Hillbrad
Reged: 12/03/08
Loc: Nashville, Tennessee
Jupiter 11-29-12 More Good Seeing
      #5548135 - 12/01/12 12:53 AM Attachment (88 downloads)
I was lucky enough to get another good night with the GRS in view. The seeing wasn't quite as nice as it was last week but it was still great. I still delt with dew inside the ota again...but this time I just heated most of it off with the dryer before I started, and then waited about 15 minutes for the corrector to cool back down. There was a little bit of jet stream that caused some hi res. shaking from time to time but there was still plenty of detail in every channel.
This composite was taken with the C14 and flea3 at 7:28UT on 11-29-12. Thanks for looking!
Hillbrad
Reged: 12/03/08
Re: Jupiter 11-29-12 More Good Seeing new [Re: Hillbrad]
      #5548136 - 12/01/12 12:54 AM Attachment (52 downloads)
And here is a closeup of Io compared to the NASA JPL simulation on the left. This is a blend of green and red light.
rik ter horst
Reged: 11/01/10
Loc: Ewer, the Netherlands
      #5548207 - 12/01/12 02:21 AM
Excellent shot again Brad! Processing is awesome!
Rik
Foehammer
Reged: 06/29/06
Loc: Cyprus
Re: Jupiter 11-29-12 More Good Seeing new [Re: rik ter horst]
      #5548216 - 12/01/12 02:28 AM
Astonishing shot! Something to look up to!
Kokatha man
Reged: 09/13/09
Loc: "cooker-ta man" downunda...
Re: Jupiter 11-29-12 More Good Seeing new [Re: Foehammer]
      #5548262 - 12/01/12 03:58 AM
Lovely Brad!!!
Freddy WILLEMS
Reged: 11/13/05
Loc: Hawaii, Honolulu
Re: Jupiter 11-29-12 More Good Seeing new [Re: Kokatha man]
      #5548305 - 12/01/12 05:20 AM
Excllnt !!!
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
Re: Jupiter 11-29-12 More Good Seeing new [Re: Freddy WILLEMS]
      #5548466 - 12/01/12 09:27 AM
Awesome shot.
astrovienna
Reged: 12/04/06
Loc: The NoVa White Zone
Re: Jupiter 11-29-12 More Good Seeing new [Re: Rankinstudio]
      #5548551 - 12/01/12 10:34 AM
Another beautiful shot, Brad. How do you get so much detail on the moons? Mine still look pretty much just like diffraction patterns, even in excellent seeing and with lots of frames. While there's a little detail around the limbs, the center always tends to be nothing but a big dark dot.
Kevin
bunyon
Reged: 10/23/10
Loc: Winston-Salem, NC
Re: Jupiter 11-29-12 More Good Seeing new [Re: astrovienna]
      #5548696 - 12/01/12 12:20 PM
Another outstanding set!
BKBrown
Reged: 08/23/09
Loc: Northern Virginia, USA
      #5548725 - 12/01/12 12:37 PM
That's another stunning beauty Brad! You are having quite the run lately, care to share some of your seeing
Clear Skies,
Brian
Baron
Reged: 11/23/12
Loc: Rome, Italy
Re: Jupiter 11-29-12 More Good Seeing new [Re: BKBrown]
      #5548801 - 12/01/12 01:28 PM
Very good!
DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
      #5549055 - 12/01/12 04:29 PM
Another fine image Brad! Wishing you all the best and more seeing like that!
Glenn
lcd1080
Reged: 06/03/10
Loc: Maryland, USA
Re: Jupiter 11-29-12 More Good Seeing new [Re: DesertRat]
      #5549068 - 12/01/12 04:36 PM
The complexity of the GRS wake is well accounted for in your image Brad; and what convincing surface detail on Io! It's very close to the JPL simulation.
Pete
Erik Bakker
Reged: 08/10/06
Loc: The Netherlands, Europe
      #5549132 - 12/01/12 05:32 PM
Brad,
What can I say? Absolutely stunning image of Jupiter
Daniel Chang
Reged: 07/05/06
Loc: Hong Kong
Re: Jupiter 11-29-12 More Good Seeing new [Re: Erik Bakker]
      #5549157 - 12/01/12 05:52 PM
Excellent shot !
Az Frank
Reged: 10/18/08
Loc: Tucson Arizona
Re: Jupiter 11-29-12 More Good Seeing new [Re: Daniel Chang]
      #5549315 - 12/01/12 07:40 PM
Another Wow factor Brad! One beautiful image!
Hillbrad
Reged: 12/03/08
      #5560320 - 12/08/12 01:49 AM Attachment (9 downloads)
Thanks for all the comments guys! Work has been really busy but I finally got around to processing one more from this batch. This one was taken at 5:54UT before the GRS had rotated into view. I think the seeing was about the same. Hope that jet-stream will get out soon while Jupiter is still big!
Hillbrad
Reged: 12/03/08
      #5560323 - 12/08/12 01:54 AM
Kevin: For the moons I have been experimenting with the processing recently. I've found that using a very small amount of frames and then not sharpening too much as been the best result. For this one of Io and my recent Ganymede, I used only 250 frames out of 12,000 per color. Then I drizzled 1.5x in AS2! and used a little bit of wavelets in Registax. No deconv. at all was used. Hope that helps!
sfugardi
Reged: 09/30/06
Loc: CT
      #5560587 - 12/08/12 09:47 AM
Brad, absolutely stunning images! Detail and color are processed perfectly. What f-ratio/focal length are you using? Also, what is the gain setting on the B channel? Lately I have been pushing higher going from f25 to f27 but getting noiser images having to increase the gain up to achieve 65% brightness and it seems to be in the wrong direction. I am thinking of going lower next time. From the super image quality it looks like you have the optimal setup. Thanks in advance for the advice and for posting these beauties. These should go straight to S&T!
Steve
edsplace
Reged: 11/02/11
Re: Jupiter 11-29-12 More Good Seeing new [Re: sfugardi]
      #5560682 - 12/08/12 11:02 AM
Fantastic image!
8 registered and 6 anonymous users are browsing this forum.
Moderator:  Boot, bilgebay
