WayneJ
Reged: 08/20/09
Loc: West Chester, PA
Re: Jupiter in good seeing, 11/10 new [Re: bunyon]
      #5514588 - 11/11/12 02:43 PM
Very nice, Paul! Well done!
Wayne
Space Cowboy
Reged: 05/30/10
Loc: Cheshire, UK
      #5514770 - 11/11/12 04:46 PM
Yep its like magic. Someone else on the forum told me about them.
bunyon
Reged: 10/23/10
Loc: Winston-Salem, NC
Re: Jupiter in good seeing, 11/10 new [Re: Space Cowboy]
      #5514958 - 11/11/12 07:20 PM Attachment (12 downloads)
It's all magic. As Todd, says, I can't believe what we can do from the ground these days. I shot some DSOs the other night and spent some time visually observing Jupiter while the DSOs were running. I love visual observing - it is what I did primarily for over 25 years. However, it was obvious that, even on a decent night, there was nothing close to the detail visible in the scope as in these images.
Here is the first image of the thread re-done with Space Cowboy's LD "trick".
bunyon
Reged: 10/23/10
      #5514962 - 11/11/12 07:22 PM Attachment (12 downloads)
And here is one from October 25 that had a terrible edge. I otherwise loved the image. Here it is with a lower LD in WinJupos.
bunyon
Reged: 10/23/10
      #5515129 - 11/11/12 09:36 PM Attachment (12 downloads)
Can't resist putting this up, too. It's the blue channel for the original RGB. Might be my best blue channel to date.
Space Cowboy
Reged: 05/30/10
Loc: Cheshire, UK
      #5515542 - 11/12/12 06:49 AM
Love this image Paul its an absolute peach!
Sunspot
Reged: 03/15/05
Loc: Surprise, AZ
      #5515669 - 11/12/12 09:40 AM
Very nice!!
Paul
mikotoy
Reged: 06/20/12
Re: Jupiter in good seeing, 11/10 new [Re: Sunspot]
      #5515777 - 11/12/12 11:03 AM
I wish I could get a blue that clear! Awesome.
MvZ
Reged: 04/03/07
Loc: The Netherlands
Re: Jupiter in good seeing, 11/10 new [Re: mikotoy]
      #5515822 - 11/12/12 11:25 AM
Good stuff!
DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
      #5516011 - 11/12/12 01:27 PM
Great work Paul!
In performing WinJupos RGB derotation I found it best to first measure the green channel with the "automatic detection of outline frame" (use the F11 key or right click the image and select that as the first option). Its important that the North pole marker be in the correct hemisphere to start. If not rotate it using the 'N' key before doing the automatic detection. The blue channel is generally ok using the green channel orientation. However the red channel is a special case. Normally the automatic detection of the frame does not work well for the red channel as the belts are not as dark or contrasty in that channel. So leaving the orientation alone it can be beneficial to turn on the LD compensation checkbox and manually move the red image with the arrow keys to fit the planet within the outline frame. This is not always necessary, but in some cases I have found it to be. Perhaps thats why you have some of the limb coloration effects.
Hope this helps, if you already had discovered that, then great. Perhaps someone can find it useful. When it works well the WinJupos derotation of RGB images provides a very nice result.
Glenn
bunyon
Reged: 10/23/10
Re: Jupiter in good seeing, 11/10 new [Re: DesertRat]
      #5516016 - 11/12/12 01:30 PM
Hi Glenn,
Thanks. I think I'm a long (looooooooooooong) way from fully understanding how to use the WinJupos features. I'll take any tips I can get.
Getting a good measurement is a big concern of mine. It looks to me like there is more leeway in the outline than there (probably) is in the software itself. I'll try your method after lab.
karlo
Reged: 05/21/09
Loc: Yorkshire,UK, BLIGHTY !!
      #5516356 - 11/12/12 05:21 PM
feels like I missed the boat with these
wonderful images Paul !
bunyon
Reged: 10/23/10
Re: Jupiter in good seeing, 11/10 new [Re: karlo]
      #5516431 - 11/12/12 06:09 PM Attachment (10 downloads)
Haven't had a chance to re-try measurement of the channels but I noticed I had two good shots at 10,200mm. I've combined these using WinJupos. It's a little better, especially, I think, in color.
Mike Phillips
Reged: 02/21/06
Loc: Swift Creek, NC - 35.682 N, 78...
Re: Jupiter in good seeing, 11/10 new [Re: tjensen]
      #5516761 - 11/12/12 09:07 PM
Superb Paul.
I was out last nigh too. Alas, my collimation is still giving me trouble and my images look like they were shot with cotton over the scope. I'm dedicating tonight to working on the collimation. If that fails, I may have a "collimation party"... I've almost come to the realization that it might be a two person job on this scope. If so, I'll provide the beer and pizza... anyone wanting to help with the scope will be welcome!
Once again... excellent work.
Cheers
I'm down! I just got my kitchen-pass used up for the trek to see my beloved Panthers loose to the Bronco's.
Great shots Paul!
Mike Phillips
Reged: 02/21/06
Re: Jupiter in good seeing, 11/10 new [Re: Mike Phillips]
      #5516764 - 11/12/12 09:09 PM
On WinJUPOS, here's the must read:
http://jupos.privat.t-online.de/rTipsMeas.htm
10 registered and 10 anonymous users are browsing this forum.
Moderator:  Boot, bilgebay
