JimmyK
Reged: 03/24/07
Greetings,
Based on the two scope I have, could someone make a suggestion of "....if I had the same two scopes, and I could only buy one Nagler, I'd choose the __mm."
So far I am looking at either the 5mm, 7mm, 11mm, 13mm. I figured at $259 the price is not that bad if indeed it really enhances the views. I like Planets with the 150mm and the 10" does well on the DSO's.
Any suggestions, including a different size is appreciated.
Thanks guys!
Jimmy
-------------------- Z10" Dob
Orion 150mm Mak-Cas on a CG-5 Advanced Go To
25x70 Binos
"The heavens declare the glory of God;
the skies proclaim the work of his hands."
MitchAlsup
Reged: 08/31/09
MY first thought is 31mm or 26mm because these are simply superb for deep sky, however you are targeting a different area of the magnification.....
So, my second thought is that if you have a 2X barlow of powermate, the 11mm and 13mm essentially become the 5mm (5.5mm) and 7mm (6.5mm). In this case its pretty much of a toss up, so I will pick the 13mm because this was the first Nagler I got (back in 1990).
Be warned, if you do get 1 Nagler, you WILL want a lot more.
FirstSight
Reged: 12/26/05
Loc: Raleigh, NC
17T4 Nagler is the most versatile for a dob of your aperture/focal length, and has the bigger eye lens over the T6 line which gives the 17T4 more of a widefield "spacewalk" experience than the 13T6, even though both are technically bona fide 82-deg AFOV EPs. You can pick these u for around $300 (sometimes around $275) used, in good condition.
That said, the 13T6 would be my second-place nominee, a very solid choice in its own right.
NOTE: I have the 31T5, 26T5, 17T4, and five consecutive T6s from 13mm through 5mm inclusive. I think the 31T5 is the finest low-power widefield eyepiece in existence. But if I could pick only ONE among the whole bunch, it would be one of the two I nominated above, in the order indicated.
-------------------- Chris M., aka "First Sight"
Orion XT12i Dob with Moonlite CR-2 focuser
WO Megrez 90 refractor on UniStar Light mount
Nikon 10x50 Binoculars
hfjacinto
Almost got me
Reged: 01/12/09
Loc: Union,NJ
I have the 11MM and while it is a nice eyepiece, the eye relief is a little on the short side. If you get the 5-13 be prepared for short eye relief.
-------------------- C9.25 ASGT 9*50 MM Finder,FT Focuser & 2" Diagonal
Meade LXD 75 6 Inch SNT w 9*50 MM Finder
5,6,9,14.5 MM Zhummel Planetary EPs
13,17,21,24,31,36 MM Baader Hyperion
6.7,8.8 MM Meade UWA & 11 MM Nagler T6
Planetary, OIII and Narrowband Filters
Thousand Oaks Dew Control w Kendrick Heaters
astro744
Reged: 09/22/07
12mm T4 Nagler. Big eye lens and good eye relief.
On the Mak it will give 150x (assuming 1800mm f12) and 1mm exit pupil. Great for planets.
On the Z10 it will give 104x (assuming 1250mm, f4.92) and 2.4mm exit pupil. Great for DSO's. (120x with Paracorr).
Erik Bakker
Reged: 08/10/06
Loc: Haren, The Netherlands, Europe
I suggest the N 16 T5. Compact with great performance in your scopes.
CS,
Erik
-------------------- Visual astronomer, main instruments:
Fully mounted Questar 7 P-BB
Celestron C 102F f/8.8 fluorite
Vixen FL 70S f/8 fluorite
Celestron C 55F f/8 fluorite
Sets of Zeiss, TeleVue and Brandon eyepieces
Zeiss 7x50 Marine B/GA
Zeiss TM german equatorial
Gitzo 224 with Manfrotto 501 fluid head
Unitron alt-az mount
Lane
Reged: 11/19/07
Loc: Frisco, Texas
I personally believe the T4s are the best of the Nagler line so I would get either the 22mm, 17mm or the 12mm. Based on the focal lengths of your scopes the 12mm is probably the best choice for you.
-------------------- Mounts: CGEM, ORION SIRIUS, AT Voyager/motorized
SCTs: C6, C8, C9.25, C11,
Refractors: TV Pronto, Orion ED80
SteveG
Reged: 09/27/06
Loc: Seattle, WA
I agree with either the 13T6 or 16T5 as they are small, easy to use, and barlow well. I did not like the 17T4 - not as sharp or contrasty as the 16T5. The 17 was big, clunky, heavy, and has a terrible moving barrel as all type 4's have.
Another thing that is bringing me to the full line of T6 is they're parfocal, with the 16T5 too. It is really nice just slipping them in and not having to refocus except for very minor adjustment.
-------------------- WO Megrez 110 ED on SP Mount
10" Meade LightBridge
Orion ED 100 on Polaris Mount
6" f8 Edmonds reflector on GP Mount
4.5" F8 Orion EQ Reflector
Astroscan
Meade 226 2.4" f11.7
cuzimthedad
Just Be Cuz
Reged: 04/09/06
Loc: Sonoma, Northern California
I'm a T4N fan but have owned all the T6 line and would suggest, if possible, that you do a comparison between the 11 and 13 T6s. Of course, the 12T4 falls right in the middle. If it were me with the two scopes you own, I would go with the 13T6. It can always be barlowed.
-------------------- Dan
20" f/5 Obsession
Antares 1529
TV102
Various Naglers, Ethos, UO Orthos and TV Plossls
The Off Fisher Lane Irregulars
JimmyK
Reged: 03/24/07
I really appreciate the responses. I already know I am out of my class in such a discussion. Far too new to this not to take heed to the voice of experience I find on this site.
Honestly, I don't know T4 from T6 but I am leaning very heavy towards the 13mm T6. I know it will out perform the EP's I currently have in both Scopes.
Up to now, one of my favorite EP's has been the Orion Edge On Planetary 12.5. The fact is it has only gotten me wanting more.
So I bought a Meade Series 5000 Ultra Wide 6.7mm and hoped to see more. There is a huge round dark shaded area that really hampers the views center of EP out to 3/4's of the viewing area. This is one of the reasons I have decided if I am going to buy anymore EP's (which of course I will, I am going to do it right the first time and quit trying to find a "deal" based on an add. It is hard to find an advertizement that does not act like they just broke the code on how to slice bread.
I have read so much here from the guys and the Nagler continues to dominate the discussions.
I recognize there is a good chance that once I get one, well I will probably be hopelessly addicted. I have been warned so I only will have myself to blame.
Warm Regards
JimmyK
25x70 Binos
SteveG
Reged: 09/27/06
Loc: Seattle, WA
Jimmy
If you're looking to save money, I might suggest you look for the older style Naglers on the used market. My 9mm (we call these type 1) is still one of the very best in my eyepiece case. This one get's a lot of use in my 10" dob. I'm frequently seeing these go for $150 - an absolute bargain. The type 6's are going for around $200 used. I just bought a 9mm T6 so I can compare it to my older 9 Nagler. The only reason I picked up the T6 is that it will be parfocal with my 13T6 and 16T5, and a little more convenient to use due to it's smaller size.
Astroscan
JimmyK
Reged: 03/24/07
Hi Steve,
To be honest I am not too worried about "saving" money. What I don't want to do is "waste" money in a field I know little about. I have taken a sort of "learn by experience" approach and throwing money into blind hope makes for a heavy EP case.
I recognize there are no doubt many good options on the used market. A 13mm T6 is roughly $275 delivered new and I do get to order at the time I choose rather than "have to gab it now".
I appreciate your comments.
Thanks! JimmyK
25x70 Binos
cuzimthedad
Just Be Cuz
Reged: 04/09/06
Hi Jimmy. On the Meade ultra wide, have you tried adjusting the twist up eye cup to get a better more comfortable view? I've owned the set at one time and they are really good eyepieces.
20" f/5 Obsession
Antares 1529
TV102
JimmyK
Reged: 03/24/07
Hi Dan,
To be honest I have not adjusted the twist up eye cup. I assumed by moving to and from the EP physically that I would see some difference if that is the case. I don't know enough about this stuff to make such an assumption so I will take it back out Sat night and mess with it more.
JimmyK
25x70 Binos
cuzimthedad
Just Be Cuz
Reged: 04/09/06
Good. The twist up eye cup does make a difference for eye placement.
20" f/5 Obsession
Antares 1529
TV102
FirstSight
Reged: 12/26/05
Loc: Raleigh, NC
GO FOR IT! I like my 13T6 so much that I kept it even after I got a 13E, and never plan to part with it. I'm a huge fan of the enormously expansive "spacewalk" the Ethos series provides (got a bunch of them too) but...there's many times when the 13T6 simply frames an object for individual study in a more pleasing way...tighter, but still extremely generous by any standard other than the Ethos.
You really can't go wrong with the 13T6. Or for that matter, with the 17T4 or the 12T4, but since your inclinations say go with the 13T6...I'd say by definition you've made the right choice.
BTW: The 16T5 has a rep as one of the more pleasingly sharp among the entire Nagler lineup, and has the max TFOV available in a 1.25" format (the slightly greater TFOV of the 17T4 comes in a 2" format)...BUT BIG CAVEAT: it has the tightest eye relief out of the entire Nagler lineup, which doens't bother some people but is prohibitively tight to many. I wouldn't choose this one without a chance to look through one under the night sky first. It may be the cat's pajamas, or it may be the cat's litter box, depending on your take on this issue.
ENJOY. (And watch out: if you like it, the Naglers are addictive, hard to stop with just one).
Edited by FirstSight (10/30/09 02:53 PM)
JimmyK
Reged: 03/24/07
Hi Chris,
Thanks and yes I have made my decision and the 13T6 will in fact be my first Nagler. I suspect from all I have read here on Cloudy Nights that I will be quite pleased with the purchase.
I started here in March of 07 and knew nothing whatsoever beyond the fact I wanted to "look up". From reading and asking questions I settled on the Z10" as my first Scope. I realized there were many other options but the Z10 seemed to best suit my bill at the time. It was in fact a good purchase. Easy to use, set up and maintain.
I then added the Mak/Cas but never really got that much use out of it until I changed out the Mount. I knew I did not know enough about the Sky and having a GT makes all the difference in the world to me. Now I am getting to places I once dreamed of but recognize the final piece that needs to be added are better optics via better EP's.
I am thinking a decent Nagler, coupled with the GT Mount driving a fairly decent little Mac/Cas will keep me busy for awhile. It will be a matter of time when new additions will be made I know but I think this will suffice as I learn more about the Sky and make better use of what I already own.
You and everyone here have been great and I appreciate the willingness folks here have to properly advise a new guy, not to mention the patience in so doing.
Thanks all!
JimmyK
25x70 Binos
HoundDog
Reged: 04/01/04
Loc: Greenwell Springs, La.
Hi Chris,
JimmyK
You have made a good choice. The 13T6 seems to hit the "sweet spot" for my scope and gives me great views for both planetary viewing and DSO's. I wrestled with the 12T4 vs. 13T6 decision prior to my purchase and went with the T6 due to it's smaller size and lighter weight for use on my Discovery dob. I wear glasses and don't mind removing them to get up closer to the eyepiece but if I fold down the T6's rubber eyecup, I can use the eyepiece with my glasses. Enjoy your 13T6, I certainly am enjoying the heck out of mine!
Ernest
Discovery DHQ 8" F7 Dob
Oberwerk 8x56 Binoculars
An odd assortment of eyepieces and other stargazing stuff
Two worthless cats!
hfjacinto
Almost got me
Reged: 01/12/09
Loc: Union,NJ
Jimmy,
I have both the Nagler and the Meade UWA and there is very little if any difference between them. I can see the same in both. I actually like the UWA more, because with the twist up eyecup it is easier to get to a point that eye relief and FOV are both maximized.
kaaikop
Reged: 07/13/08
Loc: North of the Montreal nebula
Congrats on the new Nagler Jimmy! You gonna love the 13mm, it's an awesome eyepiece, and it barlows very well as a bonus.
But you've been warned about the devastating addiction...
-------------------- Benoit, RASC Montreal
-C9.25 on EQ6 Pro - C6/ED80 on Portamount
-TV Plossls, Radians, Nags, Pans, UO Orthos.
Brian Schmidt
Reged: 01/25/09
Loc: Roswell, GA
Another vote for the 13 T6---congrats on that one! I used to use a 15mm Ultrascopic, which is a great eyepiece by the way, in my 8 inch dob. Earlier this year I got the 13 T6 and it really is my all around go to ep. It shows almost everything well, except for the larger opens. Even the planets look good in it, even though I usually use the 7 T6 for high power viewing. Honestly, that is my most used ep.
-------------------- Brian
Tiny
Reged: 05/02/08
im in the process of comparing my naglers to ES 82*s and to be honest im not seeing much of a difference.
If you want to stick with naglers, more power to you. They're proven eyepieces and are fantastic. You also wont take a very large hit if you sell any second hand. However dont think that Naglers are the end all be all of wide fields.
gtown1
Reged: 11/07/08
One eyepiece is not a good solution. You should have at least three--a low, a medium, and a high power eyepiece. You could start by purchasing a low and medium power eyepiece then add the high power one later.
-------------------- Happy owner of an Obsession, 18 inch Ultra Compact and a Mag 1, 12.5 inch Porta Ball.
Pete Kopfer
Reged: 12/01/08
...I have made my decision and the 13T6 will in fact be my first Nagler. I suspect from all I have read here on Cloudy Nights that I will be quite pleased with the purchase...
Not that you probably need more validation but I like your choice. I think you are really going to like this eyepiece in both of your telescopes. I'm always amazed at how small the 13mm really is, especially when you consider what an expansive (and sharp!) view it provides. My first TV too.
Pete
JimmyK
Reged: 03/24/07
xxx
Greetings,
Sorry if I left the impression this was my only EP. I am just not happy with what I have so far accumulated.
I have the following;
Burgess/TMB Planetary Series 2.5, 4, and 9. Mead UAW 6.7 Orion Edge On Planetary 12.5 Orion Sirius Plossl 25 Mead Super Plossel 32 Agena Astro UWA 15 (2 inch) Zhumell WF 26 (2 Inch) GSO SuperView WF 30 (2 Inch) Mead MA 25 Mead MH 9 Zhumell Plossel 9 Orion Sirius Plossel 10 Mead 2x Barlow and an unnamed 3x
Just looking to refine the views now. I can see there's more to see in what I'm seeing.
Regards
JimmyK
25x70 Binos
starrancher
Reged: 06/09/09
Loc: Northern Arizona
Cheeese ! All I have are Plossls !................. Oh ! ...By the way , .....Did I mention that I love my Plossls ?! I love all of my Plossls !
-------------------- LXD75 AR5
LXD75 SN8
Series 4000 Plossls
Misc. other stuff
Fort Rock , Az .
j3ffr0
Reged: 07/06/08
Loc: Virginia
Congrats on the 13T6; I'm sure you will love it. The 13T6 was my first Nagler too. It's remains one of my favorites (second only to the 16T5).
-------------------- 10" Dob, 127mm Mak, 120mm f5 achro, PST
35, 24 Panoptic; 16, 13, 9, 3-6 Nagler
15, 10, 7.5, 5, 3.8 Ultrascopic
20, 15, 9, 6 Expanse
PJF
Reged: 05/06/04
Loc: UK
...gives the 17T4 more of a widefield "spacewalk" experience than the 13T6, even though both are technically bona fide 82-deg AFOV EPs.
(emphasis added)
The 13T6 is not an 82-degree apparent field of view eyepiece: it doesn't even break out of the seventies. Whatever bona fide technical merits it has, an 82-degree AFOV isn’t amongst them.
Quite visually noticeable too...
-------------------- Peter
10x50 binocs
ED80 'frac
6" f/12 Maksutov
6" f/6 Newtonian alt/az
10" f/4.3 Newtonian alt/az
Bryce
Albie
Reged: 02/22/05
Loc: Alberta,Canada
-------------------- Starblast6
Stratus 24mm,Speers Waler 4.9mm 7.2mm and 9.4mm
Noble 10x28,Regal LX 8x42,Skymaster 15x70
astro744
Reged: 09/22/07
(emphasis added)
Yes. I have mentioned this a few times myself in previous posts. The numbers say it all as does visual comparison.
Here are the specs. of 3 Naglers:
13mm T6 field stop dia = 17.6mm 12mm T4 field stop dia = 17.1mm 11mm T6 field stop dia = 14.9mm
AFOV = fsd x 57.3/fl
13mm AFOV = 17.6 x 57.3/13 = 77.6 deg. (78) 12mm AFOV = 17.1 x 57.3/12 = 81.7 deg. (82) 11mm AFOV = 14.9 x 57.3/11 = 77.6 deg. (78)
The above calc does not take into acount any distortion.
Now to play with the numbers a bit more:
11/13 = 0.846 17.6 x 0.846 = 14.9
However, 11/12 = 0.917 17.1 x 0.917 = 15.7. The FSD of the 11mm should be 15.7mm.
15.7 x 57.3/11 = 81.8 deg (82)
13/12 = 1.08 17.1 x 1.08 = 18.5. The FSD of the 13mm should be 18.5mm
18.5 x 57.3/13 = 81.5 deg (82).
Visually through an 10" f6 Newt I could detect only the smallest increase in true field between the 12mm and 13mm Naglers. They were almost the same which means the 0.5mm difference in FSD is hardly noticeable which also means the AFOV cannot be the same.
Now after saying all of the above I do find the 12mm T4 a most pleasing eyepiece to use but also like the 13mm T6 for its compact size.
KRS1
Reged: 02/02/09
Loc: Anglesey, UK
Heres a spanner in the works, if money is not a problem get a 13mm Ethos
Skywatcher Heritage 130p
Orion xt10i (on the way)
Some eyepieces & a barlow, I'm just starting out.
Johndob
Reged: 12/22/08
Loc: Newport Beach,Ca
xxx
Greetings,
Regards
JimmyK
Keep us informed what you uncover with the 13t6 that you couldn't with your current EP'S. John
-------------------- Zhumell 10" Dob (Mods)
ETX-125PE UHTC
ETX-90AT
6"f/5 Newtonian
Classic 60x910
Ortho 6-7mm UO or.4mm
Meade 3000 5mm
Zhumell 2" ED Barlow
Zhumell 2" 32mm
UO. 2" 30mm
GSO 2" 26mm
GSO 40mm CPL
Hyperion 8,13,17,21&FTR
Zhumell 8-24 Zoom
ED 3.8mm,7.5mm
Owl SP4,10,15
Zhumell EP&filter set 1"1/4
Baader 2" Neodymium/IR-cut,CelestronUHC/LPR
Zhumell OIII,UHC,SkyGlow,Polarizer
Zhumell 20x80 Giant&
10x50 plus 3 More Bino's
Brunton Echo Monocular
JimmyK
Reged: 03/24/07
Hi John,
First decent weekend in The Hill Country I will be doing some comparisons and reporting back. Any notable differences, in particular at like magnifications will be documented.
I am most interested in comparing the Orion Edge On Planetary 12.5 ( $105.95 ) to the 13T6 ( $275.00 ). I want to see if the slightly better than 2 x the $$ is justified.
The difference of $170.00 is a front tire on a Harley installed which is what I will be thinking about as I compare the two.
The 12.5 produces 100x in my DOB while the 13T6 should produce 96.15.
In the MAK/CAS it is 144x compared to 138.46x.
I think this should be close enough to determine the actual worth and if more rubber on the road or sparkle in the sky is the way to go next time.
Regards
JimmyK
25x70 Binos
helpwanted
Reged: 07/04/07
Loc: Phoenix, AZ
while i love the SPL clones, it's not fair to compair it to a 13T6... that's the sharpest of all the T6s! ...i even don't like the T6 eyerelief! let us know your thoughts!
cuir
Reged: 03/03/07
Loc: Up north.
Good call on choosing the T6 13mm.
It is a fantastic FL for the 6" mak, bringing in a moderately high magnification that is almost always usable, even under the most miserable seeing conditions, and a nice, deep, yet low powered widefield for the 10" newton.
It will likely become "the" workhorse on the Mak.
-------------------- Seb
Eyepiece spreadsheet v6.8
Choosing the right eyepiece
Main scope: 150mm Maksutov
Scnd scope: 200mm Schmidt-Cassegrain
Favorite ep: 24 Panoptic and 11m T6 Nagler
Pref'ed filters: Lumicon 0III and UHC
Mounts: EQ6-Pro and Skyview AZ
Scott Watson
Reged: 05/26/06
Indeed. I have seen one on the shop & swap for $275...
cuir
Reged: 03/03/07
Loc: Up north.
The 17T4, most likely, cannot be used on his 6" Mak, which it probably a typical 1¼" part. Besides this, at 17mm of FL, this is going towards the widefield FLs, and the OP is clearly looking for a higher magnification eyepiece, and I quote:
... I am looking at either the 5mm, 7mm, 11mm, 13mm. I figured at $259 the price is not that bad...
