Doug76
Reged: 12/05/07
Loc: SE Louisiana, future Texan
It Begins
      #3097236 - 05/10/09 11:30 PM Attachment (158 downloads)
The pier has been poured, but I didn't get to see it unwrapped before I hit the road again in the big truck. Vacation starts on or about May 25th, and the building itself will start going up around then. In the meantime, a few pictures of the start of this project.
Doug
Truckstop Astronomer
The Universe, the light of God, in all it's majesty
6 achro refractors, 50mm-150mm
1 apo refractor, 90mm
1 SCT, 8 inch
UO Abbe Volcano Tops
Faworski Ortho's
Panoptic 24mm
Carton 100mm f/13 under construction
Doug76
Reged: 12/05/07
Re: It Begins new [Re: Doug76]
      #3097238 - 05/10/09 11:31 PM Attachment (101 downloads)
Next..
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Doug76
Reged: 12/05/07
      #3097242 - 05/10/09 11:32 PM Attachment (101 downloads)
And next...
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Doug76
Reged: 12/05/07
      #3097247 - 05/10/09 11:34 PM
It is an 8" diameter pier, approximately 6ft tall from the ground, as the floor of the observatory will be about 20" off the ground.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
rnoelle
Reged: 01/23/08
Loc: SW Oregon
      #3097304 - 05/11/09 12:14 AM
Hey Doug:
Congrats! Don't you love it when a good plan starts coming together. Looking forward to following your progress on this. You sure one pier is enough?
Bob
--Bob
* Meade LXD75 AR6-AT
* Orion EON 80ED
* Bogen/Manfrotto 475B; 501HDV
Chris SchroederModerator
Reged: 12/11/04
Loc: N.E. WI Sky Glow
Re: It Begins new [Re: rnoelle]
      #3097683 - 05/11/09 08:27 AM
Great start Doug, and concrete will have plenty of time to cure before you resume work, not a bad thing.
Chris
Mallincam Color Hyper Plus
10" DSH with SC DSC, CPC 800 XLT
M110 Doublet ED, AT 102Achro, ZS80FD 10th Anniv, ZS66SD, PST
CG5-AGT, EZ-Touch, Voyager
POD XL3 http://POD.SchroederCity.com
Project Galileo
Reged: 11/14/07
Loc: Douglas County, Colorado
Re: It Begins new [Re: Chris Schroeder]
      #3097810 - 05/11/09 09:57 AM
Enjoy! Good job!
Orion XT10i
Meade LXD55 LXD75 AR-6
TeleVue Binoviewers with Seibert 1x/1.3x/1.7x OCA
Minolta 10x50 Binoculars
csa/montanaModerator
Den Mother
Reged: 05/14/05
Loc: montana
      #3097948 - 05/11/09 11:31 AM
Doug, Congratulations on the start of your Observatory!
We will love taking the journey with you, building it!
Carol
AstroTech 16" Dob (Thanks ASTRONOMICS!)
Vixen 80MF/AstroTech Voyager
Masuyama's 7.5, 15, 25W, 35mm,
Pentaxes; 5XW, 7XL, 10XW.
14mm Meade 4000 UWA
TV Panoptics; 22, 35
DreamCatcher Dobservatory, #2
Doug76
Reged: 12/05/07
Re: It Begins new [Re: csa/montana]
      #3098366 - 05/11/09 02:38 PM
Thank you all. I didn't get to see it with the form removed, as I had to hit the road again. Dad removed the form late yesterday, and he says it looks really good. He's helping me to do this project, as he has built many small buildings such as this. But he's never built one with a roof that removed, and he is intrigued by the idea, and has come up with some interesting ideas on how to make it seal itself when closed. Ya'll will see it when I do.
Bob, you know one ain't enough, but it's a start!
Carol, you and others have inspired me to finally get going on this.
More will be posted as it goes along. It will restart the end of this month, when I arrive home for 5 weeks of vacation.
And ya'll might as well start adding your suggestions for a name. I'm drawing a blank so far.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
rsbfoto
Reged: 06/10/06
      #3098496 - 05/11/09 03:41 PM
Hi Doug,
I have been looking many many times on the pier you are building and allow me to give you some points of view from my side.
I do not want to take the wind out of your sails but I see some trouble coming up with the design of your pier.
Judging from the image you posted I can see that you did not go very deep into the ground with your base. The shape of that hole is also problematic as you have a narrower bottom then the top.
¿ Why do I say that it looks like trouble ? You have a 6 feet tall concrete post with a weight of maybe 350 pounds and the center of gravity is at about 6 feet high from the bottom. Now you will put on top of it how much more weight ? in equipment and suddenly your center of gravity goes up by maybe 1 or 2 feet maybe more depending of your equipment and your whole pier construction becomes unstable.
Judging from the image the diameter of the base at the top is maybe 32" but rapidly getting smaller the deeper you digged. So maybe you have there only a base with a size of 12" diameter and 12 inches deep ? That is a base weight of roughly 130pounds. Also I assume you went with the cardboard tube nearly down to the ground. The cardboard will start to rotten and then the concrete around will be of no help. If we add the weight of your base to the pier then maybe the center of gravity slips down by 2 feet.
The single rebar ? you put in there is not a big help for the concrete. Normally you have to put in at least 3 pieces tied together with some rings. Another possible problem is that you sticked the rebar directly into you soil which can be a future problem that you rebar will start rusting inside the concrete pillar. Water creeps up by capilaritybetween the boundaries of the iron rebar and concrete. From what I have seen rebar should never be driven directly into the soil.
From your equipment desciption I deduct that you are a visual observers which implies another problem that you will be movong the scopes and you personally could be leaning on the pier and ahving such a little base in the ground you pier can easily be moved by you and become unstable.
Apologies for beeing the first one to write about possible future problems ...
Just my 2 cents to your project.
You are still on time in order to stiffen the big 6 feet pier by adding a broader concrete base especially because you wrote that the deck will be 20" above the ground.
regards Rainer
Doug76
Reged: 12/05/07
Re: It Begins new [Re: rsbfoto]
      #3098529 - 05/11/09 03:53 PM
Thanks for your concern. Except for the top 5", that ground is solid very hard clay. The pier will not move, having already leaned hard on it, it didn't budge. A 6ft high pier will not have a center of gravity 6ft above ground. It would be 3ft, and with the additional weight and footprint of the base you can figure the center is just about where the floor will be. We have no such thing as a frost line, so going deeper was not necessary. The hole is 22" deep, and 18" wide at the bottom. The picture posted is not the final hole. And the tube was set only 3" into the concrete. And that isn't rebar, it's fence post, and very strong, designed to set into the ground, with lots of knobby surface for the concrete to hang onto. This isn't the first concrete post we have done, just the first for a mount pier.
And after all that, should it develop problems, well I guess I'll redo it. But I doubt that will happen.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
rsbfoto
Reged: 06/10/06
      #3098564 - 05/11/09 04:09 PM
Hi Doug,
You are welcome
regards Rainer
Doug76
Reged: 12/05/07
      #3105691 - 05/14/09 10:31 PM
Well, viewing other projects, I may have made a mistake. I used four 1/2" threaded rods evenly spaced on a 6" circle in the top of the pier. I have an 1/4" thick aluminum plate arriving tomorrow to make a mounting plate out of for my CG-5ASGT mount. Going to try to duplicate the mount plate on the tripod. Not sure how this is going to work out.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Doug76
Reged: 12/05/07
      #3105751 - 05/14/09 11:07 PM
Turns out I have the cure. I own one of the Orion extension posts for use with refractors, and it has what I need to make this work. I'll just reduce the post from 16" to 4", and fit it to my 1/4" plate.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
RobVG
Reged: 01/09/06
Loc: Seattle Washington
      #3105761 - 05/14/09 11:16 PM
I did that with my CG-5. I noticed the bottom "plug" that goes throught the hole in the tripod is tapered .040". I made the hole in the adapter accordingly but just recently realized the taper was probably just to make it easier to assemble.
This thread shows what I did and some other CNers ideas as well.
The alt/az "tang" is 6mm diameter x 1.00 pitch if you want to drill and tap your plate to use the tang from your tripod.
Looking good!
Rob
C11 SGT(XLT)CG-5
Observatory (page 5)
Doug76
Reged: 12/05/07
Re: It Begins new [Re: RobVG]
      #3105774 - 05/14/09 11:24 PM
Good info, and the way I would have gone, if I hadn't looked on Ken Dauzat's site and seen his CG-5 solution.
http://www.kendauzat.net/other.htm
This is so close to the Orion extension post, in short form, that I figure it's the best solution.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Pedestal
Reged: 03/11/06
Loc: Smoggy Bottom, Baytown,Texas
      #3105829 - 05/14/09 11:50 PM
You could also weld tabs on the Orion extension. I made this one, it has a Dousat adapter in the top. See my post here.
Hubert
Hubert
www.smoggybottom.org
Doug76
Reged: 12/05/07
Re: It Begins new [Re: Pedestal]
      #3105917 - 05/15/09 01:14 AM
Looks workable, but I don't weld, and I think I have the solution.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Doug76
Reged: 12/05/07
      #3105922 - 05/15/09 01:18 AM
Hi Doug,
On further thought, this isn't a bad idea, and I think I will. Thanks.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Doug76
Reged: 12/05/07
      #3119726 - 05/21/09 09:29 PM
Well, vacation comes in 4 days. I'll be busy with the observatory, in between fishing trips, of course!
Didn't want the thread to get too far down the list, or I might start another forgetting this one!
I could use some good pics showing y'alls various solutions to the placement, type, and number of wheels used for the roof. I've built plenty of small buildings, but none had a rolling roof.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
RobertED
Reged: 07/11/03
Loc: Johnston, RI
      #3120541 - 05/22/09 09:56 AM
Congratulations on the start of your project, Doug..."May the Force be with You!!!"
Doug76
Reged: 12/05/07
Re: It Begins new [Re: RobertED]
      #3132648 - 05/28/09 04:39 PM
I'm home. Made it here Wed. Have to rebuild a wall on the house (new windows, and the original construction is not good), but then will start on the observatory. Buying remaining material tomorrow. I will post pictures as we go along.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
andyschlei
Reged: 03/05/06
Loc: Los Angeles, CA
      #3136014 - 05/30/09 03:02 PM
Here is a shot of the Sky Shed approach garage door wheel placement (click through for a bigger shot):
And here is the corner placement in a metal wheel on top of angle iron approach. There is one wheel in each corner.
HTH,
--Andy
Observatorio de la Ballona
Mar Vista
Lake Riverside Estates
Doug76
Reged: 12/05/07
      #3147267 - 06/05/09 01:27 PM Attachment (46 downloads)
Starting again, slowly. Here is the new pier base addition to sturdy it up some more. Grandnephew Tyler here to help. Those are his initials you see.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Doug76
Reged: 12/05/07
      #3164321 - 06/15/09 04:47 PM Attachment (34 downloads)
Tyler returned home early, so I am on my own.
Got the sill frame built, and positioned temporarily on the blocks. Still have to level. Too hot to do much work. A little in the morning, a little in the evening.
Doug76
Reged: 12/05/07
      #3175760 - 06/22/09 04:29 AM Attachment (28 downloads)
A bit more progress. It has been extremely hot here, and no clouds.
Doug76
Reged: 12/05/07
      #3175762 - 06/22/09 04:30 AM Attachment (32 downloads)
Plywood going down.
Den Mother
Reged: 05/14/05
Loc: montana
      #3177424 - 06/22/09 11:44 PM
Doug, it's moving right along! Looking good!
Carol
14mm Meade 4000 UWA
Doug76
Reged: 12/05/07
      #3177452 - 06/23/09 12:02 AM Attachment (42 downloads)
Yeah, I bought the 2x4's for framing the walls today. Gonna start on that tomorrow. One more picture. That's my help, and the supervisor of this job. I call him "Dad".
Timber
Reged: 11/08/08
Loc: SW foothills of Mt. St. Helens
      #3177470 - 06/23/09 12:13 AM
Doug,
Clever under floor framing, should be a stiff floor, looks good.
Richard
My four beautiful Saluki's; Barron, Sophie, Majnun and Kassandra, and I live on a small, rural, remote farm.
No close neighbors,
No streetlights,
No private security lights,
No power poles,
No traffic,
No TV,
No HOA
No Mosquitoes
Rather Wonderful
Den Mother
Reged: 05/14/05
Loc: montana
      #3177471 - 06/23/09 12:14 AM
Darn good "help" you have there; bet his salary is reasonable.
Carol
14mm Meade 4000 UWA
Doug76
Reged: 12/05/07
Re: It Begins new [Re: Timber]
      #3177511 - 06/23/09 01:04 AM
Doug,
Richard
Dad's idea. I learned long ago to listen, and comply.
Doug76
Reged: 12/05/07
      #3177513 - 06/23/09 01:05 AM
VERY!
HunterofPhotons
Reged: 04/26/08
Loc: Rhode Island, USA
      #3178113 - 06/23/09 12:03 PM
Doug,
Clever under floor framing, should be a stiff floor....
Richard
Not really. It should have rim joists for stiffness.
dan
Doug76
Reged: 12/05/07
Re: It Begins new [Re: HunterofPhotons]
      #3178309 - 06/23/09 02:11 PM
Exactly what Dad said.
Doug76
Reged: 12/05/07
      #3181093 - 06/24/09 10:16 PM
Wall frames started being constructed today. The heat down here is killing this project. We have one wall done. We are constructing them in the barn, then we will move them to the site and fasten the frames to the floor and each other. Pictures when we do.
Doug76
Reged: 12/05/07
      #3183098 - 06/25/09 10:44 PM
Two more wall frames done. Going to install them tomorrow, then build the last(south) wall frame, the one that has a fold down section, and install it too. Pictures then.
Doug76
Reged: 12/05/07
      #3186884 - 06/28/09 11:15 AM Attachment (22 downloads)
Frame installed.
Doug76
Reged: 12/05/07
      #3186885 - 06/28/09 11:18 AM
Decided against a fold down on the south wall. Just isn't necessary. The height of the scope will be enough to see as far down toward the horizon as is practical.
andyschlei
Reged: 03/05/06
      #3187282 - 06/28/09 03:52 PM
That's really beginning to look like an observatory! Great work.
Mar Vista
Doug76
Reged: 12/05/07
Re: It Begins new [Re: andyschlei]
      #3189065 - 06/29/09 02:58 PM Attachment (46 downloads)
Walls are up. Returning to work tomorrow, vacation over. Further work will have to wait a few weeks.
dzirzow
Reged: 07/01/09
Loc: Albuquerque, NM
      #3197685 - 07/03/09 08:43 PM
Looking Good!!
15" F5 Tectron
10" F4.5 Meade Starfinder
SV85S
CI700
Doug76
Reged: 12/05/07
Re: It Begins new [Re: dzirzow]
      #3198396 - 07/04/09 10:38 AM
Thanks! Anxious to get back and do some more on it. If the heat wave breaks, Dad is going to continue on with it.
Doug76
Reged: 12/05/07
      #3198411 - 07/04/09 10:47 AM Attachment (38 downloads)
A close up...
Den Mother
Reged: 05/14/05
Loc: montana
      #3198438 - 07/04/09 11:03 AM
Wow! You're moving right along; it's looking great!
BTW, Happy Birthday Doug! (Better sneak down to the OTO forum )
Carol
14mm Meade 4000 UWA
Doug76
Reged: 12/05/07
      #3199013 - 07/04/09 04:22 PM
I snuck down. Thanks to all.
Gonna need a name for the obs. Any suggestions?
Doug76
Reged: 12/05/07
      #3199156 - 07/04/09 05:48 PM
Just called home, and was informed that Dad has primed and painted it's outside surface. It is now white on the outside. Should provide some good protection until the siding goes on.
Siderea
Astronomess
Reged: 11/21/05
Loc: Left Coast
      #3215420 - 07/13/09 01:01 PM
Isn't that great when your projects get worked on while you are gone! Mine never do that..
Great Obs, Doug, and yor Cartons will look gorgeous on that sturdy pier!.
lc Carol
..."Then the blue above grows darker and a million stars erupt
From the places where they hide throughout the day
Into pictures in the heavens even we cannot corrupt
And the vastnesses of time can't wash away..."Jeff Green
60mm Telescope Club
Doug76
Reged: 12/05/07
Re: It Begins new [Re: Siderea]
      #3222086 - 07/16/09 06:33 PM
Thank you ma'am! Yeah, Dad's a builder. I couldn't keep him away from it with a shotgun!
The Cartons yes, but first the seldom used C6R. I've been itching to get it in there. That is the main reason I built it, so I could use that bad boy more often. I love that scope, but it's a pain to move around.
DDon
Reged: 07/27/09
Loc: France, Montpellier
      #3299413 - 08/28/09 08:12 AM
Subscribed!
But we need more pics here m8!
Cheers!
D.Don
Meade 2090AT, 90/800 Refractor | Skywatcher Mercury 705, 70/500 Refractor | SW Red Dot Finder | SW AZ3
SW 25mm, 10mm Super-MA | SW 20mm UWA | SW 7.5mm, 32mm SP | Meade 26mm SP (Wide)
SW 2x Deluxe Barlow | SW 90° Dielectric Mirror Diagonal | SW Light Pollution Filter
Bresser 20x80 w. tripod
Doug76
Reged: 12/05/07
Re: It Begins new [Re: DDon]
      #3304459 - 08/30/09 06:16 PM Attachment (31 downloads)
Funny you should ask. Although it isn't rolling yet, or have the tin on it yet, the roof is up. Just got it up there today.
Doug76
Reged: 12/05/07
      #3333898 - 09/14/09 06:43 PM
I've been informed that in my absence the help (Dad) has finished installing the roof section end pieces and the tin over the plywood on top.
Pictures when I get home next week.
Doug76
Reged: 12/05/07
      #3371238 - 10/04/09 06:18 PM Attachment (29 downloads)
The tin is on the roof, wheels installed, temporary ridge cap and door. Rail posts have been installed, but I don't have a picture of that yet.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
rnoelle
Reged: 01/23/08
Loc: SW Oregon
      #3375783 - 10/07/09 12:38 AM
Nice progress Doug ... oops I meant Dad.
--Bob
* Orion EON 80ED
Doug76
Reged: 12/05/07
      #3376211 - 10/07/09 09:46 AM
LOL Yeah, you got that right. He has taken over!
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Montana_Nights
Reged: 04/19/09
Loc: Ennis,Montana
      #3377334 - 10/07/09 08:58 PM
Nice build. I can't wait to settle down in one spot long enough to make building a OB worth the time!
Southwest Montana Astronomical Society, Bozeman Montana
My Kit:
A "new to me" Celestron Celestar 8
25mm and 10mm widefield EP
2x barlow
Various filters and accessories
Many, many books
Doug76
Reged: 12/05/07
Re: It Begins new [Re: Montana_Nights]
      #3377643 - 10/08/09 12:42 AM
Thanks. I can't wait myself to be able to use it.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Doug76
Reged: 12/05/07
      #3398946 - 10/19/09 08:50 PM
I'm told the roof is rolling now, and construction is essentially finished. Only siding to install, get the mount on the pier, and wire it up.
Installing the mount comes first. I have battery power for the mount. Home tomorrow so may get to try my obs out for the first time tomorrow night. Woohoo!
Pictures ASAP after arriving home.
Thanks to my Dad for being THE MAN!
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
andyschlei
Reged: 03/05/06
      #3400882 - 10/20/09 07:17 PM
Great news -- Have fun!!!!
Mar Vista
Den Mother
Reged: 05/14/05
Loc: montana
      #3401072 - 10/20/09 09:05 PM
Congratulations Doug! We'll be anxious for the pictures. Your Dad rocks!
Carol
14mm Meade 4000 UWA
Doug76
Reged: 12/05/07
      #3403274 - 10/21/09 10:27 PM Attachment (25 downloads)
Too busy aligning the rails and wheels today to get outside pics, but here is a shot I took a few minutes after completing an important part of the process!
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Siderea
Astronomess
Reged: 11/21/05
Loc: Left Coast
      #3403411 - 10/21/09 11:39 PM
Congratulations, Dad and Doug!
Very nice!
lc Carol
60mm Telescope Club
Den Mother
Reged: 05/14/05
Loc: montana
      #3403451 - 10/22/09 12:00 AM
Hey Doug! Wow, you have an observatory! Congratulations to you & your chief contractor
Carol
14mm Meade 4000 UWA
Doug76
Reged: 12/05/07
      #3404433 - 10/22/09 03:23 PM Attachment (22 downloads)
New pics...
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Doug76
Reged: 12/05/07
      #3404437 - 10/22/09 03:25 PM Attachment (22 downloads)
Another...
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Doug76
Reged: 12/05/07
      #3404444 - 10/22/09 03:26 PM Attachment (21 downloads)
And another...
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Den Mother
Reged: 05/14/05
Loc: montana
      #3405056 - 10/22/09 09:13 PM
You are good to go! Now if your skies stay clear!
Your Dad did a great job!
Carol
14mm Meade 4000 UWA
Doug76
Reged: 12/05/07
      #3405100 - 10/22/09 09:36 PM
Yeah he did. He changed the door location to under the rails. The old door is gone, although it looks like one is there. Patch, you know? He left the door latch as a joke, typical of my Dad!
The steps are temporary, we're gonna build a wider step.
We're going to repaint the outside, as given this economy I have not the funds to buy the siding yet. So more paint, which we have, will provide protection until I can get siding installed.
Going to wire it tomorrow.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Den Mother
Reged: 05/14/05
Loc: montana
      #3405290 - 10/22/09 11:17 PM
Should have a nifty "Entrance" sign over it!
Carol
14mm Meade 4000 UWA
Doug76
Reged: 12/05/07
      #3407277 - 10/23/09 10:55 PM
First light tonight. It's complete enough to begin using. I got 45 minutes before clouds moved in. It is really very nice to not have lights coming at you from cars, and the wind is but a breeze inside the enclosure. The concrete pier helped prove the CG-5ASGT is a big enough mount for tonight's first scope, the big C6R.
I think the part I like best is except for minor tweaking, as long as I don't remove the mount, I'll not have to polar align again. That made all the hard work worthwhile!
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Den Mother
Reged: 05/14/05
Loc: montana
      #3407338 - 10/23/09 11:35 PM
Congratulations on your first light in your new Observatory!
You will have so many wonderful nights enjoying it.
BTW, now you have to come up with a name
Carol
14mm Meade 4000 UWA
Digital Don
Reged: 01/20/04
Loc: Manteno
      #3407386 - 10/23/09 11:59 PM
"I think the part I like best is except for minor tweaking, as long as I don't remove the mount, I'll not have to polar align again."
Just use the mount's "Hibernate" feature and you shouldn't have any adjustments to make. Just confirm the date and location and enter the time and you're good to go!
I know I've observed much more since having my obs built than ever before. That's a good looking setup! Have fun with your new toy!
Don
Doug76
Reged: 12/05/07
      #3407439 - 10/24/09 12:23 AM
No, Miss Carol, you have to help me come up with a name. I'm drawing a blank, and am willing to entertain all suggestions.
Thanks Don, now that it's permanent, I'll have to study up on those features I've never had need to use before.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Den Mother
Reged: 05/14/05
Loc: montana
      #3407571 - 10/24/09 02:05 AM
Well, we'll just have to start posting suggestions. I'll give it some thought!
Carol
14mm Meade 4000 UWA
Doug76
Reged: 12/05/07
      #3407837 - 10/24/09 09:48 AM
Thank you!
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Reged: 12/11/04
      #3407988 - 10/24/09 11:13 AM
Congratulations on your first light Doug, I hope you enjoy many great nights in your observatory!
P.S. The little tweaks never end, you'll always find something more to tinker with
Chris
Den Mother
Reged: 05/14/05
Loc: montana
      #3408036 - 10/24/09 11:33 AM
Since you are a trucker, how about:
"Doug's Truck Stop"
Carol
14mm Meade 4000 UWA
Bob Griffiths
Reged: 10/10/05
Loc: Frederick Maryland
      #3408433 - 10/24/09 03:33 PM Attachment (15 downloads)
Doug: First of all CONGRADULATIONS on the first light...
as for a name >>>> Dougs Rest Area...
First light is an EVENT....and as such I had a sign made up which I proudly display.
Obs name is in smallish letters...BUT FIRST light is in Bold lettering..
And I had to google to find the Star Date
Bob G.
CPC1100
Nexstar 8i + GPS & Rays Brackets
Denk S1 power switch
Orion 100 mm Refractor
Meade LXD 55 ...AR-5 127 mm Refractor
Exploradome Observatory S.I.E. (Smiling Irish Eyes)
Gerbring Heated Motorcycle clothing in the winter
39*21'03" N
77*28'12" W
The sky over my head....
Doug76
Reged: 12/05/07
Re: It Begins new [Re: Bob Griffiths]
      #3409190 - 10/25/09 12:17 AM
Now I like that name, as when I am home I'm definitely resting!
Like the sign, may do the same.
Tonight was second light, and the 80mm f/15 Carton got it's chance to play. The clouds came again, but not so quickly. I had 2 hours in there this time. Just playing, so no report, but the dew was very heavy, and I can see I'm going to have to do something about that.
Even though they are the same length, the CG-5ASGT definitely has less trouble moving the lighter 80mm f/15 around than it did the C6R. Gotta save for a bigger mount.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
rnoelle
Reged: 01/23/08
Loc: SW Oregon
      #3413249 - 10/27/09 12:10 AM
Way to go Doug and Dad!! Don't you love it when a plan comes together. You'll get a lot of enjoyment from all the effort.
As for a name ... I'm thinkin' something in honor of the builder with a little regional flavor .... how about "Crawdaddy's Observatory"
--Bob
* Orion EON 80ED
Doug76
Reged: 12/05/07
      #3414347 - 10/27/09 03:52 PM
Nice name, but Dad is actually from Alabama. But he does like Mudbugs (our name for crawfish).
Well, that's three names for it, and all good ones. Any others? All will be considered.
I do think honoring Dad in some way would be good, but he isn't into our hobby at all. He just likes to build.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
rnoelle
Reged: 01/23/08
Loc: SW Oregon
      #3415152 - 10/27/09 10:57 PM
Hi again Doug,
Yeah, maybe christening your obervatory after mudbugs wasn't the best suggestion ....
But I did think the stardate idea was pretty cool.
Looking forward to some more pictures when you get the chance to post.
Regards ...
--Bob
* Orion EON 80ED
NHRob
Reged: 08/27/04
Loc: New Hampshire
      #3415780 - 10/28/09 10:41 AM
crayfish, crawfish, crawdads, mud bugs ... any others?
Rob
Canon 12x36 IS binos
TEC-140: #433 on CGEM
Faworski orthos (7,10,16.7mm)
stuff ...
no free time ... lots of clouds !
" Life is what happens to you while you're busy making other plans" !!
Doug76
Reged: 12/05/07
Re: It Begins new [Re: NHRob]
      #3416742 - 10/28/09 07:08 PM
And old friend of mine suggested "The Douginator"! Too weird, even for me!
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
DDon
Reged: 07/27/09
      #3417602 - 10/29/09 04:30 AM
"D.Daddy's Intergalactical Truckstop"
Doug76
Reged: 12/05/07
      #3418937 - 10/29/09 07:25 PM
HAHAHAHAHA. Good one!
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
kraterkid
Reged: 03/07/05
Loc: Jacumba, California
      #3436032 - 11/08/09 09:52 AM
How about "Doug's Photon Fishin' Hole". Great roll-off, you and your pop have to be very proud of this observatory.
Rich
My CN Gallery
Doug76
Reged: 12/05/07
Re: It Begins new [Re: kraterkid]
      #3436803 - 11/08/09 05:30 PM
Oh man, that's a good one! Combines my two best loves. We may have a winner!
And thanks for the compliment.
Doug
1 SCT, 8 inch
Faworski Ortho's
Panoptic 24mm
Doug76
Reged: 12/05/07
      #3446721 - 11/13/09 08:04 PM
My floor, despite the nice framing, was a bit weak, and squeaked when I walked on it, so yesterday, my last day home this time, I laid in more plywood on top the original. Very stout now, and noise free.
Also dug the trench for the electrical wire feed in this morning before leaving. Dad will bury the wire.
It also got another coat of white paint everywhere outside but the roof.
More pics next time I'm home.
6 registered and 3 anonymous users are browsing this forum.
Moderator:  Chris Schroeder, csa/montana
