mikewirths
Vendor-Baja Dark Skies
Reged: 06/16/08
Loc: San Pedro Martir Mexico
Re: Plato under high sun! new [Re: bunyon]
      #5765032 - 03/29/13 03:36 PM
Thanks Eric and Paul
Paul heres my settings, although I forgot to set the brightness to zero like Sam recommended
Camera=ASI120MM Camera (ZWO Design)
Filter=R
Profile=Moon
Filename=Moon_031146.ser
Date=230313
Start=031146
Mid=031252
End=031357
Duration=130s
Frames captured=2880
Binning=no
ROI=1280x960
FPS (during start of capture)=22
Shutter=12.86ms
Brightness=10
Gamma=50
Gain=5
Histogramm(min)=16
Histogramm(max)=174
Histogramm=68%
Noise(avg.deviation)=4.72
AutoAlign=false
PreFilter=none
Limit=none
bunyon
Reged: 10/23/10
Loc: Winston-Salem, NC
Re: Plato under high sun! new [Re: mikewirths]
      #5765096 - 03/29/13 04:04 PM
Heh. That would do it. I'll go look up my gain but it wasn't 5, that's for sure. I notice now that you use an R/IR pass. I used the Baader 685, so I got less light than you.
Back now: gain was 40. Brightness was also 10, I didn't realize that could/should be changed. Thanks.
The one other thing I note is that I got a faster frame rate than you. I ran at 32fps (32.2 to be exact). You might not have the latest driver from Sam which speeds things up considerably).
MADRID SKY
Reged: 03/20/07
Loc: Madrid, SPAIN
      #5765548 - 03/29/13 07:04 PM
I have been off too much time!
This one rivals my "standard" of Plato this far (Wes' picture, which I have kept since he published it).
It is amazing what levels of resolution you all planetary people are achieving. It is an incredible time we are living on today. You are reaching levels only orbiting spacecrafts could get some 30 years ago.
This is remarkable, people.
I wish I had more time to be around.
mikewirths
Reged: 06/16/08
Re: Plato under high sun! new [Re: MADRID SKY]
      #5765559 - 03/29/13 07:13 PM
Paul: I actually did have Sams latest driver, but iwas using ram buffer before and had problems with shifting frames, so Torsten sent me a fix and I think (actually I know) that I forgot to reset the disk buffer from 8Kb to 128Kb so I should now be getting 32 fps again.
You might try just the R filter instead of the IR, like you said more light but if the seeings good more resolution too!
Thank you Madrid Sky! Wes's image is certainly amazing, but he has a new camera too (Grasshopper Express) so hopefully he will get back to the moon!
cheers
MADRID SKY
Reged: 03/20/07
Loc: Madrid, SPAIN
      #5765577 - 03/29/13 07:25 PM
Mike, as people pointed out, you certainly got inside Plato MANY craterlets too!
Your picture will also get inside the same folder as Wes' image, so that the day after tomorrow, if I get to Plato, I may do some comparison.
WOW!
mikewirths
Reged: 06/16/08
      #5765602 - 03/29/13 07:39 PM
Dear Sam,
I have imaged Plato at a higher image scale before but with my old camera, if Iwere to get this new camera in similar seeing but with more image scale I'm fairly sure I could surpass this image:
http://imageshack.us/f/705/platopico.jpg/
I still find the newer image more pleasing to the eye.
MADRID SKY
Reged: 03/20/07
Loc: Madrid, SPAIN
      #5765621 - 03/29/13 07:51 PM
My gosh, that's is amazing close. As I said, I have been out for too long!
Is that a cropped image?
siriusc
Reged: 04/03/07
Loc: Racine, WI
      #5777780 - 04/04/13 01:47 PM
Hi Mike,
Well, I counted about 80 craterlets and 20 white spots that are probably more craterlets so you recorded at least 100. Great work!!!
Clear skies, Dan
Brian Albin
Seeker
Reged: 08/22/06
Loc: Western Oregon
Re: Plato under high sun! new [Re: siriusc]
      #5787044 - 04/08/13 10:26 PM
That is the most detail I have seen down inside Plato A. Nifty!
mikewirths
Reged: 06/16/08
Re: Plato under high sun! new [Re: Brian Albin]
      #5788069 - 04/09/13 01:09 PM
Thanks Dan and Brian!
Dan I wish I could find Jean Luc Dauvergnes image of Plato with the Pic Du Midi scope but I'm sure he got like 150 craterlets! Of course he was shooting at some crazy fl like 14000mm or something like that too!
I redid my image using the latest version of AS2 and drizzle (1.5X's) it seemed to squeeze a bit more out, but for me this is pushed as hard as is possible, maybe a bit too much. Still a bit more detailed:
http://img600.imageshack.us/img600/5066/platodrizzlestack500.jpg
cheers
ZuoZhao
Reged: 10/16/12
      #5788187 - 04/09/13 01:55 PM
it seem your speed low. I can capture at 32fps.
mikewirths
Reged: 06/16/08
Re: Plato under high sun! new [Re: ZuoZhao]
      #5788252 - 04/09/13 02:16 PM
Yes ZZ you are right, I was only capturing at 23 fps. I just updated the FC program with an update Torsten sent me and I forgot to set processor type and disk write speed. Normally I can also capture at 32 fps.
Mert
Reged: 08/31/05
Loc: Spain, Pamplona
      #5788329 - 04/09/13 02:38 PM
Congrats with this marvelous image Mike, that's an
incredibly detailed floor inside Plato.
I've been staring at this image for a long while
siriusc
Reged: 04/03/07
Loc: Racine, WI
      #5788358 - 04/09/13 02:49 PM
Hi Mike,
Wow, what a great scope, that Starmaster must have perfect mirrors! Can we request lunar imaging targets? If so, I vote for the "Straight Wall" region next.
Best wishes, Dan
9 registered and 21 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
