Stell
Reged: 09/27/09
If I decided to add a premium EP in the 13-14 mm category, what has your personal experience revealed would be your top recommendation: a 13/T6 Nag, a 14 Pentax XL, a 13 Vixen LVW or ???? (An Ethos or Pentax XW is out of my price range- Or would you recommend waiting/saving an extra year+ to get one of those over the previous list?) Looking for your experience/expertise on the matter, knowing full well that EP selection is always a personal preference. (Note: I own a Orion XT10i if it matters) Thanks. Stell
FirstSight
Reged: 12/26/05
Loc: Raleigh, NC
13T6 Nagler or a Pentax 14XW. My own preference would be for the 13T6 Nagler (got one, kept it, still use it sometimes even after getting a 13E). The eye relief of the 13T6 is plenty for me, and it's plenty sharp and I prefer the 82 deg AFOV EPs to the 70deg AFOV ones, but those two parameters are a matter of personal preference.
-------------------- Chris M., aka "First Sight"
Orion XT12i Dob with Moonlite CR-2 focuser
WO Megrez 90 refractor on UniStar Light mount
Nikon 10x50 Binoculars
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
If used is OK, I'd suggest a Meade S4000 14mm UWA.
-------------------- - Rick
14" LX200GPS
Dyslexics Untie!
hfjacinto
Almost got me
Reged: 01/12/09
Loc: Union,NJ
I agree with Rick, to my eye I really don't see enough of a difference between the Nagler and Meade UWA. I would probably get the UWA.
-------------------- C9.25 ASGT 9*50 MM Finder,FT Focuser & 2" Diagonal
Meade LXD 75 6 Inch SNT w 9*50 MM Finder
5,6,9,14.5 MM Zhummel Planetary EPs
13,17,21,24,31,36 MM Baader Hyperion
6.7,8.8 MM Meade UWA & 11 MM Nagler T6
Planetary, OIII and Narrowband Filters
Thousand Oaks Dew Control w Kendrick Heaters
nyc_nurse
Reged: 07/29/09
Loc: nyc
Hit the nail on the head. But some things that you need to consider. Need to wear glasses? If so then 13T6 is out and best choice would be the XW. Do you like seeing the field stop? Some people do and if you fall under that group then the Nagler is not for you. I have no problem seeing and using the 82deg with my 13T6 but I can't see the field stop unless I move my eye/head into the side of the EP. That's kind of the basis of the "spacewalk effect" and some people don't like it. And lastly, what are your observing conditions? If you're in a heavily LP area then many of the benefits or performance differences between EP's (besides FOV) becomes moot - save your dough but if you have decent skies then IMO differences will be seen and definitely go with the premium brands.
If you have decent skies, like not seeing the field stop and having an expansive view, then I don't think you could go wrong with the 13T6. About $200 on used market, add $60 to $75 for new.
-------------------- Sam P.
www.agirlandaguy.blogspot.com
Pentax 7X50
TV-102 APO w/ (Starbeam - on backorder )
Ash Gibraltar w/ SkyTour DSC
NZ3-6, N9T6, N13T6
TV 20 Plossl
Pan 24, 35
Pentax XW10, XW14
turtle86
Reged: 10/09/06
Loc: Red Sox Nation
Can't go wrong with the 13 T6.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
I think you will better off with the 13 T6 for that particular scope.
-------------------- Mounts: CGEM, ORION SIRIUS, AT Voyager/motorized
SCTs: C6, C8, C9.25, C11,
Refractors: TV Pronto, Orion ED80
ausastronomer
Reged: 06/30/03
Loc: NSW Central Coast (Australia)
That eyepiece will cause major balance issues in an XT10.
In addition I think it is 20 years behind the times in terms of coatings and glass technology. Throughput and contrast to my eye are noticeably inferior to modern offerings like the 13mm ETHOS, 13mm Nagler T6, 13mm Vixen LVW, 14mm Pentax XL & XW, 14mm Denkmeier.
I own a 12mm Nagler T4, a 13mm ETHOS and a 14mm Pentax XW, but if I was buying something for an XT10 and had $250 to spend I would be buying the 14mm Denkmeier in a heartbeat.
-------------------- John Bambury
AS of NSW
AS of Hunter Valley
18"/F4.5 Obsession fully loaded with OMI optics
14"/F4.5 SDM fully loaded with Zambuto Optics
10"/F5 Newtonian with Argo Navis
Lots of Pentax XW's. 12mm & 17mm Nagler T4's, 31mm Nagler T5 & 13mm ETHOS. TV Paracorr and 1.8X TV Barlow and 2.5X TV Powermate
bsim
Reged: 01/04/08
Loc: New York City
Most people with normal vision should be able to see the field stop of an 82 degree EP. For others it may require some practice in using the EP. You may be placing your eye too close to the EP. Use the rubber eyeguard of the 13T6 as a guide.
And another recommendation for the Nagler 13T6.
nyc_nurse
Reged: 07/29/09
Loc: nyc
Humm. My problem seems to be not being able to see the field stop clearly as a defined ring of black when I look into the EP with a light source in front. My eye picks up the lens edge on the front element, which is very close to the angular size of the true field stop but I can tell that it's a bit shy of it - regardless of eye placement. It seems like I would have an easier time seeing the field stop clearly defined if the front lens element was just a bit wider.
Pentax 7X50
NZ3-6, N9T6, N13T6
TV 20 Plossl
Pan 24, 35
Pentax XW10, XW14
ssatko
Reged: 03/05/05
Loc: NC
I'll provide a contrary opinion (but then, I've never used a Nagler 13T6, Pentax XL, or Pentax XW). If you're like me and prefer EPs with plenty of eye relief, the Vixen LVW 13mm is the way to go--mine is easily one of my most-used EPs.
-------------------- Scott
SV80/9D
SV102ABV
Orion 4.5" Starblast
Meade LX90 8" UHTC
Orion XT12i
I have an XT10i and also have the following eyepieces that fit your question: 13mm Nagler Type 6, 13mm Vixen LVW and 14mm Meade Series 4000 UWA.
The Meade is my fave for sentimental reasons, but the 13mm T6 has better throughput. The 13mm LVW is also excellent, but not quite the starry-vista-machine the other two are.
-------------------- "I do not know what I may appear to the world; but to myself I seem to have been only like a boy playing on the seashore, and diverting myself in now and then finding a smoother pebble or a prettier shell than ordinary, whilst the great ocean of truth lay all undiscovered before me."
- Sir Issac Newton
ssatko
Reged: 03/05/05
Loc: NC
Jim, do you say that because the LVW doesn't have the AFOV that the other two do, or in your opinion, are there other reasons as well?
SV80/9D
SV102ABV
Meade LX90 8" UHTC
Orion XT12i
RonBurgundy
Reged: 06/16/09
Loc: Philadelphia
14mm Meade UWA... I don't know about the 4000 series, but the 5000 series is amazing... And a LOT cheaper than the Nagler for what I feel is the same quality product--with more comfortable viewing imo. As far as I can see, it's superb. You won't be disappointed.
-------------------- Kipp Ginsburg
8" LX200-ACF
Orion 120mm F/5.0 Piggybacked Refractor
Meade UWA Set [4.7mm-30mm]
DSI-II
letimotif
No Complaints
Reged: 05/20/07
Loc: Far Flung Isles of Langerhans
Stell,
I think one of the great values available right now is the Vixen LVW. It's on sale at Astronomics for only $199.
68 degree field of view and marvelously sharp out to the edge. Televue EPs have their proponents, and I know folks who have them enjoy them. But, I honestly think the LVW represents an exceptional value with excellent (20mm) eye relief.
Take a look.
-------------------- Ah, but a man's reach should exceed his grasp, or what's a Heaven for?
Pete Kopfer
Reged: 12/01/08
13T6 should work great in your scope.
Pete
David E
Reged: 05/25/06
Loc: North Carolina
I agree! However the Pentax 14 has better eye relief for viewing comfort with eye glasses. I know Pentax's are more expensive, but if you're not in a hurry, dealers sometimes put them on sale, especially closer to Christmas. I'd shop around frequently.
-------------------- David E
If you keep a stack of old Orion catalogs in your bathroom, you might be an astro-redneck.
jack45
Reged: 07/07/03
Loc: Lacey WA
The Celestron Axiom 15mm LX, maybe another choice.
Clear Skies!
-------------------- 16"f/4.5 Discovery Split Tube/TV Paracorr
12.5"f/5 Discovery PDHQ
Orion f/4.9 XT12"Intelliscope
BV's/Bugress Model 24/Stellarvue Model BV3A
TV Smooth Side Plossls,7.4mm,10.5mm,17mm,21mm,26mm
Nagler EPs 9mm T/2,13mm T/1,16mm T/2,20mm T/2,26mm T/5
Axiom EPs 23mm,31mm LX,22mm Panoptic
UO EPs 5MM,6MM,7MM,12.5MM
Baader Hyp 8mm-24mm Zoom
oldtimer
Reged: 11/13/08
Loc: NW Illinois
Premium shemium, I really like my Stratus 13mm
backwoody
Reged: 01/08/07
Loc: Idaho USA
Stell, it's unfortunate that Pentax XWs are currently out of your price range; they are very, very high quality EPs, although the 14mm is known for some field curvature.
I'm another big fan of the Vixen LVW line. The 13mm is outstanding; no field curvature that I can see, very high contrast, eye relief that's so, so comfortable, tack sharp to the edge (at least in my f4.8 scope.)
Naglers certainly have their proponents, but the LVWs are hard to beat, at any price. I'd recommend trying one before buying anything else.
c/s,
-------------------- woody
a parsec farther out...
12.5" f/4.8 custom truss dob, EQ platform
CollinofAlabama
Reged: 11/24/03
Loc: Lubbock, Texas, USA
Stell,
Weigh your options. The T6 is the lightest of your choices and offers the most 'spacewalk' of these. The choice is pretty easy, isn't it? I own the 11mm T6, and it's wonderful.
CDS
-------------------- Coelum Serendum
darylf96
Reged: 08/28/04
Loc: Danville, California
At $159 the 14mm Meade Series 5000 UWA is a pretty good choice. In fact, I am considering adding a few of these EPs to my collection.
Clear Skies!
Daryl
-------------------- Intes Micro MN66 - Meade 10" SCT
Orion EON 120mmm ED f7.5 Apo
Skywatcher 150mm f8 Achro
G-11, CG5A-GT Mounts
DM-6 With Sky Commander DSC
Astro-Tech AT80 Refractor f6.9 APO
Stellarvue 20x85 binos - Unimount
Kunming United Optics 7x50 binocs
Canon Rebel XT, Canon 20D, Canon SXi
SBIG ST-8XE
ausastronomer
Reged: 06/30/03
Clear Skies! Daryl
I did a lot of the field testing for this eyepiece review and IMO the 14mm Meade S5000 UWA was a fairly average performer, when used in a 10"/F5 newtonian. It's EOF performance left something to be desired and it is not an eyepiece I would buy for use in an F5 newtonian. I haven't used any of the other focal lengths of the Meade S5000 UWA series but I have heard from experienced users the 14mm focal length is the worst performer of the series and the other focal lengths perform noticeably better in a fast newtonian than the 14mm.
AS of NSW
AS of Hunter Valley
Nope, purely the effect of AFOV plus eye relief. The 65 degree AFOV and 20mm eye relief combination of the LVW results in a very comfortable, well-corrected view, but not nearly as "immersive" as the 13mm T6 or 14mm Series 4k UWA, which have a wider AFOV plus shorter eye relief combination; these "suck you in" whereas the LVW lets you perch at a clinical distance and examine the field.
The LVW is a splendid eyepiece and at $199 on sale at Astronomics, it's hard to beat for value. To me it comes down to how much sky you want, and whether you care about how close you are to it when observing.
- Jim
- Sir Issac Newton
ssatko
Reged: 03/05/05
Loc: NC
Thanks for the info, Jim. Maybe one day I'll spring for a used 13T6 for testing purposes, but for the time being I'm really happy with my 13LVW.
SV80/9D
SV102ABV
Meade LX90 8" UHTC
Orion XT12i
Stell
Reged: 09/27/09
You guys are awesome! This is some prime feedback. 'Thanks' doesn't really do it justice. So let me run one more question past the experts: in your personal experience, how much better is a Nagler 13mm than a Vixen LVW? The difference in cost (buying each 'used') is at least $50-70 (more than 'change' to a parochial school teacher like myself). A study by a British astronomy group rated the 8mm LVW ahead of the 7mm Nagler in almsot every category except for FoV. Any correlation here? Sharing any first-hand experience would be greatly appreciated. Blessings. Stell
I have and have extensively used both the 13mm LVW and 13mm Nagler Type 6. I also own and have extensively use both the 8mm LVW and the 7mm Nagler Type 6. I've also read the British comparison review of the 8mm LVW and several other eyepieces you mention. I have also done more controlled testing of the 7mm Nagler Type 6 and 8mm LVW in last year's World Cup effort.
Here's how I'd sort out all of those things. First, the comparison review from Sky at Night includes comparison of a couple of non-performance criteria along with several performance-related criteria. In reading any commercial article that includes weighted factors that go beyond performance, I think you have to do some filtering to get to the "useful" information. That said, I think that if you cull the fluff from the review, you end up with pretty fair rankings among the eyepieces. That is, price dependent the 8mm LVW won, and price independent, it lost to the 7mm XW and matched the 7mm Nagler Type 6.
In the World Cup, our 8mm LVW was a quarter-finalist. Our 7mm Nagler Type 6 and 7mm XW were not, BUT we didn't exactly eliminate the XW "scientifically" and the eyepiece that ultimately won was an eyepiece that tied the XW in group testing. Net-net, the 8mm LVW is somewhere up there with the bets of the best 7mm and 8mm eyepieces.
Moving on to 13mm units, I haven't done the same kind of formal compaison (same night, same target, multiple observers, formal scoring system, etc.) with the 13mm Type 6 and 13mm LVW. I find that it us VERY difficult to extrapolate comparative performance based on observations on different nights, or of different targets. Many times I've formed such "seat of the pants" impressions, only to find them contradicted when I made the effort to compare apples and apples. With that caveat, SOTP I would say that the LVW is more comfortable than the Nagler, both due to eye relief and ease of taking the whole field in without walking the eye around. The Nagler, on the other hand, will show you a bigger slice of sky which may be important with an extended target, and to my eye is noticeably brighter. To confirm the latter, I would need to pick a cluster and do star counts, but in casual observing swapping between the LVW and Nagler I feel that the Nagler shows fainter stars on open clusters.
The beauty of buying a used Nagler Type 6 is that it is a no-risk proposition. The money isn't gone; it's just temporarily transformed into an eyepiece. You will likely get every penny back out of the Type 6 if you resell it. Rightly or wrongly the LVWs do not hold their value as well or as consistently on the used market. Partially this is because the manufacturer and one of its former resellers periodically discount the units. Orion had them for $189 at one point. This retail discounting impacts the used market as well. Still, if you check sales data for several years you can come up with a target price on the LVW that should be easy to hit on resale, and patiently wait to find a seller that will meet your price. That way, if you try it and don't like it, you can convert it back to cash without loss and try again.
I would probably pick one and try it. Resell it. Buy the other. Try it. Keep it if I preferred it or sell it and re-buy the first if not.
I really like them both, but I probably use the Nagler Type 6 more often. That doesn't mean that I think it's better. Rather, I prefer narrow field of view simple eyepieces. I am much more likely to be using a 12mm Brandon, 12mm Pentax SMC Orthoscopic, 11mm Televue Plossl, etc., than I am either the LVW or Nagler. When I reach for a complex, compound eyepiece, it's usually because I want a much wider field of view at the same magnification. The Nagler gives more context.
I use the LVW for public outreach. It is easy to use for anyone, and if you're sharing the views with others often, the LVW is more attractive than the Nagler or the simple, tight eye relief units.
Good luck!
- Jim
- Sir Issac Newton
backwoody
Reged: 01/08/07
Loc: Idaho USA
Jim, this is as nice a summary as I've seen. thanks.
Brian L
Reged: 11/17/08
Loc: The garden paradise of Pittsbu...
At mid-focal lengths, the LVW's are hard to beat in terms of price and performance.
-------------------- WO FLT-110 f/6.5, TEC optics
Losmandy G-11 Gemini
Meade 10" LX200 GPS/UHTC
Questar 3.5" Standard
Vixen VMC-110L
Canon 450D, unmodified
Assortment of TV Panoptic, TV Radian, Vixen LVW, and WO eyepieces
johnnyquest
Reged: 08/01/06
Loc: Washington
while the Meade 5000 UWA 14mm does have some limited edge distortion the 18mm of the same series is one of the finest eyepieces made. I would stack it against the Nagler 13mm any day
RonBurgundy
Reged: 06/16/09
Loc: Philadelphia
I know lots of people have had issues with their 5000 series 14mm UWA eyepieces... For the record, mine has never had any problems with its edge. Either I'm really lucky, or 1000 or 2000 others are just wrong. I suppose I'm lucky
8" LX200-ACF
DSI-II
bbcoltrane
Reged: 05/07/08
Loc: Fredericksburg, VA
When considering cost...DON'T BUY ANYTHING NEW! Go for the Nagler! You will NOT be disappointed. In fact, I would recommend a 12mm T2 Nager with 82 deg Afov over any 13~14 70 deg Afov piece. You'll get more Tfov AND more contrast. You can pick up a used 12mm T2 for $150~$200 on CN or Atromart. Good luck and clear skies, Brian
-------------------- Clear Skies,
Brian
W.O. Megrez 90
Meade AR-5
C8
LXD-75 GEM
TV 17mmT4
TV 12mmT2
TV 9mmT1
TV 7mmT1
TV 4mm Radian
Dark Sky Panels knock down observatory
iluxo
journeyman
Reged: 09/23/08
Another vote for the 3mm LVW, which is my favourite eyepiece. Comfort comes first, then image quality, and field of view third priority.
180mm f/15 Mak
ED102 f/7
Vixen NLVW30, LVW22,13,8 and Vixen LV50, 25,15,10,6,4
TMB40mm
Masuyama 45mm
