guyroch
Vendor (BackyardEOS)
Reged: 01/22/08
Loc: 3rd rock from the sun, Canada
Re: ASI 120MM versus QHY5L-II
[Re: jonbosley]
#5720733 - 03/08/13 03:16 PM
Well, I just pulled the trigger and bought a QHY5L II Mono from Astrofactors; first time purchasing from them.
Shipping to Canada was only $12 ~ pretty good compared to OPT which is about $34.
Guylain
Tellescópio
Reged: 02/26/13
[Re: guyroch]
#5720980 - 03/08/13 06:29 PM
Great topic, in a most famous astronomy forum in Brazil we exactly discuss about it, please check it out: http://www.cosmobrain.com.br/cosmoforum/viewtopic.php?f=47&t=17777 The language is in portuguese, maybe a google translation works well if you do not understand.
QHY5L-II now working full on FireCapture. The developers announce the follow steps:
"Hi all, This is the very very last ;-) 2.2beta version including QHY 5L-II support.
If you have an existing 2.2beta do the following: - replace FireCapture.jar in your \lib subfolder with this version: FireCapture.jar (http://firecapture.wonderplanets.de/FireCapture.jar) - extract the files from the following archive into your 2.2beta folder: QHYCCD_Support_beta40.zip (http://firecapture.wonderplanets.de/QHYCCD_Support_beta40.zip)
If you don't have a 2.2beta use the following self-extracting archive: FireCapture_22beta40.exe (http://firecapture.wonderplanets.de/FireCapture_22beta40.exe)
Start FC using the "FireCapture_QHY" shortcut. For the unlikely case that your QHY 5L should start see the additional controls in the gamma drop-down box (right-click). Check "HighSpeed" for fast read out.
In case of errors send log.txt and all files in the \log folder.
Non QHY users don' t need to upgrade. The only changes beside QHY support are as follows: - fixed fliped image for ASI camera - improved histrogram display for color cameras"
Kokatha man
Reged: 09/13/09
Loc: "cooker-ta man" downunda...
[Re: Tellescópio]
#5720994 - 03/08/13 06:36 PM
Hi T - I take it from this in your post that the QHY5L-11 doesn't have adjustable blackpoint/brightness control then..?
Space Cowboy
Reged: 05/30/10
Loc: Cheshire, UK
[Re: Kokatha man]
#5721739 - 03/09/13 07:55 AM
The QHY5L-ll has grabbed my attention as I was considering the ASI 120MM. What concerns me about the ASI is the image scale being too large for use with my trusty 5x powermate in my f4.8 Dob. I understand the QHY5L-ll has a 1.25" body which fits directly inside the focuser therefore producing a smaller image scale. After a quick google search I saw someone mention it producing 4.5-5x with a 5x powermate which sounds ideal for me?
pippo
Reged: 01/12/13
Loc: Paris (FR), Pantelleria (IT)
[Re: Space Cowboy]
#5722509 - 03/09/13 03:43 PM
Could someone post the fps as a function of the ROI available on the QHY5L-II under Firecapture?
Can we compare such fps with those available on the ASI?
Francesco
LauraMS
Reged: 03/29/11
Loc: Germany
[Re: pippo]
#5722862 - 03/09/13 07:25 PM
With the QHY5L-II I today achieved the following fps values (EzPlanetary 3.44):
1280x960 30fps 640x480 107fps 320x240 157fps
May not be optimum yet, since I am still trying to figure out how to work best which acquistion parameters are best.
Fabio_Volpe
Reged: 03/09/13
Loc: Italy (MO)
[Re: LauraMS]
#5722921 - 03/09/13 08:08 PM
I'm also testing this cam and I have to say that in a first approach seems to promise very well, but I must say that the speed reported by Laura, are speed cam 8-bit. if the cam is used in 12-bit, the speed is halved, but still remain very good speed in relation to the most dynamic acquisition. Soon I'll post the first pictures.
Space Cowboy
Reged: 05/30/10
Loc: Cheshire, UK
[Re: Fabio_Volpe]
#5734657 - 03/15/13 06:35 PM
I've just received the QHY5L-ll mono and at the moment can only get 55fps @ 640x480 both on my quad core pc and 2 gig ram netbook which is rather a puzzle?
Also firecapture can't find the cam on my netbook but it works fine with the pc?
3 registered and 7 anonymous users are browsing this forum.
Moderator: Boot, bilgebay
