trying to make. Possibly I also didn't choose my words carefully enough.
People are "incorrectly" assuming that because they have a fast F-ratio telescope they will see field curvature. I am trying to say that because of the F-ratio alone this isn't necessarily so.
For instance a 30"/F4.5 newtonian will show less field curvature with these eyepieces than say an 8"/F6 newtonian, by virtue of its much longer focal length and radius of curvature of the primary optic, notwithstanding that it has a faster F-ratio and a shorter depth of focus. My 18"/F4.5 to 10"/F5 comparison also demonstrates this clearly.
AS of NSW
AS of Hunter Valley
HfxObserver
Reged: 11/12/04
Loc: Regina, SK, Canada
So you are saying that because the Radius is large in the longer Focal Length scopes that the light beam is flatter as the larger radius appears shallow, compared to a smaller aperture same Ratio scope, when it intersects the eyepieces field element making it less curved.
I'm imagining two circles, one the size of an Orange, we can see this has a steep curve as we hold it in our hand....the other...lets say the size of the Earth...this appears flat yet they both have the same degree or ratio of angle.
If this line of reasoning was true then f/1 scopes would be all the rage....but it's the opposite since steeper cones are more easily gobbled up by eyepieces.
My understanding of optics is that we are taking the light into a cone, not a circle. So that in essence, the focal ratio does play a pivotal role. The steep cone of the slow scope is easier on eyepieces then the shallow cone of the flat Earth...er, I mean faster scope.
Feels good to put my philosophy degree to good use
-Chris
P.S I have tested my 20XW in several 8" f6, 10" f4.7 and 12" f5 scopes the results were best performance on the higher f the scope, not on the longest focal length.
-------------------- Chris
7X50 Vixen,22X100 Antares
80mm William Optics Megrez II ED
Santel MK6
Borg 125SD f6 (Pentax/Oasis version)
Tak-Lapides
Pentax XW's 40,20,14,10,5mm XO, 3.5, 3.8XP, Speers 5-8, 30mm Widescan III
Tiny
Reged: 05/02/08
not to ask a stupid question here but why would a coma corrector/paracorr correct curvature in an eyepiece when the light is passed through the eyepiece last?
wouldnt the image simply be distorted by said eyepiece?
It also goes against the suggestion by televue to use eyepieces that themselves have good edge correction. If the above was true then you'd be able to use any piece of junk with amazing results, which... isnt true in my experience.
By the way OP, if that was a deal breaker for you, you'd probably enjoy a Meade UWA. Very flat field with pinpoints to the edges. You lose the great Eye Relief though.
ausastronomer
Reged: 06/30/03
Your analogy is close to how it works but not quite there. You are correctly understanding that the optical surface of a longer focal length optic has less curvature than the shorter focal length optic and your example is a good one. However the intercept of the light cone with the field lens of the eyepiece has nothing to do with the field curvature of the telescope. The field curvature of the telescope primary optic (not the eyepiece) is dependent on the Radius of Curvature (ROC) of the primary optic and its inherent design. The observed field curavture at the eyepiece is then dependent on matching and cancelling the field curvature of both the telescope and the eyepiece.
No, this isn't so. As the light cone gets steeper aberrations other than field curvature, like coma and off axis astigmatism get infinitely worse.
Absolutely true, but not in respect of field curvature. The shallower light cone will greatly improve eyepiece performance in terms of visible coma, off axis astigmatism and lateral colour. This is the reason you can use cheaper eyepieces in slower F-ratio scopes and they can perform reasonably well, yet perform poorly in fast scopes.
That's because all of those scopes are still fairly close in focal length and other aberrations could also be coming into play. In addition the slight increase in focal length may not be sufficient to compensate for the shallower depth of focus. Compare the 10"/F4.7 to an 18"/F4.5 and you will see what I am talking about. The eyepieces will work much better in the 18" scope.
AS of NSW
AS of Hunter Valley
Mike Hosea
Reged: 09/24/03
I don't think anyone presumes that f-ratio is the only factor. Other factors may indeed override the effect of f-ratio because they have a bigger effect, but this is a far cry from being able to say that f-ratio doesn't determine anything.
If you run the numbers on the curvature of a 10" f/5 versus an 18" f/4.5 using a 20mm Pentax XW, the curvature of the primary optic doesn't look very promising as an explanation of anything. We're talking about 0.06mm of focuser travel at the edge of the field in the 10", 0.04mm in the 18". That's a difference of 0.02mm. A typical eyepiece might need 1mm of focuser travel, often more. Maybe it's the difference in astigmatism rather than curvature in the longer instrument.
Stuff that I use:
ausastronomer
Reged: 06/30/03
I don't know why it works but you can take it to the bank that it works and works very well (with a fast newtonian). The paracorr also does a good job of cleaning up some aberrations other than coma inherrent in some other eyepieces. For example, the 17mm Nagler T4 isn't a great eyepiece in a fast newtonian without the paracorr. It is an exceptionally good eyepiece with a paracorr and one of my favourites.
There is a limit to what the paracorr can fix and be rest assured the 14mm and 20mm XW's and the 17mm Nagler are far from "any piece of junk". They are outstanding eyepieces which display slight single aberrations. With cheap eyepieces they have a dozen issues all going on at once. Also keep in mind that the totally aberration free perfect eyepiece, has yet to be designed or created.
AS of NSW
AS of Hunter Valley
ausastronomer
Reged: 06/30/03
Mike,
There is minimal astigmatism in both eyepieces. The EOF aberration is field curvature. I do know the difference between the two.
AS of NSW
AS of Hunter Valley
Mike Hosea
Reged: 09/24/03
My comment was referent to the telescopes, not the eyepiece. Astigmatism is lower in the longer focal length optic, i.e. the tangential and sagittal surfaces are closer to one another, minimizing the possibility of any unusual reinforcement or cancellation of that in the eyepiece (the 20mm XW). I don't know if this matters. I'm having a hard time figuring a theoretical explanation for your observations that would have the right magnitude of an effect. My own experience masking down an aperture only demonstrates the importance of f-ratio to perceived curvature. I have no experience trying to compare field curvature of eyepieces in both small and large Newts of the same f-ratios.
Stuff that I use:
BillP
Reged: 11/26/06
Loc: Vienna, VA
I'm guessing you mean the outer 25% of the stars were unfocused? In any event (PMed you also), I gave the 20XW vs the 19 Pan a whirl in my f/8 TSA-102 tonight. Of course field curvature is evident using either eyepiece. Choosing the Double Cluster as the target I centered it in the FOV and chose an out of focus star near the field stop using the 19 Pan. It took approx a 160 deg turn of my fine focus knob to bring that star into focus again. Switching to the XW and redoing the experiment, the same star needed approx a 180 deg turn of the fine focus knob to refocus. So although the XW needed a little more, field curvature was shown by both EPs (obviusly a combo of that coming from my objective and some contribution from the EP).
However, even with the little extra out of focus way off axis, overall I felt the rendering of the view in the XW was quite a bit better than what I was seeing in the Pan. Dimmest stars were obviously more pronounced in the XW and much easier to see with direct vision. Overall the impression thru the XW was of a "clearer" view and the 19 Pan in comparison seemed slightly veiled in appearance. Whether it was better transmission or contrast or some combo of attirbutes is anyone's guess since hard to really pin down what is the driver. Regardless, better looking star field thru the XW and was very easy to notice the cleaner looking view. Off-axis I didn't feel the stars looked any more non-pinpoint in either EP. Extra eye relief of the XW was much appreciated also...could have used that last evening as it was cold and damp and my Pans were fogging after each view thru them :-/
As a side note, was interesting that the XW needed a whole bunch more infocus compared to the Pan (or put the other way, the Pan needed a lot more out focus than the XW). I always find it interesting when same FL EPs need such vastly different focus travel.
Edited by BillP (11/03/09 11:02 PM)
starcam
Reged: 09/24/07
Loc: MD
Yes, i said it wrong, the outer 25%. That's why I don't do reviews, what I mean and what I type, make people confused.I'd be interested in your viewing of nebula's comparing the 2 eyepieces. I really like the 24 pan my 22pan is almost in the for sale bin.
Coronado PST
CG-5
UWAN 28mm
Panoptic 22mm
RKE 8,12,15,21,28
Hyperion 5,8,17/13
TMB 2.5,4,6II,7,9
Brandon 6,8,12,16
UO HD 7mm
Oberwerk bino 15x70
Burgess 8x42 bino
WO binoviewer
BillP
Reged: 11/26/06
Loc: Vienna, VA
In the XW, M42 showed itself a little brighter overall, with the dark lanes/regions being a little more pronounced, and the extent of the "wings" appearing just a little greater. I would not put the difference as being a big one, but noticable with careful viewing (except for the overall brightness which was a easy first impression when switching from the 19 Pan to the 20 XW).
Both great EPs, but the XW definitely edges the 19 Pan out IMO in many areas. Nice EP. Now if Pentax would only come out with a 24 XW
