GreatGigInTheSky
Reged: 02/06/11
Loc: Santa Clara, California
Re: AutoStakkert! 2 new [Re: Sunspot]
      #5077750 - 02/17/12 09:59 PM
Thanks, Emil -- that's what I was looking for. It's not very easily discovered, though. Having something more standard may save you being asked the same question in the future. And yes, the remember checkbox is great, but may not help if you're going from imaging Mars, say, to Jupiter with moons...
Andy Taylor
Twisted, but in a Good Way
Reged: 09/24/08
Loc: Epsom - UK
Re: AutoStakkert! 2 new [Re: MvZ]
      #5080046 - 02/19/12 11:56 AM
Once I found a particular image size that I'm going to use more often, I simply click the 'remember' checkbox, and each following set of images will be cropped to the remembered dimensions.
Also a very useful feature for processing frames for animations...
I'm getting great results from this software - thanks Emil.
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
Re: AutoStakkert! 2 new [Re: Andy Taylor]
      #5080131 - 02/19/12 12:29 PM
Awesome work Emil. AS2 works very well. Here is a little comparison I did with some data I have.
larger: http://www.rankinstudio.com/dnloads/AS2.jpg
I think I am liking the AS2 / Astraimage combination best so far.
Color Example
larger: http://www.rankinstudio.com/dnloads/AS2-2.jpg
Cheers!
Edited by Rankinstudio (02/19/12 12:53 PM)
Sunspot
Reged: 03/15/05
Loc: Surprise, AZ
Re: AutoStakkert! 2 new [Re: Rankinstudio]
      #5080217 - 02/19/12 01:04 PM
Interesting. Looking at the colour images, I see some parts looking better with Reg6, for instance the barge, also the turbulent trail behind the GRS as well as overall in the equatorial region. Yet, the polar regions look better in A!S. The GRS itself is a tossup to me. This is the same sort of results I've been seeing with Jupiter as well.
Paul
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
      #5080232 - 02/19/12 01:12 PM
I agree Paul, it is a close call between the two. I will say a lot more effort went into the R6 version. Wavelets in R6, unsharp mask in PS, and then astraimage in PS, whereas the AS2 was just AS2 and Astraimage. They both do an excellent job of stacking, that is for sure.
GreatGigInTheSky
Reged: 02/06/11
      #5080320 - 02/19/12 02:00 PM
David,
Would you mind sharing what processing you're applying in Astraimage? I assume it's some flavor of deconvolution. I've been wondering about the possibility of skipping Registax completely when using AS2 for stacking.
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
Re: AutoStakkert! 2 new [Re: GreatGigInTheSky]
      #5080324 - 02/19/12 02:03 PM
Hi Jeff,
I am just using the wavelets in the astraimage PS plugin. I usually start with the large details then work up the finer detail sliders. Not using the deconvolution.
Asimov
Reged: 05/11/10
      #5081205 - 02/19/12 10:34 PM Attachment (51 downloads)
Emil. I'm just getting around to trying AS!2 on some Saturn data. I'm finding it almost completely obliterates the Crepe ring. Only a very small portion of it is visible. I've tried stretching it of course in the low, mid & high levels in all my editing programs including Registax. Even before using Registax waveletts it is not visible. In this particular example/AVI it is there in the RAW data as well as after aligning/stacking in Registax.
Any help would be very much appreciated as it gives a MUCH superior stack to Registax apart from this C ring problem.
Kokatha man
Reged: 09/13/09
Loc: "cooker-ta man" downunda...
Re: AutoStakkert! 2 new [Re: Asimov]
      #5081235 - 02/19/12 11:00 PM
Hope you can take the time to look at my thread again Emil and see what you can make of my questions to you therein...
John, can't help you at all except to say that I haven't found any problems with AS!2 and Saturn's Crepe Ring.....except to say (and I'm sure you'd appreciate this already) that gamma levels influence the Crepe Ring very significantly - but AS!2 shouldn't have any influence there on what you bung in.
Asimov
Reged: 05/11/10
Re: AutoStakkert! 2 new [Re: Kokatha man]
      #5081301 - 02/19/12 11:43 PM Attachment (49 downloads)
I was about to ask you Darryl, as you're the only other guy here that (I thought) had Saturn data.
Yeah I know..about the gamma etc. Here's a registax version with all (mostly) the same levels etc. It's got me beat!
I guess I'll work it out - Gotta be something I'm doing wrong..
MvZ
Reged: 04/03/07
Loc: The Netherlands
      #5081621 - 02/20/12 09:19 AM
Could you post (or send me) the raw stacks?
Have you tried turning off the "normalize stack" option in AS!2?
Asimov
Reged: 05/11/10
      #5081892 - 02/20/12 12:25 PM
Can do yes.
"Normalize stack" was immediately disabled by me right from the start. I don't use that in any stacking program or procedure.
Asimov
Reged: 05/11/10
      #5082282 - 02/20/12 04:13 PM
Actually I have 75% solved it by stacking a final from AS!2 & 1 from Registax. I'd be much happier that it didn't happen at all in AS!2 naturally. Image sent BTW.
Kokatha man
Reged: 09/13/09
      #5082573 - 02/20/12 07:21 PM
Hi Jeff - in defence of Emil on this point where you're referring to the use of the arrow keys on the keyboard to "fine adjust" the slider values, this is a standard keyboard operation (once you've clicked on the control) on just about every program application I know of.....not trying to sound clever, as I only discovered it about a year ago on something else and then found it was a universal operation almost.....
GreatGigInTheSky
Reged: 02/06/11
      #5082808 - 02/20/12 10:13 PM
Hi Darryl,
I take your point -- I've since discovered this in some other programs (Registax, Gimp on Linux...) -- I was just unaware of it. It's just my ignorance of UI conventions...
Kokatha man
Reged: 09/13/09
      #5082825 - 02/20/12 10:19 PM
Hi Darryl,
.....well, I was in the same boat untill I accidentally "discovered" it awhiles back Jeff - in my case, so much to learn, so little to fit it into..!
ps: talk about ignorance - what's "UI conventions"..?!?
GreatGigInTheSky
Reged: 02/06/11
      #5083064 - 02/21/12 01:05 AM
Darryl,
UI = User Interface. So UI conventions being the standard ways that users can manipulate controls. And you think I would have encountered this before, being a computer programmer by trade, but I work on web sites doing generally back-end server stuff, so I'll have to beg pardon on that basis.
Sunspot
Reged: 03/15/05
Loc: Surprise, AZ
      #5090897 - 02/25/12 07:27 PM Attachment (39 downloads)
Emil,
As you know I drag and drop bmp files onto stacking programs (either Reg or AS!2). It seems that when I drop the bmp files on AS!2, the last bmp in the stack shows up as the first one on the display. Since I use Ninox to sort, the last bmp should be pretty lousy and the first one should be pretty good. I captured a screen to show what I mean. Be sure to note the slider position and the quality of the image. If I slide the slider only one image right, it goes from really, really bad to really good. If the quality of the first image has no effect on stacking, then it is nothing more than cosmetic. Thought you ought to know about it anyway.
Paul
Freddy WILLEMS
Reged: 11/13/05
Loc: Hawaii, Honolulu
      #5090920 - 02/25/12 07:40 PM
Interesting Paul, so how do your Saturn AS2 images come out ?
Kokatha man
Reged: 09/13/09
Re: AutoStakkert! 2 new [Re: Freddy WILLEMS]
      #5090959 - 02/25/12 07:53 PM
.....wonder whether this has anything to do with the "0000" - "0001" - "0002" sequence the ninox'd bmp's are presented as Paul - but AS!2 is going to do its own thing regardless (just as R6 would also) so I think it is probably a moot point...
15 registered and 29 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
