Nick Rose
Reged: 11/01/10
Loc: San Mateo, CA
Concrete reinforcement
#5667734 - 02/07/13 07:43 PM
We are fixing up our backyard but putting in new grass and taking out some trees. With one of the locations where the tree is coming out, I'll be putting a concrete pier. I will have a 3'x3'x3' base with a 12"x48" pier. They'll be rebar attaching the pier to the base. But what do I do with the base should I have rebar in it or will the mass of the base be enough.
Alex McConahay
Reged: 08/11/08
Loc: Moreno Valley, CA
Re: Concrete reinforcement
[Re: Nick Rose]
#5667784 - 02/07/13 08:19 PM
At the price of a few sticks of rebar----add it in. Even if the concrete cracks at some point, the rebar will keep the mass together.
Alex
dobsoscope
Reged: 05/24/06
[Re: Alex McConahay]
#5668455 - 02/08/13 08:22 AM
You can put a piece of mesh reinforcement in the base. Would also suggest that you wrap up the part which is below ground in gauge 1000 pvc sheeting.
Nick Rose
Reged: 11/01/10
Loc: San Mateo, CA
[Re: dobsoscope]
#5688121 - 02/19/13 12:25 AM
I'm now thinking if I should go some what smaller on the base. Where I live in California there is no frost line and you really don't have to go deep to get to hard soil.
Also people that have done concrete base/pier. What size and did you mix the concrete your self?
Bob Moore
Reged: 04/07/06
Loc: New York
[Re: Nick Rose]
#5688175 - 02/19/13 01:17 AM
nick take a look here https://www.dropbox.com/home/Public/LBO
thebase is 4'x4'x4' with re-bar
wolfman_4_ever
Reged: 07/15/11
Loc: El Segundo, Ca, So. Cal
[Re: Bob Moore]
#5688191 - 02/19/13 01:44 AM
Hey Bob. Your link doesn't work.. It asks you to login..
Nick, plan for an earthquake.
My pier pedestal is 7' x 7' at the base and is 6 feet deep. It is shaped like a block pyramid with rebar reinforcement everywhere.. My soil is a mixture of dirt and sand.. Almost 4 tons of concrete or 2 square yards..
If the ground moves from the "big" one, not much is going to stop it.. It's the bunch of smaller ones i'm more concerned about.
Nick Rose
Reged: 11/01/10
Loc: San Mateo, CA
[Re: wolfman_4_ever]
#5688224 - 02/19/13 02:21 AM
So 2'x2'x3'deep with rebar wont be good for a base. The reason I what to go a tad smaller is because I want to do this myself. 3x3x3 is 27cu.ft. where as 2x2x3 is only 12cu.ft. so the smaller would be easier.
Midnight Dan
Reged: 01/23/08
[Re: Nick Rose]
#5688379 - 02/19/13 06:53 AM
Nick:
Personally, I think people go a bit "overkill" on the base of these piers. I think 2' x 2' x 3' is more than large enough.
I have a porch/deck at the rear of my house, and each post is setting on a mini 'pier'. Basically an 8" diameter sonotube going 4' into the ground (due to frost line), with a 12" diameter footer. These have not budged for the past 15 years.
Compared to a building, astronomical piers have to support almost nothing in terms of weight. Unless your pier is going very high, such as with a roof-top observatory, then you really don't need much in the way of a base.
-Dan
John Fitzgerald
In Focus
Reged: 01/04/04
Loc: AR
[Re: Midnight Dan]
#5688420 - 02/19/13 07:52 AM
Nick:
-Dan
I concur. My pier footer is not very big and has not moved in 10 years. It's actually only about 5 cubic feet and 38 inches deep and holds a 6" refractor on a 4" heavy wall pipe pier.
JAT Observatory
NOT a Wimp
Reged: 02/20/05
Loc: In the Primordial Soup
[Re: John Fitzgerald]
#5688514 - 02/19/13 09:11 AM
My base is 18"x18"x3' I mixed the concrete myself. The bottom of the pier flares out to form a footer. There is no rebar in the base. It been supporting the setup shown below for over 10 years with no issues.
JJK
Reged: 04/28/08
[Re: JAT Observatory]
#5688540 - 02/19/13 09:27 AM
Is that a can of diet Pepsi on the pier?
Edited by JJK (02/19/13 09:28 AM)
JAT Observatory
NOT a Wimp
Reged: 02/20/05
[Re: JJK]
#5688546 - 02/19/13 09:31 AM
Yep the pier has a built in beverage holder
Alex McConahay
Reged: 08/11/08
#5688573 - 02/19/13 09:48 AM
My friend, with an observatory in Landers, CA, said his pier, which was polar aligned before the quake, was 18 degrees off after......
Alex
Midnight Dan
Reged: 01/23/08
#5688740 - 02/19/13 11:53 AM
If the earth moves, it isn't going to really matter how big your base is. Entire buildings, roadways, etc. will shift in the right kind of earthquake.
-Dan
wolfman_4_ever
Reged: 07/15/11
#5688973 - 02/19/13 02:04 PM
JJK
Reged: 04/28/08
[Re: Midnight Dan]
#5689001 - 02/19/13 02:27 PM
-Dan
But a more substantial base will provide better support for all shakers, except the "big one".
frolinmod
Reged: 08/06/10
#5690758 - 02/20/13 12:15 PM
Mine is moving at over 3cm/year to the Northwest and there's not a darned thing I can do to stop it because the whole Pacific plate in this area is apparently doing the same. It's moved over 126cm Northwest since I've lived here.
gdd
Reged: 11/23/05
[Re: frolinmod]
#5690809 - 02/20/13 12:40 PM
Is the pier still on your property?
Gale
Bob Moore
Reged: 04/07/06
Loc: New York
#5690977 - 02/20/13 02:06 PM
I fixed it here is the good link. https://www.dropbox.com/sh/wgwyuu9v2m7w2vj/7O54w9XQyb
Kunama
Reged: 10/22/12
Loc: Australia
[Re: Midnight Dan]
#5691028 - 02/20/13 02:37 PM
Nick:
-Dan
In some cases "overkill" is an understatement, I have spend the last 15 years supervising concrete formwork construction and have built multistorey buildings on footings smaller than some of these pier bases.
The secret is in the base preparation and reinforcement, dig the hole then COMPACT the ground well before laying down plastic, then 'chair up' a sheet of steel mesh about 3" off the ground, another sheet about 3" below the finished concrete level and then fix 6 L-shaped anglebars 1/2" diameter to the bottom mesh arranged so they end up inside the proposed pier with at least 1" of concrete to the face of the pier.
I think a base area of 3' x 3' and 18" deep would be as big as you would ever need. My own pier base will be 2' x 2' x 18".
Just my 2 cents.
jazle
Reged: 05/20/10
Loc: California, USA
[Re: Kunama]
#5691493 - 02/20/13 06:32 PM
Calculate where the center of mass will be. Add more cubic feet to the base until it's at least a foot below ground level. Then you won't have to worry about it "going anywhere" from being top heavy if your soils are saturated.
JJK
Reged: 04/28/08
[Re: Kunama]
#5691505 - 02/20/13 06:39 PM
Nick:
-Dan
Just my 2 cents.
Matt, a footer for a building and a foundation for a telescope pier are two different animals. The former has to accept the load from above, whereas the latter has to do that plus not budge one iota. At high magnification, a small displacement at the scope translates to a significant change in the EP.
Also, it is important to get the base of the foundation below frost line (i.e., well below 18" deep).
Kunama
Reged: 10/22/12
Loc: Australia
[Re: JJK]
#5691941 - 02/20/13 11:06 PM
My apologies, I did not realise that San Mateo, California suffered frosts or had a frost line.
Nick Rose
Reged: 11/01/10
Loc: San Mateo, CA
[Re: Kunama]
#5691957 - 02/20/13 11:19 PM
San Mateo does not have a frost line, at least as I know of.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
[Re: Nick Rose]
#5692009 - 02/20/13 11:46 PM
Don't overkill your project like some commercial or government projects. When putting rebar, pencil rod and wire mesh into place make sure you leave enough room to fit in a "little" concrete! Mike
Edited by mikey cee (02/20/13 11:49 PM)
Bob Moore
Reged: 04/07/06
Loc: New York
[Re: Nick Rose]
#5692016 - 02/20/13 11:54 PM
All the piers and pier blocks I do here in the north east are 48"L x 48"W x 54"D, our frost line is just about 48" down. i try to make the hole a little trapezoidal, whats another bag of cement, i have never been lucky enough to have a truck come onto the site. as you can see by the photos in the posted link above the last project took 4 palettes of 80lb bags of Quikrete mixed the a 5 bag mixer, but the kick in the butt was we had no water out at the site. We used a 100gl watering toff in the back of my truck and dipped 5gl buckets into it to get the water.
JJK
Reged: 04/28/08
[Re: Kunama]
#5692049 - 02/21/13 12:24 AM
My apologies, I did not realise that San Mateo, California suffered frosIs or had a frost line.
Matt, your comments, including the depth of the concrete base, sounded general in nature. And you're right, San Mateo doesn't suffer "frosls".
Edited by JJK (02/21/13 12:27 AM)
roscoe
curmudgeon
Reged: 02/04/09
Loc: NW Mass, inches from VT
[Re: JJK]
#5697300 - 02/23/13 08:52 PM
Hey....be nice! We all make typos sometimes.......
I don't pour concrete for a living, I build things..... including not only houses and decks, but also free-standing radio towers and once a 14-meter radio telescope, and I'm siding with Matt, in that the world of amateur astronomy about single-handedly keeps the concrete industry in business. But, joking aside, much of the ultimate stability of a pier is determined by the soil composition in which the concrete is placed, and much more is determined by the construction of the pier itself and the attention to detail of the backfill placed around it. Wide and flat bottom surfaces poured on undisturbed subsoil and against undisturbed subsoil walls are always the most stable option. Any removed and replaced fill will be less firm than before it was removed, the best possible packing and compacting of backfill will still leave a free-standing pier built in a dug-out hole able to be moved around a small amount relatively easily. For a house, not a problem - all the load is straight down, and as long as the footing can't push downward into soft fill, all is good. For something like a radio tower with a large wind-induced side load, a cube - even a big one - with dirt shoveled back in around it, will soon indicate the prevailing wind direction. Scopes in a small way replicate the loads on towers. A slab of concrete 5 x 5 x 1 foot containing 25 cubic feet with a pier sticking up from it will offer far more resistance to side forces than a 3 x 3 x 3 foot cube containing 27, with a similar diameter pier, because the leverage forces required to lift an edge are far greater. If you're wondering, my own pier, built to hold a 6" refractor, is a 2' diameter hole dug about 5' deep in firm gravely clay (liberal use of an electric jackhammer was required) filled with concrete directly into the hole about 3' deep, with a 10" sonotube to ground level, and a steel pier above ground. The pier, and the building's corner-piers, all stop at ground level in case of future removal of the building. A hard kick will vibrate the steel pier a bit, but I don't kick the top of it very often when I'm observing..... I have noticed, though, that the big town snowplow truck, main and wing down, loaded with several yards of road sand, will vibrate the scope visibly when it passes 1/4 mile away, but that thing's pretty much a rolling earthquake, so that's to be expected, I guess. Russ
JJK
Reged: 04/28/08
[Re: roscoe]
#5697890 - 02/24/13 08:42 AM
In general, if someone is located where the ground freezes, they need to get part of the pier foundation below frost line. I agree that digging a hole wider and initially deeper than the foundation is not advisable.
Nick Rose
Reged: 11/01/10
Loc: San Mateo, CA
[Re: JJK]
#5704317 - 02/27/13 09:32 PM
We are having our backyard patio done so we talked to the concrete guy that is doing that to also do the pier for me. I wanted to do concrete footings for the building but he suggested that a slab would be better, since our area is prone to settling. Will the concrete pad affect my local seeing condition or will I really not see any difference in my pictures(The temp in San Mateo rarely gets to 100 in the summer)? Also what kind of gap should there be between the slab and pier?
This is my general location. So since I'm in a area with a lot of houses, concrete drive ways and so forth and guess the slab wont affect the local seeing.
https://maps.google.com/maps?q=1509+South+Grant+Street,+San+Mateo,+CA&hl=en&sll=37.560262,-122.308195&sspn=0.013778,0.027874&oq=1509+S&t=h&hnear=1509+S+Grant+St,+San+Mateo,+California+94402&z=17
Edited by Nick Rose (02/27/13 10:20 PM)
